Card is 8800 GT 256MB G92 at vendor clocks - 700/750/1700 (2 of 3)
X2 5600 @ 2.9 Ghz, 4 gb PC2-6400, XP Pro32 SP2, MSI K9A2 Platinum, 6.23 Systray, 181.20 drivers
[00:07:32] + Attempting to get work packet
[00:07:32] - Will indicate memory of 2815 MB
[00:07:32] - Connecting to assignment server
[00:07:32] Connecting to http://assign-GPU.stanford.edu:8080/
[00:07:33] Posted data.
[00:07:33] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[00:07:33] + News From Folding@Home: GPU folding beta
[00:07:33] Loaded queue successfully.
[00:07:33] Connecting to http://171.64.65.106:8080/
[00:07:33] Initial: 0000; - Receiving payload (expected size: 68451)
[00:07:34] - Downloaded at ~66 kB/s
[00:07:34] - Averaged speed for that direction ~87 kB/s
[00:07:34] + Received work.
[00:07:34] Trying to send all finished work units
[00:07:34] + No unsent completed units remaining.
[00:07:34] + Closed connections
[00:07:39]
[00:07:39] + Processing work unit
[00:07:39] Core required: FahCore_11.exe
[00:07:39] Core found.
[00:07:39] Working on queue slot 05 [May 5 00:07:39 UTC]
[00:07:39] + Working ...
[00:07:39] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -priority 96 -checkpoint 15 -verbose -lifeline 2184 -version 623'
[00:07:39]
[00:07:39] *------------------------------*
[00:07:39] Folding@Home GPU Core - Beta
[00:07:39] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:07:39]
[00:07:39] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:07:39] Build host: amoeba
[00:07:39] Board Type: Nvidia
[00:07:39] Core :
[00:07:39] Preparing to commence simulation
[00:07:39] - Looking at optimizations...
[00:07:39] - Created dyn
[00:07:39] - Files status OK
[00:07:39] - Expanded 67939 -> 350980 (decompressed 516.6 percent)
[00:07:39] Called DecompressByteArray: compressed_data_size=67939 data_size=350980, decompressed_data_size=350980 diff=0
[00:07:39] - Digital signature verified
[00:07:39]
[00:07:39] Project: 5773 (Run 10, Clone 421, Gen 2)
[00:07:39]
[00:07:39] Assembly optimizations on if available.
[00:07:39] Entering M.D.
[00:07:45] mdrun_gpu returned
[00:07:45] Going to send back what have done -- stepsTotalG=0
[00:07:45] Work fraction=0.0000 steps=0.
[00:07:49] logfile size=4996 infoLength=4996 edr=0 trr=25
[00:07:49] - Writing 5534 bytes of core data to disk...
[00:07:49] Done: 5022 -> 1881 (compressed to 37.4 percent)
[00:07:49] ... Done.
[00:07:49]
[00:07:49] Folding@home Core Shutdown: UNSTABLE_MACHINEAt this point a familiar pop-up message Microsoft Visual C++ Runtime Library appeared saying:
Runtime Error!
Program: C:\Documents and Settings\ect...
This application has requested the Runtime to terminate in an unusual way.
Please contact the application's support team for more information.
Clicking OK brought up another popup with heading FahCore_11.exe - Application error saying:
The exception unknown software exception (0x40000015) occurred in the application at location 0x005236ee.
Click on OK to terminate program
After clicking OK, the client had this to say about my killing the core:
[01:33:31] CoreStatus = 3 (3)
[01:33:31] Client-core communications error: ERROR 0x3
[01:33:31] This is a sign of more serious problems, shutting down.Leading to the popup titled Folding@home saying:
Folding@home has run into a serious error running the core, and will shutdown.
Clicking OK kills the client. Here is the restart.
--- Opening Log file [May 5 01:36:06 UTC]
http://folding.stanford.edu
Launch directory: C:\Documents and Settings\Hammersmythe\Application Data\Folding@home-gpu2
Arguments: -gpu 1 -verbosity 9 -forcegpu nvidia_g80
[01:36:06] - Ask before connecting: No
[01:36:06] - User name: Amaruk (Team 50625)
[01:36:06] - User ID: C*************5
[01:36:06] - Machine ID: 3
[01:36:06]
[01:36:06] Loaded queue successfully.
[01:36:06] Initialization complete
[01:36:06]
[01:36:06] + Processing work unit
[01:36:06] Core required: FahCore_11.exe
[01:36:06] Core found.
[01:36:06] - Autosending finished units... [May 5 01:36:06 UTC]
[01:36:06] Trying to send all finished work units
[01:36:06] + No unsent completed units remaining.
[01:36:06] - Autosend completed
[01:36:06] Working on queue slot 05 [May 5 01:36:06 UTC]
[01:36:06] + Working ...
[01:36:06] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -priority 96 -checkpoint 15 -verbose -lifeline 780 -version 623'
[01:36:07]
[01:36:07] *------------------------------*
[01:36:07] Folding@Home GPU Core - Beta
[01:36:07] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[01:36:07]
[01:36:07] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:36:07] Build host: amoeba
[01:36:07] Board Type: Nvidia
[01:36:07] Core :
[01:36:07] Preparing to commence simulation
[01:36:07] - Looking at optimizations...
[01:36:07] - Created dyn
[01:36:07] - Files status OK
[01:36:07] Error: Missing work file=<>
[01:36:07]
[01:36:07] Folding@home Core Shutdown: MISSING_WORK_FILES
[01:36:11] CoreStatus = 74 (116)
[01:36:11] The core could not find the work files specified. Removing from queue
[01:36:11] Deleting current work unit & continuing...
[01:36:15] Trying to send all finished work units
[01:36:15] + No unsent completed units remaining.
[01:36:15] - Preparing to get new work unit...
[01:36:15] + Attempting to get work packet
[01:36:15] - Will indicate memory of 2815 MB
[01:36:15] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 11, Stepping: 2
[01:36:15] - Connecting to assignment server
[01:36:15] Connecting to http://assign-GPU.stanford.edu:8080/
[01:36:15] Posted data.
[01:36:15] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[01:36:15] + News From Folding@Home: GPU folding beta
[01:36:15] Loaded queue successfully.
[01:36:15] Connecting to http://171.64.65.106:8080/
[01:36:15] Initial: 0000; - Receiving payload (expected size: 68451)
[01:36:16] - Downloaded at ~66 kB/s
[01:36:16] - Averaged speed for that direction ~83 kB/s
[01:36:16] + Received work.
[01:36:16] + Closed connections
[01:36:21]
[01:36:21] + Processing work unit
[01:36:21] Core required: FahCore_11.exe
[01:36:21] Core found.
[01:36:21] Working on queue slot 06 [May 5 01:36:21 UTC]
[01:36:21] + Working ...
[01:36:21] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -priority 96 -checkpoint 15 -verbose -lifeline 780 -version 623'
[01:36:21]
[01:36:21] *------------------------------*
[01:36:21] Folding@Home GPU Core - Beta
[01:36:21] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[01:36:21]
[01:36:21] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:36:21] Build host: amoeba
[01:36:21] Board Type: Nvidia
[01:36:21] Core :
[01:36:21] Preparing to commence simulation
[01:36:21] - Looking at optimizations...
[01:36:21] - Created dyn
[01:36:21] - Files status OK
[01:36:21] - Expanded 67939 -> 350980 (decompressed 516.6 percent)
[01:36:21] Called DecompressByteArray: compressed_data_size=67939 data_size=350980, decompressed_data_size=350980 diff=0
[01:36:21] - Digital signature verified
[01:36:21]
[01:36:21] Project: 5773 (Run 10, Clone 421, Gen 2)
[01:36:21]
[01:36:21] Assembly optimizations on if available.
[01:36:21] Entering M.D.
[01:36:28] Working on Protein
[01:36:29] Client config found, loading data.
[01:36:29] Starting GUI Server
[01:39:12] Completed 1%
[01:41:54] Completed 2%
[01:44:36] Completed 3%
[01:47:18] Completed 4%
[01:50:00] Completed 5%
[01:52:42] Completed 6%
[01:55:24] Completed 7%
[01:58:06] Completed 8%
[02:00:48] Completed 9%
[02:03:30] Completed 10%
[02:06:12] Completed 11%
[02:08:53] Completed 12%
[02:11:36] Completed 13%
[02:14:18] Completed 14%
[02:17:01] Completed 15%
[02:19:43] Completed 16%
[02:22:26] Completed 17%
[02:25:08] Completed 18%
[02:27:51] Completed 19%
[02:30:33] Completed 20%
[02:33:16] Completed 21%
[02:35:57] Completed 22%
[02:38:38] Completed 23%
[02:41:19] Completed 24%
[02:44:00] Completed 25%
[02:46:42] Completed 26%
[02:49:25] Completed 27%
[02:52:08] Completed 28%
[02:54:50] Completed 29%
[02:57:33] Completed 30%
[03:00:16] Completed 31%
[03:02:59] Completed 32%
[03:05:42] Completed 33%
[03:08:25] Completed 34%
[03:11:09] Completed 35%
[03:13:52] Completed 36%
[03:16:35] Completed 37%
[03:19:18] Completed 38%
[03:22:01] Completed 39%
[03:24:44] Completed 40%
[03:26:05] Run: exception thrown during GuardedRun
[03:26:05] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[03:26:05] Going to send back what have done -- stepsTotalG=20000000
[03:26:05] Work fraction=0.4050 steps=20000000.
[03:26:09] logfile size=18855 infoLength=18855 edr=0 trr=23
[03:26:09] - Writing 19391 bytes of core data to disk...
[03:26:09] Done: 18879 -> 4904 (compressed to 25.9 percent)
[03:26:09] ... Done.
[03:26:09]
[03:26:09] Folding@home Core Shutdown: EARLY_UNIT_END
[03:26:13] CoreStatus = 72 (114)
[03:26:13] Sending work to server
[03:26:13] Project: 5773 (Run 10, Clone 421, Gen 2)
[03:26:13] - Read packet limit of 540015616... Set to 524286976.
[03:26:13] + Attempting to send results [May 5 03:26:13 UTC]
[03:26:13] - Reading file work/wuresults_06.dat from core
[03:26:13] (Read 5416 bytes from disk)
[03:26:13] Connecting to http://171.64.65.106:8080/
[03:26:13] Posted data.
[03:26:13] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[03:26:13] - Uploaded at ~12 kB/s
[03:26:13] - Averaged speed for that direction ~57 kB/s
[03:26:13] + Results successfully sent
[03:26:13] Thank you for your contribution to Folding@Home.So...was anyone else able to fold it?
Also, if this looks familiar it's because the same thing happened yesterday on a different GPU
viewtopic.php?f=19&t=9815
Only difference is this one EUE'd.
