point help
shadowfir3
point help
Post by shadowfir3 »
i have been using folding@home for about 4 weeks now and when i look at my user stats it says i have 0 points is their something i have to do after it finishes working please help :?:
DanGe
Hardware configuration: 2018 Mac Mini / MacOS Catalina
3.2 GHz 6-Core Intel Core i7
Re: point help
Post by DanGe »
Hello shadowfir3 and welcome to the forum
You might have a problem. But first, we need to know some basic information about your computer and your client.
What are your computer specifications (e.g. CPU, GPU (if applicable), operating system, etc.)?
Which client and what version are you using?
How long do you keep your computer on every day?
Finally, could you copy and paste the first 35-45 lines of your log file (within the tags so it looks better on your post)?
shadowfir3
Re: point help
is this what you wanted DanGe sorry if its not. my computer is a xp and it is normally on most of the day about 13 hours
[04:36:43] - Ask before connecting: No
[04:36:43] - User name: shadowfir3 (Team 143016)
[04:36:43] - User ID: 2F007B1C69E797F2
[04:36:43] - Machine ID: 1
[04:36:43]
[04:36:43] Loaded queue successfully.
[04:36:43] Initialization complete
[04:36:43]
[04:36:43] + Processing work unit
[04:36:43] Core required: FahCore_82.exe
[04:36:43] Core found.
[04:36:43] Working on queue slot 02 [May 5 04:36:43 UTC]
[04:36:43] + Working ...
[04:36:44]
[04:36:44] *------------------------------*
[04:36:44] Folding@Home PMD Core
[04:36:44] Version 1.03 (September 7, 2005)
[04:36:44]
[04:36:44] Preparing to commence simulation
[04:36:44] - Looking at optimizations...
[04:36:44] - Files status OK
[04:36:44] - Expanded 20934 -> 131630 (decompressed 628.7 percent)
[04:36:44]
[04:36:44] Project: 4603 (Run 10, Clone 77, Gen 26)
[04:36:44]
[04:36:44] Assembly optimizations on if available.
[04:36:44] Entering M.D.
[04:39:36] Opening http://fah-web.stanford.edu/cgi-bin/mai ... adowfir3...
[04:39:49] Protein: p4603_T0_ww-16_minout
[04:39:49]
[04:39:49] Completed 900000 out of 2500000 steps (36%)
ELF2000
Hardware configuration: Intel Q6600 | Asus P5K SE | 2GB DDR2 | 512MB Radeon 4870 | 650w Cool Master PSU | 1 GPU client and 1 Windows SMP client
Re: point help
Post by ELF2000 »
I guess you have finished and uploaded a work unit before the final deadline. If you uploaded a work unit after the final deadline you will receive no credit for it. It usually take a few hours after the first WU is uploaded before you appear on Stanford stats.
The 4603 WU is a uniprocessor WU. It has a final deadline of 32 days.
shadowfir3
Re: point help
thank you ELF2000 and DanGe its working now. i think it was because i was not finishing the wu in time
