Project: 4751 (Run 4, Clone 367, Gen 27)
davebodger
Hardware configuration: Machine 1: MSI X299 Carbon, i7 7820X @ 4.6GHz all cores, 64Gb DDR4, RTX2080Ti graphics, Win 10 64bit, custom watercooling.
Machine 2: Core i7 980 @ 4.1GHz, 24Gb DDR4, GTX1060 graphics, Win 10 64 bit.
Post by davebodger »
Extract of repeated problem with this WU :-
[08:04:27] mdrun_gpu returned
[08:04:27] Nonzero force sum on GPU
[08:04:27] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:04:31] CoreStatus = 7A (122)
Restarted client, downloaded different WU and runs OK.
System:-
Windows Vista Home Premium (32 bit).
Core i7 920 CPU o/c'ed to 3.76GHz (188MHz bus)
3Mb DDR3
Single card: XFX (ATI) Radeon 4890 - stock overclock (875MHz core, 975MHz DDR5 memory)
[07:59:08] Completed 97%
[08:00:36] Completed 98%
[08:02:05] Completed 99%
[08:03:33] Completed 100%
[08:03:33] Successful run
[08:03:33] DynamicWrapper: Finished Work Unit: sleep=10000
[08:03:43] Reserved 153868 bytes for xtc file; Cosm status=0
[08:03:43] Allocated 153868 bytes for xtc file
[08:03:43] - Reading up to 153868 from "work/wudata_05.xtc": Read 153868
[08:03:43] Read 153868 bytes from xtc file; available packet space=786276596
[08:03:43] xtc file hash check passed.
[08:03:43] Reserved 23472 23472 786276596 bytes for arc file=<work/wudata_05.trr> Cosm status=0
[08:03:43] Allocated 23472 bytes for arc file
[08:03:43] - Reading up to 23472 from "work/wudata_05.trr": Read 23472
[08:03:43] Read 23472 bytes from arc file; available packet space=786253124
[08:03:43] trr file hash check passed.
[08:03:43] Allocated 560 bytes for edr file
[08:03:43] Read bedfile
[08:03:43] edr file hash check passed.
[08:03:43] Allocated 16874 bytes for logfile
[08:03:43] Read logfile
[08:03:43] GuardedRun: success in DynamicWrapper
[08:03:43] GuardedRun: done
[08:03:43] Run: GuardedRun completed.
[08:03:44] - Writing 195286 bytes of core data to disk...
[08:03:44] Done: 194774 -> 184075 (compressed to 94.5 percent)
[08:03:44]   ... Done.
[08:03:44] - Shutting down core
[08:03:44]
[08:03:44] Folding@home Core Shutdown: FINISHED_UNIT
[08:03:48] CoreStatus = 64 (100)
[08:03:48] Sending work to server
[08:03:48] Project: 5745 (Run 2, Clone 58, Gen 218)
[08:03:48] - Read packet limit of 540015616... Set to 524286976.
[08:03:48] + Attempting to send results [May 1 08:03:48 UTC]
[08:04:09] - Couldn't send HTTP request to server
[08:04:09] + Could not connect to Work Server (results)
[08:04:09]     (171.64.65.102:8080)
[08:04:09] + Retrying using alternative port
[08:04:12] + Results successfully sent
[08:04:12] Thank you for your contribution to Folding@Home.
[08:04:12] + Number of Units Completed: 671
[08:04:16] - Preparing to get new work unit...
[08:04:16] + Attempting to get work packet
[08:04:16] - Connecting to assignment server
[08:04:17] - Successful: assigned to (171.64.65.103).
[08:04:17] + News From Folding@Home: GPU folding beta
[08:04:17] Loaded queue successfully.
[08:04:19] + Closed connections
[08:04:19]
[08:04:19] + Processing work unit
[08:04:19] Core required: FahCore_11.exe
[08:04:19] Core found.
[08:04:19] Working on queue slot 06 [May 1 08:04:19 UTC]
[08:04:19] + Working ...
[08:04:19]
[08:04:19] *------------------------------*
[08:04:19] Folding@Home GPU Core - Beta
[08:04:19] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[08:04:19]
[08:04:19] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[08:04:19] Build host: amoeba
[08:04:19] Board Type: AMD
[08:04:19] Core      :
[08:04:19] Preparing to commence simulation
[08:04:19] - Looking at optimizations...
[08:04:19] - Created dyn
[08:04:19] - Files status OK
[08:04:19] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[08:04:19] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[08:04:19] - Digital signature verified
[08:04:19]
[08:04:19] Project: 4751 (Run 4, Clone 367, Gen 27)
[08:04:19]
[08:04:19] Assembly optimizations on if available.
[08:04:19] Entering M.D.
[08:04:25] Tpr hash work/wudata_06.tpr:  2177645689 1032610330 3415775883 2304359576 1001613337
[08:04:25] Working on 1254 p4751_lam5w_300K_g91
[08:04:25] Client config found, loading data.
[08:04:26] Starting GUI Server
[08:04:27]
[08:04:31] Sending work to server
[08:04:31] Project: 4751 (Run 4, Clone 367, Gen 27)
[08:04:31] - Read packet limit of 540015616... Set to 524286976.
[08:04:31] - Error: Could not get length of results file work/wuresults_06.dat
[08:04:31] - Error: Could not read unit 06 file. Removing from queue.
[08:04:31] - Preparing to get new work unit...
[08:04:31] + Attempting to get work packet
[08:04:31] - Connecting to assignment server
[08:04:32] - Successful: assigned to (171.64.65.103).
[08:04:32] + News From Folding@Home: GPU folding beta
[08:04:32] Loaded queue successfully.
[08:04:34] + Closed connections
[08:04:39]
[08:04:39] + Processing work unit
[08:04:39] Core required: FahCore_11.exe
[08:04:39] Core found.
[08:04:39] Working on queue slot 07 [May 1 08:04:39 UTC]
[08:04:39] + Working ...
[08:04:39]
[08:04:39] *------------------------------*
[08:04:39] Folding@Home GPU Core - Beta
[08:04:39] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[08:04:39]
[08:04:39] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[08:04:39] Build host: amoeba
[08:04:39] Board Type: AMD
[08:04:39] Core      :
[08:04:39] Preparing to commence simulation
[08:04:39] - Looking at optimizations...
[08:04:39] - Created dyn
[08:04:39] - Files status OK
[08:04:39] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[08:04:39] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[08:04:39] - Digital signature verified
[08:04:39]
[08:04:39] Project: 4751 (Run 4, Clone 367, Gen 27)
[08:04:39]
[08:04:39] Assembly optimizations on if available.
[08:04:39] Entering M.D.
[08:04:45] Tpr hash work/wudata_07.tpr:  2177645689 1032610330 3415775883 2304359576 1001613337
[08:04:45] Working on 1254 p4751_lam5w_300K_g91
[08:04:45] Client config found, loading data.
[08:04:46] Starting GUI Server
[08:04:47] mdrun_gpu returned
[08:04:47] Nonzero force sum on GPU
[08:04:47]
[08:04:47] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:04:51] CoreStatus = 7A (122)
[08:04:51] Sending work to server
[08:04:51] Project: 4751 (Run 4, Clone 367, Gen 27)
[08:04:51] - Read packet limit of 540015616... Set to 524286976.
[08:04:51] - Error: Could not get length of results file work/wuresults_07.dat
[08:04:51] - Error: Could not read unit 07 file. Removing from queue.
[08:04:51] - Preparing to get new work unit...
[08:04:51] + Attempting to get work packet
[08:04:51] - Connecting to assignment server
[08:04:52] - Successful: assigned to (171.64.65.103).
[08:04:52] + News From Folding@Home: GPU folding beta
[08:04:52] Loaded queue successfully.
[08:04:53] + Closed connections
[08:04:58]
[08:04:58] + Processing work unit
[08:04:58] Core required: FahCore_11.exe
[08:04:58] Core found.
[08:04:58] Working on queue slot 08 [May 1 08:04:58 UTC]
[08:04:58] + Working ...
[08:04:59]
[08:04:59] *------------------------------*
[08:04:59] Folding@Home GPU Core - Beta
[08:04:59] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[08:04:59]
[08:04:59] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[08:04:59] Build host: amoeba
[08:04:59] Board Type: AMD
[08:04:59] Core      :
[08:04:59] Preparing to commence simulation
[08:04:59] - Looking at optimizations...
[08:04:59] - Created dyn
[08:04:59] - Files status OK
[08:04:59] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[08:04:59] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[08:04:59] - Digital signature verified
[08:04:59]
[08:04:59] Project: 4751 (Run 4, Clone 367, Gen 27)
[08:04:59]
[08:04:59] Assembly optimizations on if available.
[08:04:59] Entering M.D.
[08:05:05] Tpr hash work/wudata_08.tpr:  2177645689 1032610330 3415775883 2304359576 1001613337
[08:05:05] Working on 1254 p4751_lam5w_300K_g91
[08:05:05] Client config found, loading data.
[08:05:06] Starting GUI Server
[08:05:08] mdrun_gpu returned
[08:05:08] Nonzero force sum on GPU
[08:05:08]
[08:05:08] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:05:11] CoreStatus = 7A (122)
[08:05:11] Sending work to server
[08:05:11] Project: 4751 (Run 4, Clone 367, Gen 27)
[08:05:11] - Read packet limit of 540015616... Set to 524286976.
[08:05:11] - Error: Could not get length of results file work/wuresults_08.dat
[08:05:11] - Error: Could not read unit 08 file. Removing from queue.
[08:05:11] - Preparing to get new work unit...
[08:05:11] + Attempting to get work packet
[08:05:11] - Connecting to assignment server
[08:05:11] - Successful: assigned to (171.64.65.103).
[08:05:11] + News From Folding@Home: GPU folding beta
[08:05:12] Loaded queue successfully.
[08:05:13] + Closed connections
[08:05:18]
[08:05:18] + Processing work unit
[08:05:18] Core required: FahCore_11.exe
[08:05:18] Core found.
[08:05:18] Working on queue slot 09 [May 1 08:05:18 UTC]
[08:05:18] + Working ...
[08:05:18]
[08:05:18] *------------------------------*
[08:05:18] Folding@Home GPU Core - Beta
[08:05:18] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[08:05:18]
[08:05:18] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[08:05:18] Build host: amoeba
[08:05:18] Board Type: AMD
[08:05:18] Core      :
[08:05:18] Preparing to commence simulation
[08:05:18] - Looking at optimizations...
[08:05:18] - Created dyn
[08:05:18] - Files status OK
[08:05:18] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[08:05:18] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[08:05:18] - Digital signature verified
[08:05:18]
[08:05:18] Project: 4751 (Run 4, Clone 367, Gen 27)
[08:05:18]
[08:05:18] Assembly optimizations on if available.
[08:05:18] Entering M.D.
[08:05:24] Tpr hash work/wudata_09.tpr:  2177645689 1032610330 3415775883 2304359576 1001613337
[08:05:25] Working on 1254 p4751_lam5w_300K_g91
[08:05:25] Client config found, loading data.
[08:05:25] Starting GUI Server
[08:05:27] mdrun_gpu returned
[08:05:27] Nonzero force sum on GPU
[08:05:27]
[08:05:27] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:05:31] CoreStatus = 7A (122)
[08:05:31] Sending work to server
[08:05:31] Project: 4751 (Run 4, Clone 367, Gen 27)
[08:05:31] - Read packet limit of 540015616... Set to 524286976.
[08:05:31] - Error: Could not get length of results file work/wuresults_09.dat
[08:05:31] - Error: Could not read unit 09 file. Removing from queue.
[08:05:31] - Preparing to get new work unit...
[08:05:31] + Attempting to get work packet
[08:05:31] - Connecting to assignment server
[08:05:31] - Successful: assigned to (171.64.65.103).
[08:05:31] + News From Folding@Home: GPU folding beta
[08:05:31] Loaded queue successfully.
[08:05:33] + Closed connections
[08:05:38]
[08:05:38] + Processing work unit
[08:05:38] Core required: FahCore_11.exe
[08:05:38] Core found.
[08:05:38] Working on queue slot 00 [May 1 08:05:38 UTC]
[08:05:38] + Working ...
[08:05:38]
[08:05:38] *------------------------------*
[08:05:38] Folding@Home GPU Core - Beta
[08:05:38] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[08:05:38]
[08:05:38] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[08:05:38] Build host: amoeba
[08:05:38] Board Type: AMD
[08:05:38] Core      :
[08:05:38] Preparing to commence simulation
[08:05:38] - Looking at optimizations...
[08:05:39] - Created dyn
[08:05:39] - Files status OK
[08:05:39] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[08:05:39] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[08:05:39] - Digital signature verified
[08:05:39]
[08:05:39] Project: 4751 (Run 4, Clone 367, Gen 27)
[08:05:39]
[08:05:39] Assembly optimizations on if available.
[08:05:39] Entering M.D.
[08:05:45] Tpr hash work/wudata_00.tpr:  2177645689 1032610330 3415775883 2304359576 1001613337
[08:05:45] Working on 1254 p4751_lam5w_300K_g91
[08:05:45] Client config found, loading data.
[08:05:45] Starting GUI Server
[08:05:47] mdrun_gpu returned
[08:05:47] Nonzero force sum on GPU
[08:05:47]
[08:05:47] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:05:50] CoreStatus = 7A (122)
[08:05:50] Sending work to server
[08:05:50] Project: 4751 (Run 4, Clone 367, Gen 27)
[08:05:50] - Read packet limit of 540015616... Set to 524286976.
[08:05:50] - Error: Could not get length of results file work/wuresults_00.dat
[08:05:50] - Error: Could not read unit 00 file. Removing from queue.
[08:05:50] EUE limit exceeded. Pausing 24 hours.
Folding@Home Client Shutdown.
Re: Project: 4751 (Run 4, Clone 367, Gen 27)
There's another report of immediate failure in the DB.
I'll wait a bit before making it as bad, but if no one is able to complete it within a day or two, it can be considered as a bad WU.
