Project: 248x - not crediting
LargeLarry
Post by LargeLarry »
Completed 4 work units and never received credit.
Project: 2484 (Run 220, Clone 6, Gen 13)
[23:23:54] Loaded queue successfully.
[23:23:54] - Preparing to get new work unit...
[23:23:54] + Attempting to get work packet
[23:23:54] - Connecting to assignment server
[23:23:54] - Successful: assigned to (171.65.103.162).
[23:23:54] + News From Folding@Home: Welcome to Folding@Home
[23:24:37] + Closed connections
[23:24:37]
[23:24:37] + Processing work unit
[23:24:37] Core required: FahCore_78.exe
[23:24:37] Core found.
[23:24:37] Working on queue slot 04 [April 15 23:24:37 UTC]
[23:24:37] + Working ...
[23:24:37]
[23:24:37] *------------------------------*
[23:24:37] Folding@Home Gromacs Core
[23:24:37] Version 1.90 (March 8, 2006)
[23:24:37]
[23:24:37] Preparing to commence simulation
[23:24:37] - Looking at optimizations...
[23:24:37] - Created dyn
[23:24:37] - Files status OK
[23:24:41] - Expanded 3015934 -> 15234445 (decompressed 505.1 percent)
[23:24:41] - Starting from initial work packet
[23:24:41]
[23:24:41] Project: 2484 (Run 220, Clone 6, Gen 13)
[23:24:41]
[23:24:41] Assembly optimizations on if available.
[23:24:41] Entering M.D.
[04:51:20] Past main M.D. loop
[04:52:20]
[04:52:20] Finished Work Unit:
[04:52:20] - Reading up to 2320296 from "work/wudata_04.arc": Read 2320296
[04:52:20] - Reading up to 395316 from "work/wudata_04.xtc": Read 395316
[04:52:20] goefile size: 0
[04:52:20] logfile size: 33636
[04:52:20] Leaving Run
[04:52:23] - Writing 2767424 bytes of core data to disk...
[04:52:23]   ... Done.
[04:52:23] - Shutting down core
[04:52:23]
[04:52:23] Folding@home Core Shutdown: FINISHED_UNIT
[04:52:27] CoreStatus = 64 (100)
[04:52:27] Sending work to server
[04:52:27] Project: 2484 (Run 220, Clone 6, Gen 13)
[04:52:27] - Read packet limit of 540015616... Set to 524286976.
[04:52:27] + Attempting to send results [April 19 04:52:27 UTC]
[04:53:37] + Results successfully sent
[04:53:37] Thank you for your contribution to Folding@Home.
Project: 2484 (Run 102, Clone 4, Gen 19)
[23:24:50] Loaded queue successfully.
[23:24:50] - Preparing to get new work unit...
[23:24:50] + Attempting to get work packet
[23:24:50] - Connecting to assignment server
[23:24:50] - Successful: assigned to (171.65.103.162).
[23:24:50] + News From Folding@Home: Welcome to Folding@Home
[23:24:51] Loaded queue successfully.
[23:25:33] + Closed connections
[23:25:33]
[23:25:33] + Processing work unit
[23:25:33] Core required: FahCore_78.exe
[23:25:33] Core found.
[23:25:33] Working on queue slot 06 [April 15 23:25:33 UTC]
[23:25:33] + Working ...
[23:25:33]
[23:25:33] *------------------------------*
[23:25:33] Folding@Home Gromacs Core
[23:25:33] Version 1.90 (March 8, 2006)
[23:25:33]
[23:25:33] Preparing to commence simulation
[23:25:33] - Looking at optimizations...
[23:25:33] - Created dyn
[23:25:33] - Files status OK
[23:25:36] - Expanded 2952078 -> 15101125 (decompressed 511.5 percent)
[23:25:37] - Starting from initial work packet
[23:25:37]
[23:25:37] Project: 2484 (Run 102, Clone 4, Gen 19)
[23:25:37]
[23:25:37] Assembly optimizations on if available.
[23:25:37] Entering M.D.
[02:03:04] Past main M.D. loop
[02:04:04]
[02:04:04] Finished Work Unit:
[02:04:04] - Reading up to 2296536 from "work/wudata_06.arc": Read 2296536
[02:04:04] - Reading up to 395312 from "work/wudata_06.xtc": Read 395312
[02:04:04] goefile size: 0
[02:04:04] logfile size: 33635
[02:04:04] Leaving Run
[02:04:06] - Writing 2743659 bytes of core data to disk...
[02:04:06]   ... Done.
[02:04:07] - Shutting down core
[02:04:07]
[02:04:07] Folding@home Core Shutdown: FINISHED_UNIT
[02:04:10] CoreStatus = 64 (100)
[02:04:10] Sending work to server
[02:04:10] Project: 2484 (Run 102, Clone 4, Gen 19)
[02:04:10] - Read packet limit of 540015616... Set to 524286976.
[02:04:10] + Attempting to send results [April 19 02:04:10 UTC]
[02:05:21] + Results successfully sent
[02:05:21] Thank you for your contribution to Folding@Home.
Project: 2483 (Run 84, Clone 30, Gen 7)
[23:25:46] Loaded queue successfully.
[23:25:46] - Preparing to get new work unit...
[23:25:46] + Attempting to get work packet
[23:25:46] - Connecting to assignment server
[23:25:46] - Successful: assigned to (171.65.103.162).
[23:25:46] + News From Folding@Home: Welcome to Folding@Home
[23:26:29] + Closed connections
[23:26:29]
[23:26:29] + Processing work unit
[23:26:29] Core required: FahCore_78.exe
[23:26:29] Core found.
[23:26:29] Working on queue slot 00 [April 15 23:26:29 UTC]
[23:26:29] + Working ...
[23:26:29]
[23:26:29] *------------------------------*
[23:26:29] Folding@Home Gromacs Core
[23:26:29] Version 1.90 (March 8, 2006)
[23:26:29]
[23:26:29] Preparing to commence simulation
[23:26:29] - Looking at optimizations...
[23:26:29] - Created dyn
[23:26:29] - Files status OK
[23:26:32] - Expanded 2972212 -> 15076041 (decompressed 507.2 percent)
[23:26:33] - Starting from initial work packet
[23:26:33]
[23:26:33] Project: 2483 (Run 84, Clone 30, Gen 7)
[23:26:33]
[23:26:33] Assembly optimizations on if available.
[23:26:33] Entering M.D.
[01:52:25] Past main M.D. loop
[01:53:25]
[01:53:25] Finished Work Unit:
[01:53:25] - Reading up to 2296224 from "work/wudata_00.arc": Read 2296224
[01:53:25] - Reading up to 97704 from "work/wudata_00.xtc": Read 97704
[01:53:25] goefile size: 0
[01:53:25] logfile size: 33636
[01:53:25] Leaving Run
[01:53:27] - Writing 2445740 bytes of core data to disk...
[01:53:28]   ... Done.
[01:53:28] - Shutting down core
[01:53:28]
[01:53:28] Folding@home Core Shutdown: FINISHED_UNIT
[01:53:31] CoreStatus = 64 (100)
[01:53:31] Sending work to server
[01:53:31] Project: 2483 (Run 84, Clone 30, Gen 7)
[01:53:31] - Read packet limit of 540015616... Set to 524286976.
[01:53:31] + Attempting to send results [April 19 01:53:31 UTC]
[01:54:34] + Results successfully sent
[01:54:34] Thank you for your contribution to Folding@Home.
Project: 2483 (Run 85, Clone 28, Gen 7)
[23:26:41] Loaded queue successfully.
[23:26:41] - Preparing to get new work unit...
[23:26:41] + Attempting to get work packet
[23:26:41] - Connecting to assignment server
[23:26:42] - Successful: assigned to (171.65.103.162).
[23:26:42] + News From Folding@Home: Welcome to Folding@Home
[23:26:42] Loaded queue successfully.
[23:27:24] + Closed connections
[23:27:24]
[23:27:24] + Processing work unit
[23:27:24] Core required: FahCore_78.exe
[23:27:24] Core found.
[23:27:24] Working on queue slot 05 [April 15 23:27:24 UTC]
[23:27:24] + Working ...
[23:27:25]
[23:27:25] *------------------------------*
[23:27:25] Folding@Home Gromacs Core
[23:27:25] Version 1.90 (March 8, 2006)
[23:27:25]
[23:27:25] Preparing to commence simulation
[23:27:25] - Looking at optimizations...
[23:27:25] - Created dyn
[23:27:25] - Files status OK
[23:27:28] - Expanded 2966901 -> 15078465 (decompressed 508.2 percent)
[23:27:28] - Starting from initial work packet
[23:27:28]
[23:27:28] Project: 2483 (Run 85, Clone 28, Gen 7)
[23:27:28]
[23:27:29] Assembly optimizations on if available.
[23:27:29] Entering M.D.
[10:58:49] Past main M.D. loop
[10:59:49]
[10:59:49] Finished Work Unit:
[10:59:49] - Reading up to 2296656 from "work/wudata_05.arc": Read 2296656
[10:59:49] - Reading up to 97116 from "work/wudata_05.xtc": Read 97116
[10:59:49] goefile size: 0
[10:59:49] logfile size: 58322
[10:59:49] Leaving Run
[10:59:52] - Writing 2470270 bytes of core data to disk...
[10:59:52]   ... Done.
[10:59:52] - Shutting down core
[10:59:52]
[10:59:52] Folding@home Core Shutdown: FINISHED_UNIT
[10:59:56] CoreStatus = 64 (100)
[10:59:56] Sending work to server
[10:59:56] Project: 2483 (Run 85, Clone 28, Gen 7)
[10:59:56] - Read packet limit of 540015616... Set to 524286976.
[10:59:56] + Attempting to send results [April 19 10:59:56 UTC]
[11:00:59] + Results successfully sent
[11:00:59] Thank you for your contribution to Folding@Home.
Re: Project: 248x
I found partial credit for the last WU (but it's quite old) : Your WU (P2483 R85 C28 G7) was added to the stats database on 2009-02-03 18:10:19 for 250.31 points of credit.
I think there is an issue with credit with these project (or server).
Aardvark
Re: Project: 248x - not crediting
Post by Aardvark »
I have an "oar in the water" on this issue. I did post in this forum regarding Proj2484 R128C25G8, It appears to be only one of MANY WUs that somehow have been lost by PG in this recent issue. I think that the forum Moderators and Admins have done an admirable job in investigating to the limits they are allowed and have made the problem/issue known to PG. At what point is it reasonable for us (as members of this Folding Project) to expect PG to come to this Forum and explain what happened to all the 248x WU credit that has been lost in this recent problem? If there was some equipment or system failure, so be it, BUT I think we need to know.
What is past is prologue!
ppetrone
Pande Group Member
Post by ppetrone »
The request for information is completely fair given that the donors are making a contribution and they want to know what is happening with their credits.
I am aware of the issue of Proj2484 and Proj2483 thanks to the forum posters and personal messages that have arrived, and I apologize for not writing before. The reason for the silence is that we only give recredits in exceptional circumstances and I wanted to make sure this was the case before I made any statement here in the forum. I have been working on it and identified that the equipment was down for some hours and during those times, some WUs were completed and accepted by the server, but unfortunately the server failed to upload them. Please, bear with me and in the next 24 hours and I will be able to give more info regarding recredit.
Thank you for your patience and understanding. I am doing my best to gather the info you requested and deserve.
Paula.
Aardvark
Post by Aardvark »
Thank you, paula, for the response. We will await the results .
ppetrone
Pande Group Member
Post by ppetrone »
Hi all, as an update we have the list for recredit! the bad news is that the key team member that is in charge of fah payroll & recredits is out.
So I will post here as soon as the recredits go through.
Thanks for your patience.
Paula
LargeLarry
20 days have passed since I uploaded the work units on April 19th. :(
Just got a 905 point credit, and had no other machines with recent turn ins, so I am assuming the one I had been waiting to show up has gone through the re-credit process.
LargeLarry
I got a 1810 point credit, which must be two of the four work units I completed. Wonder what happened to the other two. I had given up on this after so much time had passed.
Aardvark
Post by Aardvark »
I notice that I received a 905 point credit on 5/13/2009. I assume this is for a Proj 2484 WU which had gone "missing".
A solid THANK YOU to all that worked on the recovery effort.
ppetrone
Pande Group Member
Post by ppetrone »
... the recredit came ... for Mother's day
Thank you for your patience and for contributing to this project.
