is F@H single or double precision?
alpha754293
Post by alpha754293 »
jaak ennuste
Hardware configuration: 3 x Nvidia Geforce GTX 295 cards (total 6 GPU's)
AMD Phenom x4 2600MHz Black Edition
MSI 790FX K9A2 Platinum system board, 4GB RAM
ATX case, 1000 W Chieftec PS
Windows XP 64-bit
More: http://estoniadonates.wordpress.com/
Re: is F@H single or double precision?
Post by jaak ennuste »
I have a wild guess -- single
Jaak
building 32 GPU folding rig: 16 x NVIDIA GeForce GTX 295 cards; dual PSU solution; 4 nodes.
Website: Estonia Donates, ambitious 400 PPD supercomputer project
Sponsored by AdlerFlow ceramic coated Porsche exhausts
^w^ing
Hardware configuration: C2D E6400 2.13 GHz @ 3.2 GHz
Asus EN8800GTS 640 (G80) @ 660/792/1700 running the 6.23 w/ core11 v1.19
forceware 260.89
Asus P5N-E SLi
2GB 800MHz DDRII (2xCorsair TwinX 512MB)
WinXP 32 SP3
Post by ^w^ing »
I think all the fah cores are single precision, except for the double gromacs cores (79,7b,7c), those are double precision.
Here is a list of all cores that have ever been used in FAH with a brief description : http://fahwiki.net/index.php/Cores
metal03326
Hardware configuration: Mainboard: Asus M2R32-MVP (AMD 580X CrossFire Chipset)
CPU: AMD Athlon X2 3800+@2.4GHz
CPU cooler: Arctic Cooling Freezer 64 Pro PWM
RAM: 2x1 GB Team XTreme Dark 800MHz@5-5-5-16 in Dual Channel mode
Video Card: Sapphire HD 2600 XT@850MHz GDDR4@2200MHz
HDD: WESTERN DIGITAL 640GB Caviar® Black™ SATA2 7200rpm 32MB
OS: Microsoft Windows 7 Ultimate x64
Clients (always latest version): SMP2
Dell Inspiron 1000 (Celeron@2.2GHz)
Post by metal03326 »
I guess the GPU cores are single, because they run on HD 2x00, which do not have double precision.
John Naylor
Hardware configuration: Q9450 OC @ 3.2GHz (Win7 Home Premium) - SMP2
i5-3750k @ 3.8GHz (Win7 Pro) - SMP2
Post by John Naylor »
All cores are single precision except the three DGromacs cores which are double precision, as said by ^w^ing.
Folding whatever I'm sent since March 2006 :) Beta testing since October 2006. www.FAH-Addict.net Administrator since August 2009.
^w^ing
forceware 260.89
Asus P5N-E SLi
WinXP 32 SP3
Post by ^w^ing »
John Naylor wrote:All cores are single precision except the three DGromacs cores which are double precision, as said by ^w^ing.
woohoo \o/ :lol:
metal03326 wrote:I guess the GPU cores are single, because they run on HD 2x00, which do not have double precision.
There's someone who know's GPUs. ;) Here's another bit of trivia for you to tuck away...
mhouston wrote:It's all currently single precision. All 800 on the 48XX SPs can support single precision floating point, leading to a 2.5X increase in peak performance. Double precision on the 48XX is also 2.5X the performance of the 38XX.
VijayPande wrote:With a lot of effort, one can rewrite code that depends on double precision to run in single. It's rare that the whole code requires double -- usually there's just a few precision sensitive parts. By treating these parts carefully (e.g. reordering the numerics to avoid things like adding big numbers to small numbers, etc.) single precision can always work, but with a lot of effort in some cases.
We've already done that effort in GPU1, so the GPU2 code benefits from this today.
alpha754293
Good to know. Thanks guys. :)
ColonelCain
Post by ColonelCain »
alpha754293 wrote:Good to know. Thanks guys. :)
Indeed. :D Quite.
