WUs not computed.
Fernando_Celio
WUs not computed.
Post by Fernando_Celio »
Gentlemen,
A member of my team, Forum PCs, 13802, nickname quickinho had two Wus that seems to be not computed to him.
The WUs are :
Project: 2665 (Run 1, Clone 605, Gen 108)
Project: 2665 (Run 3, Clone 986, Gen 106)
His FAHlog.txt looks normal, at time of sending. Any help will be appreciated.
Thanks in advanced.
Best Regards, Fernando.
Always remember Dick Howell.
Re: WUs not computed.
First WU has been completed by another donor.
Second WU is showing 3 reports for partial credit.
P.S : there are currently some delays in credits for p2665 ... so that's not surprising that I can't find any results for quickinho.
Fernando_Celio
Thanks toTOW.
Now comes the problem.
FAHlog.txt of the first WU :
[14:16:51] Completed 245000 out of 250000 steps (98 percent)
[14:21:51] Timered checkpoint triggered.
[14:26:52] Timered checkpoint triggered.
[14:31:53] Timered checkpoint triggered.
[14:34:01] Writing local files
[14:34:01] Completed 247500 out of 250000 steps (99 percent)
[14:39:02] Timered checkpoint triggered.
[14:44:03] Timered checkpoint triggered.
[14:49:04] Timered checkpoint triggered.
[14:51:27] Writing local files
[14:51:27] Completed 250000 out of 250000 steps (100 percent)
[14:51:27] Writing final coordinates.
[14:51:28] Past main M.D. loop
[14:51:28] Will end MPI now
[14:52:28]
[14:52:28] Finished Work Unit:
[14:52:28] - Reading up to 21193200 from "work/wudata_04.arc": Read 21193200
[14:52:28] - Reading up to 529808 from "work/wudata_04.xtc": Read 529808
[14:52:28] goefile size: 0
[14:52:28] logfile size: 239882
[14:52:28] Leaving Run
[14:52:33] - Writing 21969262 bytes of core data to disk...
[14:52:33] ... Done.
[14:52:33] - Failed to delete work/wudata_04.sas
[14:52:33] - Failed to delete work/wudata_04.goe
[14:52:33] Warning: check for stray files
[14:52:33] - Shutting down core
[14:54:33]
[14:54:33] Folding@home Core Shutdown: FINISHED_UNIT
[14:54:33]
[14:54:37] CoreStatus = 7B (123)
[14:54:37] Sending work to server
[14:54:37] Project: 2665 (Run 1, Clone 605, Gen 108)
[14:54:37] + Attempting to send results [April 23 14:54:37 UTC]
[14:54:37] - Reading file work/wuresults_04.dat from core
[14:54:37] (Read 21969262 bytes from disk)
[14:54:37] Connecting to http://171.64.65.64:80/
[15:00:31] Posted data.
[15:00:31] Initial: 0000; - Uploaded at ~60 kB/s
[15:00:31] - Averaged speed for that direction ~34 kB/s
[15:00:31] + Results successfully sent
[15:00:31] Thank you for your contribution to Folding@Home.
Log of the second WU :
[07:52:36] Completed 245000 out of 250000 steps (98 percent)
[07:57:36] Timered checkpoint triggered.
[08:02:37] Timered checkpoint triggered.
[08:07:38] Timered checkpoint triggered.
[08:09:40] Writing local files
[08:09:40] Completed 247500 out of 250000 steps (99 percent)
[08:14:41] Timered checkpoint triggered.
[08:19:42] Timered checkpoint triggered.
[08:24:43] Timered checkpoint triggered.
[08:26:45] Writing local files
[08:26:45] Completed 250000 out of 250000 steps (100 percent)
[08:26:45] Writing final coordinates.
[08:26:46] Past main M.D. loop
[08:26:46] Will end MPI now
[08:27:46]
[08:27:46] Finished Work Unit:
[08:27:46] - Reading up to 21310704 from "work/wudata_05.arc": Read 21310704
[08:27:46] - Reading up to 559632 from "work/wudata_05.xtc": Read 559632
[08:27:46] goefile size: 0
[08:27:46] logfile size: 249064
[08:27:46] Leaving Run
[08:27:50] - Writing 22125772 bytes of core data to disk...
[08:27:51] ... Done.
[08:27:52] - Failed to delete work/wudata_05.sas
[08:27:52] - Failed to delete work/wudata_05.goe
[08:27:52] Warning: check for stray files
[08:27:52] - Shutting down core
[08:29:52]
[08:29:52] Folding@home Core Shutdown: FINISHED_UNIT
[08:29:52]
[08:29:56] CoreStatus = 64 (100)
[08:29:56] Unit 5 finished with 71 percent of time to deadline remaining.
[08:29:56] Updated performance fraction: 0.735232
[08:29:56] Sending work to server
[08:29:56] Project: 2665 (Run 3, Clone 986, Gen 106)
[08:29:56] + Attempting to send results [April 25 08:29:56 UTC]
[08:29:56] - Reading file work/wuresults_05.dat from core
[08:29:56] (Read 22125772 bytes from disk)
[08:29:56] Connecting to http://171.64.65.64:8080/
[08:35:41] Posted data.
[08:35:41] Initial: 0000; - Uploaded at ~62 kB/s
[08:35:41] - Averaged speed for that direction ~41 kB/s
[08:35:41] + Results successfully sent
[08:35:41] Thank you for your contribution to Folding@Home.
Is there any explanation on how this could happens ???
Thank you once more.
See my PS ... and this thread too : viewtopic.php?f=16&t=9702
Fernando_Celio
toTOW wrote:First WU has been completed by another donor.
toTOW,
This is the point that I did not understand. If my team mate sended the WU three days ago, and he did this because the work did not reach the deadline, how the credits for that WU went to other people ?
Thanks for your patient and the indication of the other post.
When toTOW said there were some delays in credits for p2665, he meant that the credit for some WUs which have been upload were temporarily misplaced by the stats system -- which is just what you're reporting. This has been reported to the Pande Group and I expect that they'll find the problem and then manually add the credits that are missing. There's no way to know when they'll be able to do that, however.
Fernando_Celio
Thanks Bruce.
There is any way to help them to do this job, like open a new topic with WUs p2665 not computed or add a post in the topic above mentioned by toTOW ?
I could do that.
Thanks once more.
Fernando_Celio wrote:There is any way to help them to do this job . . . ?
Not really. Just be patient.
PS- Welcome back to the forum. I haven't seen you recently.
Fernando_Celio
bruce wrote: .......
Thanks for the welcome, bruce.
I am fighting (actually) against several wealth problems in almost all off my family and I am returning to post here now, even I never stopped to fold.
And with the help of several new outstanding members, we are pushing forward the Forum PCs team.
