Project: 2499 (Run 73, Clone 30, Gen 0)
shiryunaga
Hardware configuration: Intel Core i3 2100 3092.91 MHz (99.77 x 31.0)
Post by shiryunaga »
FILE_IO_ERROR :shock:
[10:56:29] Completed 65000 out of 250000 steps  (26%)
[11:06:00]
[11:06:00] Folding@home Core Shutdown: INTERRUPTED
[11:06:04] CoreStatus = 66 (102)
[11:06:04] + Shutdown requested by user. Exiting.***** Got a SIGTERM signal (2)
[11:06:04] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [April 25 11:07:50 UTC]
                          http://folding.stanford.edu
Launch directory: G:\CPU1
Service: G:\CPU1\Folding@home-Win32-x86.exe
Arguments: -svcstart -d G:\CPU1 -advmethods -forceasm -verbosity 9
Launched as a service.
Entered G:\CPU1 to do work.
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[11:07:50] - Ask before connecting: No
[11:07:51] - User name: shiryunaga (Team 153760)
[11:07:51] - User ID: 73178E15B3AB94B
[11:07:51] - Machine ID: 1
[11:07:51]
[11:07:51] Loaded queue successfully.
[11:07:51]
[11:07:51] + Processing work unit
[11:07:51] Core required: FahCore_78.exe
[11:07:51] Core found.
[11:07:51] - Autosending finished units... [April 25 11:07:51 UTC]
[11:07:51] Trying to send all finished work units
[11:07:51] + No unsent completed units remaining.
[11:07:51] - Autosend completed
[11:07:51] Working on queue slot 04 [April 25 11:07:51 UTC]
[11:07:51] + Working ...
[11:07:51] - Calling '.\FahCore_78.exe -dir work/ -suffix 04 -checkpoint 30 -service -forceasm -verbose -lifeline 1476 -version 623'
[11:07:52]
[11:07:52] *------------------------------*
[11:07:52] Folding@Home Gromacs Core
[11:07:52] Version 1.90 (March 8, 2006)
[11:07:52]
[11:07:52] Preparing to commence simulation
[11:07:52] - Assembly optimizations manually forced on.
[11:07:52] - Not checking prior termination.
[11:07:57] - Expanded 2211861 -> 15090897 (decompressed 682.2 percent)
[11:07:58]
[11:07:58] Project: 2499 (Run 73, Clone 30, Gen 0)
[11:07:58]
[11:07:58] Assembly optimizations on if available.
[11:07:58] Entering M.D.
[11:08:20] (Starting from checkpoint)
[11:08:20] Protein: Translocon_ALX2
[11:08:20]
[11:08:21] Writing local files
[11:08:21] Completed 65000 out of 250000 steps  (26%)
[11:08:26] Extra SSE boost OK.
[11:24:54] teps  (26%)
[11:25:04] Extra SSE boost OK.
[11:49:19] ze of work/wudata_04.xtc not what saved.
[11:49:19]
[11:49:19] Folding@home Core Shutdown: FILE_IO_ERROR
[11:49:22] CoreStatus = 75 (117)
[11:49:22] Error opening or reading from a file.
[11:49:22] Deleting current work unit & continuing...
[11:49:26] Trying to send all finished work units
[11:49:26] + No unsent completed units remaining.
[11:49:26] - Preparing to get new work unit...
[11:49:26] + Attempting to get work packet
[11:49:26] - Will indicate memory of 1022 MB
[11:49:26] - Detect CPU. Vendor: GenuineIntel, Family: 15, Model: 4, Stepping: 7
[11:49:26] - Connecting to assignment server
[11:49:26] Connecting to http://assign.stanford.edu:8080/
[11:49:36] Posted data.
[11:49:36] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[11:49:36] + News From Folding@Home: Welcome to Folding@Home
[11:49:36] Loaded queue successfully.
[11:49:36] Connecting to http://171.65.103.162:8080/
[11:49:44] Posted data.
[11:49:49] Initial: 0000; - Receiving payload (expected size: 2988447)
[12:10:46] - Downloaded at ~2 kB/s
[12:10:46] - Averaged speed for that direction ~9 kB/s
[12:10:46] + Received work.
[12:10:46] + Closed connections
[12:10:51]
[12:10:51] + Processing work unit
[12:10:51] Core required: FahCore_78.exe
[12:10:51] Core found.
[12:10:51] Working on queue slot 05 [April 25 12:10:51 UTC]
[12:10:51] + Working ...
[12:10:51] - Calling '.\FahCore_78.exe -dir work/ -suffix 05 -checkpoint 30 -service -forceasm -verbose -lifeline 1476 -version 623'
[12:10:51]
[12:10:51] *------------------------------*
[12:10:51] Folding@Home Gromacs Core
[12:10:51] Version 1.90 (March 8, 2006)
[12:10:51]
[12:10:51] Preparing to commence simulation
[12:10:51] - Assembly optimizations manually forced on.
[12:10:51] - Not checking prior termination.
[12:10:58] - Expanded 2987935 -> 15097361 (decompressed 505.2 percent)
[12:10:58] - Starting from initial work packet
[12:10:58]
[12:10:58] Project: 2498 (Run 10, Clone 16, Gen 1)
[12:10:58]
[12:10:58] Assembly optimizations on if available.
[12:10:58] Entering M.D.
[12:11:06] Protein: Translocon_GLX2
[12:11:06]
[12:11:06] Writing local files
[12:11:11] Extra SSE boost OK.
[12:11:13] Writing local files
[12:11:13] Completed 0 out of 250000 steps  (0%)
[12:24:10]  of 250000 steps  (0%)
[12:28:49] xtc not what saved.
[12:28:49]
[12:28:49] Folding@home Core Shutdown: FILE_IO_ERROR
[12:28:51] CoreStatus = 75 (117)
[12:28:51] Error opening or reading from a file.
[12:28:51] Deleting current work unit & continuing...
[12:28:55] Trying to send all finished work units
[12:28:55] + No unsent completed units remaining.
[12:28:55] - Preparing to get new work unit...
[12:28:55] + Attempting to get work packet
[12:28:55] - Will indicate memory of 1022 MB
[12:28:55] - Connecting to assignment server
[12:28:55] Connecting to http://assign.stanford.edu:8080/
[12:29:02] Posted data.
[12:29:02] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[12:29:02] + News From Folding@Home: Welcome to Folding@Home
[12:29:03] Loaded queue successfully.
[12:29:03] Connecting to http://171.65.103.162:8080/
[12:29:11] Posted data.
[12:29:12] Initial: 0000; - Receiving payload (expected size: 2988447)
Folding@Home user since Feb 2009
Re: Project: 2499 (Run 73, Clone 30, Gen 0)
There are two reports of failure on this WU (they both got partial credit).
