Project: 5746 (Run 4, Clone 6, Gen 173)
shiryunaga
Hardware configuration: Intel Core i3 2100 3092.91 MHz (99.77 x 31.0)
Post by shiryunaga »
NANs detected on GPU :x
[06:28:55] + Closed connections
[06:29:00]
[06:29:00] + Processing work unit
[06:29:00] Core required: FahCore_11.exe
[06:29:00] Core found.
[06:29:00] Working on queue slot 01 [April 25 06:29:00 UTC]
[06:29:00] + Working ...
[06:29:00] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -checkpoint 30 -verbose -lifeline 13888 -version 623'
[06:29:00]
[06:29:00] *------------------------------*
[06:29:00] Folding@Home GPU Core - Beta
[06:29:00] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[06:29:00]
[06:29:00] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:29:00] Build host: amoeba
[06:29:00] Board Type: AMD
[06:29:00] Core      :
[06:29:00] Preparing to commence simulation
[06:29:00] - Looking at optimizations...
[06:29:00] - Created dyn
[06:29:00] - Files status OK
[06:29:00] - Expanded 68554 -> 357580 (decompressed 521.6 percent)
[06:29:00] Called DecompressByteArray: compressed_data_size=68554 data_size=357580, decompressed_data_size=357580 diff=0
[06:29:00] - Digital signature verified
[06:29:00]
[06:29:00] Project: 5746 (Run 4, Clone 6, Gen 173)
[06:29:00]
[06:29:00] Assembly optimizations on if available.
[06:29:00] Entering M.D.
[06:29:06] Tpr hash work/wudata_01.tpr:  2856688551 4051160946 1693861755 2996639776 2020209054
[06:29:06] Working on Protein
[06:29:07] Client config found, loading data.
[06:29:07] Starting GUI Server
[06:33:12] Completed 1%
[06:37:52] Completed 2%
[06:42:39] Completed 3%
[06:47:21] Completed 4%
[06:50:45] Completed 5%
[06:54:18] Completed 6%
[06:57:41] Completed 7%
[07:01:09] Completed 8%
[07:04:38] Completed 9%
[07:09:05] Completed 10%
[07:12:56] Completed 11%
[07:17:04] Completed 12%
[07:20:52] Completed 13%
[07:24:31] Completed 14%
[07:28:33] Completed 15%
[07:32:29] Completed 16%
[07:36:04] Completed 17%
[07:39:50] Completed 18%
[07:43:49] Completed 19%
[07:48:08] Completed 20%
[07:53:05] Completed 21%
[07:57:32] Completed 22%
[08:01:53] Completed 23%
[08:06:03] Completed 24%
[08:10:02] Completed 25%
[08:13:55] Completed 26%
[08:18:04] Completed 27%
[08:22:04] Completed 28%
[08:25:59] Completed 29%
[08:30:04] Completed 30%
[08:33:51] Completed 31%
[08:37:35] Completed 32%
[08:41:31] Completed 33%
[08:45:14] Completed 34%
[08:48:53] Completed 35%
[08:52:39] Completed 36%
[08:56:46] Completed 37%
[09:01:05] Completed 38%
[09:05:22] Completed 39%
[09:09:08] Completed 40%
[09:12:49] Completed 41%
[09:16:30] Completed 42%
[09:20:18] Completed 43%
[09:23:46] Completed 44%
[09:27:21] Completed 45%
[09:30:55] Completed 46%
[09:35:51] Completed 47%
[09:41:06] Completed 48%
[09:47:24] Completed 49%
[09:53:29] Completed 50%
[09:57:32] Completed 51%
[10:03:33] Completed 52%
[10:07:19] mdrun_gpu returned
[10:07:19] NANs detected on GPU
[10:07:19]
[10:07:19] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:07:21] CoreStatus = 7A (122)
[10:07:21] Sending work to server
[10:07:21] Project: 5746 (Run 4, Clone 6, Gen 173)
[10:07:21] - Error: Could not get length of results file work/wuresults_01.dat
[10:07:21] - Error: Could not read unit 01 file. Removing from queue.
[10:07:21] Trying to send all finished work units
[10:07:21] + No unsent completed units remaining.
[10:07:21] - Preparing to get new work unit...
[10:07:21] + Attempting to get work packet
[10:07:21] - Will indicate memory of 1022 MB
[10:07:21] - Connecting to assignment server
[10:07:21] Connecting to http://assign-GPU.stanford.edu:8080/
[10:07:28] Posted data.
[10:07:28] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[10:07:28] + News From Folding@Home: GPU folding beta
[10:07:28] Loaded queue successfully.
[10:07:28] Connecting to http://171.64.65.102:8080/
[10:07:34] Posted data.
[10:07:34] Initial: 0000; - Receiving payload (expected size: 97111)
[10:08:10] - Downloaded at ~2 kB/s
[10:08:10] - Averaged speed for that direction ~8 kB/s
[10:08:10] + Received work.
[10:08:10] Trying to send all finished work units
[10:08:10] + No unsent completed units remaining.
[10:08:10] + Closed connections
[10:08:15]
Folding@Home user since Feb 2009
Re: Project: 5746 (Run 4, Clone 6, Gen 173)
There's no data for this WU in the DB yet ...
