[16:56:51] + Closed connections
[16:56:51]
[16:56:51] + Processing work unit
[16:56:51] Core required: FahCore_11.exe
[16:56:51] Core found.
[16:56:51] Working on queue slot 08 [April 24 16:56:51 UTC]
[16:56:51] + Working ...
[16:56:51] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -checkpoint 30 -verbose -lifeline 7740 -version 623'
[16:56:51]
[16:56:51] *------------------------------*
[16:56:51] Folding@Home GPU Core - Beta
[16:56:51] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[16:56:51]
[16:56:51] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:56:51] Build host: amoeba
[16:56:51] Board Type: AMD
[16:56:51] Core :
[16:56:51] Preparing to commence simulation
[16:56:51] - Looking at optimizations...
[16:56:51] - Created dyn
[16:56:51] - Files status OK
[16:56:51] - Expanded 96548 -> 489152 (decompressed 506.6 percent)
[16:56:51] Called DecompressByteArray: compressed_data_size=96548 data_size=489152, decompressed_data_size=489152 diff=0
[16:56:51] - Digital signature verified
[16:56:51]
[16:56:51] Project: 5738 (Run 2, Clone 49, Gen 129)
[16:56:51]
[16:56:51] Assembly optimizations on if available.
[16:56:51] Entering M.D.
[16:56:58] Tpr hash work/wudata_08.tpr: 3253872903 1868588147 1356972098 2568613648 2841075789
[16:56:58] Working on Protein
[16:56:59] Client config found, loading data.
[16:56:59] Starting GUI Server
[17:01:34] Completed 1%
[17:10:25] Completed 2%
[17:10:58] mdrun_gpu returned
[17:10:58] NANs detected on GPU
[17:10:58]
[17:10:58] Folding@home Core Shutdown: UNSTABLE_MACHINE
[17:11:02] CoreStatus = 7A (122)
[17:11:02] Sending work to server
[17:11:02] Project: 5738 (Run 2, Clone 49, Gen 129)
[17:11:02] - Error: Could not get length of results file work/wuresults_08.dat
[17:11:02] - Error: Could not read unit 08 file. Removing from queue.
[17:11:02] Trying to send all finished work units
[17:11:02] + No unsent completed units remaining.
[17:11:02] - Preparing to get new work unit...
[17:11:02] + Attempting to get work packet
[17:11:02] - Will indicate memory of 1022 MB
[17:11:02] - Connecting to assignment server
[17:11:02] Connecting to http://assign-GPU.stanford.edu:8080/
[17:11:07] Posted data.
[17:11:08] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[17:11:08] + News From Folding@Home: GPU folding beta
[17:11:08] Loaded queue successfully.
[17:11:08] Connecting to http://171.64.65.103:8080/
[17:11:12] Posted data.
[17:11:12] Initial: 0000; + Could not connect to Work Server
[17:11:12] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[17:11:28] + Attempting to get work packet
[17:11:28] - Will indicate memory of 1022 MB
[17:11:28] - Connecting to assignment server
[17:11:28] Connecting to http://assign-GPU.stanford.edu:8080/
[17:11:33] Posted data.
[17:11:33] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[17:11:33] + News From Folding@Home: GPU folding beta
[17:11:33] Loaded queue successfully.
[17:11:33] Connecting to http://171.64.65.103:8080/
[17:11:34] Posted data.
[17:11:34] Initial: 0000; - Receiving payload (expected size: 86251)
[17:11:45] - Downloaded at ~7 kB/s
[17:11:45] - Averaged speed for that direction ~6 kB/s
[17:11:45] + Received work.
[17:11:45] Trying to send all finished work units
[17:11:45] + No unsent completed units remaining.
[17:11:45] + Closed connections
[17:11:50]
