171.67.108.11
silveradocyn
171.67.108.11
Post by silveradocyn »
My system can't seem to get this WU uploaded...
[13:00:18] Connecting to http://171.67.108.11:80/
[13:00:39] - Couldn't send HTTP request to server
[13:00:39] + Could not connect to Work Server (results)
[13:00:39]     (171.67.108.11:80)
[13:00:39] - Error: Could not transmit unit 06 (completed April 23) to work server.
[13:00:39] - 14 failed uploads of this unit.
In the wild Canyons of OC.
Re: Server Issue?
It is in Reject mode ... :(
umc
Re: 171.67.108.11
Post by umc »
I got stuck for about 50 result files can't be sent and they gonna be expired soon. backup server doesn't want to take my results either
Jeff-M
Re: 171.67.108.11
Post by Jeff-M »
I have almost 6000 points waiting to upload on server 171.67.108.12 which is in reject mode :(
Back up and uploaded 8-)
IkkeDus
Hardware configuration: Q9550 @ 2.8 GHz
WIN10 x64
2x Radeon R9 280X-3GB
1x Radeon R9 7950-3GB
Re: 171.67.108.11
Post by IkkeDus »
Unable to upload for some time (GPU client).
I do not get the OK response in the browser. I can, however, ping to this address.
Tried also (at random) 171.64.65.103 to check: I get a proper OK response.
[08:57:30] + Attempting to get work packet
[08:57:30] - Connecting to assignment server
[08:57:50] - Couldn't send HTTP request to server
[08:57:50] + Could not connect to Assignment Server
[08:57:51] - Successful: assigned to (171.67.108.11).
[08:57:51] + News From Folding@Home: GPU folding beta
[08:57:51] Loaded queue successfully.
[08:57:58] - Couldn't send HTTP request to server
[08:57:58] + Could not connect to Work Server
[08:57:58] - Attempt #10 to get work failed, and no other work to do.
Waiting before retry.
Q9550 @ 2.8 GHz | 2x R9 280X-3GB | HD 7950-3GB | Win10 x64
IkkeDus
WIN10 x64
Re: 171.67.108.11
Post by IkkeDus »
With Verbosity -9
[12:02:10] Loaded queue successfully.
[12:02:10] - Preparing to get new work unit...
[12:02:10] + Attempting to get work packet
[12:02:10] - Will indicate memory of 3582 MB
[12:02:10] - Detect CPU.[12:02:10] - Autosending finished units... [May 1 12:02:10 UTC]
Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 6[12:02:10] Trying to send all finished work units
[12:02:10] Project: 5767 (Run 14, Clone 93, Gen 296)
[12:02:10] - Connecting to assignment server
[12:02:10] Connecting to http://assign-GPU.stanford.edu:8080/
[12:02:10] + Attempting to send results [May 1 12:02:10 UTC]
[12:02:10] - Reading file work/wuresults_00.dat from core
[12:02:10] (Read 99596 bytes from disk)
[12:02:10] Connecting to http://171.67.108.11:8080/
[12:02:31] - Couldn't send HTTP request to server
[12:02:31] + Could not connect to Work Server (results)
[12:02:31] (171.67.108.11:8080)
[12:02:31] + Retrying using alternative port
[12:02:31] + Could not connect to Assignment Server[12:02:31] Connecting to http://171.67.108.11:80/
[12:02:31] Connecting to http://assign-GPU.stanford.edu:80/
[12:02:32] Posted data.
[12:02:32] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[12:02:32] + News From Folding@Home: GPU folding beta
[12:02:32] Loaded queue successfully.
[12:02:35] Connecting to http://171.67.108.11:80/
[12:02:38] - Couldn't send HTTP request to server
[12:02:38] + Could not connect to Work Server (results)
[12:02:38] (171.67.108.11:80)
[12:02:38] - Error: Could not transmit unit 00 (completed May 1) to work server.
[12:02:38] - 4 failed uploads of this unit.
[12:02:38] + Attempting to send results [May 1 12:02:38 UTC]
[12:02:38] - Reading file work/wuresults_00.dat from core
[12:02:38] (Read 99596 bytes from disk)
[12:02:38] Connecting to http://171.67.108.25:8080/
[12:02:42] - Couldn't send HTTP request to server
[12:02:42] + Could not connect to Work Server
[12:02:42] - Attempt #1 to get work failed, and no other work to do.
Re: 171.67.108.11
http://171.67.108.11:8080/ works for me, although http://171.67.108.11:80/ does not.
I'll let them know about it.
bollix47
Re: 171.67.108.11
Post by bollix47 »
In REJECT again:
May 4 06:20:20 PDT 2009 	171.67.108.11 	GPU 	vsp07v 	vvoelz 	full 	Reject 	1.37 	30 	0 	22 	26815 	9083 	4 	6.28 	193077 	187751 	50410 	- 	- 	70 	- 	5974 	189 	2 	10 	 1 	171.64.122.86
171.67.108.25
	171.67.108.25 	0 	0 	W; W; W; W; 	10, 10, 10, 1 	6.119, 6.119, 6.119, 6.119 	- 	49, 49, 49, 49 	64, 64, 64, 64 	- 	F, A, B, I 	8080G, 8080G, 8080G, 8080G 	6.28.01 	- 	241 	170 	0 	vvoelz 	1 	vsp07v
Mon May 4 06:30:20 PDT 2009 	171.67.108.11 	GPU 	vsp07v 	vvoelz 	full 	Reject 	1.25 	22 	1 	22 	26815 	9083 	4 	6.28 	193077 	187751 	50410 	- 	- 	53 	- 	5974 	189 	2 	10 	1 	171.64.122.86
171.67.108.25
codysluder
Re: 171.67.108.11
Post by codysluder »
Both are working again.
silveradocyn
Re: 171.67.108.11
It seems to be acting up again....
[23:47:44]   (Read 262361 bytes from disk)
[23:47:44] Connecting to http://171.67.108.11:8080/
[23:47:45] - Couldn't send HTTP request to server
[23:47:45] + Could not connect to Work Server (results)
[23:47:45]     (171.67.108.11:8080)
[23:47:45] + Retrying using alternative port
[23:47:45] Connecting to http://171.67.108.11:80/
[23:47:46] - Couldn't send HTTP request to server
[23:47:46] + Could not connect to Work Server (results)
[23:47:46]     (171.67.108.11:80)
[23:47:46] - Error: Could not transmit unit 05 (completed May 15) to work server.
[23:47:46] - 4 failed uploads of this unit.
[23:47:46] - Read packet limit of 540015616... Set to 524286976.
[23:47:46] + Attempting to send results [May 15 23:47:46 UTC]
[23:47:46] - Reading file work/wuresults_05.dat from core
[23:47:46]   (Read 262361 bytes from disk)
[23:47:46] Connecting to http://171.67.108.25:8080/
[23:47:46]   (Got status 503)
[23:47:46]     (171.67.108.25:8080)
[23:47:46] + Retrying using alternative port
[23:47:46] Connecting to http://171.67.108.25:80/
[23:47:46]     (171.67.108.25:80)
[23:47:46]   Could not transmit unit 05 to Collection server; keeping in queue.
[23:47:46] + Sent 0 of 1 completed units to the server
[23:47:46] - Autosend completed
shdbcamping
Hardware configuration: XPS 720 Q6600 9800GX2 3gig RAM
750W primary PSU 650W Aux VGA PSU
171.67.108.11
Post by shdbcamping »
I cannot send or receive for the last 3 clients that have finished :cry:
Edit: make that 7 GPU2 console clients now :?:
--- Opening Log file [May 19 12:55:16 UTC]
                       Folding@Home Client Version 6.20r1
                          http://folding.stanford.edu
Launch directory: C:\GPU1
Executable: C:\GPU1\Folding@home-Win32-GPU1.exe
Arguments: -gpu 1
[12:55:16] - Ask before connecting: No
[12:55:16] - User name: shdbcamping (Team 80856)
[12:55:16] - User ID: xxxxxxxxxxxxxxx
[12:55:16] - Machine ID: 5
[12:55:16]
[12:55:16] Loaded queue successfully.
[12:55:16] Deleting incompletely fetched item (4) from queue position #2
[12:55:16] - Preparing to get new work unit...
[12:55:16] Project: 5749 (Run 7, Clone 247, Gen 265)
[12:55:16] + Attempting to get work packet
[12:55:16] - Read packet limit of 540015616... Set to 524286976.
[12:55:16] + Attempting to send results [May 19 12:55:16 UTC]
[12:55:17] + No appropriate work server was available; will try again in a bit.
[12:55:17] + Couldn't get work instructions.
[12:55:17] - Attempt #1  to get work failed, and no other work to do.
[12:55:17] - Couldn't send HTTP request to server
[12:55:17] + Could not connect to Work Server (results)
[12:55:17]     (171.67.108.11:8080)
[12:55:17] + Retrying using alternative port
[12:55:19] - Couldn't send HTTP request to server
[12:55:19] + Could not connect to Work Server (results)
[12:55:19]     (171.67.108.11:80)
[12:55:19] - Error: Could not transmit unit 01 (completed May 19) to work server.
[12:55:19] - Read packet limit of 540015616... Set to 524286976.
[12:55:19] + Attempting to send results [May 19 12:55:19 UTC]
[12:55:19]   (Got status 503)
[12:55:19]     (171.67.108.25:8080)
[12:55:19] + Retrying using alternative port
[12:55:19]     (171.67.108.25:80)
[12:55:19]   Could not transmit unit 01 to Collection server; keeping in queue.
[12:55:26] + Attempting to get work packet
[12:55:26] - Connecting to assignment server
[12:55:26] + No appropriate work server was available; will try again in a bit.
[12:55:26] + Couldn't get work instructions.
[12:55:26] - Attempt #2  to get work failed, and no other work to do.
[12:55:51] + Attempting to get work packet
[12:55:51] - Connecting to assignment server
[12:55:51] + No appropriate work server was available; will try again in a bit.
[12:55:51] + Couldn't get work instructions.
[12:55:51] - Attempt #3  to get work failed, and no other work to do.
[12:56:14] + Attempting to get work packet
[12:56:14] - Connecting to assignment server
[12:56:15] + No appropriate work server was available; will try again in a bit.
[12:56:15] + Couldn't get work instructions.
[12:56:15] - Attempt #4  to get work failed, and no other work to do.
[12:56:55] + Attempting to get work packet
[12:56:55] - Connecting to assignment server
[12:56:56] + No appropriate work server was available; will try again in a bit.
[12:56:56] + Couldn't get work instructions.
[12:56:56] - Attempt #5  to get work failed, and no other work to do.
[12:58:23] + Attempting to get work packet
[12:58:23] - Connecting to assignment server
[12:58:23] + No appropriate work server was available; will try again in a bit.
[12:58:23] + Couldn't get work instructions.
[12:58:23] - Attempt #6  to get work failed, and no other work to do.
Reason: Added code tags.
Re: 171.67.108.11
According to server status page, this server is back up ... it should also help with the NV clients having troubles with 171.64.65.106 ...
umc
Re: 171.67.108.11
Post by umc »
both server 11 and .106 are down. i couldn't get work from them
Re: 171.67.108.11
Perhaps you are behind a proxy that blocks port 8080. I can connect to http://171.67.108.11:8080/ but not to http://171.67.108.11/
It's probably unintentional. I'll notify the Pande Group.
Do you mean 171.65.103.106, which is currently out of work, or do you mean 171.64.65.106 which seems to be working normally?
Teddy
Re: 171.67.108.11
Post by Teddy »
Many idle clients here I am getting "no appropriate work server available" for ALL my Nvidia GPU clients.
Have the servers gone into meltdown or something?
Teddy
