Project: 2665 (Run 3 Clone 160 Gen 107)
I would appreciate it if a moderator could check the db for the above-noted WU, which was completed and successfully transmitted (got the Thank You message) over a day ago. Haven't received any points for it. Thanks.
Re: Project: 2665 (R3 C160 G107)
Unfortunately, there's no data for this WU in the DB
Re: Project: 2665 (Run 3 Clone 160 Gen 107)
Bummer, but thanks for checking.
What name do you use for FAH? If it's the same as your forum name, the WU has been completed by someone else:
Your WU (P2665 R3 C160 G107) was added to the stats database on 2009-04-24 12:19:41 for 1920 points of credit.
Hi Bruce, I fold under this username, for Team 328. I could send the log snippet but as I said, it looks totally normal. Only noteworthy thing at all was that it was an a_1 as opposed to the usual a_2 and seemed to take forever (adding insult to injury I guess) since .65.56 was down and I got borked over to .65.64 .
Thanks for the dbl check and let me know if the log's of any help.
The log showing the segment surrounding the upload is generally useful. It shows the time of upload (simplifying the process of checking the logs) and any responses that you got. It should confirm the PRCG numbers. (Please include the date of the upload in your commentary or perhaps as the next WU starts.)
[04:23:49] Working on Unit 02 [April 21 04:23:49]
[04:23:49] + Working ...
[04:23:49]
[04:23:49] *------------------------------*
[04:23:49] Folding@Home Gromacs SMP Core
[04:23:49] Version 1.74 (November 27, 2006)
[04:23:49]
[04:23:49] Preparing to commence simulation
[04:23:49] - Ensuring status. Please wait.
[04:23:50] - Starting from initial work packet
[04:23:51]
[04:23:51] Project: 2665 (Run 3, Clone 160, Gen 107)
[04:23:51]
[04:23:51] Assembly optimizations on if available.
[04:23:51] Entering M.D.
[04:24:09] on if available.
[04:24:09] Entering M.D.
[04:24:16] Rejecting checkpoint
[04:24:18]
[04:24:18] Writing local files
[04:24:18]
[04:24:20] Extra SSE boost OK.
[04:24:21] Writing local files
[04:24:21] Completed 0 out of 250000 steps (0 percent)
[04:55:49] Writing local files
[04:55:49] Completed 2500 out of 250000 steps (1 percent)
<-----snip-----
[07:18:27] Completed 247500 out of 250000 steps (99 percent)
[07:49:01] Writing local files
[07:49:01] Completed 250000 out of 250000 steps (100 percent)
[07:49:01] Writing final coordinates.
[07:49:01] Past main M.D. loop
[07:49:02] Will end MPI now
[07:50:01]
[07:50:01] Finished Work Unit:
[07:50:01] - Reading up to 21310704 from "work/wudata_02.arc": Read 21310704
[07:50:02] - Reading up to 557836 from "work/wudata_02.xtc": Read 557836
[07:50:02] goefile size: 0
[07:50:02] logfile size: 197781
[07:50:02] Leaving Run
[07:50:05] - Writing 22072693 bytes of core data to disk...
[07:50:05] ... Done.
[07:50:06] - Shutting down core
[07:50:06]
[07:50:06] Folding@home Core Shutdown: FINISHED_UNIT
[07:50:11] CoreStatus = 64 (100)
[07:50:11] Sending work to server
[07:50:11] + Attempting to send results
[07:57:05] + Results successfully sent
[07:57:05] Thank you for your contribution to Folding@Home.
[07:57:05] + Number of Units Completed: 2
[08:01:14] - Preparing to get new work unit...
[08:01:14] + Attempting to get work packet
[08:01:14] - Connecting to assignment server
[08:01:14] - Successful: assigned to (171.64.65.56).
[08:01:14] + News From Folding@Home: Welcome to Folding@Home
[08:01:14] Loaded queue successfully.
[08:01:40] + Closed connections
[08:01:40]
[08:01:40] + Processing work unit
[08:01:40] At least 4 processors must be requested.Core required: FahCore_a2.exe
[08:01:40] Core found.
[08:01:40] Working on Unit 03 [April 23 08:01:40]
[08:01:40] + Working ...
[08:01:40]
[08:01:40] *------------------------------*
[08:01:40] Folding@Home Gromacs SMP Core
