Project: 2484 (Run 39, Clone 3, Gen 16)
martiou
Post by martiou »
This unit was completed by one of my machines yesterday and successfully sent. But no credit has shown up so far. Could someone check its status?
[22:27:49] Connecting to http://assign.stanford.edu:8080/
[22:27:49] Posted data.
[22:27:49] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[22:27:49] + News From Folding@Home: Welcome to Folding@Home
[22:27:49] Loaded queue successfully.
[22:27:49] Connecting to http://171.65.103.162:8080/
[22:27:56] Posted data.
[22:27:56] Initial: 0000; - Receiving payload (expected size: 2981947)
[22:28:10] - Downloaded at ~208 kB/s
[22:28:10] - Averaged speed for that direction ~168 kB/s
[22:28:10] + Received work.
[22:28:10] Trying to send all finished work units
[22:28:10] + No unsent completed units remaining.
[22:28:10] + Closed connections
[22:28:10]
[22:28:10] + Processing work unit
[22:28:10] Core required: FahCore_78.exe
[22:28:10] Core found.
[22:28:10] Working on queue slot 08 [April 15 22:28:10 UTC]
[22:28:10] + Working ...
[22:28:10] - Calling '.\FahCore_78.exe -dir work/ -suffix 08 -checkpoint 5 -service -verbose -lifeline 968 -version 620'
[22:28:10]
[22:28:10] *------------------------------*
[22:28:10] Folding@Home Gromacs Core
[22:28:10] Version 1.90 (March 8, 2006)
[22:28:10]
[22:28:10] Preparing to commence simulation
[22:28:10] - Looking at optimizations...
[22:28:10] - Created dyn
[22:28:10] - Files status OK
[22:28:18] - Expanded 2981435 -> 15101061 (decompressed 506.5 percent)
[22:28:18] - Starting from initial work packet
[22:28:18]
[22:28:18] Project: 2484 (Run 39, Clone 3, Gen 16)
[22:28:18]
[22:28:18] Assembly optimizations on if available.
[22:28:18] Entering M.D.
[22:28:26] Protein: system
[22:28:26]
[22:28:26] Writing local files
[22:28:33] Extra SSE boost OK.
[22:28:35] Writing local files
[22:28:35] Completed 0 out of 250000 steps  (0%)
[22:33:36] Timered checkpoint triggered.
[22:38:36] Timered checkpoint triggered.
[22:43:36] Timered checkpoint triggered.
[22:48:37] Timered checkpoint triggered.
[22:53:41] Timered checkpoint triggered.
[22:58:41] Timered checkpoint triggered.
[23:03:42] Timered checkpoint triggered.
[23:08:42] Timered checkpoint triggered.
[23:13:43] Timered checkpoint triggered.
[23:18:47] Timered checkpoint triggered.
[23:24:44] Timered checkpoint triggered.
[23:29:44] Timered checkpoint triggered.
[23:34:45] Timered checkpoint triggered.
[23:39:47] Timered checkpoint triggered.
[23:44:47] Timered checkpoint triggered.
[23:49:48] Timered checkpoint triggered.
[23:54:50] Timered checkpoint triggered.
[23:58:14] Writing local files
[23:58:15] Completed 2500 out of 250000 steps  (1%)
[00:03:15] Timered checkpoint triggered.
[18:05:16] Writing local files
[18:05:16] Completed 247500 out of 250000 steps  (99%)
[18:10:17] Timered checkpoint triggered.
[18:15:18] Timered checkpoint triggered.
[18:20:20] Timered checkpoint triggered.
[18:21:41] - Autosending finished units... [April 22 18:21:41 UTC]
[18:21:41] Trying to send all finished work units
[18:21:41] + No unsent completed units remaining.
[18:21:41] - Autosend completed
[18:26:19] Timered checkpoint triggered.
[18:31:20] Timered checkpoint triggered.
[18:36:22] Timered checkpoint triggered.
[18:42:21] Timered checkpoint triggered.
[18:47:22] Timered checkpoint triggered.
[18:52:24] Timered checkpoint triggered.
[18:57:25] Timered checkpoint triggered.
[19:02:41] Timered checkpoint triggered.
[19:07:42] Timered checkpoint triggered.
[19:12:43] Timered checkpoint triggered.
[19:17:45] Timered checkpoint triggered.
[19:23:43] Timered checkpoint triggered.
[19:28:45] Timered checkpoint triggered.
[19:33:47] Timered checkpoint triggered.
[19:38:48] Timered checkpoint triggered.
[19:43:48] Timered checkpoint triggered.
[19:44:23] Writing local files
[19:44:23] Completed 250000 out of 250000 steps  (100%)
[19:44:23] Writing final coordinates.
[19:44:25] Past main M.D. loop
[19:45:25]
[19:45:25] Finished Work Unit:
[19:45:25] - Reading up to 2296944 from "work/wudata_08.arc": Read 2296944
[19:45:26] - Reading up to 361300 from "work/wudata_08.xtc": Read 361300
[19:45:26] goefile size: 0
[19:45:26] logfile size: 41878
[19:45:26] Leaving Run
[19:45:27] - Writing 2718298 bytes of core data to disk...
[19:45:28]   ... Done.
[19:45:28] - Shutting down core
[19:45:28]
[19:45:28] Folding@home Core Shutdown: FINISHED_UNIT
[19:45:32] CoreStatus = 64 (100)
[19:45:32] Unit 8 finished with 93 percent of time to deadline remaining.
[19:45:32] Updated performance fraction: 0.942758
[19:45:32] Sending work to server
[19:45:32] Project: 2484 (Run 39, Clone 3, Gen 16)
[19:45:32] - Read packet limit of 540015616... Set to 524286976.
[19:45:32] + Attempting to send results [April 22 19:45:32 UTC]
[19:45:32] - Reading file work/wuresults_08.dat from core
[19:45:32]   (Read 2718298 bytes from disk)
[19:45:32] Connecting to http://171.65.103.162:8080/
[19:45:58] Posted data.
[19:45:58] Initial: 0000; - Uploaded at ~94 kB/s
[19:46:00] - Averaged speed for that direction ~86 kB/s
[19:46:00] + Results successfully sent
[19:46:00] Thank you for your contribution to Folding@Home.
[19:46:00] + Number of Units Completed: 994
Thanks
Martiou
Re: Project: 2484 (Run 39, Clone 3, Gen 16)
Hi Martiou (team 35819),
Your WU (P2484 R39 C3 G16) was added to the stats database on 2009-04-22 14:07:48 for 905 points of credit.
martiou
Post by martiou »
Hi toTOW,
When you say 2009-04-22 14:07:48 which time is it 2009-04-22 21:07:48 in UTC ?
If it's right then it's another WU I lost.
Is it possible for you to see for these WUs :
- Project: 2493 (Run 103, Clone 23, Gen 0)
- Project: 2498 (Run 81, Clone 4, Gen 0)
Thanks
Martiou
