Project: 4755 (Run 2, Clone 392, Gen 6)
shiryunaga
Hardware configuration: Intel Core i3 2100 3092.91 MHz (99.77 x 31.0)
Post by shiryunaga »
NANs detected on GPU :x
[05:55:30] + Closed connections
[05:55:30]
[05:55:30] + Processing work unit
[05:55:30] Core required: FahCore_11.exe
[05:55:30] Core found.
[05:55:30] Working on queue slot 02 [April 23 05:55:30 UTC]
[05:55:30] + Working ...
[05:55:30] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -checkpoint 30 -verbose -lifeline 3232 -version 623'
[05:55:31]
[05:55:31] *------------------------------*
[05:55:31] Folding@Home GPU Core - Beta
[05:55:31] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[05:55:31]
[05:55:31] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:55:31] Build host: amoeba
[05:55:31] Board Type: AMD
[05:55:31] Core      :
[05:55:31] Preparing to commence simulation
[05:55:31] - Looking at optimizations...
[05:55:31] - Created dyn
[05:55:31] - Files status OK
[05:55:31] - Expanded 85706 -> 444252 (decompressed 518.3 percent)
[05:55:31] Called DecompressByteArray: compressed_data_size=85706 data_size=444252, decompressed_data_size=444252 diff=0
[05:55:31] - Digital signature verified
[05:55:31]
[05:55:31] Project: 4755 (Run 2, Clone 392, Gen 6)
[05:55:31]
[05:55:31] Assembly optimizations on if available.
[05:55:31] Entering M.D.
[05:55:37] Tpr hash work/wudata_02.tpr:  2004068929 4036596044 1689636728 118541000 83787084
[05:55:38] Working on 1254 p4755_lam5w_300K_g91
[05:55:39] Client config found, loading data.
[05:55:39] Starting GUI Server
[06:00:01] Completed 1%
[06:04:46] Completed 2%
[06:09:53] Completed 3%
[06:16:37] Completed 4%
[06:19:30] mdrun_gpu returned
[06:19:30] NANs detected on GPU
[06:19:30]
[06:19:30] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:19:35] CoreStatus = 7A (122)
[06:19:35] Sending work to server
[06:19:35] Project: 4755 (Run 2, Clone 392, Gen 6)
[06:19:35] - Read packet limit of 540015616... Set to 524286976.
[06:19:35] - Error: Could not get length of results file work/wuresults_02.dat
[06:19:35] - Error: Could not read unit 02 file. Removing from queue.
[06:19:35] Trying to send all finished work units
[06:19:35] + No unsent completed units remaining.
[06:19:35] - Preparing to get new work unit...
[06:19:35] + Attempting to get work packet
[06:19:35] - Will indicate memory of 510 MB
[06:19:35] - Connecting to assignment server
[06:19:35] Connecting to http://assign-GPU.stanford.edu:8080/
[06:19:49] Posted data.
[06:19:49] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[06:19:49] + News From Folding@Home: GPU folding beta
[06:19:49] Loaded queue successfully.
[06:19:49] Connecting to http://171.64.65.103:8080/
[06:19:53] Posted data.
[06:19:53] Initial: 0000; - Receiving payload (expected size: 86206)
[06:19:58] - Downloaded at ~16 kB/s
[06:19:58] - Averaged speed for that direction ~12 kB/s
[06:19:58] + Received work.
[06:19:58] Trying to send all finished work units
[06:19:58] + No unsent completed units remaining.
[06:19:58] + Closed connections
[06:20:03]
Folding@Home user since Feb 2009
Re: Project: 4755 (Run 2, Clone 392, Gen 6)
There's no data for this WU in the DB yet ...
