Project: 5764 (Run 12, Clone 438, Gen 9)
Kibbo
Hardware configuration: Intel Core i7 920 @ 3.8GHz | 2x MSI 560 Ti FROZR II OC | OCZ Platinum XTC DDR3 PC12800 12GB 7-7-7-24 | DFI LanParty UT X58-T3eH8 | Seasonic M12D 850W | Windows 7 Ultimate 64-bit
Post by Kibbo »
If I understand this correctly my 8800GT immediately fails on this WU without completing a single step. This system (listed as system 2 under my profile) isn't overclocked in any way and temps are good.
[19:06:52] - Connecting to assignment server
[19:06:53] - Successful: assigned to (171.64.65.106).
[19:06:53] + News From Folding@Home: GPU folding beta
[19:06:53] Loaded queue successfully.
[19:06:55] + Closed connections
[19:06:55]
[19:06:55] + Processing work unit
[19:06:55] Core required: FahCore_11.exe
[19:06:55] Core found.
[19:06:55] Working on queue slot 02 [April 22 19:06:55 UTC]
[19:06:55] + Working ...
[19:06:55]
[19:06:55] *------------------------------*
[19:06:55] Folding@Home GPU Core - Beta
[19:06:55] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[19:06:55]
[19:06:55] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:06:55] Build host: amoeba
[19:06:55] Board Type: Nvidia
[19:06:55] Core      :
[19:06:55] Preparing to commence simulation
[19:06:55] - Looking at optimizations...
[19:06:55] - Created dyn
[19:06:55] - Files status OK
[19:06:55] - Expanded 70234 -> 360060 (decompressed 512.6 percent)
[19:06:55] Called DecompressByteArray: compressed_data_size=70234 data_size=360060, decompressed_data_size=360060 diff=0
[19:06:55] - Digital signature verified
[19:06:55]
[19:06:55] Project: 5764 (Run 12, Clone 438, Gen 9)
[19:06:55]
[19:06:55] Assembly optimizations on if available.
[19:06:55] Entering M.D.
[19:07:02] mdrun_gpu returned
[19:07:02] Going to send back what have done -- stepsTotalG=0
[19:07:02] Work fraction=0.0000 steps=0.
[19:07:06] logfile size=4996 infoLength=4996 edr=0 trr=25
[19:07:06] - Writing 5534 bytes of core data to disk...
[19:07:06] Done: 5022 -> 1890 (compressed to 37.6 percent)
[19:07:06]   ... Done.
[19:07:06]
[19:07:06] Folding@home Core Shutdown: UNSTABLE_MACHINE
[19:07:09] CoreStatus = 7A (122)
[19:07:09] Sending work to server
[19:07:09] Project: 5764 (Run 12, Clone 438, Gen 9)
[19:07:09] - Read packet limit of 540015616... Set to 524286976.
[19:07:09] + Attempting to send results [April 22 19:07:09 UTC]
[19:07:10] + Results successfully sent
[19:07:10] Thank you for your contribution to Folding@Home.
Re: Project: 5764 (Run 12, Clone 438, Gen 9)
Another donor was able to complete this WU without issue.
