Project: 5900 (Run 3, Clone 104, Gen 43)
Oldhat
Post by Oldhat »
Just having a spot of bother with this work unit. As always this could be a machine error or possibly a faulty WU.
NAN errors on start up.
Stock Windows Vista 32, nVidia 181.2, e8200, 2048Mb RAM, 2 x 8800GT
 Opening Log file [April 15 20:50:02 UTC]
                       Folding@Home Client Version 6.20r1
                          http://folding.stanford.edu
[15:36:27] + Attempting to send results [April 21 15:36:27 UTC]
[15:36:31] + Results successfully sent
[15:36:31] Thank you for your contribution to Folding@Home.
[15:36:31] + Number of Units Completed: 269
[15:36:35] - Preparing to get new work unit...
[15:36:35] + Attempting to get work packet
[15:36:35] - Connecting to assignment server
[15:36:35] - Successful: assigned to (171.64.122.70).
[15:36:35] + News From Folding@Home: GPU folding beta
[15:36:36] Loaded queue successfully.
[15:36:40] + Closed connections
[15:36:40]
[15:36:40] + Processing work unit
[15:36:40] Core required: FahCore_14.exe
[15:36:40] Core found.
[15:36:40] Working on queue slot 04 [April 21 15:36:40 UTC]
[15:36:40] + Working ...
[15:36:40]
[15:36:40] *------------------------------*
[15:36:40] Folding@Home GPU Core - Beta
[15:36:40] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[15:36:40]
[15:36:40] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:36:40] Build host: vspm46
[15:36:40] Board Type: Nvidia
[15:36:40] Core      :
[15:36:40] Preparing to commence simulation
[15:36:40] - Looking at optimizations...
[15:36:40] - Created dyn
[15:36:40] - Files status OK
[15:36:40] - Expanded 70292 -> 360060 (decompressed 512.2 percent)
[15:36:40] Called DecompressByteArray: compressed_data_size=70292 data_size=360060, decompressed_data_size=360060 diff=0
[15:36:40] - Digital signature verified
[15:36:40]
[15:36:40] Project: 5900 (Run 3, Clone 104, Gen 43)
[15:36:40]
[15:36:40] Assembly optimizations on if available.
[15:36:40] Entering M.D.
[15:36:46] Tpr hash work/wudata_04.tpr:  2514729580 971524117 705246607 986845543 4100804939
[15:36:47] Working on Protein
[15:36:47] Client config found, loading data.
[15:36:47] Starting GUI Server
[15:36:47] mdrun_gpu returned
[15:36:47] NANs detected on GPU
[15:36:47]
[15:36:47] Folding@home Core Shutdown: UNSTABLE_MACHINE
[15:36:51] CoreStatus = 7A (122)
[15:36:51] Sending work to server
[15:36:51] Project: 5900 (Run 3, Clone 104, Gen 43)
[15:36:51] - Read packet limit of 540015616... Set to 524286976.
[15:36:51] - Error: Could not get length of results file work/wuresults_04.dat
[15:36:51] - Error: Could not read unit 04 file. Removing from queue.
[15:36:51] - Preparing to get new work unit...
[15:36:51] + Attempting to get work packet
[15:36:51] - Connecting to assignment server
[15:36:51] - Successful: assigned to (171.64.122.70).
[15:36:51] + News From Folding@Home: GPU folding beta
[15:36:51] Loaded queue successfully.
[15:36:53] + Closed connections
[15:36:58]
[15:36:58] + Processing work unit
[15:36:58] Core required: FahCore_14.exe
[15:36:58] Core found.
[15:36:58] Working on queue slot 05 [April 21 15:36:58 UTC]
[15:36:58] + Working ...
[15:36:58]
[15:36:58] *------------------------------*
[15:36:58] Folding@Home GPU Core - Beta
[15:36:58] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[15:36:58]
[15:36:58] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:36:58] Build host: vspm46
[15:36:58] Board Type: Nvidia
[15:36:58] Core      :
[15:36:58] Preparing to commence simulation
[15:36:58] - Looking at optimizations...
[15:36:58] - Created dyn
[15:36:58] - Files status OK
[15:36:58] - Expanded 70292 -> 360060 (decompressed 512.2 percent)
[15:36:58] Called DecompressByteArray: compressed_data_size=70292 data_size=360060, decompressed_data_size=360060 diff=0
[15:36:58] - Digital signature verified
[15:36:58]
[15:36:58] Project: 5900 (Run 3, Clone 104, Gen 43)
[15:36:58]
[15:36:58] Assembly optimizations on if available.
[15:36:58] Entering M.D.
[15:37:04] Tpr hash work/wudata_05.tpr:  2514729580 971524117 705246607 986845543 4100804939
[15:37:04] Working on Protein
[15:37:05] Client config found, loading data.
[15:37:05] Starting GUI Server
[15:37:05] mdrun_gpu returned
[15:37:05] NANs detected on GPU
[15:37:05]
[15:37:05] Folding@home Core Shutdown: UNSTABLE_MACHINE
[15:37:08] CoreStatus = 7A (122)
[15:37:08] Sending work to server
[15:37:08] Project: 5900 (Run 3, Clone 104, Gen 43)
[15:37:08] - Read packet limit of 540015616... Set to 524286976.
[15:37:08] - Error: Could not get length of results file work/wuresults_05.dat
[15:37:08] - Error: Could not read unit 05 file. Removing from queue.
[15:37:08] - Preparing to get new work unit...
[15:37:08] + Attempting to get work packet
[15:37:08] - Connecting to assignment server
[15:37:09] - Successful: assigned to (171.64.122.70).
[15:37:09] + News From Folding@Home: GPU folding beta
[15:37:09] Loaded queue successfully.
[15:37:10] + Closed connections
[15:37:15]
[15:37:15] + Processing work unit
[15:37:15] Core required: FahCore_14.exe
[15:37:15] Core found.
[15:37:15] Working on queue slot 06 [April 21 15:37:15 UTC]
[15:37:15] + Working ...
[15:37:15]
[15:37:15] *------------------------------*
[15:37:15] Folding@Home GPU Core - Beta
[15:37:15] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[15:37:15]
[15:37:15] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:37:15] Build host: vspm46
[15:37:15] Board Type: Nvidia
[15:37:15] Core      :
[15:37:15] Preparing to commence simulation
[15:37:15] - Looking at optimizations...
[15:37:15] - Created dyn
[15:37:15] - Files status OK
[15:37:15] - Expanded 70292 -> 360060 (decompressed 512.2 percent)
[15:37:15] Called DecompressByteArray: compressed_data_size=70292 data_size=360060, decompressed_data_size=360060 diff=0
[15:37:15] - Digital signature verified
[15:37:15]
[15:37:15] Project: 5900 (Run 3, Clone 104, Gen 43)
[15:37:15]
[15:37:15] Assembly optimizations on if available.
[15:37:15] Entering M.D.
[15:37:22] Tpr hash work/wudata_06.tpr:  2514729580 971524117 705246607 986845543 4100804939
[15:37:22] Working on Protein
[15:37:23] Client config found, loading data.
[15:37:23] mdrun_gpu returned
[15:37:23] NANs detected on GPU
[15:37:23]
[15:37:23] Folding@home Core Shutdown: UNSTABLE_MACHINE
[15:37:26] CoreStatus = 7A (122)
[15:37:26] Sending work to server
[15:37:26] Project: 5900 (Run 3, Clone 104, Gen 43)
[15:37:26] - Read packet limit of 540015616... Set to 524286976.
[15:37:26] - Error: Could not get length of results file work/wuresults_06.dat
[15:37:26] - Error: Could not read unit 06 file. Removing from queue.
[15:37:26] - Preparing to get new work unit...
[15:37:26] + Attempting to get work packet
[15:37:26] - Connecting to assignment server
[15:37:27] - Successful: assigned to (171.64.122.70).
[15:37:27] + News From Folding@Home: GPU folding beta
[15:37:27] Loaded queue successfully.
[15:37:28] + Closed connections
[15:37:33]
[15:37:33] + Processing work unit
[15:37:33] Core required: FahCore_14.exe
[15:37:33] Core found.
[15:37:33] Working on queue slot 07 [April 21 15:37:33 UTC]
[15:37:33] + Working ...
[15:37:33]
[15:37:33] *------------------------------*
[15:37:33] Folding@Home GPU Core - Beta
[15:37:33] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[15:37:33]
[15:37:33] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:37:33] Build host: vspm46
[15:37:33] Board Type: Nvidia
[15:37:33] Core      :
[15:37:33] Preparing to commence simulation
[15:37:33] - Looking at optimizations...
[15:37:33] - Created dyn
[15:37:33] - Files status OK
[15:37:33] - Expanded 70292 -> 360060 (decompressed 512.2 percent)
[15:37:33] Called DecompressByteArray: compressed_data_size=70292 data_size=360060, decompressed_data_size=360060 diff=0
[15:37:33] - Digital signature verified
[15:37:33]
[15:37:33] Project: 5900 (Run 3, Clone 104, Gen 43)
[15:37:33]
[15:37:33] Assembly optimizations on if available.
[15:37:33] Entering M.D.
[15:37:39] Tpr hash work/wudata_07.tpr:  2514729580 971524117 705246607 986845543 4100804939
[15:37:40] Working on Protein
[15:37:40] Client config found, loading data.
[15:37:40] mdrun_gpu returned
[15:37:40] NANs detected on GPU
[15:37:40]
[15:37:40] Folding@home Core Shutdown: UNSTABLE_MACHINE
[15:37:44] CoreStatus = 7A (122)
[15:37:44] Sending work to server
[15:37:44] Project: 5900 (Run 3, Clone 104, Gen 43)
[15:37:44] - Read packet limit of 540015616... Set to 524286976.
[15:37:44] - Error: Could not get length of results file work/wuresults_07.dat
[15:37:44] - Error: Could not read unit 07 file. Removing from queue.
[15:37:44] - Preparing to get new work unit...
[15:37:44] + Attempting to get work packet
[15:37:44] - Connecting to assignment server
[15:37:44] - Successful: assigned to (171.64.122.70).
[15:37:44] + News From Folding@Home: GPU folding beta
[15:37:44] Loaded queue successfully.
[15:37:46] + Closed connections
[15:37:51]
[15:37:51] + Processing work unit
[15:37:51] Core required: FahCore_14.exe
[15:37:51] Core found.
[15:37:51] Working on queue slot 08 [April 21 15:37:51 UTC]
[15:37:51] + Working ...
[15:37:51]
[15:37:51] *------------------------------*
[15:37:51] Folding@Home GPU Core - Beta
[15:37:51] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[15:37:51]
[15:37:51] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:37:51] Build host: vspm46
[15:37:51] Board Type: Nvidia
[15:37:51] Core      :
[15:37:51] Preparing to commence simulation
[15:37:51] - Looking at optimizations...
[15:37:51] - Created dyn
[15:37:51] - Files status OK
[15:37:51] - Expanded 70292 -> 360060 (decompressed 512.2 percent)
[15:37:51] Called DecompressByteArray: compressed_data_size=70292 data_size=360060, decompressed_data_size=360060 diff=0
[15:37:51] - Digital signature verified
[15:37:51]
[15:37:51] Project: 5900 (Run 3, Clone 104, Gen 43)
[15:37:51]
[15:37:51] Assembly optimizations on if available.
[15:37:51] Entering M.D.
[15:37:57] Tpr hash work/wudata_08.tpr:  2514729580 971524117 705246607 986845543 4100804939
[15:37:58] Working on Protein
[15:37:58] Client config found, loading data.
[15:37:58] Starting GUI Server
[15:37:58] mdrun_gpu returned
[15:37:58] NANs detected on GPU
[15:37:58]
[15:37:58] Folding@home Core Shutdown: UNSTABLE_MACHINE
[15:38:01] CoreStatus = 7A (122)
[15:38:01] Sending work to server
[15:38:01] Project: 5900 (Run 3, Clone 104, Gen 43)
[15:38:01] - Read packet limit of 540015616... Set to 524286976.
[15:38:01] - Error: Could not get length of results file work/wuresults_08.dat
[15:38:01] - Error: Could not read unit 08 file. Removing from queue.
[15:38:01] EUE limit exceeded. Pausing 24 hours.
[20:21:49] + Working...
Cheers.
Re: Project: 5900 (Run 3, Clone 104, Gen 43)
Several other people have reported and immediate EUE so I've reported this as a bad WU.
