Project: 2484 (Run 29, Clone 34, Gen 17)
Hardware configuration: Mac Pro 2.8 quad 12 GB smp4
MacBook Pro 2.9 i7 8 GB smp2
This unit was completed by one of my machines Saturday and turned in. But no credit has shown up so far. Could someone check its status?
[05:07:31] - Connecting to assignment server
[05:07:32] - Successful: assigned to (171.65.103.162).
[05:07:32] + News From Folding@Home: Welcome to Folding@Home
[05:07:32] Loaded queue successfully.
[05:07:47] + Closed connections
[05:07:47]
[05:07:47] + Processing work unit
[05:07:47] Core required: FahCore_78.exe
[05:07:47] Core found.
[05:07:47] Working on Unit 04 [April 13 05:07:47]
[05:07:47] + Working ...
[05:07:47]
[05:07:47] *------------------------------*
[05:07:47] Folding@Home Gromacs Core
[05:07:47] Version 1.90 (March 8, 2006)
[05:07:47]
[05:07:47] Preparing to commence simulation
[05:07:47] - Looking at optimizations...
[05:07:47] - Created dyn
[05:07:47] - Files status OK
[05:07:48] - Expanded 2949919 -> 15104357 (decompressed 512.0 percent)
[05:07:49] - Starting from initial work packet
[05:07:49]
[05:07:49] Project: 2484 (Run 29, Clone 34, Gen 17)
[05:07:49]
[05:07:49] Assembly optimizations on if available.
[05:07:49] Entering M.D.
[05:07:57] Protein: system
[05:07:57]
[05:07:57] Writing local files
[05:07:59] Testing CPU type...
[05:07:59] Done testing.
[05:07:59] Extra AltiVec boost OK.
[05:08:01] Writing local files
[05:08:02] Completed 0 out of 250000 steps  (0)
[06:29:28] Writing local files
[06:29:29] Completed 2500 out of 250000 steps  (1)
[07:50:51] Writing local files
[07:50:51] Completed 5000 out of 250000 steps  (2)
[19:13:08] Writing local files
[19:13:08] Completed 247500 out of 250000 steps  (99)
[20:33:44] Writing local files
[20:33:45] Completed 250000 out of 250000 steps  (100)
[20:33:45] Writing final coordinates.
[20:33:46] Past main M.D. loop
[20:34:46]
[20:34:46] Finished Work Unit:
[20:34:46] - Reading up to 2297112 from "work/wudata_04.arc": Read 2297112
[20:34:46] - Reading up to 396752 from "work/wudata_04.xtc": Read 396752
[20:34:46] goefile size: 0
[20:34:46] logfile size: 32721
[20:34:46] Leaving Run
[20:34:46] - Writing 2744761 bytes of core data to disk...
[20:34:46]   ... Done.
[20:34:47] - Shutting down core
[20:34:47]
[20:34:47] Folding@home Core Shutdown: FINISHED_UNIT
[20:34:48] CoreStatus = 64 (100)
[20:34:48] Sending work to server
[20:34:48] + Attempting to send results
[20:35:20] + Results successfully sent
[20:35:20] Thank you for your contribution to Folding@Home.
[20:35:20] + Number of Units Completed: 468
Just wondering if I will eventually see the 900 points show up.
Thanks,
Team: 38910
iMac 2.8 i7 12 GB smp8, Mac Pro 2.8 quad 12 GB smp6
MacBook Pro 2.9 i7 8 GB smp3
Re: Project: 2484 (Run 29, Clone 34, Gen 17)
I've reported this issue to the appropriate members of the Pande Group. You're not the only person reporting this problem.
In the past, when there was a stats reporting problem, the correction of the problem went in two stages. First the problem on a server was identified and newly assigned WUs started getting credit. Then the records for the missing credits were gathered (a manual process that must be carefully checked, so it will take some time) and the missing credits were added manually.
Welcome to the foldingforum, Joe_H
ppetrone
Pande Group Member
Post by ppetrone »
Thanks for the report. I am looking at it now.
Paula
ppetrone
Pande Group Member
Post by ppetrone »
Hi,
The server was down during the weekend, and I am afraid the WU was taken by the collection server. Please, give it a couple days and let me know.
Thanks.
Paula
Credit for this unit still has not shown up. Hopefully it eventually shows up in one of the re-credit runs. Oh well, tomorrow's project is to pull the logs from a different machine that has had a few EUE's on it running the 6.24 client and apparently has sent them in, but no credit.
frank239
Post by frank239 »
nice work .............hopping for good ..............time...
ppetrone
Pande Group Member
Post by ppetrone »
Thanks.
The server was busy, probably overloaded with connections. I have restarted it so it should be uploading now. Let me know if they went through.
Cheers!
paula
ppetrone
Pande Group Member
Post by ppetrone »
Regarding the missing credits for PROJ2484 and PROJ2483, please take a look at my post in:
viewtopic.php?f=19&t=9759. Thank you once again for the reports here and your contribution to the project.
Paula
I saw that post last night, good luck with fixing up the problem. Still no sign of credit, I will just wait and see if it eventually shows.
