Project: 5768 (various)
Escher
Post by Escher »
[02:46:58]
[02:46:58] *------------------------------*
[02:46:58] Folding@Home GPU Core - Beta
[02:46:58] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[02:46:58]
[02:46:58] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[02:46:58] Build host: amoeba
[02:46:58] Board Type: Nvidia
[02:46:58] Core      :
[02:46:58] Preparing to commence simulation
[02:46:58] - Looking at optimizations...
[02:46:58] - Created dyn
[02:46:58] - Files status OK
[02:46:58] - Expanded 46645 -> 252912 (decompressed 542.2 percent)
[02:46:58] Called DecompressByteArray: compressed_data_size=46645 data_size=252912, decompressed_data_size=252912 diff=0
[02:46:58] - Digital signature verified
[02:46:58]
[02:46:58] Project: 5768 (Run 7, Clone 56, Gen 548)
[02:46:58]
[02:46:59] Assembly optimizations on if available.
[02:46:59] Entering M.D.
[02:47:05] Working on Protein
[02:47:06] Client config found, loading data.
[02:47:06] Starting GUI Server
[02:47:06] mdrun_gpu returned
[02:47:06] NANs detected on GPU
[02:47:06]
[02:47:06] Folding@home Core Shutdown: UNSTABLE_MACHINE
[02:47:11] CoreStatus = 7A (122)
Escher
Project: 5768 (Run 2, Clone 161, Gen 286)
Post by Escher »
I really hate these 5768 projects.
[02:47:52]
[02:47:52] *------------------------------*
[02:47:52] Folding@Home GPU Core - Beta
[02:47:52] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[02:47:52]
[02:47:52] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[02:47:52] Build host: amoeba
[02:47:52] Board Type: Nvidia
[02:47:52] Core      :
[02:47:52] Preparing to commence simulation
[02:47:52] - Looking at optimizations...
[02:47:52] - Created dyn
[02:47:52] - Files status OK
[02:47:52] - Expanded 46710 -> 252912 (decompressed 541.4 percent)
[02:47:52] Called DecompressByteArray: compressed_data_size=46710 data_size=252912, decompressed_data_size=252912 diff=0
[02:47:52] - Digital signature verified
[02:47:52]
[02:47:52] Project: 5768 (Run 2, Clone 161, Gen 286)
[02:47:52]
[02:47:52] Assembly optimizations on if available.
[02:47:52] Entering M.D.
[02:47:59] Working on Protein
[02:48:00] Client config found, loading data.
[02:48:00] Starting GUI Server
[02:48:00] mdrun_gpu returned
[02:48:00] NANs detected on GPU
[02:48:00]
[02:48:00] Folding@home Core Shutdown: UNSTABLE_MACHINE
[02:48:04] CoreStatus = 7A (122)
Escher
Project: 5766 (Run 4, Clone 333, Gen 346)
Post by Escher »
[02:51:52]
[02:51:52] *------------------------------*
[02:51:52] Folding@Home GPU Core - Beta
[02:51:52] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[02:51:52]
[02:51:52] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[02:51:52] Build host: amoeba
[02:51:52] Board Type: Nvidia
[02:51:52] Core      :
[02:51:52] Preparing to commence simulation
[02:51:52] - Looking at optimizations...
[02:51:52] - Created dyn
[02:51:52] - Files status OK
[02:51:52] - Expanded 46698 -> 252912 (decompressed 541.5 percent)
[02:51:52] Called DecompressByteArray: compressed_data_size=46698 data_size=252912, decompressed_data_size=252912 diff=0
[02:51:52] - Digital signature verified
[02:51:52]
[02:51:52] Project: 5766 (Run 4, Clone 333, Gen 346)
[02:51:52]
[02:51:52] Assembly optimizations on if available.
[02:51:52] Entering M.D.
[02:51:59] Working on Protein
[02:52:00] Client config found, loading data.
[02:52:00] Starting GUI Server
[02:52:00] mdrun_gpu returned
[02:52:00] NANs detected on GPU
[02:52:00]
[02:52:00] Folding@home Core Shutdown: UNSTABLE_MACHINE
[02:52:04] CoreStatus = 7A (122)
Escher
Project: 5766 (Run 11, Clone 190, Gen 285)
Post by Escher »
[02:54:10]
[02:54:10] *------------------------------*
[02:54:10] Folding@Home GPU Core - Beta
[02:54:10] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[02:54:10]
[02:54:10] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[02:54:10] Build host: amoeba
[02:54:10] Board Type: Nvidia
[02:54:10] Core      :
[02:54:10] Preparing to commence simulation
[02:54:10] - Looking at optimizations...
[02:54:10] - Created dyn
[02:54:10] - Files status OK
[02:54:10] - Expanded 46703 -> 252912 (decompressed 541.5 percent)
[02:54:10] Called DecompressByteArray: compressed_data_size=46703 data_size=252912, decompressed_data_size=252912 diff=0
[02:54:10] - Digital signature verified
[02:54:10]
[02:54:10] Project: 5766 (Run 11, Clone 190, Gen 285)
[02:54:10]
[02:54:10] Assembly optimizations on if available.
[02:54:10] Entering M.D.
[02:54:17] Working on Protein
[02:54:18] Client config found, loading data.
[02:54:18] mdrun_gpu returned
[02:54:18] NANs detected on GPU
[02:54:18]
[02:54:18] Folding@home Core Shutdown: UNSTABLE_MACHINE
[02:54:22] CoreStatus = 7A (122)
Re: Project: 5766 (Run 4, Clone 333, Gen 346)
Hi Eugene (team 39160),
Your WU (P5766 R4 C333 G346) was added to the stats database on 2009-04-19 20:19:30 for 0 points of credit.
No one else has uploaded this result yet.
Re: Project: 5766 (Run 11, Clone 190, Gen 285)
Project: 5766 (Run 11, Clone 190, Gen 285) was successfully completed by someone else.
Conclusion: You do have an unstable machine.
Overclocked?
Insufficient 12v power?
Overheating?
Bad drivers?
Defective GPU?
Please fix your installation rather than continuing to fold with defective hardware.
Re: Project: 5768 (various)
That might be good to clean up the work folder too ... if there are some remaining checkpoint file, they might corrupt next WUs using that queue slot.
Escher
Post by Escher »
Wow, I don't think I've ever run into a jerk like you Bruce. I'll have you know that I've been folding without any problem for a year or more now, with the exception of these projects. And it's not just me that has these issues with these projects, so back off bud. There is an issue with the projects and certain hardware configurations, and perhaps you guys could take the data faithfully submitted to you by volunteers such as me and figure out the true issue.
Congratulations, you seriously make me want to stop contributing. toTOW on the other hand has always been very helpful, and I thank him for that. He's probably the only reason I keep posting my findings here.
Escher
Post by Escher »
Oh, and to answer your questions:
Overclocked? No
Insufficient 12v power? No
Overheating? No
Bad drivers? No, I've tried multiple drivers to fix the problem and they all give back the same error.
Defective GPU? No, I've tried multiple replacement cards (always the same make/model) to fix the problem.
You didn't specify what version of Windows you're running. This MIGHT be a driver issue. WinXP uses different drivers than Vista/7 and those who are running on XP seem to be having a lot better luck with these projects than those who are on 7/Vista.
Escher
Post by Escher »
I am in fact running Windows Vista Ultimate 64-bit Edition. Running the 182.08 drivers. I tried many previous to that and still had the same issues. I see the 182.50 drivers out as of 4/2, so I'll put those on and report any issues I have with them. Hopefully, you won't hear from me again on these projects. At least that's what I hope.
