why still using tinker core
shiryunaga
Hardware configuration: Intel Core i3 2100 3092.91 MHz (99.77 x 31.0)
Post by shiryunaga »
tinker core have 400 frame (i see from benchmark Fahmon) that make the PPD drop,
that coz error at Fahmon too, complete 4% but @ panel say 1%,
coz that different frame (400), why still using that core :shock:,
Folding@Home user since Feb 2009
Re: why still using tinker core
They are not still using Tinker core. Tinker is the default name when adding new work to the Project Summary page. When the page is finished updating, the name changes. Tinker is also the default name when they are testing new types of fahcores that are not yet named, or named but not yet announced.
shiryunaga
ok i understand about 'tinker' name, but why that core have different frame(400), that make progress 4x longer
Generally, frames equate to how many steps in takes to reach 100% completion. It varies from one work unit to the next. Some take 100 steps, some take 100,000 steps. It only realates to how big a time frame is being processed, not the size or speed of the work unit.
shiryunaga
 Project : 5744
 Core    : Tinker
 Frames  : 400
 Credit  : 384
 -- GPU --
 Min. Time / Frame : 2mn 20s  - 592.46 ppd
 Avg. Time / Frame : 2mn 20s  - 592.46 ppd
 No Cur. Time / Frame
 No R3F. Time / Frame
 No Eff. Time / Frame
 Project : 5746
 Core    : Tinker
 Frames  : 100
 Credit  : 384
 -- GPU --
 Min. Time / Frame : 2mn 21s  - 2353.02 ppd
 Avg. Time / Frame : 2mn 21s  - 2353.02 ppd
that frame make count of PPD drop,
i still don't understand that both WU has same credit(384) but why they have different frame
or maybe that just bug from Fahmon, i confuse :roll:
That's a fahmon bug ... it probably had trouble parsing the psummary.
Try to update your data.
shiryunaga
how to update my data :roll:
Tools > Download new projects.
shiryunaga
i use Tools > Download new projects but still that frame not change
first i still don't know how much that 'tinker' core frame, coz from http://fah-web.stanford.edu/psummary.html that core don't have detail
IMO that core make error Fahmon, say that have 400(maybe that the real frame for that core), the panel from Fahmon not display the true progress (say 1% but the true is 4%) :(
bapriebe
Hardware configuration: HP xw4600 workstation (4GB)+Q9650+Sapphire Vapor-X HD4890,
HP Z600 workstation (4GB)+2xXEON E5540+Sapphire HD5770,
HP ML350 server (4GB)+2xXEON E5520+Diamond HD3850
Post by bapriebe »
shiryunaga wrote:
 Project : 5744
 Core    : Tinker
 Frames  : 400
 Credit  : 384
Sounds like your FAHMON is the one that is confused. Here's a benchmark from my FAHMON 2.3.2b:
 Project : 5744
 Core    : GPUv2 Gromacs
 Frames  : 100
 Credit  : 384
 -- ADMIN2: GPU2 --
 Min. Time / Frame : 2mn 40s  - 2073.60 ppd
 Avg. Time / Frame : 2mn 47s  - 1986.68 ppd
FahMon is confused, but that's because the data on the Project Summary page is confused. You'll notice that there is a column called "Frames" for each project. In fact, for project 5744. There are two entries and in one case, that column is currently blank, which is clearly wrong.
If the project is actually reporting 400 frames, then four frames must be completed to complete 1% of the WU. That used to be true for some projects for the original Tinker core. It might also be true for whatever core is actually be used by that project. (If 100 GROGPU2 is correct, it will be fixed when the extra data no longer appears in psummary.html.
In any case, FahMon knows how to deal with various numbers of Frames, . . . provided that the correct data is reported in psummary.html. I'll be sure that vvoelz is notified of the problem.
shiryunaga
so the problem from Project Summary page ( i assume that Fahmon get error coz the ambiguous data from that page), can anyone from Pande Group give clarification about this issue, i just want to know that is really tinker core still use for this project or not, or just mistake list, Fahmon give me data Tinker and GPUv2 by turns from project that have the tinker core, make confuse everyone
I told you Tinker is no longer in use, it's a default name on PSummary when the correct data is not available.
toTOW is a forum Moderator, and said the same thing, and added that the problem was Fahmon reading outdated info on PSummary, which backs up my answer.
Bruce is a Forum Administrator, and explained this again in detail, confirming both toTOW and my statements.
There is NO need for Pande Group to repeat this same answer again for a 4th time.
As a 5th confirmation, please read the Fahmon thread in the 3rd Party Tools section. This question has been asked before, and answered by the Fahmon developer, Uncle Fungus. BTW, Uncle Fungus is also a Pande Group member.
Yes, it can be confusing, but now that you know, it isn't so confusing. Pande Group is aware if this issue, and tries to minimize its affect, but it will never be perfect. I think that about covers it. ;)
shiryunaga
thx 7im for your answer, sorry if i make noob question :oops:, so there are 1 core (GPUv2) for project 5744, the different name coz the ambiguous data from Project Summary page :lol:, 400 frame maybe coz Fahmon count from frame old tinker core, so last question for this thread, why that Project Summary page not update, so everyone like me not confuse again :mrgreen:
The Psummary page is dynamically updated from the data on the work servers. If there is confusing data on Psummary, it is because there is conflicting data on the work servers.
Pande Group is working on 100s of projects, and they occasionally forget to update the list, or overlook the double entry made during a test, or are just too busy looking for cures to all these diseases and didn't have time to fix the problem. This is not the first time it has happened, and it won't be the last time either. Again, thank you for pointing out the problem, but it may or may not be fixed any time soon. Pande Group has a limited staff, and this is rather low on the priority list to fix. Sorry.
