Project: 2665 (Run 0, Clone 93, Gen 100)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
EUE. This is interesting since I believe that Project: 2665 (Run 0, Clone 93, Gen 95) was marked bad:
http://foldingforum.org/viewtopic.php?f=19&t=8723
[09:11:32] + Closed connections
[09:11:32]
[09:11:32] + Processing work unit
[09:11:32] Work type a1 not eligible for variable processors
[09:11:32] Core required: FahCore_a1.exe
[09:11:32] Core found.
[09:11:32] Using generic mpiexec calls
[09:11:32] Working on queue slot 06 [April 6 09:11:32 UTC]
[09:11:32] + Working ...
[09:11:32] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 06 -checkpoint 15 -verbose -lifeline 3804 -version 623'
[09:11:32]
[09:11:32] *------------------------------*
[09:11:32] Folding@Home Gromacs SMP Core
[09:11:32] Version 1.74 (March 10, 2007)
[09:11:32]
[09:11:32] Preparing to commence simulation
[09:11:32] - Ensuring status. Please wait.
[09:11:37] - Starting from initial work packet
[09:11:37]
[09:11:37] Project: 2665 (Run 0, Clone 93, Gen 100)
[09:11:37]
[09:11:37] Assembly optimizations on if available.
[09:11:37] Entering M.D.
[09:11:56]  percent)
[09:11:56] - Starting from initial work packet
[09:11:56]
[09:11:56] Project: 2665 (Run 0, Clone 93, Gen 100)
[09:11:56]
[09:12:01] Entering M.D.
[09:12:07] Rejecting checkpoint
[09:12:08] Protein: HGG in water
[09:12:09] Writing local files
[09:12:15] Extra SSE boost OK.
[09:12:16] Writing local files
[09:12:16] Completed 0 out of 250000 steps  (0 percent)
[09:27:15] Timered checkpoint triggered.
[09:29:47] Writing local files
[09:29:47] Completed 2500 out of 250000 steps  (1 percent)
                        {snip}
[09:43:34] Timered checkpoint triggered.
[09:46:17] Writing local files
[09:46:17] Completed 207500 out of 250000 steps  (83 percent)
[09:53:54] Warning:  long 1-4 interactions
[09:53:54] Gromacs cannot continue further.
[09:53:54] Going to send back what have done.
[09:53:54] logfile size: 164404
[09:53:54] - Writing 164940 bytes of core data to disk...
[09:53:54]   ... Done.
[09:53:55] - Failed to delete work/wudata_06.sas
[09:53:55] - Failed to delete work/wudata_06.goe
[09:53:55] Warning:  check for stray files
[09:55:55]
[09:55:55] Folding@home Core Shutdown: EARLY_UNIT_END
[09:55:55]
[09:55:58] CoreStatus = 7B (123)
[09:55:58] Sending work to server
[09:55:58] Project: 2665 (Run 0, Clone 93, Gen 100)
[09:55:58] + Attempting to send results [April 7 09:55:58 UTC]
[09:55:58] - Reading file work/wuresults_06.dat from core
[09:55:58]   (Read 164940 bytes from disk)
[09:55:58] Connecting to http://171.64.65.64:8080/
[09:55:59] Posted data.
[09:55:59] Initial: 0000; - Uploaded at ~162 kB/s
[09:55:59] - Averaged speed for that direction ~433 kB/s
[09:55:59] + Results successfully sent
[09:55:59] Thank you for your contribution to Folding@Home.
Re: Project: 2665 (Run 0, Clone 93, Gen 100)
Strange indeed ... Project: 2665 (Run 0, Clone 93, Gen 95) has been completed successfully on 2009-03-08 12:41:23 ...
There are 6 reports for partial credit for Project: 2665 (Run 0, Clone 93, Gen 100) ... it looks like this trajectory is becoming highly unstable :(
anko1
Post by anko1 »
Thanks for checking , toTOW.
