![Confused :?](./images/smilies/icon_confused.gif)
New to F@H, have a question
i'm new to F@H and I accidentally turned off my computer. when i turned it back on my F@H wasn't in the taskbar so i turned it back on. when i did it it showed i have 20/1500
. Before i turned off my computer i had 585/1500. Does this mean i have lost all of my folding??
Re: New to F@H, have a question
Post the fahlog.txt file in [code][/code] tags it will show what happend. But, the systray at startup sometimes didn't show the correct progress so you might be fine. And you shouldn't loose that much, it makes a backup of progress at each percentage completed, but you might have corrupted the data which caused the client to start from scratch again.
--- Opening Log file [April 6 22:02:48 UTC]
# Windows CPU Systray Edition #################################################
http://folding.stanford.edu
Launch directory: C:\Users\Patrick\AppData\Roaming\Folding@home-x86
[22:04:14] - Ask before connecting: No
[22:04:14] - User name: Meerkat_96 (Team 143016)
[22:04:14] - User ID not found locally
[22:04:14] + Requesting User ID from server
[22:04:18] - Machine ID: 1
[22:04:18]
[22:04:18] Work directory not found. Creating...
[22:04:18] Could not open work queue, generating new queue...
[22:04:18] Initialization complete
[22:04:18] - Preparing to get new work unit...
[22:04:18] + Attempting to get work packet
[22:04:18] - Connecting to assignment server
[22:04:24] - Successful: assigned to (171.67.108.13).
[22:04:24] + News From Folding@Home: Welcome to Folding@Home
[22:04:24] Loaded queue successfully.
[22:04:49] + Closed connections
[22:04:49]
[22:04:49] + Processing work unit
[22:04:49] Core required: FahCore_78.exe
[22:04:49] Core not found.
[22:04:49] - Core is not present or corrupted.
[22:04:49] - Attempting to download new core...
[22:04:49] + Downloading new core: FahCore_78.exe
[22:04:54] + 10240 bytes downloaded
[22:04:55] + 20480 bytes downloaded
[22:04:57] + 30720 bytes downloaded
[22:04:59] + 40960 bytes downloaded
[22:05:00] + 51200 bytes downloaded
[22:05:01] + 61440 bytes downloaded
[22:05:02] + 71680 bytes downloaded
[22:05:03] + 81920 bytes downloaded
[22:05:04] + 92160 bytes downloaded
[22:05:05] + 102400 bytes downloaded
[22:05:05] + 112640 bytes downloaded
[22:05:07] + 122880 bytes downloaded
[22:05:08] + 133120 bytes downloaded
[22:05:08] + 143360 bytes downloaded
[22:05:09] + 153600 bytes downloaded
[22:05:10] + 163840 bytes downloaded
[22:05:11] + 174080 bytes downloaded
[22:05:11] + 184320 bytes downloaded
[22:05:12] + 194560 bytes downloaded
[22:05:13] + 204800 bytes downloaded
[22:05:13] + 215040 bytes downloaded
[22:05:14] + 225280 bytes downloaded
[22:05:15] + 235520 bytes downloaded
[22:05:15] + 245760 bytes downloaded
[22:05:16] + 256000 bytes downloaded
[22:05:16] + 266240 bytes downloaded
[22:05:17] + 276480 bytes downloaded
[22:05:18] + 286720 bytes downloaded
[22:05:18] + 296960 bytes downloaded
[22:05:19] + 307200 bytes downloaded
[22:05:20] + 317440 bytes downloaded
[22:05:20] + 327680 bytes downloaded
[22:05:21] + 337920 bytes downloaded
[22:05:21] + 348160 bytes downloaded
[22:05:24] + 358400 bytes downloaded
[22:05:25] + 368640 bytes downloaded
[22:05:26] + 378880 bytes downloaded
[22:05:27] + 389120 bytes downloaded
[22:05:28] + 399360 bytes downloaded
[22:05:29] + 409600 bytes downloaded
[22:05:29] + 419840 bytes downloaded
[22:05:30] + 430080 bytes downloaded
[22:05:31] + 440320 bytes downloaded
[22:05:31] + 450560 bytes downloaded
[22:05:32] + 460800 bytes downloaded
[22:05:32] + 471040 bytes downloaded
[22:05:33] + 481280 bytes downloaded
[22:05:33] + 491520 bytes downloaded
[22:05:33] + 501760 bytes downloaded
[22:05:33] + 512000 bytes downloaded
[22:05:34] + 522240 bytes downloaded
[22:05:34] + 532480 bytes downloaded
[22:05:34] + 542720 bytes downloaded
[22:05:34] + 552960 bytes downloaded
[22:05:35] + 563200 bytes downloaded
[22:05:35] + 573440 bytes downloaded
[22:05:35] + 583680 bytes downloaded
[22:05:35] + 593920 bytes downloaded
[22:05:36] + 604160 bytes downloaded
[22:05:36] + 614400 bytes downloaded
[22:05:36] + 624640 bytes downloaded
[22:05:37] + 634880 bytes downloaded
[22:05:37] + 645120 bytes downloaded
[22:05:37] + 655360 bytes downloaded
[22:05:37] + 665600 bytes downloaded
[22:05:38] + 675840 bytes downloaded
[22:05:38] + 686080 bytes downloaded
[22:05:38] + 696320 bytes downloaded
[22:05:38] + 706560 bytes downloaded
[22:05:39] + 716800 bytes downloaded
[22:05:39] + 727040 bytes downloaded
[22:05:39] + 737280 bytes downloaded
[22:05:40] + 747520 bytes downloaded
[22:05:40] + 757760 bytes downloaded
[22:05:40] + 768000 bytes downloaded
[22:05:40] + 778240 bytes downloaded
[22:05:41] + 788480 bytes downloaded
[22:05:41] + 798720 bytes downloaded
[22:05:42] + 808960 bytes downloaded
[22:05:42] + 819200 bytes downloaded
[22:05:42] + 825633 bytes downloaded
[22:05:42] Verifying core Core_78.fah...
[22:05:42] Signature is VALID
[22:05:42]
[22:05:42] Trying to unzip core FahCore_78.exe
[22:05:43] Decompressed FahCore_78.exe (2338816 bytes) successfully
[22:05:48] + Core successfully engaged
[22:05:53]
[22:05:53] + Processing work unit
[22:05:53] Core required: FahCore_78.exe
[22:05:53] Core found.
[22:05:53] Working on queue slot 01 [April 6 22:05:53 UTC]
[22:05:53] + Working ...
[22:05:54]
[22:05:54] *------------------------------*
[22:05:54] Folding@Home Gromacs Core
[22:05:54] Version 1.90 (March 8, 2006)
[22:05:54]
[22:05:54] Preparing to commence simulation
[22:05:54] - Looking at optimizations...
[22:05:54] - Created dyn
[22:05:54] - Files status OK
[22:05:54] - Expanded 238189 -> 1164961 (decompressed 489.0 percent)
[22:05:54] - Starting from initial work packet
[22:05:54]
[22:05:54] Project: 4460 (Run 448, Clone 3, Gen 12)
[22:05:54]
[22:05:54] Assembly optimizations on if available.
[22:05:54] Entering M.D.
[22:06:01] Protein: p4460_Seq52_Amber03
[22:06:01]
[22:06:01] Writing local files
[22:07:12] Opening C:\Users\Patrick\AppData\Roaming\Folding@home-x86\MyFolding.html...
[22:08:00] Extra SSE boost OK.
[22:08:01] Writing local files
[22:08:01] Completed 0 out of 1500000 steps (0%)
[05:58:38] + Working...
[06:40:38] Writing local files
[06:40:38] Completed 15000 out of 1500000 steps (1%)
[07:26:53] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Meerkat_96...
Folding@Home Client Shutdown.
--- Opening Log file [April 14 07:30:44 UTC]
[07:30:44] - Ask before connecting: No
[07:30:44] - User name: Meerkat_96 (Team 143016)
[07:30:44] - User ID: 5043919154D3B410
[07:30:44] - Machine ID: 1
[07:30:44]
[07:30:45] Loaded queue successfully.
[07:30:45] Initialization complete
[07:30:47]
[07:30:47] + Processing work unit
[07:30:47] Core required: FahCore_78.exe
[07:30:47] Core found.
[07:30:49] Working on queue slot 01 [April 14 07:30:49 UTC]
[07:30:49] + Working ...
[07:30:52]
[07:30:52] *------------------------------*
[07:30:52] Folding@Home Gromacs Core
[07:30:52] Version 1.90 (March 8, 2006)
[07:30:52]
[07:30:52] Preparing to commence simulation
[07:30:52] - Looking at optimizations...
[07:30:52] - Files status OK
[07:30:52] - Expanded 238189 -> 1164961 (decompressed 489.0 percent)
[07:30:57]
[07:30:57] Project: 4460 (Run 448, Clone 3, Gen 12)
[07:30:57]
[07:30:58] Assembly optimizations on if available.
[07:30:58] Entering M.D.
[07:31:19] (Starting from checkpoint)
[07:31:19] Protein: p4460_Seq52_Amber03
[07:31:19]
[07:31:20] Writing local files
[07:32:29] Opening C:\Users\Patrick\AppData\Roaming\Folding@home-x86\MyFolding.html...
[07:33:19] Completed 20088 out of 1500000 steps (1%)
[07:33:19] Extra SSE boost OK.
[07:52:20] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Meerkat_96...
[08:07:40] Opening C:\Users\Patrick\AppData\Roaming\Folding@home-x86\MyFolding.html...
[08:09:11] Writing local files
[08:09:11] Completed 30000 out of 1500000 steps (2%)
[08:09:29] Opening http://foldingforum.org/...
thats my log file up to date, it show 30/1500 now. thanks for the help so far
You didn't loose that much work, a few frames between 1% and the next checkpoint.
Deadline is 43 days, you got 10 days spare.
Edit:
It should have written checkpoints between those two frames, adding -verbosity 9 the the additional parameters will make the log show more information.
And you need to fully complete the work unit before any points will be awarded ( see you opend the stats and forums after the first checkpoint so just thought I'd mention it as well ).
Edit:
thanks, i just wondered why it was displaying like that.
