not getting accurate ppd
damian
Post by damian »
I have a GTX 260 (core 216) and a Core I7 920. FaHmon reports ppd count of 6900~7500ppd (average 7100). But my EOC stats has never seen anything higher than 3100ppd. I'v been folding for days yet EOC still reports 3100ppd and kakao stats with 4k ppd.
Any ideas as to what need to be done?
DanGe
Hardware configuration: 2018 Mac Mini / MacOS Catalina
3.2 GHz 6-Core Intel Core i7
Re: not getting accurate ppd
Post by DanGe »
FahMon reports your theoretical PPD assuming that your computer is on 24/7 working on the same WU over and over again. The 3rd party stats report your real PPD based on what you turned in from the last 24 days or the entire week.
jaak ennuste
Hardware configuration: 3 x Nvidia Geforce GTX 295 cards (total 6 GPU's)
AMD Phenom x4 2600MHz Black Edition
MSI 790FX K9A2 Platinum system board, 4GB RAM
ATX case, 1000 W Chieftec PS
Windows XP 64-bit
More: http://estoniadonates.wordpress.com/
Post by jaak ennuste »
Check Your user and team numbers. I had once wrong team number caused by typo and points went to other team....
Jaak
building 32 GPU folding rig: 16 x NVIDIA GeForce GTX 295 cards; dual PSU solution; 4 nodes.
Website: Estonia Donates, ambitious 400 PPD supercomputer project
Sponsored by AdlerFlow ceramic coated Porsche exhausts
shdbcamping
Hardware configuration: XPS 720 Q6600 9800GX2 3gig RAM
750W primary PSU 650W Aux VGA PSU
Post by shdbcamping »
Also check that your name is exact in each client config. you may see 2 you's (slightly different) on your team as well.
MtM
Hardware configuration: Q6600 - 8gb - p5q deluxe - gtx275 - hd4350 ( not folding ) win7 x64 - smp:4 - gpu slot
T5450 - 4gb - ?? - 8600M GT 512 ( DDR2 ) - win7 x64 - smp:2 - gpu slot
Post by MtM »
And check your logs for EUE's, as the reported ppd is theoretical and based on you actually completing the work unit fully :)
Steeve
Post by Steeve »
shdbcamping wrote:Also check that your name is exact in each client config. you may see 2 you's (slightly different) on your team as well.
Agree, I made the same mistake once. It's very hard to find, but be patient.
ChelseaOilman
Post by ChelseaOilman »
The last WU turned in by your PS3:
Hi Damian (team 0),
Your WU (P3460 R10 C11 G309) was added to the stats database on 2011-04-03 15:03:07 for 251 points of credit.
Probably should go into your PS3 settings and change the team number if your in fact folding on a PS3. That could be someone else since you didn't mention it.
I only see one client running on your computer:
Hi DAMIAN (team 149125),
Your WU (P6883 R213 C13 G26) was added to the stats database on 2011-04-02 21:06:45 for 69 points of credit.
Looks like a classic WU. You should use the -smp flag on that client.
No sign of any GPU WUs. Check name/team # on that client and for EUEs as MtM mentioned.
Also, you need to successfully turn in 10 SMP WUs before you get bonus points. FahMon doesn't know if your bonus points eligible so will show you getting bonus points even though your probably not.
patonb
Post by patonb »
Woew Chelsea... the initial post is yrs ago..... need to check the yr... even though the dates are close.
ChelseaOilman
LOL, that's funny! Wonder how Steeve dragged up this thread.
patonb
Post by patonb »
Atleast you found an active client still running.
Its the internet.... people find very odd stuff on hee. ;)
Steeve
Post by Steeve »
I was lookin' through the threads and I got interested in the topic. After posting the reply I noticed the date :)
