please help i am using cpu client but i want the gpu client
how do i change it do i have to delete it and reinstall?
Vista 64 Q6600 2.4 o/c 3.0
gtx 285 sli 2-way
500 gig 7200 rpm drive X 2 Raid 0
1000 watt psu
8 gig ddr2@800
gtx 285 sli 2-way
1000 watt psu
8 gig ddr2@800
- Hardware configuration: 2018 Mac Mini / MacOS Catalina
3.2 GHz 6-Core Intel Core i7 - Location: California, United States
Re: please help i am using cpu client but i want the gpu client
You don't have to uninstall the CPU client. You can run the CPU and the GPU clients side-by-side because the GPU client does not use much CPU.
It depends; If you're running ATi it will use more CPU than Nvidia. If you have single core, I would just run the GPU client.DanGe wrote:You don't have to uninstall the CPU client. You can run the CPU and the GPU clients side-by-side because the GPU client does not use much CPU.
Not so with the latest ATI core (1.24) and drivers (Catalyst 9.2 and newer). It now uses less than 2% of a core, though you may need to set some Environment Variables to get it working right on your machine (viewtopic.php?f=51&t=9162&start=180).
Wow, seems as though the ati team have really made progress, thanks for the infojrweiss wrote:Not so with the latest ATI core (1.24) and drivers (Catalyst 9.2 and newer). It now uses less than 2% of a core, though you may need to set some Environment Variables to get it working right on your machine (viewtopic.php?f=51&t=9162&start=180).
