In the log there is a statement about updating preformance, does it literally mean that the GPU client has a throttel on it and the preformance on the next WU will be increased.
[17:10:53] Unit 4 finished with 94 percent of time to deadline remaining.
[17:10:53] Updated performance fraction: 0.934357
Just Curious
- Hardware configuration: 3 - Supermicro H8QGi-F AMD MC 6174=144 cores 2.5Ghz, 96GB G.Skill DDR3 1333Mhz Ubuntu 10.10
Just Curious
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
Re: Just Curious
The performance fraction is the average amount of time remaining to the deadline that the last four units have completed with. So for instance if you finished the last four units using only 5% of the time to the deadline your PF would be 0.950000, and if you took 90% of the time to the deadline your PF would be 0.100000. The higher the PF the better
Folding whatever I'm sent since March 2006 Beta testing since October 2006. www.FAH-Addict.net Administrator since August 2009.
Re: Just Curious
Thanks for explaining
Re: Just Curious
Re: Just Curious
This is true.
But I will say that John's explination is allot simpler than wiki. May-be it should be added
Edit by Mod: Done.
-b
