p5777 (2, 213, 13)
P5-133XL
Machine #2:
Machine 3:
p5777 (2, 213, 13)
Post by P5-133XL »
I have no idea why. Observation: FAHCore_11 was running at a full 25% (a full core). I shut down and restarted the client and It restarted at 2%. Everything appears to be running normally again.
Q9550@Stock; Asus 9600 GSO (512)@Stock; 4GB RAM
WS2008 Server (sp1). Nvidia 85.20 drivers
[14:53:53] CoreStatus = 64 (100)
[14:53:53] Sending work to server
[14:53:53] Project: 5775 (Run 0, Clone 278, Gen 9)
[14:53:53] - Read packet limit of 540015616... Set to 524286976.
[14:53:53] + Attempting to send results [April 10 14:53:53 UTC]
[14:53:56] + Results successfully sent
[14:53:56] Thank you for your contribution to Folding@Home.
[14:53:56] + Number of Units Completed: 58
[14:54:01] - Preparing to get new work unit...
[14:54:01] + Attempting to get work packet
[14:54:01] - Connecting to assignment server
[14:54:02] - Successful: assigned to (171.64.65.106).
[14:54:02] + News From Folding@Home: GPU folding beta
[14:54:02] Loaded queue successfully.
[14:54:02] + Closed connections
[14:54:02]
[14:54:02] + Processing work unit
[14:54:02] Core required: FahCore_11.exe
[14:54:02] Core found.
[14:54:02] Working on queue slot 03 [April 10 14:54:02 UTC]
[14:54:02] + Working ...
[14:54:02]
[14:54:02] *------------------------------*
[14:54:02] Folding@Home GPU Core - Beta
[14:54:02] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[14:54:02]
[14:54:02] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:54:02] Build host: amoeba
[14:54:02] Board Type: Nvidia
[14:54:02] Core      :
[14:54:02] Preparing to commence simulation
[14:54:02] - Looking at optimizations...
[14:54:02] - Created dyn
[14:54:02] - Files status OK
[14:54:02] - Expanded 66295 -> 348500 (decompressed 525.6 percent)
[14:54:02] Called DecompressByteArray: compressed_data_size=66295 data_size=348500, decompressed_data_size=348500 diff=0
[14:54:03] - Digital signature verified
[14:54:03]
[14:54:03] Project: 5777 (Run 2, Clone 213, Gen 13)
[14:54:03]
[14:54:03] Assembly optimizations on if available.
[14:54:03] Entering M.D.
[14:54:16] Working on Protein
[14:54:18] Client config found, loading data.
[14:54:18] Starting GUI Server
[14:58:02] Completed 1%
[15:01:45] Completed 2%
[15:06:37] + Working...
[21:06:36] + Working...
[03:06:35] + Working...
Re: p5777 (2, 213, 13)
It looks like the GPU crashed (that should be a VPU Recover on ATI, and a driver reset on NV) ... when this occurs, the Fahcore process starts to use a whole core without making any progress unless you retart the client.
