I can't seem to upload to this server. It appears to have started sometime yesterday evening. This is happening on all 4 cores of a FreeBSD workstation.
--- Opening Log file [April 10 15:21:21]
# Linux Console Edition #######################################################
Folding@Home Client Version 6.02
http://folding.stanford.edu
Launch directory: /usr/home/davidc/folding/fah1
Executable: ./fah6
Arguments: -send all -verbosity 9
[15:21:21] - Ask before connecting: No
[15:21:21] - Machine ID: 1
[15:21:21]
[15:21:21] Loaded queue successfully.
[15:21:21] Attempting to return result(s) to server...
[15:21:21] Trying to send all finished work units
[15:21:21] - Read packet limit of 540015616... Set to 524286976.
[15:21:21] + Attempting to send results
[15:21:21] - Reading file work/wuresults_04.dat from core
[15:21:21] (Read 2811951 bytes from disk)
[15:21:21] Connecting to http://171.65.103.162:8080/
[15:21:22] - Couldn't send HTTP request to server
[15:21:22] + Could not connect to Work Server (results)
[15:21:22] (171.65.103.162:8080)
[15:21:22] - Error: Could not transmit unit 04 (completed April 10) to work server.
[15:21:22] - 9 failed uploads of this unit.
[15:21:22] - Read packet limit of 540015616... Set to 524286976.
[15:21:22] + Attempting to send results
[15:21:22] - Reading file work/wuresults_04.dat from core
[15:21:22] (Read 2811951 bytes from disk)
[15:21:22] Connecting to http://171.65.103.100:8080/
[15:22:49] Posted data.
[15:22:49] Initial: 0000; - Uploaded at ~31 kB/s
[15:22:49] - Averaged speed for that direction ~30 kB/s
[15:22:49] - Server does not have record of this unit. Will try again later.
[15:22:49] Could not transmit unit 04 to Collection server; keeping in queue.
[15:22:49] + Sent 0 of 1 completed units to the server
[15:22:49] - Failed to send all units to server
[15:22:49] ***** Got a SIGTERM signal (15)
[15:22:49] Killing all core threads
Folding@Home Client Shutdown.
I am having a similar issue with several boxes running Windoze. Yesterday they started not connecting and reporting that the server had no record of this unit. Any help would be appreciated.
All the PCs are trying to "talk" to the same server, and one PC is running 2 "local" instances of Fah.
Launch directory: C:\Folding 1
Executable: fah623
Arguments: -local
[16:59:28] - Ask before connecting: No
[16:59:28] - User name: Douglas (Team 77397)
[16:59:28] - User ID: 5DD4DA5967C0D57D
[16:59:28] - Machine ID: 4
[16:59:28]
[16:59:28] Loaded queue successfully.
[16:59:28]
[16:59:28] Project: 2484 (Run 189, Clone 32, Gen 9)
[16:59:28] + Processing work unit
[16:59:28] - Read packet limit of 540015616... [16:59:28] Core required: FahCore_78.exe
Set to 524286976.
[16:59:28] Core found.
[16:59:28] + Attempting to send results [April 10 16:59:28 UTC]
[16:59:28] Working on queue slot 09 [April 10 16:59:28 UTC]
[16:59:28] + Working ...
[16:59:28]
[16:59:28] *------------------------------*
[16:59:28] Folding@Home Gromacs Core
[16:59:28] Version 1.90 (March 8, 2006)
[16:59:28]
[16:59:28] Preparing to commence simulation
[16:59:28] - Looking at optimizations...
[16:59:28] - Files status OK
[16:59:31] - Expanded 2946983 -> 15071865 (decompressed 511.4 percent)
[16:59:31]
[16:59:31] Project: 2484 (Run 187, Clone 2, Gen 5)
[16:59:31]
[16:59:31] Assembly optimizations on if available.
[16:59:31] Entering M.D.
[16:59:52] (Starting from checkpoint)
[16:59:52] Protein: system
[16:59:52]
[16:59:52] Writing local files
[16:59:52] Completed 105000 out of 250000 steps (42%)
[16:59:54] Extra SSE boost OK.
[17:00:08] - Couldn't send HTTP request to server
[17:00:08] + Could not connect to Work Server (results)
[17:00:08] (171.65.103.162:8080)
[17:00:08] + Retrying using alternative port
[17:00:13] - Couldn't send HTTP request to server
[17:00:13] (Got status 504)
[17:00:13] + Could not connect to Work Server (results)
[17:00:13] (171.65.103.162:80)
[17:00:13] - Error: Could not transmit unit 08 (completed April 9) to work server.
[17:00:13] - Read packet limit of 540015616... Set to 524286976.
[17:00:13] + Attempting to send results [April 10 17:00:13 UTC]
[17:01:18] - Server does not have record of this unit. Will try again later.
[17:01:18] Could not transmit unit 08 to Collection server; keeping in queue.
It appears that the problem uploading to the server has rectified itself for me. Last night by 11PM the results started going through, by this morning all the held results had been sent.
