Project: 2497 (Run 4, Clone 15, Gen 0)- EUE@59%
anandhanju
Post by anandhanju »
Project: 2497 (Run 4, Clone 15, Gen 0)- EUE@59% [LINCS WARNING Step 150089]
[21:55:11] Folding@Home Gromacs Core
[21:55:11] Version 1.90 (March 8, 2006)
[21:55:11]
[21:55:11] Preparing to commence simulation
[21:55:11] - Assembly optimizations manually forced on.
[21:55:11] - Not checking prior termination.
[21:55:16] - Expanded 2215206 -> 15100993 (decompressed 681.6 percent)
[21:55:17]
[21:55:17] Project: 2497 (Run 4, Clone 15, Gen 0)
[21:55:17]
[21:55:17] Assembly optimizations on if available.
[21:55:17] Entering M.D.
[21:55:40] (Starting from checkpoint)
[21:55:40] Protein: system
[21:55:40]
[21:55:40] Writing local files
[21:55:40] Completed 130000 out of 250000 steps  (52%)
[21:55:43] Extra SSE boost OK.
[03:48:24] Completed 147500 out of 250000 steps  (59%)
[03:55:11] - Autosending finished units... [April 10 03:55:11 UTC]
[03:55:11] Trying to send all finished work units
[03:55:11] + No unsent completed units remaining.
[03:55:11] - Autosend completed
[04:18:24] Timered checkpoint triggered.
[04:39:00] Writing local files
[04:39:01] Completed 150000 out of 250000 steps  (60%)
[04:40:44] Quit 101 - Fatal error:
[04:40:44] Step 150089, time 300.178 (ps)  LINCS WARNING
[04:40:44] relative constraint deviation after LINCS:
[04:40:44] max 11712414273150498000000000.000000 (between atoms 18595 and 18596) rms 157776587329506630000000.000000
[04:40:44]
[04:40:44] Simulation instability has been encountered. The run has entered a
[04:40:44]   state from which no further progress can be made.
[04:40:44] This may be the correct result of the simulation, however if you
[04:40:44]   often see other project units terminating early like this
[04:40:44]   too, you may wish to check the stability of your computer (issues
[04:40:44]   such as high temperature, overclocking, etc.).
[04:40:44] Going to send back what have done.
[04:40:44] logfile size: 67780
[04:40:44] - Writing 68514 bytes of core data to disk...
[04:40:44]   ... Done.
[04:40:44]
[04:40:44] Folding@home Core Shutdown: EARLY_UNIT_END
[04:40:46] CoreStatus = 72 (114)
[04:40:46] Sending work to server
[04:40:46] Project: 2497 (Run 4, Clone 15, Gen 0)
[04:40:46] - Read packet limit of 540015616... Set to 524286976.
[04:40:46] + Attempting to send results [April 10 04:40:46 UTC]
[04:40:46] - Reading file work/wuresults_01.dat from core
[04:40:46]   (Read 68514 bytes from disk)
[04:40:46] Connecting to http://171.65.103.160:8080/
[04:40:48] Posted data.
[04:40:48] Initial: 0000; - Uploaded at ~33 kB/s
[04:40:48] - Averaged speed for that direction ~39 kB/s
[04:40:48] + Results successfully sent
[04:40:48] Thank you for your contribution to Folding@Home.
Partial results returned successfully. Thank you in advance for looking it up/ marking it as bad! :)
ppetrone
Pande Group Member
Re: Project: 2497 (Run 4, Clone 15, Gen 0)- EUE@59%
Post by ppetrone »
Thanks for the report, & marked bad.
Paula
