Project: 5904 (Run 0, Clone 20, Gen 21)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Catching up on Big Red's GPUs now.
[19:25:36] + Closed connections
[19:25:36]
[19:25:36] + Processing work unit
[19:25:36] Core required: FahCore_14.exe
[19:25:36] Core found.
[19:25:36] Working on queue slot 02 [April 1 19:25:36 UTC]
[19:25:36] + Working ...
[19:25:36] - Calling '.\FahCore_14.exe -dir work/ -suffix 02 -priority 96 -checkpoint 15 -verbose -lifeline 3536 -version 620'
[19:25:37]
[19:25:37] *------------------------------*
[19:25:37] Folding@Home GPU Core - Beta
[19:25:37] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[19:25:37]
[19:25:37] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:25:37] Build host: vspm46
[19:25:37] Board Type: Nvidia
[19:25:37] Core      :
[19:25:37] Preparing to commence simulation
[19:25:37] - Looking at optimizations...
[19:25:37] - Created dyn
[19:25:37] - Files status OK
[19:25:37] - Expanded 68521 -> 357580 (decompressed 521.8 percent)
[19:25:37] Called DecompressByteArray: compressed_data_size=68521 data_size=357580, decompressed_data_size=357580 diff=0
[19:25:37] - Digital signature verified
[19:25:37]
[19:25:37] Project: 5904 (Run 0, Clone 20, Gen 21)
[19:25:37]
[19:25:37] Assembly optimizations on if available.
[19:25:37] Entering M.D.
[19:25:43] Tpr hash work/wudata_02.tpr:  3485745680 3975253882 2954718867 1514359188 2740373840
[19:25:43] Working on Protein
[19:25:44] Client config found, loading data.
[19:25:44] Starting GUI Server
[19:31:33] Completed 1%
         {snip}
[05:15:24] Completed 93%
[05:17:40] SEH code: 3221225477
[05:17:40] Run: exception thrown during GuardedRun
[05:17:40] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[05:17:40] Going to send back what have done -- stepsTotalG=8000000
[05:17:40] Work fraction=0.9331 steps=8000000.
[05:17:44] logfile size=288560 infoLength=288560 edr=0 trr=23
[05:17:44] - Writing 289096 bytes of core data to disk...
[05:17:44] Done: 288584 -> 8692 (compressed to 3.0 percent)
[05:17:44]   ... Done.
[05:17:44]
[05:17:44] Folding@home Core Shutdown: UNSTABLE_MACHINE
[05:17:47] CoreStatus = 7A (122)
[05:17:47] Sending work to server
[05:17:47] Project: 5904 (Run 0, Clone 20, Gen 21)
[05:17:47] - Read packet limit of 540015616... Set to 524286976.
[05:17:47] + Attempting to send results [April 2 05:17:47 UTC]
[05:17:47] - Reading file work/wuresults_02.dat from core
[05:17:47]   (Read 9204 bytes from disk)
[05:17:47] Connecting to http://171.64.122.70:8080/
[05:17:47] Posted data.
[05:17:47] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[05:17:47] - Uploaded at ~19 kB/s
[05:17:47] - Averaged speed for that direction ~111 kB/s
[05:17:47] + Results successfully sent
[05:17:47] Thank you for your contribution to Folding@Home.
Well that was the only one. :-)
Re: Project: 5904 (Run 0, Clone 20, Gen 21)
Your WU (P5904 R0 C20 G21) was added to the stats database on 2009-04-01 22:15:35 for 1761.61 points of credit.
There's no other report in the DB yet ...
anko1
Post by anko1 »
Thanks for checking, toTOW.
