Project: 5904 (Run 5, Clone 507, Gen 0)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
OK, it's beginning to look like the Lenovo doesn't like the 59xx's.
[23:40:02] + Closed connections
[23:40:02]
[23:40:02] + Processing work unit
[23:40:02] Core required: FahCore_14.exe
[23:40:02] Core found.
[23:40:02] Working on queue slot 01 [March 27 23:40:02 UTC]
[23:40:02] + Working ...
[23:40:02] - Calling '.\FahCore_14.exe -dir work/ -suffix 01 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 4908 -version 620'
[23:40:02]
[23:40:02] *------------------------------*
[23:40:02] Folding@Home GPU Core - Beta
[23:40:02] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[23:40:02]
[23:40:02] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[23:40:02] Build host: vspm46
[23:40:02] Board Type: Nvidia
[23:40:02] Core      :
[23:40:02] Preparing to commence simulation
[23:40:02] - Looking at optimizations...
[23:40:02] - Created dyn
[23:40:02] - Files status OK
[23:40:02] - Expanded 65872 -> 357580 (decompressed 542.8 percent)
[23:40:02] Called DecompressByteArray: compressed_data_size=65872 data_size=357580, decompressed_data_size=357580 diff=0
[23:40:03] - Digital signature verified
[23:40:03]
[23:40:03] Project: 5904 (Run 5, Clone 507, Gen 0)
[23:40:03]
[23:40:03] Assembly optimizations on if available.
[23:40:03] Entering M.D.
[23:40:09] Tpr hash work/wudata_01.tpr:  3102020891 4262583436 4127850436 1067379282 3197841207
[23:40:09] Working on Protein
[23:40:10] Client config found, loading data.
[23:40:11] Starting GUI Server
[23:49:11] Completed 1%
                      {snip}
[02:26:39] Completed 18%
[02:30:25] SEH code: 3221225477
[02:30:25] Run: exception thrown during GuardedRun
[02:30:25] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[02:30:25] Going to send back what have done -- stepsTotalG=8000000
[02:30:25] Work fraction=0.1838 steps=8000000.
[02:30:29] logfile size=46091 infoLength=46091 edr=0 trr=23
[02:30:29] - Writing 46627 bytes of core data to disk...
[02:30:29] Done: 46115 -> 5208 (compressed to 11.2 percent)
[02:30:29]   ... Done.
[02:30:29]
[02:30:29] Folding@home Core Shutdown: UNSTABLE_MACHINE
[02:30:33] CoreStatus = 7A (122)
[02:30:33] Sending work to server
[02:30:33] Project: 5904 (Run 5, Clone 507, Gen 0)
[02:30:33] - Read packet limit of 540015616... Set to 524286976.
[02:30:33] + Attempting to send results [March 28 02:30:33 UTC]
[02:30:33] - Reading file work/wuresults_01.dat from core
[02:30:33]   (Read 5720 bytes from disk)
[02:30:33] Connecting to http://171.64.122.70:8080/
[02:30:44] Posted data.
[02:30:45] Initial: 0000; - Uploaded at ~0 kB/s
[02:30:45] - Averaged speed for that direction ~62 kB/s
[02:30:45] + Results successfully sent
[02:30:45] Thank you for your contribution to Folding@Home.
Re: Project: 5904 (Run 5, Clone 507, Gen 0)
Your WU (P5904 R5 C507 G0) was added to the stats database on 2009-03-27 20:08:05 for 347.06 points of credit.
There's no other report for this WU in the DB yet ...
