Project: 5739 (Run 2, Clone 43, Gen 92)
frontier204
Post by frontier204 »
This work unit has failed in at 2% five times over, causing my computer to do a 24 hour pause (this was after completing 4 WUs in a row with no problems). Note that I do not have the resources to run the WU on another PC.
My computer's specs:
Vista Business x64
Phenom 9950 OC to 2.97 GHz
4 GB RAM
Asus EAH 4870 DK TOP running at its default 815 / 925
Running a systray client with no compatibility mode flag or admin mode. Work directory is on a USB stick.
FLUSH_INTERVAL 150
Logs:
[09:02:04]
[09:02:04] *------------------------------*
[09:02:04] Folding@Home GPU Core - Beta
[09:02:04] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[09:02:04]
[09:02:04] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:02:04] Build host: amoeba
[09:02:04] Board Type: AMD
[09:02:04] Core      :
[09:02:04] Preparing to commence simulation
[09:02:04] - User disabled assembly optimizations.
[09:02:06] - Created dyn
[09:02:06] - Files status OK
[09:02:06] - Expanded 96618 -> 489152 (decompressed 506.2 percent)
[09:02:06] Called DecompressByteArray: compressed_data_size=96618 data_size=489152, decompressed_data_size=489152 diff=0
[09:02:06] - Digital signature verified
[09:02:07]
[09:02:07] Project: 5739 (Run 2, Clone 43, Gen 92)
[09:02:07]
[09:02:08] Entering M.D.
[09:02:14] Tpr hash work/wudata_03.tpr:  1173464371 4130509737 1340261622 2197566550 394395292
[09:02:15] Working on Protein
[09:02:16] Client config found, loading data.
[09:02:16] Starting GUI Server
[09:05:29] Completed 1%
[09:08:36] Completed 2%
[09:08:39] mdrun_gpu returned
[09:08:39] Nonzero force sum on GPU
[09:08:39]
[09:08:39] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:08:42] CoreStatus = 7A (122)
[09:08:43] Sending work to server
[09:08:43] Project: 5739 (Run 2, Clone 43, Gen 92)
[09:08:43] - Read packet limit of 540015616... Set to 524286976.
[09:08:43] - Error: Could not get length of results file work/wuresults_03.dat
[09:08:43] - Error: Could not read unit 03 file. Removing from queue.
[09:08:44] Trying to send all finished work units
[09:08:44] + No unsent completed units remaining.
[09:08:44] - Preparing to get new work unit...
[09:08:44] + Attempting to get work packet
[09:08:44] - Will indicate memory of 4094 MB
[09:08:44] - Connecting to assignment server
[09:08:44] Connecting to http://assign-GPU.stanford.edu:8080/
[09:08:45] Posted data.
[09:08:45] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[09:08:45] + News From Folding@Home: GPU folding beta
[09:08:45] Loaded queue successfully.
[09:08:45] Connecting to http://171.64.65.102:8080/
[09:08:46] Posted data.
[09:08:46] Initial: 0000; - Receiving payload (expected size: 97130)
[09:08:46] Conversation time very short, giving reduced weight in bandwidth avg
[09:08:46] - Downloaded at ~189 kB/s
[09:08:46] - Averaged speed for that direction ~161 kB/s
[09:08:46] + Received work.
[09:08:48] Trying to send all finished work units
[09:08:48] + No unsent completed units remaining.
[09:08:48] + Closed connections
[09:08:53]
[09:08:53] + Processing work unit
[09:08:53] Core required: FahCore_11.exe
[09:08:53] Core found.
[09:08:53] Working on queue slot 04 [April 5 09:08:53 UTC]
[09:08:53] + Working ...
[09:08:53] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -cpu 90 -noassembly -nocpulock -checkpoint 30 -verbose -lifeline 5460 -version 623'
[09:08:54]
[09:08:54] *------------------------------*
[09:08:54] Folding@Home GPU Core - Beta
[09:08:54] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[09:08:54]
[09:08:54] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:08:54] Build host: amoeba
[09:08:54] Board Type: AMD
[09:08:54] Core      :
[09:08:54] Preparing to commence simulation
[09:08:55] - User disabled assembly optimizations.
[09:08:56] - Created dyn
[09:08:56] - Files status OK
[09:08:56] - Expanded 96618 -> 489152 (decompressed 506.2 percent)
[09:08:56] Called DecompressByteArray: compressed_data_size=96618 data_size=489152, decompressed_data_size=489152 diff=0
[09:08:56] - Digital signature verified
[09:08:57]
[09:08:57] Project: 5739 (Run 2, Clone 43, Gen 92)
[09:08:57]
[09:08:58] Entering M.D.
[09:09:04] Tpr hash work/wudata_04.tpr:  1173464371 4130509737 1340261622 2197566550 394395292
[09:09:05] Working on Protein
[09:09:06] Client config found, loading data.
[09:09:06] Starting GUI Server
[09:12:15] Completed 1%
[09:15:22] Completed 2%
[09:15:24] mdrun_gpu returned
[09:15:24] Nonzero force sum on GPU
[09:15:24]
[09:15:24] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:15:28] CoreStatus = 7A (122)
[09:15:29] Sending work to server
[09:15:29] Project: 5739 (Run 2, Clone 43, Gen 92)
[09:15:29] - Read packet limit of 540015616... Set to 524286976.
[09:15:29] - Error: Could not get length of results file work/wuresults_04.dat
[09:15:29] - Error: Could not read unit 04 file. Removing from queue.
[09:15:32] Trying to send all finished work units
[09:15:32] + No unsent completed units remaining.
[09:15:32] - Preparing to get new work unit...
[09:15:32] + Attempting to get work packet
[09:15:32] - Will indicate memory of 4094 MB
[09:15:32] - Connecting to assignment server
[09:15:32] Connecting to http://assign-GPU.stanford.edu:8080/
[09:15:32] Posted data.
[09:15:32] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[09:15:32] + News From Folding@Home: GPU folding beta
[09:15:33] Loaded queue successfully.
[09:15:33] Connecting to http://171.64.65.102:8080/
[09:15:33] Posted data.
[09:15:33] Initial: 0000; - Receiving payload (expected size: 97130)
[09:15:34] - Downloaded at ~94 kB/s
[09:15:34] - Averaged speed for that direction ~147 kB/s
[09:15:34] + Received work.
[09:15:35] Trying to send all finished work units
[09:15:35] + No unsent completed units remaining.
[09:15:35] + Closed connections
[09:15:40]
[09:15:40] + Processing work unit
[09:15:40] Core required: FahCore_11.exe
[09:15:40] Core found.
[09:15:40] Working on queue slot 05 [April 5 09:15:40 UTC]
[09:15:40] + Working ...
[09:15:40] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -priority 96 -cpu 90 -noassembly -nocpulock -checkpoint 30 -verbose -lifeline 5460 -version 623'
[09:15:42]
[09:15:42] *------------------------------*
[09:15:42] Folding@Home GPU Core - Beta
[09:15:42] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[09:15:42]
[09:15:42] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:15:42] Build host: amoeba
[09:15:42] Board Type: AMD
[09:15:42] Core      :
[09:15:42] Preparing to commence simulation
[09:15:42] - User disabled assembly optimizations.
[09:15:42] - Created dyn
[09:15:42] - Files status OK
[09:15:42] - Expanded 96618 -> 489152 (decompressed 506.2 percent)
[09:15:42] Called DecompressByteArray: compressed_data_size=96618 data_size=489152, decompressed_data_size=489152 diff=0
[09:15:42] - Digital signature verified
[09:15:44]
[09:15:44] Project: 5739 (Run 2, Clone 43, Gen 92)
[09:15:44]
[09:15:46] Entering M.D.
[09:15:53] Tpr hash work/wudata_05.tpr:  1173464371 4130509737 1340261622 2197566550 394395292
[09:15:53] Working on Protein
[09:15:54] Client config found, loading data.
[09:15:54] Starting GUI Server
[09:19:05] Completed 1%
[09:22:11] Completed 2%
[09:22:13] mdrun_gpu returned
[09:22:13] Nonzero force sum on GPU
[09:22:13]
[09:22:13] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:22:19] CoreStatus = 7A (122)
[09:22:21] Sending work to server
[09:22:21] Project: 5739 (Run 2, Clone 43, Gen 92)
[09:22:21] - Read packet limit of 540015616... Set to 524286976.
[09:22:21] - Error: Could not get length of results file work/wuresults_05.dat
[09:22:21] - Error: Could not read unit 05 file. Removing from queue.
[09:22:24] Trying to send all finished work units
[09:22:24] + No unsent completed units remaining.
[09:22:24] - Preparing to get new work unit...
[09:22:24] + Attempting to get work packet
[09:22:24] - Will indicate memory of 4094 MB
[09:22:24] - Connecting to assignment server
[09:22:24] Connecting to http://assign-GPU.stanford.edu:8080/
[09:22:24] Posted data.
[09:22:24] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[09:22:24] + News From Folding@Home: GPU folding beta
[09:22:24] Loaded queue successfully.
[09:22:24] Connecting to http://171.64.65.102:8080/
[09:22:25] Posted data.
[09:22:25] Initial: 0000; - Receiving payload (expected size: 97130)
[09:22:25] Conversation time very short, giving reduced weight in bandwidth avg
[09:22:25] - Downloaded at ~189 kB/s
[09:22:25] - Averaged speed for that direction ~152 kB/s
[09:22:25] + Received work.
[09:22:29] Trying to send all finished work units
[09:22:29] + No unsent completed units remaining.
[09:22:29] + Closed connections
[09:22:34]
[09:22:34] + Processing work unit
[09:22:34] Core required: FahCore_11.exe
[09:22:34] Core found.
[09:22:34] Working on queue slot 06 [April 5 09:22:34 UTC]
[09:22:34] + Working ...
[09:22:34] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -priority 96 -cpu 90 -noassembly -nocpulock -checkpoint 30 -verbose -lifeline 5460 -version 623'
[09:22:35]
[09:22:35] *------------------------------*
[09:22:35] Folding@Home GPU Core - Beta
[09:22:35] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[09:22:36]
[09:22:36] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:22:36] Build host: amoeba
[09:22:36] Board Type: AMD
[09:22:36] Core      :
[09:22:36] Preparing to commence simulation
[09:22:36] - User disabled assembly optimizations.
[09:22:36] - Created dyn
[09:22:36] - Files status OK
[09:22:36] - Expanded 96618 -> 489152 (decompressed 506.2 percent)
[09:22:36] Called DecompressByteArray: compressed_data_size=96618 data_size=489152, decompressed_data_size=489152 diff=0
[09:22:36] - Digital signature verified
[09:22:36]
[09:22:36] Project: 5739 (Run 2, Clone 43, Gen 92)
[09:22:36]
[09:22:37] Entering M.D.
[09:22:43] Tpr hash work/wudata_06.tpr:  1173464371 4130509737 1340261622 2197566550 394395292
[09:22:44] Working on Protein
[09:22:45] Client config found, loading data.
[09:22:45] Starting GUI Server
[09:25:55] Completed 1%
[09:29:00] Completed 2%
[09:29:02] mdrun_gpu returned
[09:29:02] Nonzero force sum on GPU
[09:29:02]
[09:29:02] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:29:07] CoreStatus = 7A (122)
[09:29:08] Sending work to server
[09:29:08] Project: 5739 (Run 2, Clone 43, Gen 92)
[09:29:08] - Read packet limit of 540015616... Set to 524286976.
[09:29:08] - Error: Could not get length of results file work/wuresults_06.dat
[09:29:08] - Error: Could not read unit 06 file. Removing from queue.
[09:29:09] Trying to send all finished work units
[09:29:09] + No unsent completed units remaining.
[09:29:09] - Preparing to get new work unit...
[09:29:09] + Attempting to get work packet
[09:29:09] - Will indicate memory of 4094 MB
[09:29:09] - Connecting to assignment server
[09:29:09] Connecting to http://assign-GPU.stanford.edu:8080/
[09:29:10] Posted data.
[09:29:10] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[09:29:10] + News From Folding@Home: GPU folding beta
[09:29:10] Loaded queue successfully.
[09:29:10] Connecting to http://171.64.65.102:8080/
[09:29:11] Posted data.
[09:29:11] Initial: 0000; - Receiving payload (expected size: 97130)
[09:29:11] Conversation time very short, giving reduced weight in bandwidth avg
[09:29:11] - Downloaded at ~189 kB/s
[09:29:11] - Averaged speed for that direction ~156 kB/s
[09:29:11] + Received work.
[09:29:12] Trying to send all finished work units
[09:29:12] + No unsent completed units remaining.
[09:29:12] + Closed connections
[09:29:17]
[09:29:17] + Processing work unit
[09:29:17] Core required: FahCore_11.exe
[09:29:17] Core found.
[09:29:17] Working on queue slot 07 [April 5 09:29:17 UTC]
[09:29:17] + Working ...
[09:29:17] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -priority 96 -cpu 90 -noassembly -nocpulock -checkpoint 30 -verbose -lifeline 5460 -version 623'
[09:29:18]
[09:29:18] *------------------------------*
[09:29:18] Folding@Home GPU Core - Beta
[09:29:18] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[09:29:18]
[09:29:18] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:29:18] Build host: amoeba
[09:29:18] Board Type: AMD
[09:29:18] Core      :
[09:29:18] Preparing to commence simulation
[09:29:18] - User disabled assembly optimizations.
[09:29:20] - Created dyn
[09:29:20] - Files status OK
[09:29:20] - Expanded 96618 -> 489152 (decompressed 506.2 percent)
[09:29:20] Called DecompressByteArray: compressed_data_size=96618 data_size=489152, decompressed_data_size=489152 diff=0
[09:29:20] - Digital signature verified
[09:29:23]
[09:29:23] Project: 5739 (Run 2, Clone 43, Gen 92)
[09:29:23]
[09:29:24] Entering M.D.
[09:29:30] Tpr hash work/wudata_07.tpr:  1173464371 4130509737 1340261622 2197566550 394395292
[09:29:31] Working on Protein
[09:29:32] Client config found, loading data.
[09:29:32] Starting GUI Server
[09:32:43] Completed 1%
[09:35:51] Completed 2%
[09:35:54] mdrun_gpu returned
[09:35:54] Nonzero force sum on GPU
[09:35:54]
[09:35:54] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:35:58] CoreStatus = 7A (122)
[09:35:59] Sending work to server
[09:35:59] Project: 5739 (Run 2, Clone 43, Gen 92)
[09:35:59] - Read packet limit of 540015616... Set to 524286976.
[09:35:59] - Error: Could not get length of results file work/wuresults_07.dat
[09:35:59] - Error: Could not read unit 07 file. Removing from queue.
[09:36:00] EUE limit exceeded. Pausing 24 hours.
Re: Project: 5739 (Run 2, Clone 43, Gen 92)
There's no data for this WU in the DB yet ...
