Project: 4743 (Run 9, Clone 139, Gen 10) - Instant EUE
SparkyJJO
Post by SparkyJJO »
This one is bad. Was having EUE and UNSTABLE_MACHINE galore today until I got it to get another unit and been fine since. Was fine up until this unit as well.
I'm not the only one who got this WU and had trouble either, Riptide in this thread did as well:
viewtopic.php?f=51&t=9288
Thanks.
====================Folding since 2006====================
Leoslocks
Hardware configuration: Q6600 | P35-DQ6 | Crucial 2 x 1 GB ram | VisionTek 3870
GPU2 Version 6.20| CPU three 6.20 Clients
Re: Project: 4743 (Run 9, Clone 139, Gen 10) - Instant EUE
Post by Leoslocks »
Multiple instant EUE, shut down the client 11 hours before I caught it.
[01:23:24] *------------------------------*
[01:23:24] Folding@Home GPU Core - Beta
[01:23:24] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[01:23:24]
[01:23:24] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:23:24] Build host: amoeba
[01:23:24] Board Type: AMD
[01:23:24] Core      :
[01:23:24] Preparing to commence simulation
[01:23:24] - Looking at optimizations...
[01:23:24] - Created dyn
[01:23:24] - Files status OK
[01:23:24] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[01:23:24] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[01:23:24] - Digital signature verified
[01:23:24]
[01:23:24] Project: 4743 (Run 9, Clone 139, Gen 10)
[01:23:24]
[01:23:24] Assembly optimizations on if available.
[01:23:24] Entering M.D.
[01:23:31] Working on p4743_lam5w_300K
[01:23:31] Client config found, loading data.
[01:23:31] Starting GUI Server
[01:23:34] mdrun_gpu returned
[01:23:34] NANs detected on GPU
[01:23:34]
[01:23:34] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:23:37] CoreStatus = 7A (122)
[01:23:37] Sending work to server
[01:23:37] Project: 4743 (Run 9, Clone 139, Gen 10)
[01:23:37] - Error: Could not get length of results file work/wuresults_05.dat
[01:23:37] - Error: Could not read unit 05 file. Removing from queue.
[01:23:37] - Preparing to get new work unit...
[01:23:37] + Attempting to get work packet
[01:23:37] - Connecting to assignment server
[01:23:37] - Successful: assigned to (171.64.65.103).
[01:23:37] + News From Folding@Home: GPU folding beta
[01:23:37] Loaded queue successfully.
[01:23:38] + Closed connections
[01:23:43]
[01:23:43] + Processing work unit
[01:23:43] Core required: FahCore_11.exe
[01:23:43] Core found.
[01:23:43] Working on queue slot 06 [April 5 01:23:43 UTC]
[01:23:43] + Working ...
[01:23:43]
[01:23:43] *------------------------------*
[01:23:43] Folding@Home GPU Core - Beta
[01:23:43] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[01:23:43]
[01:23:43] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:23:43] Build host: amoeba
[01:23:43] Board Type: AMD
[01:23:43] Core      :
[01:23:43] Preparing to commence simulation
[01:23:43] - Looking at optimizations...
[01:23:43] - Created dyn
[01:23:43] - Files status OK
[01:23:43] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[01:23:43] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[01:23:43] - Digital signature verified
[01:23:43]
[01:23:43] Project: 4743 (Run 9, Clone 139, Gen 10)
[01:23:43]
[01:23:43] Assembly optimizations on if available.
[01:23:43] Entering M.D.
[01:23:50] Working on p4743_lam5w_300K
[01:23:50] Client config found, loading data.
[01:23:50] Starting GUI Server
[01:23:53] mdrun_gpu returned
[01:23:53] NANs detected on GPU
[01:23:53]
[01:23:53] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:23:55] CoreStatus = 7A (122)
[01:23:55] Sending work to server
[01:23:55] Project: 4743 (Run 9, Clone 139, Gen 10)
[01:23:55] - Error: Could not get length of results file work/wuresults_06.dat
[01:23:55] - Error: Could not read unit 06 file. Removing from queue.
[01:23:55] - Preparing to get new work unit...
[01:23:55] + Attempting to get work packet
[01:23:55] - Connecting to assignment server
[01:23:56] - Successful: assigned to (171.64.65.103).
[01:23:56] + News From Folding@Home: GPU folding beta
[01:23:56] Loaded queue successfully.
[01:23:57] + Closed connections
[01:24:02]
[01:24:02] + Processing work unit
[01:24:02] Core required: FahCore_11.exe
[01:24:02] Core found.
[01:24:02] Working on queue slot 07 [April 5 01:24:02 UTC]
[01:24:02] + Working ...
[01:24:02]
[01:24:02] *------------------------------*
[01:24:02] Folding@Home GPU Core - Beta
[01:24:02] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[01:24:02]
[01:24:02] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:24:02] Build host: amoeba
[01:24:02] Board Type: AMD
[01:24:02] Core      :
[01:24:02] Preparing to commence simulation
[01:24:02] - Looking at optimizations...
[01:24:02] - Created dyn
[01:24:02] - Files status OK
[01:24:02] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[01:24:02] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[01:24:02] - Digital signature verified
[01:24:02]
[01:24:02] Project: 4743 (Run 9, Clone 139, Gen 10)
[01:24:02]
[01:24:02] Assembly optimizations on if available.
[01:24:02] Entering M.D.
[01:24:09] Working on p4743_lam5w_300K
[01:24:09] Client config found, loading data.
[01:24:09] Starting GUI Server
[01:24:12] mdrun_gpu returned
[01:24:12] NANs detected on GPU
[01:24:12]
[01:24:12] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:24:14] CoreStatus = 7A (122)
[01:24:14] Sending work to server
[01:24:14] Project: 4743 (Run 9, Clone 139, Gen 10)
[01:24:14] - Error: Could not get length of results file work/wuresults_07.dat
[01:24:14] - Error: Could not read unit 07 file. Removing from queue.
[01:24:14] - Preparing to get new work unit...
[01:24:14] + Attempting to get work packet
[01:24:14] - Connecting to assignment server
[01:24:15] - Successful: assigned to (171.64.65.103).
[01:24:15] + News From Folding@Home: GPU folding beta
[01:24:15] Loaded queue successfully.
[01:24:16] + Closed connections
[01:24:21]
[01:24:21] + Processing work unit
[01:24:21] Core required: FahCore_11.exe
[01:24:21] Core found.
[01:24:21] Working on queue slot 08 [April 5 01:24:21 UTC]
[01:24:21] + Working ...
[01:24:21]
[01:24:21] *------------------------------*
[01:24:21] Folding@Home GPU Core - Beta
[01:24:21] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[01:24:21]
[01:24:21] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:24:21] Build host: amoeba
[01:24:21] Board Type: AMD
[01:24:21] Core      :
[01:24:21] Preparing to commence simulation
[01:24:21] - Looking at optimizations...
[01:24:21] - Created dyn
[01:24:21] - Files status OK
[01:24:21] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[01:24:21] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[01:24:21] - Digital signature verified
[01:24:21]
[01:24:21] Project: 4743 (Run 9, Clone 139, Gen 10)
[01:24:21]
[01:24:21] Assembly optimizations on if available.
[01:24:21] Entering M.D.
[01:24:28] Working on p4743_lam5w_300K
[01:24:28] Client config found, loading data.
[01:24:28] Starting GUI Server
[01:24:31] mdrun_gpu returned
[01:24:31] NANs detected on GPU
[01:24:31]
[01:24:31] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:24:33] CoreStatus = 7A (122)
[01:24:33] Sending work to server
[01:24:33] Project: 4743 (Run 9, Clone 139, Gen 10)
[01:24:33] - Error: Could not get length of results file work/wuresults_08.dat
[01:24:33] - Error: Could not read unit 08 file. Removing from queue.
[01:24:33] - Preparing to get new work unit...
[01:24:33] + Attempting to get work packet
[01:24:33] - Connecting to assignment server
[01:24:34] - Successful: assigned to (171.64.65.103).
[01:24:34] + News From Folding@Home: GPU folding beta
[01:24:34] Loaded queue successfully.
[01:24:35] + Closed connections
[01:24:40]
[01:24:40] + Processing work unit
[01:24:40] Core required: FahCore_11.exe
[01:24:40] Core found.
[01:24:40] Working on queue slot 09 [April 5 01:24:40 UTC]
[01:24:40] + Working ...
[01:24:40]
[01:24:40] *------------------------------*
[01:24:40] Folding@Home GPU Core - Beta
[01:24:40] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[01:24:40]
[01:24:40] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:24:40] Build host: amoeba
[01:24:40] Board Type: AMD
[01:24:40] Core      :
[01:24:40] Preparing to commence simulation
[01:24:40] - Looking at optimizations...
[01:24:40] - Created dyn
[01:24:40] - Files status OK
[01:24:40] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[01:24:40] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[01:24:40] - Digital signature verified
[01:24:40]
[01:24:40] Project: 4743 (Run 9, Clone 139, Gen 10)
[01:24:40]
[01:24:40] Assembly optimizations on if available.
[01:24:40] Entering M.D.
[01:24:47] Working on p4743_lam5w_300K
[01:24:47] Client config found, loading data.
[01:24:47] Starting GUI Server
[01:24:50] mdrun_gpu returned
[01:24:50] NANs detected on GPU
[01:24:50]
[01:24:50] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:24:52] CoreStatus = 7A (122)
[01:24:52] Sending work to server
[01:24:52] Project: 4743 (Run 9, Clone 139, Gen 10)
[01:24:52] - Error: Could not get length of results file work/wuresults_09.dat
[01:24:52] - Error: Could not read unit 09 file. Removing from queue.
[01:24:52] EUE limit exceeded. Pausing 24 hours.
[06:33:38] + Working...
[12:33:37] + Working...
There are many similar reports in the DB for this WU ... I've marked it as bad.
X_ArchAngel
Post by X_ArchAngel »
Tossing in another report of instant EUE's. My GPU client has been operating flawlessly for months until it attempted to digest this exact WU. Repeated attempts to delete my queue always get me reassigned this work unit, too. :(
Leoslocks
Post by Leoslocks »
Finished the new WU and got it again.
[16:10:03] Completed 100%
[16:10:03] Successful run
[16:10:03] DynamicWrapper: Finished Work Unit: sleep=10000
[16:10:13] Reserved 154052 bytes for xtc file; Cosm status=0
[16:10:13] Allocated 154052 bytes for xtc file
[16:10:13] - Reading up to 154052 from "work/wudata_00.xtc": Read 154052
[16:10:13] Read 154052 bytes from xtc file; available packet space=786276412
[16:10:13] xtc file hash check passed.
[16:10:13] Reserved 23472 23472 786276412 bytes for arc file=<work/wudata_00.trr> Cosm status=0
[16:10:13] Allocated 23472 bytes for arc file
[16:10:13] - Reading up to 23472 from "work/wudata_00.trr": Read 23472
[16:10:13] Read 23472 bytes from arc file; available packet space=786252940
[16:10:13] trr file hash check passed.
[16:10:13] Allocated 560 bytes for edr file
[16:10:13] Read bedfile
[16:10:13] edr file hash check passed.
[16:10:13] Allocated 21623 bytes for logfile
[16:10:13] Read logfile
[16:10:13] GuardedRun: success in DynamicWrapper
[16:10:13] GuardedRun: done
[16:10:13] Run: GuardedRun completed.
[16:10:15] - Writing 200219 bytes of core data to disk...
[16:10:15] Done: 199707 -> 185155 (compressed to 92.7 percent)
[16:10:15]   ... Done.
[16:10:16] - Shutting down core
[16:10:16]
[16:10:16] Folding@home Core Shutdown: FINISHED_UNIT
[16:10:18] CoreStatus = 64 (100)
[16:10:18] Sending work to server
[16:10:18] Project: 5745 (Run 2, Clone 18, Gen 186)
[16:10:18] + Attempting to send results [April 5 16:10:18 UTC]
[16:10:20] + Results successfully sent
[16:10:20] Thank you for your contribution to Folding@Home.
[16:10:20] + Number of Units Completed: 411
[16:10:24] - Preparing to get new work unit...
[16:10:24] + Attempting to get work packet
[16:10:24] - Connecting to assignment server
[16:10:25] - Successful: assigned to (171.64.65.103).
[16:10:25] + News From Folding@Home: GPU folding beta
[16:10:25] Loaded queue successfully.
[16:10:25] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[16:10:42] + Attempting to get work packet
[16:10:42] - Connecting to assignment server
[16:10:42] - Successful: assigned to (171.64.65.103).
[16:10:42] + News From Folding@Home: GPU folding beta
[16:10:43] Loaded queue successfully.
[16:10:44] + Closed connections
[16:10:44]
[16:10:44] + Processing work unit
[16:10:44] Core required: FahCore_11.exe
[16:10:44] Core found.
[16:10:44] Working on queue slot 01 [April 5 16:10:44 UTC]
[16:10:44] + Working ...
[16:10:44]
[16:10:44] *------------------------------*
[16:10:44] Folding@Home GPU Core - Beta
[16:10:44] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[16:10:44]
[16:10:44] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:10:44] Build host: amoeba
[16:10:44] Board Type: AMD
[16:10:44] Core      :
[16:10:44] Preparing to commence simulation
[16:10:44] - Looking at optimizations...
[16:10:44] - Created dyn
[16:10:44] - Files status OK
[16:10:44] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[16:10:44] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[16:10:44] - Digital signature verified
[16:10:44]
[16:10:44] Project: 4743 (Run 9, Clone 139, Gen 10)
[16:10:44]
[16:10:44] Assembly optimizations on if available.
[16:10:44] Entering M.D.
[16:10:50] Working on p4743_lam5w_300K
[16:10:51] Client config found, loading data.
[16:10:51] Starting GUI Server
[16:10:53] mdrun_gpu returned
[16:10:53] NANs detected on GPU
[16:10:53]
[16:10:53] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:10:56] CoreStatus = 7A (122)
[16:10:56] Sending work to server
[16:10:56] Project: 4743 (Run 9, Clone 139, Gen 10)
[16:10:56] - Error: Could not get length of results file work/wuresults_01.dat
[16:10:56] - Error: Could not read unit 01 file. Removing from queue.
[16:10:56] - Preparing to get new work unit...
[16:10:56] + Attempting to get work packet
[16:10:56] - Connecting to assignment server
[16:10:56] - Successful: assigned to (171.64.65.103).
[16:10:56] + News From Folding@Home: GPU folding beta
[16:10:57] Loaded queue successfully.
[16:10:57] + Closed connections
[16:11:02]
[16:11:02] + Processing work unit
[16:11:02] Core required: FahCore_11.exe
[16:11:02] Core found.
[16:11:02] Working on queue slot 02 [April 5 16:11:02 UTC]
[16:11:02] + Working ...
[16:11:03]
[16:11:03] *------------------------------*
[16:11:03] Folding@Home GPU Core - Beta
[16:11:03] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[16:11:03]
[16:11:03] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:11:03] Build host: amoeba
[16:11:03] Board Type: AMD
[16:11:03] Core      :
[16:11:03] Preparing to commence simulation
[16:11:03] - Looking at optimizations...
[16:11:03] - Created dyn
[16:11:03] - Files status OK
[16:11:03] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[16:11:03] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[16:11:03] - Digital signature verified
[16:11:03]
[16:11:03] Project: 4743 (Run 9, Clone 139, Gen 10)
[16:11:03]
[16:11:03] Assembly optimizations on if available.
[16:11:03] Entering M.D.
[16:11:09] Working on p4743_lam5w_300K
[16:11:10] Client config found, loading data.
[16:11:10] Starting GUI Server
[16:11:12] mdrun_gpu returned
[16:11:12] NANs detected on GPU
[16:11:12]
[16:11:12] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:11:15] CoreStatus = 7A (122)
[16:11:15] Sending work to server
[16:11:15] Project: 4743 (Run 9, Clone 139, Gen 10)
[16:11:15] - Error: Could not get length of results file work/wuresults_02.dat
[16:11:15] - Error: Could not read unit 02 file. Removing from queue.
[16:11:15] - Preparing to get new work unit...
[16:11:15] + Attempting to get work packet
[16:11:15] - Connecting to assignment server
[16:11:15] - Successful: assigned to (171.64.65.103).
[16:11:15] + News From Folding@Home: GPU folding beta
[16:11:15] Loaded queue successfully.
[16:11:17] + Closed connections
[16:11:22]
[16:11:22] + Processing work unit
[16:11:22] Core required: FahCore_11.exe
[16:11:22] Core found.
[16:11:22] Working on queue slot 03 [April 5 16:11:22 UTC]
[16:11:22] + Working ...
[16:11:22]
[16:11:22] *------------------------------*
[16:11:22] Folding@Home GPU Core - Beta
[16:11:22] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[16:11:22]
[16:11:22] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:11:22] Build host: amoeba
[16:11:22] Board Type: AMD
[16:11:22] Core      :
[16:11:22] Preparing to commence simulation
[16:11:22] - Looking at optimizations...
[16:11:22] - Created dyn
[16:11:22] - Files status OK
[16:11:22] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[16:11:22] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[16:11:22] - Digital signature verified
[16:11:22]
[16:11:22] Project: 4743 (Run 9, Clone 139, Gen 10)
[16:11:22]
[16:11:22] Assembly optimizations on if available.
[16:11:22] Entering M.D.
[16:11:28] Working on p4743_lam5w_300K
[16:11:28] Client config found, loading data.
[16:11:29] Starting GUI Server
[16:11:31] mdrun_gpu returned
[16:11:31] NANs detected on GPU
[16:11:31]
[16:11:31] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:11:34] CoreStatus = 7A (122)
[16:11:34] Sending work to server
[16:11:34] Project: 4743 (Run 9, Clone 139, Gen 10)
[16:11:34] - Error: Could not get length of results file work/wuresults_03.dat
[16:11:34] - Error: Could not read unit 03 file. Removing from queue.
[16:11:34] - Preparing to get new work unit...
[16:11:34] + Attempting to get work packet
[16:11:34] - Connecting to assignment server
[16:11:34] - Successful: assigned to (171.64.65.103).
[16:11:34] + News From Folding@Home: GPU folding beta
[16:11:35] Loaded queue successfully.
[16:11:36] + Closed connections
[16:11:41]
[16:11:41] + Processing work unit
[16:11:41] Core required: FahCore_11.exe
[16:11:41] Core found.
[16:11:41] Working on queue slot 04 [April 5 16:11:41 UTC]
[16:11:41] + Working ...
[16:11:41]
[16:11:41] *------------------------------*
[16:11:41] Folding@Home GPU Core - Beta
[16:11:41] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[16:11:41]
[16:11:41] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:11:41] Build host: amoeba
[16:11:41] Board Type: AMD
[16:11:41] Core      :
[16:11:41] Preparing to commence simulation
[16:11:41] - Looking at optimizations...
[16:11:41] - Created dyn
[16:11:41] - Files status OK
[16:11:41] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[16:11:41] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[16:11:41] - Digital signature verified
[16:11:41]
[16:11:41] Project: 4743 (Run 9, Clone 139, Gen 10)
[16:11:41]
[16:11:41] Assembly optimizations on if available.
[16:11:41] Entering M.D.
[16:11:47] Working on p4743_lam5w_300K
[16:11:47] Client config found, loading data.
[16:11:48] Starting GUI Server
[16:11:50] mdrun_gpu returned
[16:11:50] NANs detected on GPU
[16:11:50]
[16:11:50] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:11:53] CoreStatus = 7A (122)
[16:11:53] Sending work to server
[16:11:53] Project: 4743 (Run 9, Clone 139, Gen 10)
[16:11:53] - Error: Could not get length of results file work/wuresults_04.dat
[16:11:53] - Error: Could not read unit 04 file. Removing from queue.
[16:11:53] - Preparing to get new work unit...
[16:11:53] + Attempting to get work packet
[16:11:53] - Connecting to assignment server
[16:11:53] - Successful: assigned to (171.64.65.103).
[16:11:53] + News From Folding@Home: GPU folding beta
[16:11:53] Loaded queue successfully.
[16:11:54] + Closed connections
[16:11:59]
[16:11:59] + Processing work unit
[16:11:59] Core required: FahCore_11.exe
[16:11:59] Core found.
[16:11:59] Working on queue slot 05 [April 5 16:11:59 UTC]
[16:11:59] + Working ...
[16:12:00]
[16:12:00] *------------------------------*
[16:12:00] Folding@Home GPU Core - Beta
[16:12:00] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[16:12:00]
[16:12:00] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:12:00] Build host: amoeba
[16:12:00] Board Type: AMD
[16:12:00] Core      :
[16:12:00] Preparing to commence simulation
[16:12:00] - Looking at optimizations...
[16:12:00] - Created dyn
[16:12:00] - Files status OK
[16:12:00] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[16:12:00] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[16:12:00] - Digital signature verified
[16:12:00]
[16:12:00] Project: 4743 (Run 9, Clone 139, Gen 10)
[16:12:00]
[16:12:00] Assembly optimizations on if available.
[16:12:00] Entering M.D.
[16:12:06] Working on p4743_lam5w_300K
[16:12:07] Client config found, loading data.
[16:12:07] Starting GUI Server
[16:12:09] mdrun_gpu returned
[16:12:09] NANs detected on GPU
[16:12:09]
[16:12:09] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:12:12] CoreStatus = 7A (122)
[16:12:12] Sending work to server
[16:12:12] Project: 4743 (Run 9, Clone 139, Gen 10)
[16:12:12] - Error: Could not get length of results file work/wuresults_05.dat
[16:12:12] - Error: Could not read unit 05 file. Removing from queue.
[16:12:12] EUE limit exceeded. Pausing
ColonelCain
Post by ColonelCain »
Not to go of topic, but I have seen this same behavior with a few ATI WU's as well, so I don't think that it is isolated to just this one.
Leoslocks
Post by Leoslocks »
Is anyone at the shop to address this issue.
Got it again.
[14:11:19] *------------------------------*
[14:11:19] Folding@Home GPU Core - Beta
[14:11:19] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[14:11:19]
[14:11:19] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:11:19] Build host: amoeba
[14:11:19] Board Type: AMD
[14:11:19] Core      :
[14:11:19] Preparing to commence simulation
[14:11:19] - Looking at optimizations...
[14:11:19] - Created dyn
[14:11:19] - Files status OK
[14:11:19] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[14:11:20] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[14:11:20] - Digital signature verified
[14:11:20]
[14:11:20] Project: 4743 (Run 9, Clone 139, Gen 10)
[14:11:20]
[14:11:20] Assembly optimizations on if available.
[14:11:20] Entering M.D.
[14:11:26] Working on p4743_lam5w_300K
[14:11:26] Client config found, loading data.
[14:11:26] Starting GUI Server
[14:11:29] mdrun_gpu returned
[14:11:29] NANs detected on GPU
[14:11:29]
[14:11:29] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:11:31] CoreStatus = 7A (122)
[14:11:31] Sending work to server
[14:11:31] Project: 4743 (Run 9, Clone 139, Gen 10)
[14:11:31] - Error: Could not get length of results file work/wuresults_02.dat
[14:11:31] - Error: Could not read unit 02 file. Removing from queue.
[14:11:31] - Preparing to get new work unit...
[14:11:31] + Attempting to get work packet
[14:11:31] - Connecting to assignment server
[14:11:32] - Successful: assigned to (171.64.65.103).
[14:11:32] + News From Folding@Home: GPU folding beta
[14:11:32] Loaded queue successfully.
[14:11:33] + Closed connections
[14:11:38]
[14:11:38] + Processing work unit
[14:11:38] Core required: FahCore_11.exe
[14:11:38] Core found.
[14:11:38] Working on queue slot 03 [April 6 14:11:38 UTC]
[14:11:38] + Working ...
[14:11:38]
[14:11:38] *------------------------------*
[14:11:38] Folding@Home GPU Core - Beta
[14:11:38] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[14:11:38]
[14:11:38] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:11:38] Build host: amoeba
[14:11:38] Board Type: AMD
[14:11:38] Core      :
[14:11:38] Preparing to commence simulation
[14:11:38] - Looking at optimizations...
[14:11:38] - Created dyn
[14:11:38] - Files status OK
[14:11:38] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[14:11:38] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[14:11:38] - Digital signature verified
[14:11:38]
[14:11:38] Project: 4743 (Run 9, Clone 139, Gen 10)
[14:11:38]
[14:11:38] Assembly optimizations on if available.
[14:11:38] Entering M.D.
[14:11:45] Working on p4743_lam5w_300K
[14:11:45] Client config found, loading data.
[14:11:45] Starting GUI Server
[14:11:48] mdrun_gpu returned
[14:11:48] NANs detected on GPU
[14:11:48]
[14:11:48] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:11:50] CoreStatus = 7A (122)
[14:11:50] Sending work to server
[14:11:50] Project: 4743 (Run 9, Clone 139, Gen 10)
[14:11:50] - Error: Could not get length of results file work/wuresults_03.dat
[14:11:50] - Error: Could not read unit 03 file. Removing from queue.
[14:11:50] - Preparing to get new work unit...
[14:11:50] + Attempting to get work packet
[14:11:50] - Connecting to assignment server
[14:11:51] - Successful: assigned to (171.64.65.103).
[14:11:51] + News From Folding@Home: GPU folding beta
[14:11:51] Loaded queue successfully.
[14:11:52] + Closed connections
[14:11:57]
[14:11:57] + Processing work unit
[14:11:57] Core required: FahCore_11.exe
[14:11:57] Core found.
[14:11:57] Working on queue slot 04 [April 6 14:11:57 UTC]
[14:11:57] + Working ...
[14:11:57]
[14:11:57] *------------------------------*
[14:11:57] Folding@Home GPU Core - Beta
[14:11:57] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[14:11:57]
[14:11:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:11:57] Build host: amoeba
[14:11:57] Board Type: AMD
[14:11:57] Core      :
[14:11:57] Preparing to commence simulation
[14:11:57] - Looking at optimizations...
[14:11:57] - Created dyn
[14:11:57] - Files status OK
[14:11:57] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[14:11:57] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[14:11:57] - Digital signature verified
[14:11:57]
[14:11:57] Project: 4743 (Run 9, Clone 139, Gen 10)
[14:11:57]
[14:11:57] Assembly optimizations on if available.
[14:11:57] Entering M.D.
[14:12:03] Working on p4743_lam5w_300K
[14:12:04] Client config found, loading data.
[14:12:04] Starting GUI Server
[14:12:06] mdrun_gpu returned
[14:12:06] NANs detected on GPU
[14:12:06]
[14:12:06] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:12:09] CoreStatus = 7A (122)
[14:12:09] Sending work to server
[14:12:09] Project: 4743 (Run 9, Clone 139, Gen 10)
[14:12:09] - Error: Could not get length of results file work/wuresults_04.dat
[14:12:09] - Error: Could not read unit 04 file. Removing from queue.
[14:12:09] - Preparing to get new work unit...
[14:12:09] + Attempting to get work packet
[14:12:09] - Connecting to assignment server
[14:12:10] - Successful: assigned to (171.64.65.103).
[14:12:10] + News From Folding@Home: GPU folding beta
[14:12:10] Loaded queue successfully.
[14:12:11] + Closed connections
[14:12:16]
[14:12:16] + Processing work unit
[14:12:16] Core required: FahCore_11.exe
[14:12:16] Core found.
[14:12:16] Working on queue slot 05 [April 6 14:12:16 UTC]
[14:12:16] + Working ...
[14:12:16]
[14:12:16] *------------------------------*
[14:12:16] Folding@Home GPU Core - Beta
[14:12:16] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[14:12:16]
[14:12:16] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:12:16] Build host: amoeba
[14:12:16] Board Type: AMD
[14:12:16] Core      :
[14:12:16] Preparing to commence simulation
[14:12:16] - Looking at optimizations...
[14:12:16] - Created dyn
[14:12:16] - Files status OK
[14:12:16] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[14:12:16] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[14:12:16] - Digital signature verified
[14:12:16]
[14:12:16] Project: 4743 (Run 9, Clone 139, Gen 10)
[14:12:16]
[14:12:16] Assembly optimizations on if available.
[14:12:16] Entering M.D.
[14:12:22] Working on p4743_lam5w_300K
[14:12:23] Client config found, loading data.
[14:12:23] Starting GUI Server
[14:12:25] mdrun_gpu returned
[14:12:25] NANs detected on GPU
[14:12:25]
[14:12:25] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:12:28] CoreStatus = 7A (122)
[14:12:28] Sending work to server
[14:12:28] Project: 4743 (Run 9, Clone 139, Gen 10)
[14:12:28] - Error: Could not get length of results file work/wuresults_05.dat
[14:12:28] - Error: Could not read unit 05 file. Removing from queue.
[14:12:28] - Preparing to get new work unit...
[14:12:28] + Attempting to get work packet
[14:12:28] - Connecting to assignment server
[14:12:28] - Successful: assigned to (171.64.65.103).
[14:12:28] + News From Folding@Home: GPU folding beta
[14:12:29] Loaded queue successfully.
[14:12:29] + Closed connections
[14:12:34]
[14:12:34] + Processing work unit
[14:12:34] Core required: FahCore_11.exe
[14:12:34] Core found.
[14:12:34] Working on queue slot 06 [April 6 14:12:34 UTC]
[14:12:34] + Working ...
[14:12:35]
[14:12:35] *------------------------------*
[14:12:35] Folding@Home GPU Core - Beta
[14:12:35] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[14:12:35]
[14:12:35] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:12:35] Build host: amoeba
[14:12:35] Board Type: AMD
[14:12:35] Core      :
[14:12:35] Preparing to commence simulation
[14:12:35] - Looking at optimizations...
[14:12:35] - Created dyn
[14:12:35] - Files status OK
[14:12:35] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[14:12:35] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[14:12:35] - Digital signature verified
[14:12:35]
[14:12:35] Project: 4743 (Run 9, Clone 139, Gen 10)
[14:12:35]
[14:12:35] Assembly optimizations on if available.
[14:12:35] Entering M.D.
[14:12:41] Working on p4743_lam5w_300K
[14:12:41] Client config found, loading data.
[14:12:42] Starting GUI Server
[14:12:44] mdrun_gpu returned
[14:12:44] NANs detected on GPU
[14:12:44]
[14:12:44] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:12:47] CoreStatus = 7A (122)
[14:12:47] Sending work to server
[14:12:47] Project: 4743 (Run 9, Clone 139, Gen 10)
[14:12:47] - Error: Could not get length of results file work/wuresults_06.dat
[14:12:47] - Error: Could not read unit 06 file. Removing from queue.
[14:12:47] EUE limit exceeded. Pausing 24 hours.
[code]
[/code]
Leoslocks
Post by Leoslocks »
Well, I knew that 6:33 am (Previous post) pacifc time was too early for anyone to be at work. I trust some one will look into this WU as I received this WU as the first WU on a new install this afternoon.
--- Opening Log file [April 6 21:21:28 UTC]
                          http://folding.stanford.edu
Launch directory: c:\GPU
Executable: 4870.exe
Arguments: -configonly
[21:21:28] Configuring Folding@Home...
[21:23:00] - Ask before connecting: No
[21:23:00] - User name: [inMEMORYof]_rangeral (Team 34878)
[21:23:00] - User ID: 3D2C8FA83022ECE0
[21:23:00] - Machine ID: 2
[21:23:00]
[21:23:00] -configonly flag given, so exiting.
--- Opening Log file [April 6 21:23:53 UTC]
Launch directory: C:\GPU
Executable: C:\GPU\4870.exe
[21:23:53] - Ask before connecting: No
[21:23:53] - User name: [inMEMORYof]_rangeral (Team 34878)
[21:23:53] - User ID: 7D270EDE0095C29E
[21:23:53] - Machine ID: 2
[21:23:53]
[21:23:53] Work directory not found. Creating...
[21:23:53] Could not open work queue, generating new queue...
[21:23:53] - Preparing to get new work unit...
[21:23:53] + Attempting to get work packet
[21:23:53] - Connecting to assignment server
[21:23:54] - Successful: assigned to (171.64.65.103).
[21:23:54] + News From Folding@Home: GPU folding beta
[21:23:54] Loaded queue successfully.
[21:23:55] + Could not connect to Work Server
[21:23:55] - Attempt #1  to get work failed, and no other work to do.
[21:24:12] + Attempting to get work packet
[21:24:12] - Connecting to assignment server
[21:24:13] - Successful: assigned to (171.64.65.103).
[21:24:13] + News From Folding@Home: GPU folding beta
[21:24:13] Loaded queue successfully.
[21:24:14] + Could not connect to Work Server
[21:24:14] - Attempt #2  to get work failed, and no other work to do.
[21:24:37] + Attempting to get work packet
[21:24:37] - Connecting to assignment server
[21:24:37] - Successful: assigned to (171.64.65.103).
[21:24:37] + News From Folding@Home: GPU folding beta
[21:24:37] Loaded queue successfully.
[21:24:38] + Could not connect to Work Server
[21:24:38] - Attempt #3  to get work failed, and no other work to do.
[21:25:08] + Attempting to get work packet
[21:25:08] - Connecting to assignment server
[21:25:09] - Successful: assigned to (171.64.65.103).
[21:25:09] + News From Folding@Home: GPU folding beta
[21:25:09] Loaded queue successfully.
[21:25:10] + Could not connect to Work Server
[21:25:10] - Attempt #4  to get work failed, and no other work to do.
[21:25:59] + Attempting to get work packet
[21:25:59] - Connecting to assignment server
[21:26:00] - Successful: assigned to (171.64.65.103).
[21:26:00] + News From Folding@Home: GPU folding beta
[21:26:00] Loaded queue successfully.
[21:26:01] + Could not connect to Work Server
[21:26:01] - Attempt #5  to get work failed, and no other work to do.
Folding@Home Client Shutdown.
--- Opening Log file [April 6 21:27:17 UTC]
[21:27:17] - Ask before connecting: No
[21:27:17] - User name: [inMEMORYof]_rangeral (Team 34878)
[21:27:17] - User ID: 7D270EDE0095C29E
[21:27:17] - Machine ID: 2
[21:27:17]
[21:27:17] Loaded queue successfully.
[21:27:17] - Preparing to get new work unit...
[21:27:17] + Attempting to get work packet
[21:27:17] - Connecting to assignment server
[21:27:18] - Successful: assigned to (171.64.65.103).
[21:27:18] + News From Folding@Home: GPU folding beta
[21:27:18] Loaded queue successfully.
[21:27:18] + Could not connect to Work Server
[21:27:18] - Attempt #1  to get work failed, and no other work to do.
[21:27:30] + Attempting to get work packet
[21:27:30] - Connecting to assignment server
[21:27:30] - Successful: assigned to (171.64.65.103).
[21:27:30] + News From Folding@Home: GPU folding beta
[21:27:30] Loaded queue successfully.
[21:27:31] + Closed connections
[21:27:31]
[21:27:31] + Processing work unit
[21:27:31] Core required: FahCore_11.exe
[21:27:31] Core not found.
[21:27:31] - Core is not present or corrupted.
[21:27:31] - Attempting to download new core...
[21:27:31] + Downloading new core: FahCore_11.exe
[21:27:32] + 10240 bytes downloaded
[21:27:32] + 20480 bytes downloaded
[21:27:32] + 30720 bytes downloaded
[21:27:32] + 40960 bytes downloaded
[21:27:33] + 51200 bytes downloaded
[21:27:33] + 61440 bytes downloaded
[21:27:33] + 71680 bytes downloaded
[21:27:33] + 81920 bytes downloaded
[21:27:33] + 92160 bytes downloaded
[21:27:33] + 102400 bytes downloaded
[21:27:33] + 112640 bytes downloaded
[21:27:33] + 122880 bytes downloaded
[21:27:33] + 133120 bytes downloaded
[21:27:33] + 143360 bytes downloaded
[21:27:33] + 153600 bytes downloaded
[21:27:33] + 163840 bytes downloaded
[21:27:33] + 174080 bytes downloaded
[21:27:33] + 184320 bytes downloaded
[21:27:33] + 194560 bytes downloaded
[21:27:33] + 204800 bytes downloaded
[21:27:33] + 215040 bytes downloaded
[21:27:33] + 225280 bytes downloaded
[21:27:33] + 235520 bytes downloaded
[21:27:33] + 245760 bytes downloaded
[21:27:33] + 256000 bytes downloaded
[21:27:33] + 266240 bytes downloaded
[21:27:33] + 276480 bytes downloaded
[21:27:33] + 286720 bytes downloaded
[21:27:33] + 296960 bytes downloaded
[21:27:33] + 307200 bytes downloaded
[21:27:33] + 317440 bytes downloaded
[21:27:33] + 327680 bytes downloaded
[21:27:33] + 337920 bytes downloaded
[21:27:33] + 348160 bytes downloaded
[21:27:33] + 358400 bytes downloaded
[21:27:33] + 368640 bytes downloaded
[21:27:33] + 378880 bytes downloaded
[21:27:33] + 389120 bytes downloaded
[21:27:33] + 399360 bytes downloaded
[21:27:33] + 409600 bytes downloaded
[21:27:33] + 419840 bytes downloaded
[21:27:33] + 430080 bytes downloaded
[21:27:33] + 440320 bytes downloaded
[21:27:33] + 450560 bytes downloaded
[21:27:33] + 460800 bytes downloaded
[21:27:33] + 471040 bytes downloaded
[21:27:33] + 481280 bytes downloaded
[21:27:33] + 491520 bytes downloaded
[21:27:33] + 501760 bytes downloaded
[21:27:33] + 512000 bytes downloaded
[21:27:34] + 522240 bytes downloaded
[21:27:34] + 532480 bytes downloaded
[21:27:34] + 542720 bytes downloaded
[21:27:34] + 552960 bytes downloaded
[21:27:34] + 563200 bytes downloaded
[21:27:34] + 573440 bytes downloaded
[21:27:34] + 583680 bytes downloaded
[21:27:34] + 593920 bytes downloaded
[21:27:34] + 604160 bytes downloaded
[21:27:34] + 614400 bytes downloaded
[21:27:34] + 624640 bytes downloaded
[21:27:34] + 634880 bytes downloaded
[21:27:34] + 645120 bytes downloaded
[21:27:34] + 655360 bytes downloaded
[21:27:34] + 665600 bytes downloaded
[21:27:34] + 675840 bytes downloaded
[21:27:34] + 686080 bytes downloaded
[21:27:34] + 696320 bytes downloaded
[21:27:34] + 706560 bytes downloaded
[21:27:34] + 716800 bytes downloaded
[21:27:34] + 727040 bytes downloaded
[21:27:34] + 737280 bytes downloaded
[21:27:34] + 747520 bytes downloaded
[21:27:34] + 757760 bytes downloaded
[21:27:34] + 768000 bytes downloaded
[21:27:34] + 778240 bytes downloaded
[21:27:34] + 788480 bytes downloaded
[21:27:34] + 798720 bytes downloaded
[21:27:34] + 808960 bytes downloaded
[21:27:34] + 819200 bytes downloaded
[21:27:35] + 829440 bytes downloaded
[21:27:35] + 839680 bytes downloaded
[21:27:35] + 849920 bytes downloaded
[21:27:35] + 860160 bytes downloaded
[21:27:35] + 870400 bytes downloaded
[21:27:35] + 880640 bytes downloaded
[21:27:35] + 890880 bytes downloaded
[21:27:35] + 901120 bytes downloaded
[21:27:35] + 911360 bytes downloaded
[21:27:35] + 921600 bytes downloaded
[21:27:35] + 931840 bytes downloaded
[21:27:35] + 942080 bytes downloaded
[21:27:35] + 952320 bytes downloaded
[21:27:35] + 962560 bytes downloaded
[21:27:35] + 972800 bytes downloaded
[21:27:35] + 983040 bytes downloaded
[21:27:35] + 993280 bytes downloaded
[21:27:35] + 1003520 bytes downloaded
[21:27:35] + 1013760 bytes downloaded
[21:27:35] + 1024000 bytes downloaded
[21:27:35] + 1034240 bytes downloaded
[21:27:35] + 1044480 bytes downloaded
[21:27:35] + 1054720 bytes downloaded
[21:27:35] + 1064960 bytes downloaded
[21:27:35] + 1075200 bytes downloaded
[21:27:35] + 1085440 bytes downloaded
[21:27:35] + 1091180 bytes downloaded
[21:27:35] Verifying core Core_11.fah...
[21:27:35] Signature is VALID
[21:27:35]
[21:27:35] Trying to unzip core FahCore_11.exe
[21:27:35] Decompressed FahCore_11.exe (3203072 bytes) successfully
[21:27:40] + Core successfully engaged
[21:27:45]
[21:27:45] + Processing work unit
[21:27:45] Core required: FahCore_11.exe
[21:27:45] Core found.
[21:27:45] Working on queue slot 01 [April 6 21:27:45 UTC]
[21:27:45] + Working ...
[21:27:45]
[21:27:45] *------------------------------*
[21:27:45] Folding@Home GPU Core - Beta
[21:27:45] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[21:27:45]
[21:27:45] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:27:45] Build host: amoeba
[21:27:45] Board Type: AMD
[21:27:45] Core      :
[21:27:45] Preparing to commence simulation
[21:27:45] - Looking at optimizations...
[21:27:45] - Created dyn
[21:27:45] - Files status OK
[21:27:45] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[21:27:45] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[21:27:45] - Digital signature verified
[21:27:45]
[21:27:45] Project: 4743 (Run 9, Clone 139, Gen 10)
[21:27:45]
[21:27:45] Assembly optimizations on if available.
[21:27:45] Entering M.D.
[21:27:51] Tpr hash work/wudata_01.tpr:  2860864008 3149223251 1509629602 2141700241 551907839
[21:27:52] Working on p4743_lam5w_300K
[21:27:52] Client config found, loading data.
[21:27:52] Starting GUI Server
[21:27:57] mdrun_gpu returned
[21:27:57] NANs detected on GPU
[21:27:57]
[21:27:57] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:27:59] CoreStatus = 7A (122)
[21:27:59] Sending work to server
[21:27:59] Project: 4743 (Run 9, Clone 139, Gen 10)
[21:27:59] - Read packet limit of 540015616... Set to 524286976.
[21:27:59] - Error: Could not get length of results file work/wuresults_01.dat
[21:27:59] - Error: Could not read unit 01 file. Removing from queue.
[21:27:59] - Preparing to get new work unit...
[21:27:59] + Attempting to get work packet
[21:27:59] - Connecting to assignment server
[21:28:00] - Successful: assigned to (171.64.65.103).
[21:28:00] + News From Folding@Home: GPU folding beta
[21:28:00] Loaded queue successfully.
[21:28:01] + Closed connections
[21:28:06]
[21:28:06] + Processing work unit
[21:28:06] Core required: FahCore_11.exe
[21:28:06] Core found.
[21:28:06] Working on queue slot 02 [April 6 21:28:06 UTC]
[21:28:06] + Working ...
[21:28:06]
[21:28:06] *------------------------------*
[21:28:06] Folding@Home GPU Core - Beta
[21:28:06] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[21:28:06]
[21:28:06] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:28:06] Build host: amoeba
[21:28:06] Board Type: AMD
[21:28:06] Core      :
[21:28:06] Preparing to commence simulation
[21:28:06] - Looking at optimizations...
[21:28:06] - Created dyn
[21:28:06] - Files status OK
[21:28:06] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[21:28:06] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[21:28:06] - Digital signature verified
[21:28:06]
[21:28:06] Project: 4743 (Run 9, Clone 139, Gen 10)
[21:28:06]
[21:28:06] Assembly optimizations on if available.
[21:28:06] Entering M.D.
[21:28:12] Tpr hash work/wudata_02.tpr:  2860864008 3149223251 1509629602 2141700241 551907839
[21:28:13] Working on p4743_lam5w_300K
[21:28:13] Client config found, loading data.
[21:28:14] Starting GUI Server
[21:28:18] mdrun_gpu returned
[21:28:18] NANs detected on GPU
[21:28:18]
[21:28:18] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:28:22] CoreStatus = 7A (122)
[21:28:22] Sending work to server
[21:28:22] Project: 4743 (Run 9, Clone 139, Gen 10)
[21:28:22] - Read packet limit of 540015616... Set to 524286976.
[21:28:22] - Error: Could not get length of results file work/wuresults_02.dat
[21:28:22] - Error: Could not read unit 02 file. Removing from queue.
[21:28:22] - Preparing to get new work unit...
[21:28:22] + Attempting to get work packet
[21:28:22] - Connecting to assignment server
[21:28:23] - Successful: assigned to (171.64.65.103).
[21:28:23] + News From Folding@Home: GPU folding beta
[21:28:23] Loaded queue successfully.
[21:28:24] + Closed connections
[21:28:29]
[21:28:29] + Processing work unit
[21:28:29] Core required: FahCore_11.exe
[21:28:29] Core found.
[21:28:29] Working on queue slot 03 [April 6 21:28:29 UTC]
[21:28:29] + Working ...
[21:28:29]
[21:28:29] *------------------------------*
[21:28:29] Folding@Home GPU Core - Beta
[21:28:29] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[21:28:29]
[21:28:29] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:28:29] Build host: amoeba
[21:28:29] Board Type: AMD
[21:28:29] Core      :
[21:28:29] Preparing to commence simulation
[21:28:29] - Looking at optimizations...
[21:28:29] - Created dyn
[21:28:29] - Files status OK
[21:28:29] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[21:28:29] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[21:28:29] - Digital signature verified
[21:28:29]
[21:28:29] Project: 4743 (Run 9, Clone 139, Gen 10)
[21:28:29]
[21:28:29] Assembly optimizations on if available.
[21:28:29] Entering M.D.
[21:28:35] Tpr hash work/wudata_03.tpr:  2860864008 3149223251 1509629602 2141700241 551907839
[21:28:35] Working on p4743_lam5w_300K
[21:28:36] Client config found, loading data.
[21:28:36] Starting GUI Server
[21:28:41] mdrun_gpu returned
[21:28:41] NANs detected on GPU
[21:28:41]
[21:28:41] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:28:43] CoreStatus = 7A (122)
[21:28:43] Sending work to server
[21:28:43] Project: 4743 (Run 9, Clone 139, Gen 10)
[21:28:43] - Read packet limit of 540015616... Set to 524286976.
[21:28:43] - Error: Could not get length of results file work/wuresults_03.dat
[21:28:43] - Error: Could not read unit 03 file. Removing from queue.
[21:28:43] - Preparing to get new work unit...
[21:28:43] + Attempting to get work packet
[21:28:43] - Connecting to assignment server
[21:28:44] - Successful: assigned to (171.64.65.103).
[21:28:44] + News From Folding@Home: GPU folding beta
[21:28:44] Loaded queue successfully.
[21:28:45] + Closed connections
[21:28:50]
[21:28:50] + Processing work unit
[21:28:50] Core required: FahCore_11.exe
[21:28:50] Core found.
[21:28:50] Working on queue slot 04 [April 6 21:28:50 UTC]
[21:28:50] + Working ...
[21:28:50]
[21:28:50] *------------------------------*
[21:28:50] Folding@Home GPU Core - Beta
[21:28:50] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[21:28:50]
[21:28:50] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:28:50] Build host: amoeba
[21:28:50] Board Type: AMD
[21:28:50] Core      :
[21:28:50] Preparing to commence simulation
[21:28:50] - Looking at optimizations...
[21:28:50] - Created dyn
[21:28:50] - Files status OK
[21:28:50] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[21:28:50] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[21:28:50] - Digital signature verified
[21:28:50]
[21:28:50] Project: 4743 (Run 9, Clone 139, Gen 10)
[21:28:50]
[21:28:50] Assembly optimizations on if available.
[21:28:50] Entering M.D.
[21:28:56] Tpr hash work/wudata_04.tpr:  2860864008 3149223251 1509629602 2141700241 551907839
[21:28:56] Working on p4743_lam5w_300K
[21:28:57] Client config found, loading data.
[21:28:57] Starting GUI Server
[21:29:02] mdrun_gpu returned
[21:29:02] NANs detected on GPU
[21:29:02]
[21:29:02] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:29:04] CoreStatus = 7A (122)
[21:29:04] Sending work to server
[21:29:04] Project: 4743 (Run 9, Clone 139, Gen 10)
[21:29:04] - Read packet limit of 540015616... Set to 524286976.
[21:29:04] - Error: Could not get length of results file work/wuresults_04.dat
[21:29:04] - Error: Could not read unit 04 file. Removing from queue.
[21:29:04] - Preparing to get new work unit...
[21:29:04] + Attempting to get work packet
[21:29:04] - Connecting to assignment server
[21:29:04] - Successful: assigned to (171.64.65.103).
[21:29:04] + News From Folding@Home: GPU folding beta
[21:29:04] Loaded queue successfully.
[21:29:05] + Closed connections
[21:29:10]
[21:29:10] + Processing work unit
[21:29:10] Core required: FahCore_11.exe
[21:29:10] Core found.
[21:29:10] Working on queue slot 05 [April 6 21:29:10 UTC]
[21:29:10] + Working ...
[21:29:11]
[21:29:11] *------------------------------*
[21:29:11] Folding@Home GPU Core - Beta
[21:29:11] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[21:29:11]
[21:29:11] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:29:11] Build host: amoeba
[21:29:11] Board Type: AMD
[21:29:11] Core      :
[21:29:11] Preparing to commence simulation
[21:29:11] - Looking at optimizations...
[21:29:11] - Created dyn
[21:29:11] - Files status OK
[21:29:11] - Expanded 57514 -> 447304 (decompressed 777.7 percent)
[21:29:11] Called DecompressByteArray: compressed_data_size=57514 data_size=447304, decompressed_data_size=447304 diff=0
[21:29:11] - Digital signature verified
[21:29:11]
[21:29:11] Project: 4743 (Run 9, Clone 139, Gen 10)
[21:29:11]
[21:29:11] Assembly optimizations on if available.
[21:29:11] Entering M.D.
[21:29:17] Tpr hash work/wudata_05.tpr:  2860864008 3149223251 1509629602 2141700241 551907839
[21:29:17] Working on p4743_lam5w_300K
[21:29:18] Client config found, loading data.
[21:29:18] Starting GUI Server
[21:29:23] mdrun_gpu returned
[21:29:23] NANs detected on GPU
[21:29:23]
[21:29:23] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:29:25] CoreStatus = 7A (122)
[21:29:25] Sending work to server
[21:29:25] Project: 4743 (Run 9, Clone 139, Gen 10)
[21:29:25] - Read packet limit of 540015616... Set to 524286976.
[21:29:25] - Error: Could not get length of results file work/wuresults_05.dat
[21:29:25] - Error: Could not read unit 05 file. Removing from queue.
[21:29:25] EUE limit exceeded. Pausing 24 hours.
After shutting down the console client twice, I was able to get the new baby folder working on a good WU.
[21:27:45] Project: 4743 (Run 9, Clone 139, Gen 10) has been reported as a bad WU.
planetclown
Hardware configuration: Ryzen 7 5700x
32GB (2X16GB) DDR4 3200MHz
EVGA RTX 3060 Ti
Post by planetclown »
I am still receiving WU's from this project.
I received one this morning and got the EUE limit exceeded and client pause as Leoslocks reported.
planetclown wrote:I am still receiving WU's from this project.
When we report a problem with a WU, the individual WU is removed from circulation. The project is not stopped. Bad WUs represent a very small fraction of any given project.
Did you receive another copy of (Run 9, Clone 139, Gen 10)? Sometimes another copy of that WU is still in circulation and it may take some time for it to be removed, too.
planetclown
EVGA RTX 3060 Ti
Yes, I meant to say I received another WU from this PRCG - not just the project.
I didn't realize this was the case. I just wanted to let someone know that WU's from the PRCG were still being sent out and could affect other clients' folding.
Thanks for the help, bruce!
susato
Post by susato »
bruce wrote: Sometimes another copy of that WU is still in circulation and it may take some time for it to be removed, too.
Good thought Bruce -- that could account for some of the instances we've seen of a bad WU apparently staying in circulation.
SparkyJJO
Post by SparkyJJO »
Guys this unit is still in the wild, I just got it again and it paused my GPU for 24 hours :roll:
