Project: 4610 (Run 33, Clone 16, Gen 50) EUE at 0%
anandhanju
Post by anandhanju »
Project: 4610 (Run 33, Clone 16, Gen 50) EUEd at 0%
[23:24:33] Folding@Home PMD Core
[23:24:33] Version 1.03 (September 7, 2005)
[23:24:33]
[23:24:33] Preparing to commence simulation
[23:24:33] - Assembly optimizations manually forced on.
[23:24:33] - Not checking prior termination.
[23:24:33] - Expanded 11804 -> 78053 (decompressed 661.2 percent)
[23:24:33]
[23:24:33] Project: 4610 (Run 33, Clone 16, Gen 50)
[23:24:33]
[23:24:33] Assembly optimizations on if available.
[23:24:33] Entering M.D.
[23:24:39] Going to send back what have done.
[23:24:39] logfile size: 5649
[23:24:39] - Writing 6169 bytes of core data to disk...
[23:24:39]   ... Done.
[23:24:39]
[23:24:39] Folding@home Core Shutdown: EARLY_UNIT_END
[23:24:43] CoreStatus = 72 (114)
[23:24:43] Sending work to server
[23:24:43] Project: 4610 (Run 33, Clone 16, Gen 50)
[23:24:43] + Attempting to send results [April 2 23:24:43 UTC]
[23:24:43] - Reading file work/wuresults_02.dat from core
[23:24:43]   (Read 6169 bytes from disk)
[23:24:43] Connecting to http://169.230.26.30:8080/
[23:24:43] Posted data.
[23:24:43] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[23:24:43] - Uploaded at ~14 kB/s
[23:24:43] - Averaged speed for that direction ~32 kB/s
[23:24:43] + Results successfully sent
[23:24:43] Thank you for your contribution to Folding@Home.
Partial result (or whatever was generated) sent successfully.
Re: Project: 4610 (Run 33, Clone 16, Gen 50) EUE at 0%
I've marked this WU as a bad one, there are similar reports in the DB.
anandhanju
Thanks!
