Problems sending to 171.64.65.65 ?
pompeyrodney
Hardware configuration: 1 Dell server running Quad Xeon 2.4 Deino, SMP client. 2 Vista GPU client and 2 6.23 BetaR1. 8 other XP clients running 6.23.
Post by pompeyrodney »
[07:45:12] + Attempting to send results [April 1 07:45:12 UTC]
[07:45:12] - Reading file work/wuresults_05.dat from core
[07:45:12] (Read 17461834 bytes from disk)
[07:45:12] Connecting to http://171.64.65.65:8080/
[08:05:19] Posted data.
[08:05:57] Initial: 0000; + Could not connect to Work Server (results)
[08:05:57] (171.64.65.65:8080)
[08:05:57] + Retrying using alternative port
[08:05:57] Connecting to http://171.64.65.65:80/
[08:26:05] Posted data.
[08:46:05] Initial: 0000; - Unknown packet returned from server, expected ACK for results
[09:01:51] - Error: Could not transmit unit 05 (completed March 14) to work server.
[09:01:52] - 41 failed uploads of this unit.
Each time the client tries I get the text in bold and this is the only one of my clients that do this, I am not using a firewall on the machine incidentally.
Re: Problems sending to 171.64.65.65 ?
Do you use the last version of the client (v6.23) ?
pompeyrodney
I do now so thanks very much for pointing me in the right direction :D
