Project: 2665 (Run 0, Clone 35, Gen 86) EUE
Eveofwar
Hardware configuration: ASUS M2A-VM Motherboard
AMD Athlon 6000+ 64 X2 @ 3.00GHz (Stock)
nVidia GeForce 9800GT @ 650MHz GPU/950MHz Memory/1620MHz Shader (Stock)
2GB DDR2 RAM
Post by Eveofwar »
Folding@Home Client Version 6.23 Beta R1
http://folding.stanford.edu
Launch directory: C:\Documents and Settings\Mike\Desktop\FAHSMP
Service: C:\Documents and Settings\Mike\Desktop\FAHSMP\fah6
Arguments: -svcstart -d C:\Documents and Settings\Mike\Desktop\FAHSMP -smp -deino -verbosity 9 -forceasm -advmethods -local
Launched as a service.
Entered C:\Documents and Settings\Mike\Desktop\FAHSMP to do work.
Warning:
By using the -forceasm flag, you are overriding
safeguards in the program. If you did not intend to
do this, please restart the program without -forceasm.
If work units are not completing fully (and particularly
if your machine is overclocked), then please discontinue
use of the flag.
[21:11:26] - Ask before connecting: No
[21:11:26] - User name: Eveofwar (Team 159889)
[21:11:26] - User ID: 7E0AE41804D06E2A
[21:11:26] - Machine ID: 4
[21:11:26]
[21:11:26] Loaded queue successfully.
[21:11:26]
[21:11:26] + Processing work unit
[21:11:26] Work type a1 not eligible for variable processors
[21:11:26] Core required: FahCore_a1.exe
[21:11:26] Core found.
[21:11:26] - Autosending finished units... [March 31 21:11:26 UTC]
[21:11:26] Trying to send all finished work units
[21:11:26] + No unsent completed units remaining.
[21:11:26] - Autosend completed
[21:11:26] Working on queue slot 05 [March 31 21:11:26 UTC]
[21:11:26] + Working ...
[21:11:26] - Calling 'mpiexec -np 4 -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 05 -checkpoint 15 -service -forceasm -verbose -lifeline 2716 -version 623'
[21:11:27]
[21:11:27] *------------------------------*
[21:11:27] Folding@Home Gromacs SMP Core
[21:11:27] Version 1.76 (February 23, 2008)
[21:11:27]
[21:11:27] Preparing to commence simulation
[21:11:27] - Ensuring status. Please wait.
[21:11:44] - Assembly optimizations manually forced on.
[21:11:44] - Not checking prior termination.
[21:12:00] - Expanded 4753262 -> 24426905 (decompressed 513.8 percent)
[21:12:01]
[21:12:01] Project: 2665 (Run 0, Clone 35, Gen 86)
[21:12:01]
[21:12:04] Assembly optimizations on if available.
[21:12:04] Entering M.D.
[21:12:11] Calling FAH init
[21:12:12] Read topology
[21:12:13] ocal files
[21:12:13] rom checkpoint)
[21:12:13] Read checkpoint
[21:12:13] Protein: HGG in water
[21:12:13] Writing local files
[21:12:13] Completed 3562 out of 250000 steps (1 percent)
[21:12:21] Extra SSE boost OK.
[21:27:14] Timered checkpoint triggered.
[21:29:27] Writing local files
[21:29:28] Completed 5000 out of 250000 steps (2 percent)
[21:44:28] Timered checkpoint triggered.
[21:57:40] Writing local files
[21:57:40] Completed 7500 out of 250000 steps (3 percent)
[22:12:41] Timered checkpoint triggered.
[22:26:41] Writing local files
[22:26:41] Completed 10000 out of 250000 steps (4 percent)
[22:41:42] Timered checkpoint triggered.
[22:55:20] Writing local files
[22:55:20] Completed 12500 out of 250000 steps (5 percent)
[23:10:21] Timered checkpoint triggered.
[23:23:38] Writing local files
[23:23:38] Completed 15000 out of 250000 steps (6 percent)
[23:38:39] Timered checkpoint triggered.
[23:44:50] Warning: long 1-4 interactions
[23:44:50] Gromacs cannot continue further.
[23:44:50] Going to send back what have done.
[23:44:50] logfile size: 30914
[23:44:50] - Writing 31450 bytes of core data to disk...
[23:44:50] ... Done.
[23:46:50]
[23:46:50] Folding@home Core Shutdown: EARLY_UNIT_END
[23:46:50]
[23:46:54] CoreStatus = 63 (99)
[23:46:54] + Error starting Folding@Home core.
Re: Project: 2665 (Run 0, Clone 35, Gen 86) EUE
There are 7 reports of EUE in the DB for this WU. I've marked it as bad.
Eveofwar
2GB DDR2 RAM
Post by Eveofwar »
Thank you =]
BrianStevens
Post by BrianStevens »
I just wanted to add that this new FahCore.a1 is giving a malware/antivirus warning from AVast. Ever since I got this core today my client will not run. No matter what I do at this point I get this core every time and it hangs like the OP.
Please see about the Avast issue : viewtopic.php?f=19&t=9317
