Project: 2497 (Run 1, Clone 28, Gen 0) - EUE @ 49%
anandhanju
Post by anandhanju »
Project: 2497 (Run 1, Clone 28, Gen 0) - EUE @ 49% (Step 124954, time 249.908 (ps) LINCS WARNING).
[21:52:39] Folding@Home Gromacs Core
[21:52:39] Version 1.90 (March 8, 2006)
[21:52:39]
[21:52:39] Preparing to commence simulation
[21:52:39] - Assembly optimizations manually forced on.
[21:52:39] - Not checking prior termination.
[21:52:43] - Expanded 2229061 -> 15267441 (decompressed 684.9 percent)
[21:52:45]
[21:52:45] Project: 2497 (Run 1, Clone 28, Gen 0)
[21:52:45]
[21:52:46] Assembly optimizations on if available.
[21:52:46] Entering M.D.
[21:53:08] (Starting from checkpoint)
[21:53:08] Protein: system
[21:53:08]
[21:53:08] Writing local files
[21:53:08] Completed 81251 out of 250000 steps  (33%)
[21:53:11] Extra SSE boost OK.
[22:23:11] Writing local files
[22:23:11] Completed 82500 out of 250000 steps  (33%)
[13:36:57] Completed 122500 out of 250000 steps  (49%)
[14:06:58] Timered checkpoint triggered.
[14:30:05] Quit 101 - Fatal error:
[14:30:05] Step 124954, time 249.908 (ps)  LINCS WARNING
[14:30:05] relative constraint deviation after LINCS:
[14:30:05] max 697058935758685050000000.000000 (between atoms 18584 and 18586) rms 8955568862712909800000.000000
[14:30:05]
[14:30:05] Simulation instability has been encountered. The run has entered a
[14:30:05]   state from which no further progress can be made.
[14:30:05] This may be the correct result of the simulation, however if you
[14:30:05]   often see other project units terminating early like this
[14:30:05]   too, you may wish to check the stability of your computer (issues
[14:30:05]   such as high temperature, overclocking, etc.).
[14:30:05] Going to send back what have done.
[14:30:05] logfile size: 81007
[14:30:05] - Writing 81737 bytes of core data to disk...
[14:30:05]   ... Done.
[14:30:05]
[14:30:05] Folding@home Core Shutdown: EARLY_UNIT_END
[14:30:10] CoreStatus = 72 (114)
[14:30:10] Sending work to server
[14:30:10] Project: 2497 (Run 1, Clone 28, Gen 0)
[14:30:10] - Read packet limit of 540015616... Set to 524286976.
[14:30:10] + Attempting to send results [March 31 14:30:10 UTC]
[14:30:10] - Reading file work/wuresults_01.dat from core
[14:30:10]   (Read 81737 bytes from disk)
[14:30:10] Connecting to http://171.65.103.160:8080/
[14:30:14] Posted data.
[14:30:20] Initial: 0000; - Uploaded at ~8 kB/s
[14:30:20] - Averaged speed for that direction ~8 kB/s
[14:30:20] + Results successfully sent
[14:30:20] Thank you for your contribution to Folding@Home.
Partial results submitted successfully.
Re: Project: 2497 (Run 1, Clone 28, Gen 0) - EUE @ 49%
There are multiple reports for partial credit at various progress for this WU. I've marked it as bad.
anandhanju
Thanks toTOW :)
