Project: 2446 (Run 13, Clone 2, Gen 0) - Error 0x79
John Naylor
Hardware configuration: Q9450 OC @ 3.2GHz (Win7 Home Premium) - SMP2
i5-3750k @ 3.8GHz (Win7 Pro) - SMP2
Post by John Naylor »
Can someone please stop this unit from being reassigned? One of my clients is in an endless loop downloading it even when I delete the work directory and the queue. I have made no changes to my software or hardware to precipitate this, and temps are well within the limits (55C @ 100% on both cores). This machine has folded some 400 units successfully before this failure. If specs are necessary its the first system on my profile:
Intel C2D E6750 @ 2.66GHz | 8600GT 256MB | Vista HP SP1 32-bit | 2x 6.23 CPU | FW 182.08 | Big WU
--- Opening Log file [March 30 10:16:37 UTC]
                          http://folding.stanford.edu
Launch directory: C:\Users\John\FAH\2
Service: C:\Users\John\FAH\2\Folding@home-Win32-x86.exe
Arguments: -svcstart -d C:\Users\John\FAH\2 -verbosity 9 -forceasm
Launched as a service.
Entered C:\Users\John\FAH\2 to do work.
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[10:16:37] - Ask before connecting: No
[10:16:37] - User name: John_Naylor (Team 35947)
[10:16:37] - User ID: 4177AF0D03D44085
[10:16:37] - Machine ID: 1
[10:16:37]
[10:16:37] Loaded queue successfully.
[10:16:37]
[10:16:37] + Processing work unit
[10:16:37] Core required: FahCore_78.exe
[10:16:37] Core found.
[10:16:37] - Autosending finished units... [March 30 10:16:37 UTC]
[10:16:37] Trying to send all finished work units
[10:16:37] + No unsent completed units remaining.
[10:16:37] - Autosend completed
[10:16:37] Working on queue slot 04 [March 30 10:16:37 UTC]
[10:16:37] + Working ...
[10:16:37] - Calling '.\FahCore_78.exe -dir work/ -suffix 04 -nocpulock -checkpoint 15 -service -forceasm -verbose -lifeline 488 -version 623'
[10:16:38]
[10:16:38] *------------------------------*
[10:16:38] Folding@Home Gromacs Core
[10:16:38] Version 1.90 (March 8, 2006)
[10:16:38]
[10:16:38] Preparing to commence simulation
[10:16:38] - Ensuring status. Please wait.
[10:16:55] - Assembly optimizations manually forced on.
[10:16:55] - Not checking prior termination.
[10:16:55] - Expanded 92800 -> 2711553 (decompressed 2921.9 percent)
[10:16:55] - Starting from initial work packet
[10:16:55]
[10:16:55] Project: 2446 (Run 13, Clone 2, Gen 0)
[10:16:55]
[10:16:55] Assembly optimizations on if available.
[10:16:55] Entering M.D.
[10:17:06] Protein: Protein
[10:17:06]
[10:17:06] Writing local files
[10:17:06] Gromacs error.
[10:17:06]
[10:17:06] Folding@home Core Shutdown: UNKNOWN_ERROR
[10:17:10] CoreStatus = 79 (121)
[10:17:10] Client-core communications error: ERROR 0x79
[10:17:10] This is a sign of more serious problems, shutting down.
[10:21:13] Service stop request received.
[10:21:13] ***** Got a SIGTERM signal (2)
[10:21:13] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [March 30 10:21:24 UTC]
Warning:
 use of the flag.
[10:21:24] - Ask before connecting: No
[10:21:24] - User name: John_Naylor (Team 35947)
[10:21:24] - User ID: 4177AF0D03D44085
[10:21:24] - Machine ID: 1
[10:21:24]
[10:21:24] Work directory not found. Creating...
[10:21:24] Could not open work queue, generating new queue...
[10:21:24] - Preparing to get new work unit...
[10:21:24] + Attempting to get work packet
[10:21:24] - Will indicate memory of 3325 MB
[10:21:24] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 11
[10:21:24] - Connecting to assignment server
[10:21:24] Connecting to http://assign.stanford.edu:8080/
[10:21:24] - Autosending finished units... [March 30 10:21:24 UTC]
[10:21:24] Trying to send all finished work units
[10:21:24] + No unsent completed units remaining.
[10:21:24] - Autosend completed
[10:21:25] Posted data.
[10:21:25] Initial: 41AB; - Successful: assigned to (171.65.103.160).
[10:21:25] + News From Folding@Home: Welcome to Folding@Home
[10:21:25] Loaded queue successfully.
[10:21:25] Connecting to http://171.65.103.160:8080/
[10:21:27] Posted data.
[10:21:27] Initial: 0000; - Receiving payload (expected size: 93312)
[10:21:27] Conversation time very short, giving reduced weight in bandwidth avg
[10:21:27] - Downloaded at ~182 kB/s
[10:21:27] - Averaged speed for that direction ~182 kB/s
[10:21:27] + Received work.
[10:21:27] + Closed connections
[10:21:27]
[10:21:27] + Processing work unit
[10:21:27] Core required: FahCore_78.exe
[10:21:27] Core found.
[10:21:27] Working on queue slot 01 [March 30 10:21:27 UTC]
[10:21:27] + Working ...
[10:21:27] - Calling '.\FahCore_78.exe -dir work/ -suffix 01 -nocpulock -checkpoint 15 -service -forceasm -verbose -lifeline 3608 -version 623'
[10:21:27]
[10:21:27] *------------------------------*
[10:21:27] Folding@Home Gromacs Core
[10:21:27] Version 1.90 (March 8, 2006)
[10:21:27]
[10:21:27] Preparing to commence simulation
[10:21:27] - Assembly optimizations manually forced on.
[10:21:27] - Not checking prior termination.
[10:21:28] - Expanded 92800 -> 2711553 (decompressed 2921.9 percent)
[10:21:28] - Starting from initial work packet
[10:21:28]
[10:21:28] Project: 2446 (Run 13, Clone 2, Gen 0)
[10:21:28]
[10:21:28] Assembly optimizations on if available.
[10:21:28] Entering M.D.
[10:21:40] Protein: Protein
[10:21:40]
[10:21:40] Writing local files
[10:21:40] Gromacs error.
[10:21:40]
[10:21:40] Folding@home Core Shutdown: UNKNOWN_ERROR
[10:21:43] CoreStatus = 79 (121)
[10:21:43] Client-core communications error: ERROR 0x79
[10:21:43] This is a sign of more serious problems, shutting down.
EDIT: ninja edit for system specs
Folding whatever I'm sent since March 2006 :) Beta testing since October 2006. www.FAH-Addict.net Administrator since August 2009.
Re: Project: 2446 (Run 13, Clone 2, Gen 0) - Error 0x79
I've marked it as a bad WU.
John Naylor
Thanks, but I'm still being sent it :(
That a common behavior with 0x79 error ... it's hard to get a working WU after :( (try to change your client settings)
John Naylor
Messed around with some flags and it's crunching away :) thanks a lot.
