New to Folding, a few questions.
radioattack
Have questions regarding PS3, GPU and SMP. I'm doing everything here as opposed to multiple threads elsewhere, sorry in advance if that's a no-no. Also, some of these questions may have been covered, even frequently, but I'm all FAQ'd out for the night and just need a little human input so be gentle. Win7x64 where applicable.
1. I first started folding as anon on PS3 but just entered a username, will I get credit for the workunits completed prior to doing so or are the in the system as anon for good? And just to make sure, all work done on the PS3 from now on will go towards the same credit total, assuming it's the same username (PS3/PC)?
2. Why does the GPU client display use so much CPU?
3. I'm running MPICH, installed using the guide in the beta forum and as far as I can tell I did it right. There are four instances of FahCore_78.exe (guide says they should be FahCore_Ax.exe[?]) running and 2 of 2 cores are maxed at 100% but I don't seem to be making any progress.
[04:28:07] Starting from checkpoint)
[04:28:07] Protein: p2613_TETHERED VESICLES
[04:28:07]
[04:28:07] Writing local files
[04:28:08] Completed 1250 out of 125000 steps (1%)
[04:28:26] Extra SSE boost OK.
[04:28:38] )
[04:28:38] Protein: p2613_TETHERED VESICLES
[04:28:38]
[04:28:38] Writing local files
[04:28:38] Completed 1250 out of 125000 steps (1%)
They started at 1% and have been stuck there for over an hour now. Are the workunits that big/normally take that long or is something not right? Running on an E8400 @ 3.6, nothing else running that would get in its way.
edit: I only have two instances of FahCore_78.exe running now and I got "Folding@home Core Shutdown: FILE_IO_ERROR". Sup with that?
edit2: I restarted the client and now I have 4 FahCore_a1.exe's running. Sup with that?
4. I'm currently running PS3, GPU and CPU but only the GPU workunit shows up in unitinfo.txt. Is that right?
[04:28:07]
[04:28:38] )
[04:28:38]
DanGe
- Hardware configuration: 2018 Mac Mini / MacOS Catalina
3.2 GHz 6-Core Intel Core i7 - Location: California, United States
Re: New to Folding, a few questions.
Hello radioattack and welcome to the forum.
1. Once work units are submitted, they stay permanently tied to your original username/team there. So unfortunately, you will not be able to receive credit for the work units you submitted as anon.
2. I don't know the answer, but I can tell you that we advise you not to use the viewer because it takes up so much CPU (and it's buggy for some people). To monitor your client, you should use a monitoring software (e.g. FahMon) from the Tools list.
3. FahCore_78.exe is a uniprocessor core and p2613 is a uniprocessor work unit. You probably forgot to add the necessary -smp flag in the beginning when you first got that WU and then added it afterward. My guess is that the client deleted your uniprocessor WU from the queue and picked up an SMP WU.
4. Your CPU work unit should also show up in its own unitinfo.txt too.
Zagen30
1. You can't transfer credit between usernames at this point in time. Any WUs you folded under a previous name will always be credited to that username. As long as the username you've entered for your PS3 and PC clients are exactly the same, they'll all be credited together. If you change teams it'll keep separate counts for each team you've folded under, but will also show your grand total.
2. Someone else can provide a technical answer much better than I can. I only know that the display doesn't really work, and shouldn't be used, not only because it's buggy but because it slows down folding progress drastically. If you want to see how fast your clients are performing, download a monitoring client. They use far fewer computer resources. I don't think any of them can monitor PS3s because the PS3 client doesn't let you access the log files.
3. No, SMP WUs use Core_a1 or Core_a2 (a2 WUs only for Mac and Linux clients). Did you initially configure the SMP client without using the -configonly flag? I believe that certain changes in the configuration only take place after the client has been shut down. If you start up the client for the first time without using -configonly, it'll allow you to input all of your preferences and then immediately go to work, but flags such as -smp don't take effect, and so when it then goes to download a WU it will grab a uniprocessor one. Nothing you can do about it except to finish it and make sure that you have the -smp flag set before it's turned in. Don't delete the uniprocessor WU because it'll take several weeks for the servers to assume it's not coming back, and in the meantime science will be held up.
Over an hour for a 3.6 GHz C2D sounds long, but I think that even if the SMP client is running uniprocessor cores it shouldn't open 4 of them. I'm not going to suggest anything since I don't rightly know why this would happen.
4. Each client is (well, should be) installed to a separate folder, and each client has its own separate files such as unitinfo.txt. Search for something like "Folding@home-Win64-x86.exe" to find the folder for the SMP client, and it'll have it's own unitinfo.txt.
radioattack
Thanks for the quick responses, guys, greatly appreciated.
I have another issue/question that popped up over night. When I first ran the GPU client everything seemed fine, took ~1 hour to complete the first WU, if I recall correctly, and my GPU was nice and hot. But now this morning it's running slooooow, I'm at 35% with FahMon reporting 5 hours left. GPU temps are low, just barely above normal idle. Feels like something isn't right. Any ideas?
edited to add: pausing or restarting the client doesn't change anything
DanGe
Could you post the contents of your log file (inside the tags)? Your GPU is probably working through work units from different projects.
radioattack
--- Opening Log file [March 28 02:23:03 UTC]
http://folding.stanford.edu
Launch directory: C:\Users\radio\AppData\Roaming\Folding@home-gpu
[02:24:15] - Ask before connecting: No
[02:24:15] - User name: radioattack (Team 0)
[02:24:15] - User ID not found locally
[02:24:15] + Requesting User ID from server
[02:24:16] - Machine ID: 2
[02:24:16]
[02:24:16] Work directory not found. Creating...
[02:24:16] Could not open work queue, generating new queue...
[02:24:16] Initialization complete
[02:24:16] - Preparing to get new work unit...
[02:24:16] + Attempting to get work packet
[02:24:16] - Connecting to assignment server
[02:24:16] - Successful: assigned to (171.64.65.106).
[02:24:16] + News From Folding@Home: GPU folding beta
[02:24:17] Loaded queue successfully.
[02:24:18] + Closed connections
[02:24:18]
[02:24:18] + Processing work unit
[02:24:18] Core required: FahCore_11.exe
[02:24:18] Core not found.
[02:24:18] - Core is not present or corrupted.
[02:24:18] - Attempting to download new core...
[02:24:18] + Downloading new core: FahCore_11.exe
[02:24:19] + 10240 bytes downloaded
[02:24:19] + 20480 bytes downloaded
[02:24:19] + 30720 bytes downloaded
[02:24:19] + 40960 bytes downloaded
[02:24:19] + 51200 bytes downloaded
[02:24:19] + 61440 bytes downloaded
[02:24:19] + 71680 bytes downloaded
[02:24:19] + 81920 bytes downloaded
[02:24:19] + 92160 bytes downloaded
[02:24:19] + 102400 bytes downloaded
[02:24:19] + 112640 bytes downloaded
[02:24:20] + 122880 bytes downloaded
[02:24:20] + 133120 bytes downloaded
[02:24:20] + 143360 bytes downloaded
[02:24:20] + 153600 bytes downloaded
[02:24:20] + 163840 bytes downloaded
[02:24:20] + 174080 bytes downloaded
[02:24:20] + 184320 bytes downloaded
[02:24:20] + 194560 bytes downloaded
[02:24:20] + 204800 bytes downloaded
[02:24:20] + 215040 bytes downloaded
[02:24:20] + 225280 bytes downloaded
[02:24:20] + 235520 bytes downloaded
[02:24:20] + 245760 bytes downloaded
[02:24:20] + 256000 bytes downloaded
[02:24:20] + 266240 bytes downloaded
[02:24:21] + 276480 bytes downloaded
[02:24:21] + 286720 bytes downloaded
[02:24:21] + 296960 bytes downloaded
[02:24:21] + 307200 bytes downloaded
[02:24:21] + 317440 bytes downloaded
[02:24:21] + 327680 bytes downloaded
[02:24:21] + 337920 bytes downloaded
[02:24:21] + 348160 bytes downloaded
[02:24:21] + 358400 bytes downloaded
[02:24:21] + 368640 bytes downloaded
[02:24:21] + 378880 bytes downloaded
[02:24:21] + 389120 bytes downloaded
[02:24:21] + 399360 bytes downloaded
[02:24:21] + 409600 bytes downloaded
[02:24:22] + 419840 bytes downloaded
[02:24:22] + 430080 bytes downloaded
[02:24:22] + 440320 bytes downloaded
[02:24:22] + 450560 bytes downloaded
[02:24:22] + 460800 bytes downloaded
[02:24:24] + 471040 bytes downloaded
[02:24:26] + 481280 bytes downloaded
[02:24:26] + 491520 bytes downloaded
[02:24:27] + 501760 bytes downloaded
[02:24:27] + 512000 bytes downloaded
[02:24:27] + 522240 bytes downloaded
[02:24:27] + 532480 bytes downloaded
[02:24:27] + 542720 bytes downloaded
[02:24:28] + 552960 bytes downloaded
[02:24:28] + 563200 bytes downloaded
[02:24:28] + 573440 bytes downloaded
[02:24:28] + 583680 bytes downloaded
[02:24:28] + 593920 bytes downloaded
[02:24:28] + 604160 bytes downloaded
[02:24:28] + 614400 bytes downloaded
[02:24:28] + 624640 bytes downloaded
[02:24:29] + 634880 bytes downloaded
[02:24:29] + 642475 bytes downloaded
[02:24:29] Verifying core Core_11.fah...
[02:24:29] Signature is VALID
[02:24:29]
[02:24:29] Trying to unzip core FahCore_11.exe
[02:24:29] Decompressed FahCore_11.exe (1843200 bytes) successfully
[02:24:34] + Core successfully engaged
[02:24:39]
[02:24:39] + Processing work unit
[02:24:39] Core required: FahCore_11.exe
[02:24:39] Core found.
[02:24:39] Working on queue slot 01 [March 28 02:24:39 UTC]
[02:24:39] + Working ...
[02:24:39]
[02:24:39] *------------------------------*
[02:24:39] Folding@Home GPU Core - Beta
[02:24:39] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[02:24:39]
[02:24:39] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[02:24:39] Build host: amoeba
[02:24:39] Board Type: Nvidia
[02:24:39] Core :
[02:24:39] Preparing to commence simulation
[02:24:39] - Looking at optimizations...
[02:24:39] - Created dyn
[02:24:39] - Files status OK
[02:24:39] - Expanded 66349 -> 348500 (decompressed 525.2 percent)
[02:24:39] Called DecompressByteArray: compressed_data_size=66349 data_size=348500, decompressed_data_size=348500 diff=0
[02:24:39] - Digital signature verified
[02:24:39]
[02:24:39] Project: 5779 (Run 6, Clone 4, Gen 21)
[02:24:39]
[02:24:39] Assembly optimizations on if available.
[02:24:39] Entering M.D.
[02:24:46] Working on Protein
[02:24:49] Client config found, loading data.
[02:24:49] Starting GUI Server
[02:26:23] Opening C:\Users\radio\AppData\Roaming\Folding@home-gpu\MyFolding.html...
[02:27:04] Completed 1%
[02:29:25] Completed 2%
[02:32:26] + Paused
[02:32:39] + Working ...
[02:32:40] Suspending work thread...
[02:32:40] Resuming work thread...
[02:32:56] Completed 3%
[02:34:45] Completed 4%
[02:36:36] Completed 5%
[02:38:27] Completed 6%
[02:40:15] Completed 7%
[02:42:04] Completed 8%
[02:43:53] Completed 9%
[02:45:42] Completed 10%
[02:47:30] Completed 11%
[02:47:39] Timer requesting checkpoint
[02:49:23] Completed 12%
[02:51:14] Completed 13%
[02:53:04] Completed 14%
[02:54:54] Completed 15%
[02:56:43] Completed 16%
[02:58:32] Completed 17%
[03:00:22] Completed 18%
[03:02:11] Completed 19%
[03:02:39] Timer requesting checkpoint
[03:04:01] Completed 20%
[03:05:53] Completed 21%
[03:07:49] Completed 22%
[03:09:41] Completed 23%
[03:11:33] Completed 24%
[03:13:24] Completed 25%
[03:15:16] Completed 26%
[03:17:07] Completed 27%
[03:17:39] Timer requesting checkpoint
[03:18:59] Completed 28%
[03:20:47] Completed 29%
[03:22:36] Completed 30%
[03:24:25] Completed 31%
[03:26:14] Completed 32%
[03:28:02] Completed 33%
[03:30:03] Completed 34%
[03:31:51] Completed 35%
[03:32:39] Timer requesting checkpoint
[03:33:39] Completed 36%
[03:35:28] Completed 37%
[03:37:19] Completed 38%
[03:39:09] Completed 39%
[03:41:01] Completed 40%
[03:42:50] Completed 41%
[03:44:38] Completed 42%
[03:46:27] Completed 43%
[03:47:39] Timer requesting checkpoint
[03:48:16] Completed 44%
[03:50:05] Completed 45%
[03:51:54] Completed 46%
[03:53:42] Completed 47%
[03:55:32] Completed 48%
[03:57:21] Completed 49%
[03:59:11] Completed 50%
[04:01:01] Completed 51%
[04:02:39] Timer requesting checkpoint
[04:02:50] Completed 52%
[04:04:40] Completed 53%
[04:06:31] Completed 54%
[04:07:45] Opening C:\Users\radio\AppData\Roaming\Folding@home-gpu\MyFolding.html...
[04:08:23] Completed 55%
[04:10:13] Completed 56%
[04:12:02] Completed 57%
[04:13:52] Completed 58%
[04:15:47] Completed 59%
[04:17:37] Completed 60%
[04:17:39] Timer requesting checkpoint
[04:19:34] Completed 61%
[04:21:30] Completed 62%
[04:23:20] Completed 63%
[04:25:16] Completed 64%
[04:27:15] Completed 65%
[04:29:12] Completed 66%
[04:31:16] Completed 67%
[04:32:39] Timer requesting checkpoint
[04:33:16] Completed 68%
[04:35:12] Completed 69%
[04:37:10] Completed 70%
[04:39:05] Completed 71%
[04:40:58] Completed 72%
[04:43:03] Completed 73%
[04:44:58] Completed 74%
[04:47:24] Completed 75%
[04:47:39] Timer requesting checkpoint
[04:49:19] Completed 76%
[04:51:15] Completed 77%
[04:53:09] Completed 78%
[04:54:59] Completed 79%
[04:56:49] Completed 80%
[04:58:40] Completed 81%
[05:00:31] Completed 82%
[05:02:28] Completed 83%
[05:02:39] Timer requesting checkpoint
[05:04:25] Completed 84%
[05:06:22] Completed 85%
[05:08:20] Completed 86%
[05:10:20] Completed 87%
[05:12:19] Completed 88%
[05:14:17] Completed 89%
[05:16:14] Completed 90%
[05:17:39] Timer requesting checkpoint
[05:18:17] Completed 91%
[05:20:16] Completed 92%
[05:22:17] Completed 93%
[05:24:17] Completed 94%
[05:26:17] Completed 95%
[05:26:40] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=radioattack...
[05:28:16] Completed 96%
[05:30:14] Completed 97%
[05:32:12] Completed 98%
[05:32:39] Timer requesting checkpoint
[05:34:10] Completed 99%
[05:36:08] Completed 100%
[05:36:09] Successful run
[05:36:09] DynamicWrapper: Finished Work Unit: sleep=10000
[05:36:19] Reserved 152368 bytes for xtc file; Cosm status=0
[05:36:19] Allocated 152368 bytes for xtc file
[05:36:19] - Reading up to 152368 from "work/wudata_01.xtc": Read 152368
[05:36:19] Read 152368 bytes from xtc file; available packet space=786278096
[05:36:19] xtc file hash check passed.
[05:36:19] Reserved 23232 23232 786278096 bytes for arc file=<work/wudata_01.trr> Cosm status=0
[05:36:19] Allocated 23232 bytes for arc file
[05:36:19] - Reading up to 23232 from "work/wudata_01.trr": Read 23232
[05:36:19] Read 23232 bytes from arc file; available packet space=786254864
[05:36:19] trr file hash check passed.
[05:36:19] Allocated 560 bytes for edr file
[05:36:19] Read bedfile
[05:36:19] edr file hash check passed.
[05:36:19] Allocated 16124 bytes for logfile
[05:36:19] Read logfile
[05:36:19] GuardedRun: success in DynamicWrapper
[05:36:19] GuardedRun: done
[05:36:19] Run: GuardedRun completed.
[05:36:21] - Writing 192796 bytes of core data to disk...
[05:36:21] Done: 192284 -> 181044 (compressed to 94.1 percent)
[05:36:21] ... Done.
[05:36:21] - Shutting down core
[05:36:21]
[05:36:21] Folding@home Core Shutdown: FINISHED_UNIT
[05:36:27] CoreStatus = 64 (100)
[05:36:27] Sending work to server
[05:36:27] Project: 5779 (Run 6, Clone 4, Gen 21)
[05:36:27] + Attempting to send results [March 28 05:36:27 UTC]
[05:36:32] + Results successfully sent
[05:36:32] Thank you for your contribution to Folding@Home.
[05:36:32] + Starting local stats count at 1
[05:36:36] - Preparing to get new work unit...
[05:36:36] + Attempting to get work packet
[05:36:36] - Connecting to assignment server
[05:36:37] - Successful: assigned to (171.64.65.106).
[05:36:37] + News From Folding@Home: GPU folding beta
[05:36:37] Loaded queue successfully.
[05:36:39] + Closed connections
[05:36:39]
[05:36:39] + Processing work unit
[05:36:39] Core required: FahCore_11.exe
[05:36:39] Core found.
[05:36:39] Working on queue slot 02 [March 28 05:36:39 UTC]
[05:36:39] + Working ...
[05:36:39]
[05:36:39] *------------------------------*
[05:36:39] Folding@Home GPU Core - Beta
[05:36:39] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[05:36:39]
[05:36:39] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:36:39] Build host: amoeba
[05:36:39] Board Type: Nvidia
[05:36:39] Core :
[05:36:39] Preparing to commence simulation
[05:36:39] - Looking at optimizations...
[05:36:39] - Created dyn
[05:36:39] - Files status OK
[05:36:39] - Expanded 66379 -> 348500 (decompressed 525.0 percent)
[05:36:39] Called DecompressByteArray: compressed_data_size=66379 data_size=348500, decompressed_data_size=348500 diff=0
[05:36:39] - Digital signature verified
[05:36:39]
[05:36:39] Project: 5777 (Run 14, Clone 13, Gen 17)
[05:36:39]
[05:36:39] Assembly optimizations on if available.
[05:36:39] Entering M.D.
[05:36:46] Working on Protein
[05:36:49] Client config found, loading data.
[05:36:49] Starting GUI Server
[05:38:50] Completed 1%
[05:39:51] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=radioattack...
[05:40:10] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=radioattack...
[05:40:16] Opening C:\Users\radio\AppData\Roaming\Folding@home-gpu\MyFolding.html...
[05:40:51] Completed 2%
[05:42:50] Completed 3%
[05:44:48] Completed 4%
[05:46:46] Completed 5%
[05:48:45] Completed 6%
[05:50:43] Completed 7%
[05:52:43] Completed 8%
[05:54:44] Completed 9%
[05:56:40] Completed 10%
[05:58:34] Completed 11%
[06:00:31] Completed 12%
[06:02:29] Completed 13%
[06:04:26] Completed 14%
[06:06:14] Completed 15%
[06:08:07] Completed 16%
[06:10:04] Completed 17%
[06:11:56] Completed 18%
[06:13:44] Completed 19%
[06:15:36] Completed 20%
[06:17:31] Completed 21%
[06:19:22] Completed 22%
[06:21:16] Completed 23%
[06:23:16] Completed 24%
[06:25:13] Completed 25%
[06:27:02] Completed 26%
[06:28:52] Completed 27%
[06:30:46] Completed 28%
[06:32:39] Completed 29%
[06:34:32] Completed 30%
[06:36:22] Completed 31%
[06:38:13] Completed 32%
[06:40:05] Completed 33%
[06:41:58] Completed 34%
[06:43:47] Completed 35%
[06:45:40] Completed 36%
[06:47:32] Completed 37%
[06:49:21] Completed 38%
[06:51:14] Completed 39%
[06:53:08] Completed 40%
[06:55:04] Completed 41%
[06:57:09] Completed 42%
[06:59:13] Completed 43%
[07:01:19] Completed 44%
[07:03:20] Completed 45%
[07:05:13] Completed 46%
[07:07:07] Completed 47%
[07:08:58] Completed 48%
[07:10:52] Completed 49%
[07:12:43] Completed 50%
[07:14:33] Completed 51%
[07:16:23] Completed 52%
[07:18:11] Completed 53%
[07:20:02] Completed 54%
[07:21:53] Completed 55%
[07:23:49] Completed 56%
[07:25:40] Completed 57%
[07:27:31] Completed 58%
[07:29:21] Completed 59%
[07:31:09] Completed 60%
[07:32:57] Completed 61%
[07:34:45] Completed 62%
[07:36:33] Completed 63%
[07:38:23] Completed 64%
[07:40:11] Completed 65%
[07:41:59] Completed 66%
[07:43:47] Completed 67%
[07:45:36] Completed 68%
[07:47:24] Completed 69%
[07:49:12] Completed 70%
[07:51:00] Completed 71%
[07:52:48] Completed 72%
[07:54:36] Completed 73%
[07:56:24] Completed 74%
[07:58:12] Completed 75%
[07:59:59] Completed 76%
[08:01:47] Completed 77%
[08:03:36] Completed 78%
[08:05:24] Completed 79%
[08:07:11] Completed 80%
[08:08:59] Completed 81%
[08:10:47] Completed 82%
[08:12:36] Completed 83%
[08:14:24] Completed 84%
[08:16:12] Completed 85%
[08:17:59] Completed 86%
[08:19:47] Completed 87%
[08:21:35] Completed 88%
[08:23:26] Completed 89%
[08:24:16] + Working...
[08:25:14] Completed 90%
[08:27:02] Completed 91%
[08:28:50] Completed 92%
[08:30:38] Completed 93%
[08:32:27] Completed 94%
[08:34:03] Completed 95%
[08:35:13] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=radioattack...
[08:35:39] Completed 96%
[08:37:12] Completed 97%
[08:38:43] Completed 98%
[08:40:14] Completed 99%
[08:41:45] Completed 100%
[08:41:45] Successful run
[08:41:45] DynamicWrapper: Finished Work Unit: sleep=10000
[08:41:55] Reserved 152776 bytes for xtc file; Cosm status=0
[08:41:55] Allocated 152776 bytes for xtc file
[08:41:55] - Reading up to 152776 from "work/wudata_02.xtc": Read 152776
[08:41:55] Read 152776 bytes from xtc file; available packet space=786277688
[08:41:55] xtc file hash check passed.
[08:41:55] Reserved 23232 23232 786277688 bytes for arc file=<work/wudata_02.trr> Cosm status=0
[08:41:55] Allocated 23232 bytes for arc file
[08:41:55] - Reading up to 23232 from "work/wudata_02.trr": Read 23232
[08:41:55] Read 23232 bytes from arc file; available packet space=786254456
[08:41:55] trr file hash check passed.
[08:41:55] Allocated 560 bytes for edr file
[08:41:55] Read bedfile
[08:41:55] edr file hash check passed.
[08:41:55] Allocated 23743 bytes for logfile
[08:41:55] Read logfile
[08:41:55] GuardedRun: success in DynamicWrapper
[08:41:55] GuardedRun: done
[08:41:55] Run: GuardedRun completed.
[08:41:57] - Writing 200823 bytes of core data to disk...
[08:41:57] Done: 200311 -> 182480 (compressed to 91.0 percent)
[08:41:57] ... Done.
[08:41:57] - Shutting down core
[08:41:57]
[08:41:57] Folding@home Core Shutdown: FINISHED_UNIT
[08:42:01] CoreStatus = 64 (100)
[08:42:01] Sending work to server
[08:42:01] Project: 5777 (Run 14, Clone 13, Gen 17)
[08:42:01] + Attempting to send results [March 28 08:42:01 UTC]
[08:42:06] + Results successfully sent
[08:42:06] Thank you for your contribution to Folding@Home.
[08:42:06] + Number of Units Completed: 2
[08:42:10] - Preparing to get new work unit...
[08:42:10] + Attempting to get work packet
[08:42:10] - Connecting to assignment server
[08:42:11] - Successful: assigned to (171.64.122.70).
[08:42:11] + News From Folding@Home: GPU folding beta
[08:42:11] Loaded queue successfully.
[08:42:13] + Closed connections
[08:42:13]
[08:42:13] + Processing work unit
[08:42:13] Core required: FahCore_14.exe
[08:42:13] Core not found.
[08:42:13] - Core is not present or corrupted.
[08:42:13] - Attempting to download new core...
[08:42:13] + Downloading new core: FahCore_14.exe
[08:42:14] + 10240 bytes downloaded
[08:42:14] + 20480 bytes downloaded
[08:42:14] + 30720 bytes downloaded
[08:42:14] + 40960 bytes downloaded
[08:42:14] + 51200 bytes downloaded
[08:42:14] + 61440 bytes downloaded
[08:42:14] + 71680 bytes downloaded
[08:42:14] + 81920 bytes downloaded
[08:42:14] + 92160 bytes downloaded
[08:42:14] + 102400 bytes downloaded
[08:42:14] + 112640 bytes downloaded
[08:42:14] + 122880 bytes downloaded
[08:42:14] + 133120 bytes downloaded
[08:42:14] + 143360 bytes downloaded
[08:42:14] + 153600 bytes downloaded
[08:42:15] + 163840 bytes downloaded
[08:42:15] + 174080 bytes downloaded
[08:42:16] + 184320 bytes downloaded
[08:42:16] + 194560 bytes downloaded
[08:42:16] + 204800 bytes downloaded
[08:42:16] + 215040 bytes downloaded
[08:42:16] + 225280 bytes downloaded
[08:42:16] + 235520 bytes downloaded
[08:42:16] + 245760 bytes downloaded
[08:42:16] + 256000 bytes downloaded
[08:42:16] + 266240 bytes downloaded
[08:42:16] + 276480 bytes downloaded
[08:42:16] + 286720 bytes downloaded
[08:42:16] + 296960 bytes downloaded
[08:42:17] + 307200 bytes downloaded
[08:42:17] + 317440 bytes downloaded
[08:42:17] + 327680 bytes downloaded
[08:42:17] + 337920 bytes downloaded
[08:42:17] + 348160 bytes downloaded
[08:42:17] + 358400 bytes downloaded
[08:42:17] + 368640 bytes downloaded
[08:42:17] + 378880 bytes downloaded
[08:42:17] + 389120 bytes downloaded
[08:42:17] + 399360 bytes downloaded
[08:42:17] + 409600 bytes downloaded
[08:42:17] + 419840 bytes downloaded
[08:42:17] + 430080 bytes downloaded
[08:42:18] + 440320 bytes downloaded
[08:42:20] + 450560 bytes downloaded
[08:42:23] + 460800 bytes downloaded
[08:42:23] + 471040 bytes downloaded
[08:42:24] + 481280 bytes downloaded
[08:42:24] + 491520 bytes downloaded
[08:42:24] + 501760 bytes downloaded
[08:42:24] + 512000 bytes downloaded
[08:42:24] + 522240 bytes downloaded
[08:42:25] + 532480 bytes downloaded
[08:42:25] + 542720 bytes downloaded
[08:42:25] + 552960 bytes downloaded
[08:42:25] + 563200 bytes downloaded
[08:42:25] + 565928 bytes downloaded
[08:42:25] Verifying core Core_14.fah...
[08:42:25] Signature is VALID
[08:42:25]
[08:42:25] Trying to unzip core FahCore_14.exe
[08:42:25] Decompressed FahCore_14.exe (1298432 bytes) successfully
[08:42:30] + Core successfully engaged
[08:42:35]
[08:42:35] + Processing work unit
[08:42:35] Core required: FahCore_14.exe
[08:42:35] Core found.
[08:42:35] Working on queue slot 03 [March 28 08:42:35 UTC]
[08:42:35] + Working ...
[08:42:35]
[08:42:35] *------------------------------*
[08:42:35] Folding@Home GPU Core - Beta
[08:42:35] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[08:42:35]
[08:42:35] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[08:42:35] Build host: vspm46
[08:42:35] Board Type: Nvidia
[08:42:35] Core :
[08:42:35] Preparing to commence simulation
[08:42:35] - Looking at optimizations...
[08:42:35] - Created dyn
[08:42:35] - Files status OK
[08:42:35] - Expanded 68438 -> 357580 (decompressed 522.4 percent)
[08:42:35] Called DecompressByteArray: compressed_data_size=68438 data_size=357580, decompressed_data_size=357580 diff=0
[08:42:35] - Digital signature verified
[08:42:35]
[08:42:35] Project: 5903 (Run 2, Clone 818, Gen 14)
[08:42:35]
[08:42:35] Assembly optimizations on if available.
[08:42:35] Entering M.D.
[08:42:41] Tpr hash work/wudata_03.tpr: 3409341533 3929024060 2879543244 1422370852 42005139
[08:42:41] Working on Protein
[08:42:42] Client config found, loading data.
[08:42:42] Starting GUI Server
[08:46:20] Completed 1%
[08:50:30] Completed 2%
[08:54:37] Completed 3%
[08:58:35] Completed 4%
[09:02:38] Completed 5%
[09:06:40] Completed 6%
[09:10:38] Completed 7%
[09:14:40] Completed 8%
[09:18:40] Completed 9%
[09:22:55] Completed 10%
[09:26:46] Completed 11%
[09:30:40] Completed 12%
[09:34:35] Completed 13%
[09:38:37] Completed 14%
[09:42:28] Completed 15%
[09:46:37] Completed 16%
[09:50:32] Completed 17%
[09:54:35] Completed 18%
[09:58:54] Completed 19%
[10:04:25] Completed 20%
[10:08:41] Completed 21%
[10:14:02] Completed 22%
[10:18:30] Completed 23%
[10:23:23] Completed 24%
[10:28:08] Completed 25%
[10:32:25] Completed 26%
[10:36:23] Completed 27%
[10:40:37] Completed 28%
[10:44:31] Completed 29%
[10:48:45] Completed 30%
[10:52:47] Completed 31%
[10:56:42] Completed 32%
[11:00:43] Completed 33%
[11:04:43] Completed 34%
[11:08:50] Completed 35%
[11:13:03] Completed 36%
[11:17:01] Completed 37%
[11:20:50] Completed 38%
[11:24:40] Completed 39%
[11:28:37] Completed 40%
[11:32:47] Completed 41%
[11:36:50] Completed 42%
[11:40:51] Completed 43%
[11:44:48] Completed 44%
[11:48:54] Completed 45%
[11:52:50] Completed 46%
[11:56:45] Completed 47%
[12:00:38] Completed 48%
[12:04:35] Completed 49%
[12:08:29] Completed 50%
[12:12:22] Completed 51%
[12:16:09] Completed 52%
[12:20:01] Completed 53%
[12:24:12] Completed 54%
[12:28:06] Completed 55%
[12:32:13] Completed 56%
[12:36:08] Completed 57%
[12:40:01] Completed 58%
[12:44:15] Completed 59%
[12:48:25] Completed 60%
[12:52:45] Completed 61%
[12:56:41] Completed 62%
[13:00:25] Completed 63%
[13:04:17] Completed 64%
[13:08:31] Completed 65%
[13:12:32] Completed 66%
[13:16:33] Completed 67%
[13:20:25] Completed 68%
[13:24:27] Completed 69%
[13:28:46] Completed 70%
[13:32:52] Completed 71%
[13:36:51] Completed 72%
[13:41:02] Completed 73%
[13:44:57] Completed 74%
[13:49:01] Completed 75%
[13:52:55] Completed 76%
[13:56:54] Completed 77%
[14:00:46] Completed 78%
[14:04:55] Completed 79%
[14:09:07] Completed 80%
[14:13:09] Completed 81%
[14:17:02] Completed 82%
[14:21:22] Completed 83%
[14:24:16] + Working...
[14:25:12] Completed 84%
[14:29:18] Completed 85%
[14:33:25] Completed 86%
[14:37:26] Completed 87%
[14:41:18] Completed 88%
[14:45:18] Completed 89%
[14:49:20] Completed 90%
[14:53:31] Completed 91%
[14:57:26] Completed 92%
[15:01:26] Completed 93%
[15:05:43] Completed 94%
[15:09:42] Completed 95%
[15:13:42] Completed 96%
[15:17:53] Completed 97%
[15:21:56] Completed 98%
[15:25:51] Completed 99%
[15:29:57] Completed 100%
[15:29:57] Successful run
[15:29:57] DynamicWrapper: Finished Work Unit: sleep=10000
[15:30:07] Reserved 33620 bytes for xtc file; Cosm status=0
[15:30:07] Allocated 33620 bytes for xtc file
[15:30:07] - Reading up to 33620 from "work/wudata_03.xtc": Read 33620
[15:30:07] Read 33620 bytes from xtc file; available packet space=786396844
[15:30:07] xtc file hash check passed.
[15:30:07] Reserved 23472 23472 786396844 bytes for arc file=<work/wudata_03.trr> Cosm status=0
[15:30:07] Allocated 23472 bytes for arc file
[15:30:07] - Reading up to 23472 from "work/wudata_03.trr": Read 23472
[15:30:07] Read 23472 bytes from arc file; available packet space=786373372
[15:30:07] trr file hash check passed.
[15:30:07] Allocated 560 bytes for edr file
[15:30:07] Read bedfile
[15:30:07] edr file hash check passed.
[15:30:07] Allocated 47737 bytes for logfile
[15:30:07] Read logfile
[15:30:07] GuardedRun: success in DynamicWrapper
[15:30:07] GuardedRun: done
[15:30:07] Run: GuardedRun completed.
[15:30:08] - Writing 105901 bytes of core data to disk...
[15:30:08] Done: 105389 -> 64325 (compressed to 61.0 percent)
[15:30:08] ... Done.
[15:30:08] - Shutting down core
[15:30:08]
[15:30:08] Folding@home Core Shutdown: FINISHED_UNIT
[15:30:11] CoreStatus = 64 (100)
[15:30:11] Sending work to server
[15:30:11] Project: 5903 (Run 2, Clone 818, Gen 14)
[15:30:11] + Attempting to send results [March 28 15:30:11 UTC]
[15:30:14] + Results successfully sent
[15:30:14] Thank you for your contribution to Folding@Home.
[15:30:14] + Number of Units Completed: 3
[15:30:18] - Preparing to get new work unit...
[15:30:18] + Attempting to get work packet
[15:30:18] - Connecting to assignment server
[15:30:18] - Successful: assigned to (171.64.122.70).
[15:30:18] + News From Folding@Home: GPU folding beta
[15:30:19] Loaded queue successfully.
[15:30:20] + Closed connections
[15:30:20]
[15:30:20] + Processing work unit
[15:30:20] Core required: FahCore_14.exe
[15:30:20] Core found.
[15:30:20] Working on queue slot 04 [March 28 15:30:20 UTC]
[15:30:20] + Working ...
[15:30:20]
[15:30:20] *------------------------------*
[15:30:20] Folding@Home GPU Core - Beta
[15:30:20] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[15:30:20]
[15:30:20] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:30:20] Build host: vspm46
[15:30:20] Board Type: Nvidia
[15:30:20] Core :
[15:30:20] Preparing to commence simulation
[15:30:20] - Looking at optimizations...
[15:30:20] - Created dyn
[15:30:20] - Files status OK
[15:30:20] - Expanded 68482 -> 357580 (decompressed 522.1 percent)
[15:30:20] Called DecompressByteArray: compressed_data_size=68482 data_size=357580, decompressed_data_size=357580 diff=0
[15:30:20] - Digital signature verified
[15:30:20]
[15:30:20] Project: 5904 (Run 8, Clone 354, Gen 5)
[15:30:20]
[15:30:20] Assembly optimizations on if available.
[15:30:20] Entering M.D.
[15:30:26] Tpr hash work/wudata_04.tpr: 737294885 2281520832 2221344994 1875770519 195765296
[15:30:27] Working on Protein
[15:30:27] Client config found, loading data.
[15:30:27] Starting GUI Server
[15:34:00] Completed 1%
[15:38:04] Completed 2%
[15:41:52] Completed 3%
[15:45:46] Completed 4%
[15:49:48] Completed 5%
[15:53:46] Completed 6%
[15:57:38] Completed 7%
[16:01:38] Completed 8%
[16:05:38] Completed 9%
[16:09:41] Completed 10%
[16:13:36] Completed 11%
[16:17:43] Completed 12%
[16:21:42] Completed 13%
[16:25:47] Completed 14%
[16:29:49] Completed 15%
[16:33:47] Completed 16%
[16:37:46] Completed 17%
[16:41:45] Completed 18%
[16:45:50] Completed 19%
[16:50:01] Completed 20%
[16:53:51] Completed 21%
[16:57:49] Completed 22%
[17:02:00] Completed 23%
[17:05:54] Completed 24%
[17:10:20] Completed 25%
[17:14:18] Completed 26%
[17:18:26] Completed 27%
[17:19:17] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=radioattack...
[17:23:08] Completed 28%
[17:27:16] Completed 29%
[17:31:29] Completed 30%
[17:34:13] Opening C:\Users\radio\AppData\Roaming\Folding@home-gpu\MyFolding.html...
[17:35:17] Completed 31%
[17:39:17] Completed 32%
[17:43:43] Completed 33%
[17:44:02] + Paused
[17:44:30] + Working ...
[17:44:31] Suspending work thread...
[17:44:31] Resuming work thread...
Folding@Home Client Shutdown.
--- Opening Log file [March 28 17:47:21 UTC]
[17:47:21] - Ask before connecting: No
[17:47:21] - User name: radioattack (Team 0)
[17:47:21] - User ID: 79F773A16C39C734
[17:47:21] - Machine ID: 2
[17:47:21]
[17:47:21] Loaded queue successfully.
[17:47:21] Initialization complete
[17:47:21]
[17:47:21] + Processing work unit
[17:47:21] Core required: FahCore_14.exe
[17:47:21] Core found.
[17:47:21] Working on queue slot 04 [March 28 17:47:21 UTC]
[17:47:21] + Working ...
[17:47:21] + Working...
[17:47:21]
[17:47:21] *------------------------------*
[17:47:21] Folding@Home GPU Core - Beta
[17:47:21] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[17:47:21]
[17:47:21] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[17:47:21] Build host: vspm46
[17:47:21] Board Type: Nvidia
[17:47:21] Core :
[17:47:21] Preparing to commence simulation
[17:47:21] - Looking at optimizations...
[17:47:21] - Files status OK
[17:47:21] - Expanded 68482 -> 357580 (decompressed 522.1 percent)
[17:47:21] Called DecompressByteArray: compressed_data_size=68482 data_size=357580, decompressed_data_size=357580 diff=0
[17:47:21] - Digital signature verified
[17:47:21]
[17:47:21] Project: 5904 (Run 8, Clone 354, Gen 5)
[17:47:21]
[17:47:21] Assembly optimizations on if available.
[17:47:21] Entering M.D.
[17:47:27] Will resume from checkpoint file
[17:47:27] Tpr hash work/wudata_04.tpr: 737294885 2281520832 2221344994 1875770519 195765296
[17:47:27] Working on Protein
[17:47:28] Client config found, loading data.
[17:47:28] Resuming from checkpoint
[17:47:28] fcCheckPointResume: retrieved and current tpr file hash:
[17:47:28] 0 737294885 737294885
[17:47:28] 1 2281520832 2281520832
[17:47:28] 2 2221344994 2221344994
[17:47:28] 3 1875770519 1875770519
[17:47:28] 4 195765296 195765296
[17:47:28] Verified work/wudata_04.log
[17:47:28] Verified work/wudata_04.edr
[17:47:28] Verified work/wudata_04.xtc
[17:47:28] Completed 33%
[17:47:28] Starting GUI Server
[17:51:10] Completed 34%
[17:55:45] Completed 35%
[18:00:47] Completed 36%
[18:05:53] Completed 37%
[18:06:30] Opening C:\Users\radio\AppData\Roaming\Folding@home-gpu\MyFolding.html...
[18:11:06] Completed 38%
[18:16:00] Completed 39%
[18:21:03] Completed 40%
[18:26:04] Completed 41%
[18:31:34] Completed 42%
[18:34:09] Opening C:\Users\radio\AppData\Roaming\Folding@home-gpu\MyFolding.html...
[18:36:44] Completed 43%
[18:41:31] Completed 44%
[18:46:33] Completed 45%
[18:51:41] Completed 46%
[18:56:48] Completed 47%
[19:02:07] Completed 48%
[19:03:12] Opening C:\Users\radio\AppData\Roaming\Folding@home-gpu\MyFolding.html...
[19:07:07] Completed 49%
[19:12:15] Completed 50%
[19:17:11] Completed 51%
[19:18:43] + Paused
--- Opening Log file [March 28 19:57:16 UTC]
[19:57:16] - Ask before connecting: No
[19:57:16] - User name: radioattack (Team 0)
[19:57:16] - User ID: 79F773A16C39C734
[19:57:16] - Machine ID: 2
[19:57:16]
[19:57:16] Loaded queue successfully.
[19:57:16] Initialization complete
[19:57:16]
[19:57:16] + Processing work unit
[19:57:16] Core required: FahCore_14.exe
[19:57:16] Core found.
[19:57:16] Working on queue slot 04 [March 28 19:57:16 UTC]
[19:57:16] + Working ...
[19:57:17]
[19:57:17] *------------------------------*
[19:57:17] Folding@Home GPU Core - Beta
[19:57:17] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[19:57:17]
[19:57:17] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:57:17] Build host: vspm46
[19:57:17] Board Type: Nvidia
[19:57:17] Core :
[19:57:17] Preparing to commence simulation
[19:57:17] - Ensuring status. Please wait.
[19:57:26] - Looking at optimizations...
[19:57:26] - Working with standard loops on this execution.
[19:57:26] - Previous termination of core was improper.
[19:57:26] - Files status OK
[19:57:26] - Expanded 68482 -> 357580 (decompressed 522.1 percent)
[19:57:26] Called DecompressByteArray: compressed_data_size=68482 data_size=357580, decompressed_data_size=357580 diff=0
[19:57:26] - Digital signature verified
[19:57:26]
[19:57:26] Project: 5904 (Run 8, Clone 354, Gen 5)
[19:57:26]
[19:57:27] Entering M.D.
[19:57:33] Will resume from checkpoint file
[19:57:33] Tpr hash work/wudata_04.tpr: 737294885 2281520832 2221344994 1875770519 195765296
[19:57:33] Working on Protein
[19:57:34] Client config found, loading data.
[19:57:34] Resuming from checkpoint
[19:57:34] fcCheckPointResume: retrieved and current tpr file hash:
[19:57:34] 0 737294885 737294885
[19:57:34] 1 2281520832 2281520832
[19:57:34] 2 2221344994 2221344994
[19:57:34] 3 1875770519 1875770519
[19:57:34] 4 195765296 195765296
[19:57:34] Verified work/wudata_04.log
[19:57:34] Verified work/wudata_04.edr
[19:57:34] Verified work/wudata_04.xtc
[19:57:34] Completed 51%
[19:57:34] Starting GUI Server
DanGe
Yeah, you're just getting different-sized WUs. The the p5903's are larger and take more time, and are thus worth more.
radioattack
I figured that was the case but the temp thing doesn't make any sense to me. It's running right now but you couldn't tell by the GPU temps. When doing SETI CUDA WU's it'll get dangerously hot unless I crank the fan up.
Thanks again for the help.
DanGe
Forgot to mention this: the p590x projects use a different core and do not appear to push the GPU that hard (not sure if that's really the case). That would explain your temperatures (I get lower temps on these work units).
More info on the new core 14: viewtopic.php?f=52&t=8734
There have since been four new projects using this new core and the core has since rolled out of advmethods testing.
