Project 3064 (Run 2, Clone 204, Generation 17)
klasseng
Hardware configuration: System 1: Mac Studio, M1 Max,
System 2: Mac Mini, M2
Post by klasseng »
Early end:
[02:10:39] Completed 3900000 out of 5000000 steps  (78 percent)
[02:26:17] Writing local files
[02:26:17] Completed 3950000 out of 5000000 steps  (79 percent)
[02:41:54] Writing local files
[02:41:54] Completed 4000000 out of 5000000 steps  (80 percent)
[02:57:30] Writing local files
[02:57:30] Completed 4050000 out of 5000000 steps  (81 percent)
[03:13:07] Warning:  long 1-4 interactions
[0]0:Return code = 0, signaled with Segmentation fault
[0]1:Return code = 0, signaled with Quit
[0]2:Return code = 0, signaled with Segmentation fault
[0]3:Return code = 0, signaled with Segmentation fault
[03:13:11] CoreStatus = 0 (0)
[03:13:11] Sending work to server
[03:13:11] Project: 3064 (Run 2, Clone 204, Gen 17)
[03:13:11] - Error: Could not get length of results file work/wuresults_01.dat
[03:13:11] - Error: Could not read unit 01 file. Removing from queue.
81% done, no points?
peace,
Grant
MstrBlstr
Re: Project 3064 (Run 2, Clone 204, Generation 17)
Post by MstrBlstr »
Looks like the results file was corrupt. So it could not read it and just deleted it. It never actually sent anything. So, no points.
-=MB=-
susato
Post by susato »
Hi Grant,
Rats, that's a bummer. You appear to be the first person who has received this unit.
Unfortunately when the unit ends like this, no points are awarded since nothing is sent back. If your machine has begun folding this unit again, try stopping it, especially when it gets near the previous failure point, and restarting. Sometimes that's enough to get the unit past the sticking point and allow it to complete.
Also, check which version of the FahCore_a2.exe you have. If it's version 2.01 or 2.02, trash it at the end of a work unit or while you are running a Core_a1 work unit. The newer version, version 2.04, will download when needed. Its error handling is better than the earlier versions though still not perfect. Don't replace the core in the middle of a work unit though, because version 2.04 can't finish out a work unit begun by a older version.
Hope that helps and that you are able to finish the unit on the second try.
