Project: 3065 (Run 3, Clone 141, Gen 46)
bollix47
Post by bollix47 »
FYI
[17:02:41] + Processing work unit
[17:02:41] Work type a1 not eligible for variable processors
[17:02:41] Core required: FahCore_a1.exe
[17:02:41] Core found.
[17:02:41] Working on queue slot 02 [March 24 17:02:41 UTC]
[17:02:41] + Working ...
[17:02:41] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 02 -checkpoint 30 -forceasm -verbose -lifeline 533 -version 624'
[17:02:41]
[17:02:41] *------------------------------*
[17:02:41] Folding@Home Gromacs SMP Core
[17:02:41] Version 1.74 (November 27, 2006)
[17:02:41]
[17:02:41] Preparing to commence simulation
[17:02:41] - Ensuring status. Please wait.
[17:02:59] - Assembly optimizations manually forced on.
[17:02:59] - Not checking prior termination.
[17:02:59] - Expanded 1649963 -> 9524377 (decompressed 577.2 percent)
[17:02:59] - Starting from initial work packet
[17:02:59]
[17:02:59] Project: 3065 (Run 3, Clone 141, Gen 46)
[17:02:59]
[17:02:59] Assembly optimizations on if available.
[17:02:59] Entering M.D.
[17:03:05] Rejecting checkpoint
[17:03:06] Protein: 66728 p3065_lambda5_99sb_bigExtra SSE boost OK.
[17:03:06]
[17:03:06] Extra SSE boost OK.
[17:03:06] Writing local files
[17:03:06] Completed 0 out of 2500000 steps  (0 percent)
[17:15:22] Writing local files
[17:15:22] Completed 25000 out of 2500000 steps  (1 percent)
[17:27:31] Writing local files
[17:27:31] Completed 50000 out of 2500000 steps  (2 percent)
[17:39:40] Writing local files
[17:39:40] Completed 75000 out of 2500000 steps  (3 percent)
[17:52:06] Writing local files
[17:52:06] Completed 100000 out of 2500000 steps  (4 percent)
[17:59:53] Warning:  long 1-4 interactions
[17:59:57] CoreStatus = 0 (0)
[17:59:57] Sending work to server
[17:59:57] Project: 3065 (Run 3, Clone 141, Gen 46)
[17:59:57] - Error: Could not get length of results file work/wuresults_02.dat
[17:59:57] - Error: Could not read unit 02 file. Removing from queue.
[17:59:57] Trying to send all finished work units
[17:59:57] + No unsent completed units remaining.
[17:59:57] - Preparing to get new work unit...
[17:59:57] + Attempting to get work packet
[17:59:57] - Will indicate memory of 991 MB
[17:59:57] - Connecting to assignment server
[17:59:57] Connecting to http://assign.stanford.edu:8080/
[17:59:57] Posted data.
[17:59:57] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[17:59:57] + News From Folding@Home: Welcome to Folding@Home
[17:59:57] Loaded queue successfully.
[17:59:57] Connecting to http://171.64.65.63:8080/
[18:00:00] Posted data.
[18:00:00] Initial: 0000; - Receiving payload (expected size: 1650475)
[18:00:03] - Downloaded at ~537 kB/s
[18:00:03] - Averaged speed for that direction ~477 kB/s
[18:00:03] + Received work.
[18:00:03] Trying to send all finished work units
[18:00:03] + No unsent completed units remaining.
[18:00:03] + Closed connections
[18:00:08]
[18:00:08] + Processing work unit
[18:00:08] Work type a1 not eligible for variable processors
[18:00:08] Core required: FahCore_a1.exe
[18:00:08] Core found.
[18:00:08] Working on queue slot 03 [March 24 18:00:08 UTC]
[18:00:08] + Working ...
[18:00:08] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 03 -checkpoint 30 -forceasm -verbose -lifeline 533 -version 624'
[18:00:08]
[18:00:08] *------------------------------*
[18:00:08] Folding@Home Gromacs SMP Core
[18:00:08] Version 1.74 (November 27, 2006)
[18:00:08]
[18:00:08] Preparing to commence simulation
[18:00:08] - Ensuring status. Please wait.
[18:00:25] - Assembly optimizations manually forced on.
[18:00:25] - Not checking prior termination.
[18:00:26] - Expanded 1649963 -> 9524377 (decompressed 577.2 percent)
[18:00:26] - Starting from initial work packet
[18:00:26]
[18:00:26] Project: 3065 (Run 3, Clone 141, Gen 46)
[18:00:26]
[18:00:26] Assembly optimizations on if available.
[18:00:26] Entering M.D.
[18:00:32] Rejecting checkpoint
[18:00:32] Protein: 66728 p3065_lambda5_99sb_bigExtra SSE boost OK.
[18:00:32]
[18:00:32] Extra SSE boost OK.
[18:00:32] Writing local files
[18:00:32] Completed 0 out of 2500000 steps  (0 percent)
[18:12:41] Writing local files
[18:12:41] Completed 25000 out of 2500000 steps  (1 percent)
[18:25:00] Writing local files
[18:25:00] Completed 50000 out of 2500000 steps  (2 percent)
[18:37:26] Writing local files
[18:37:26] Completed 75000 out of 2500000 steps  (3 percent)
[18:49:48] Writing local files
[18:49:48] Completed 100000 out of 2500000 steps  (4 percent)
[18:57:38] Warning:  long 1-4 interactions
[18:57:42] CoreStatus = 0 (0)
[18:57:42] Sending work to server
[18:57:42] Project: 3065 (Run 3, Clone 141, Gen 46)
[18:57:42] - Error: Could not get length of results file work/wuresults_03.dat
[18:57:42] - Error: Could not read unit 03 file. Removing from queue.
[18:57:42] Trying to send all finished work units
[18:57:42] + No unsent completed units remaining.
[18:57:42] - Preparing to get new work unit...
[18:57:42] + Attempting to get work packet
[18:57:42] - Will indicate memory of 991 MB
[18:57:42] - Connecting to assignment server
[18:57:42] Connecting to http://assign.stanford.edu:8080/
[18:57:43] Posted data.
[18:57:43] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[18:57:43] + News From Folding@Home: Welcome to Folding@Home
[18:57:43] Loaded queue successfully.
[18:57:43] Connecting to http://171.64.65.64:8080/
[18:57:44] Posted data.
[18:57:45] Initial: 0000; - Receiving payload (expected size: 1157354)
[18:57:47] - Downloaded at ~565 kB/s
[18:57:47] - Averaged speed for that direction ~495 kB/s
[18:57:47] + Received work.
[18:57:47] Trying to send all finished work units
[18:57:47] + No unsent completed units remaining.
[18:57:47] + Closed connections
[18:57:52]
[18:57:52] + Processing work unit
[18:57:52] Work type a1 not eligible for variable processors
[18:57:52] Core required: FahCore_a1.exe
[18:57:52] Core found.
[18:57:52] Working on queue slot 04 [March 24 18:57:52 UTC]
[18:57:52] + Working ...
[18:57:52] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 04 -checkpoint 30 -forceasm -verbose -lifeline 533 -version 624'
[18:57:52]
[18:57:52] *------------------------------*
[18:57:52] Folding@Home Gromacs SMP Core
[18:57:52] Version 1.74 (November 27, 2006)
[18:57:52]
[18:57:52] Preparing to commence simulation
[18:57:52] - Ensuring status. Please wait.
[18:58:09] - Assembly optimizations manually forced on.
[18:58:09] - Not checking prior termination.
[18:58:10] - Expanded 1156842 -> 6173133 (decompressed 533.6 percent)
[18:58:10] - Starting from initial work packet
[18:58:10]
Tried the WU twice and then moved on to a different one.
Re: Project: 3065 (Run 3, Clone 141, Gen 46)
There's no data for this WU in the DB yet.
