Project: 2665 (Run 3, Clone 94, Gen 96) Long Interactions
Oldhat
Post by Oldhat »
Just having a few problems with this WU.
q6600, 2048MB RAM, notfred's Linux CD FAH Client 6.02
Getting user SigTerm shutdown at 10% and after restarting it then gives 1-4 long Interactions
at 25% completion.
Have failed to complete the run twice now with exactly the same results.
I'll see if I can complete on a different PC, unless of course someone else has already succeeded in completing it.
Attempted to run on a different PC with same specs as above and this failed at 12% with a client core communications error.
Cheers.
susato
Re: Project: 2665 (Run 3, Clone 94, Gen 96) Long Interactions
Post by susato »
5 people have failed to complete this WU, getting partial credit. Others like yourself may have tried and had the WU deleted without producing any points. I've marked it a bad WU.
Thank you for your report.
