Project: 2497 (Run 0, Clone 15, Gen 0)
codysluder
Post by codysluder »
[01:19:24] Completed 137500 out of 250000 steps  (55)
[02:08:51] Writing local files
[02:08:52] Completed 140000 out of 250000 steps  (56)
[02:58:22] Writing local files
[02:58:23] Completed 142500 out of 250000 steps  (57)
[06:13:23] At least 3 hours since checkpoint written...
[06:13:23]
[06:13:23] Folding@home Core Shutdown: EARLY_UNIT_END
[06:13:26] CoreStatus = 72 (114)
[06:13:26] Sending work to server
[06:13:26] - Error: Could not get length of results file work/wuresults_05.dat
[06:13:26] - Error: Could not read unit 05 file. Removing from queue.
I have a second client running on the other core and it's still processing normally so whatever caused the WU to hang probably isn't a problem with the computer, especially since I've had no troubles with this computer at all.
Re: Project: 2497 (Run 0, Clone 15, Gen 0)
There are 10 reports for EUE in the DB, I've marked the WU as a bad one ...
