WU named 'system'
Kuptis
WU named 'system'
Post by Kuptis »
For CPU1 my first WU was named 'system'. It finished and now I have another WU also named 'system' also on CPU1. I just created a CPU2 directory and it shows a name 'p4446_Seq45_Amber03'. CPU1 is configured for 'big' whereas CPU2 is configured for 'normal'. Other than that why the discrepancy in the names?
John Naylor
Hardware configuration: Q9450 OC @ 3.2GHz (Win7 Home Premium) - SMP2
i5-3750k @ 3.8GHz (Win7 Pro) - SMP2
Re: WU named 'system'
Post by John Naylor »
Welcome to the forums. :)
The researcher that created the project displaying "system" presumably forgot to put in the proper protein name (it's different for each of the many different projects). It's nothing to worry about, but is a pain if you want to know exactly what proteins you're folding :)
Folding whatever I'm sent since March 2006 :) Beta testing since October 2006. www.FAH-Addict.net Administrator since August 2009.
Kuptis
Post by Kuptis »
OK. Thanks. Didn't know if that was a problem or not.
I did notice in the unitinfo.txt file there is a tag line which compared with the name on a WU that has a name:
Tag: P4446R812C2G7
And if I open the progress in a window or even in the FAHlog.txt it shows by how they are recorded like in the forums such as: Project: 4446 (Run 812, Clone 2, Gen 7). Which I just realized that's how the tag is set up since this matches the tag above and is the same WU.
I think this should be added as a FAQ or given in the instructions somewhere.
Where did you see the name "system"? Was that in the Viewer or perhaps in a 3rd party monitoring program? Was it in unitinfo.txt?
In the only data you posted (for CPU2), I see Name: p4446_Seq45_Amber03 which is correct. A snippet from CPU1's FAHlog.txt would be helpful.
"System" WUs are p2465 to p2499 from 171.65.103.160 ...
Kuptis
Post by Kuptis »
bruce wrote:Where did you see the name "system"? Was that in the Viewer or perhaps in a 3rd party monitoring program? Was it in unitinfo.txt?
It's in unitinfo.txt.
bruce wrote:In the only data you posted (for CPU2), I see Name: p4446_Seq45_Amber03 which is correct. A snippet from CPU1's FAHlog.txt would be helpful.
I just started and learned that they have names and tags (such as in unitinfo.txt). The name is showing 'system' but the tag shows PaaRbbCccGdd which equals Project: aa (Run: bb, Clone: cc, Gen: dd) which is really how they're referenced.
FAHlog-Prev.txt:
[01:06:10]
[01:06:10] *------------------------------*
[01:06:10] Folding@Home Gromacs Core
[01:06:10] Version 1.90 (March 8, 2006)
[01:06:10]
[01:06:10] Preparing to commence simulation
[01:06:10] - Looking at optimizations...
[01:06:10] - Created dyn
[01:06:10] - Files status OK
[01:06:12] - Expanded 2962148 -> 15097085 (decompressed 509.6 percent)
[01:06:12] - Starting from initial work packet
[01:06:12]
[01:06:12] Project: 2484 (Run 114, Clone 22, Gen 14)
[01:06:12]
[01:06:12] Assembly optimizations on if available.
[01:06:12] Entering M.D.
[01:06:21] Protein: system
[01:06:21]
[01:06:21] Writing local files
[01:06:22] Extra SSE boost OK.
[01:06:24] Writing local files
[01:06:24] Completed 0 out of 250000 steps  (0%)
Notice above you first see the project how it's referenced and then a few lines down it shows the protein name as 'Protein: system'.
