Project: 5902 (Run 6, Clone 449, Gen 16)
Amaruk
Post by Amaruk »
Card is 8800 GT 256MB G92 at vendor clocks - 700/750/1700
X2 5600 @ 2.9 Ghz, 4 gb PC2-6400, XP Pro32 SP2, MSI K9A2 Platinum, 6.20 Systray, 178.08 drivers
[02:58:59] Project: 5902 (Run 6, Clone 449, Gen 16)
[02:58:59]
[02:58:59] Assembly optimizations on if available.
[02:58:59] Entering M.D.
[02:59:05] Tpr hash work/wudata_02.tpr:  2570213145 282718595 1273994961 3539747061 3044258223
[02:59:06] Working on Protein
[02:59:07] Client config found, loading data.
[02:59:07] Starting GUI Server
[03:04:47] Completed 1%
<snip>
[10:55:48] Completed 76%
[11:02:07] SEH code: 3221225477
[11:02:07] Run: exception thrown during GuardedRun
[11:02:07] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[11:02:07] Going to send back what have done -- stepsTotalG=8000000
[11:02:07] Work fraction=0.7691 steps=8000000.
[11:02:11] logfile size=132289 infoLength=132289 edr=0 trr=23
[11:02:11] - Writing 132825 bytes of core data to disk...
[11:02:11] Done: 132313 -> 6398 (compressed to 4.8 percent)
[11:02:11]   ... Done.
[11:02:11]
[11:02:11] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:02:15] CoreStatus = 7A (122)
[11:02:15] Sending work to server
[11:02:15] Project: 5902 (Run 6, Clone 449, Gen 16)
[11:02:15] - Read packet limit of 540015616... Set to 524286976.
[11:02:15] + Attempting to send results [March 21 11:02:15 UTC]
[11:02:15] - Reading file work/wuresults_02.dat from core
[11:02:15]   (Read 6910 bytes from disk)
[11:02:15] Connecting to http://171.64.122.70:8080/
[11:02:15] Posted data.
[11:02:15] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[11:02:15] - Uploaded at ~15 kB/s
[11:02:15] - Averaged speed for that direction ~49 kB/s
[11:02:15] + Results successfully sent
[11:02:15] Thank you for your contribution to Folding@Home.
Re: Project: 5902 (Run 6, Clone 449, Gen 16)
Hi Amaruk (team 50625),
Your WU (P5902 R6 C449 G16) was added to the stats database on 2009-03-21 04:07:50 for 1292.14 points of credit.
There's no other report in the DB, but ihaque is monitoring closely each EUE, so you don't have to worry.
