Project: 3064 (Run 2, Clone 288, Gen 21) CoreStatus = 0 (0)
parkut
Post by parkut »
This WU failed twice at the same 3% completed stage. The machine
has since moved on to a different WU
model name : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
cpu MHz : 2394.000
cache size : 4096 KB
Memory: 1.94 GB physical, 1.94 GB virtual
Client Version 6.24beta
Core: FahCore_a1.exe
Core Version 1.74 (November 27, 2006)
[06:28:56] Project: 3064 (Run 2, Clone 288, Gen 21)
[06:28:57] Entering M.D.
[06:29:03] 3064_lambda5_2003
[06:29:03] Writing local files
[06:29:03] Extra SSE boost OK.
[06:29:03] Completed 0 out of 5000000 steps  (0 percent)
[06:39:08] Writing local files
[06:39:08] Completed 50000 out of 5000000 steps  (1 percent)
[06:49:10] Writing local files
[06:49:10] Completed 100000 out of 5000000 steps  (2 percent)
[06:59:16] Writing local files
[06:59:16] Completed 150000 out of 5000000 steps  (3 percent)
[07:08:25] Warning:  long 1-4 interactions
[07:08:29] CoreStatus = 0 (0)
[07:08:29] Sending work to server
[07:08:29] Project: 3064 (Run 2, Clone 288, Gen 21)
[07:08:29] - Error: Could not get length of results file work/wuresults_08.dat
[07:08:29] - Error: Could not read unit 08 file. Removing from queue.
[07:08:29] Trying to send all finished work units
[07:08:29] + No unsent completed units remaining.
parkut
Re: Project: 3064 (Run 2, Clone 288, Gen 21) CoreStatus = 0 (0)
Post by parkut »
The same WU was assigned to me again. Ran twice more with failure at the same point.
cpu MHz : 2394.000
[22:31:52] Project: 3064 (Run 2, Clone 288, Gen 21)
[22:31:52]
[22:31:52] Entering M.D.
[22:31:58] 3064_lambda5_2003Extra SSE boost OK.
[22:31:58]
[22:31:58] Extra SSE boost OK.
[22:31:58] Writing local files
[22:31:58] Completed 0 out of 5000000 steps  (0 percent)
[22:42:05] Writing local files
[22:42:05] Completed 50000 out of 5000000 steps  (1 percent)
[22:52:07] Writing local files
[22:52:07] Completed 100000 out of 5000000 steps  (2 percent)
[23:02:08] Writing local files
[23:02:08] Completed 150000 out of 5000000 steps  (3 percent)
[23:11:17] Warning:  long 1-4 interactions
[23:11:21] CoreStatus = 0 (0)
[23:11:21] Sending work to server
[23:11:21] Project: 3064 (Run 2, Clone 288, Gen 21)
[23:11:21] - Error: Could not get length of results file work/wuresults_04.dat
[23:11:21] - Error: Could not read unit 04 file. Removing from queue.
[23:11:21] Trying to send all finished work units
[23:11:21] + No unsent completed units remaining.
There's no data in the DB for this WU. I've marked it as a bad one.
