Quick question on client.cfg
WangFeiHong
Post by WangFeiHong »
strictly speaking, Is the editing of the client.cfg against the Folding@Home license? E.g. changing MachineID through client.cfg instead of -configonly
"You may not alter the software or associated data files."
MtM
Hardware configuration: Q6600 - 8gb - p5q deluxe - gtx275 - hd4350 ( not folding ) win7 x64 - smp:4 - gpu slot
T5450 - 4gb - ?? - 8600M GT 512 ( DDR2 ) - win7 x64 - smp:2 - gpu slot
Re: Quick question on client.cfg
Post by MtM »
I think it's more a question of if direct edits will always be fail safe. clients.cfg uses chr(10) as linebreak as opposed to chr(13) or chr(10) & chr(13) and it might confuse people trying to edit with notepad. Using the clients built in configuration options is just fail safe.
I think I was told it's also not allowed when I made a gui for editing settings for client settings which directly wrote to the cfg file but I'm not sure if I remember that 100% clearly, I do clearly recall the above as a strong point to discourage it as alternative. It's is an associated data file, even if it's not directly the targer of the statement I think ( that would afaik be more aimed at editing wuresults ( creating fake one's ) or altering the clients themselfs to prevent downloading newer core revisions for instance.
Editing the config.cfg is not recommended because of the reasons described by MtM : manual edit often breaks the formatting, and resets client configuration.
Strictly speaking, yes. Editing the client.cfg file is against the EULA. Use -config, or -configonly.
