Project: 5900 (Run 0, Clone 220, Gen 34)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Another EUE on the Lenovo (I have done some successfully!).
[11:57:17] + Closed connections
[11:57:22]
[11:57:22] + Processing work unit
[11:57:22] Core required: FahCore_14.exe
[11:57:22] Core found.
[11:57:22] Working on queue slot 03 [March 14 11:57:22 UTC]
[11:57:22] + Working ...
[11:57:22] - Calling '.\FahCore_14.exe -dir work/ -suffix 03 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 4788 -version 620'
[11:57:22]
[11:57:22] *------------------------------*
[11:57:22] Folding@Home GPU Core - Beta
[11:57:22] Version 1.24 (Mon Mar 2 19:49:32 PST 2009)
[11:57:22]
[11:57:22] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:57:22] Build host: vspm46
[11:57:22] Board Type: Nvidia
[11:57:22] Core      :
[11:57:22] Preparing to commence simulation
[11:57:22] - Looking at optimizations...
[11:57:22] - Created dyn
[11:57:22] - Files status OK
[11:57:22] - Expanded 70207 -> 360060 (decompressed 512.8 percent)
[11:57:22] Called DecompressByteArray: compressed_data_size=70207 data_size=360060, decompressed_data_size=360060 diff=0
[11:57:22] - Digital signature verified
[11:57:22]
[11:57:22] Project: 5900 (Run 0, Clone 220, Gen 34)
[11:57:22]
[11:57:22] Assembly optimizations on if available.
[11:57:22] Entering M.D.
[11:57:28] Tpr hash work/wudata_03.tpr:  1289219347 3583477144 2512291785 3244706304 1488289796
[11:57:29] Working on Protein
[11:57:31] Client config found, loading data.
[11:57:32] Starting GUI Server
[12:01:22] Completed 1%
               {snip}
[15:20:40] Completed 37%
[15:21:36] SEH code: 3221225477
[15:21:36] Run: exception thrown during GuardedRun
[15:21:36] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[15:21:36] Going to send back what have done -- stepsTotalG=2000000
[15:21:36] Work fraction=0.3711 steps=2000000.
[15:21:40] logfile size=108560 infoLength=108560 edr=0 trr=23
[15:21:40] - Writing 109096 bytes of core data to disk...
[15:21:40] Done: 108584 -> 5569 (compressed to 5.1 percent)
[15:21:40]   ... Done.
[15:21:40]
[15:21:40] Folding@home Core Shutdown: EARLY_UNIT_END
[15:21:42] CoreStatus = 72 (114)
[15:21:42] Sending work to server
[15:21:42] Project: 5900 (Run 0, Clone 220, Gen 34)
[15:21:42] - Read packet limit of 540015616... Set to 524286976.
[15:21:42] + Attempting to send results [March 14 15:21:42 UTC]
[15:21:42] - Reading file work/wuresults_03.dat from core
[15:21:42]   (Read 6081 bytes from disk)
[15:21:42] Connecting to http://171.64.122.70:8080/
[15:21:44] Posted data.
[15:21:44] Initial: 0000; - Uploaded at ~3 kB/s
[15:21:44] - Averaged speed for that direction ~39 kB/s
[15:21:44] + Results successfully sent
[15:21:44] Thank you for your contribution to Folding@Home.
Re: Project: 5900 (Run 0, Clone 220, Gen 34)
Hi anko1 (team 47815),
Your WU (P5900 R0 C220 G34) was added to the stats database on 2009-03-14 07:37:05 for 155.87 points of credit.
Unfortunately, there's no other report for this WU in the DB yet ...
