Project: 3064 (Run 4, Clone 151, Gen 49)
Rreini
Post by Rreini »
I've been hung up on this particular WU for a couple of days, getting nothing but frequent shutdowns.
[18:44:58] + Processing work unit
[18:44:58] Core required: FahCore_a1.exe
[18:44:58] Core found.
[18:44:58] Working on queue slot 03 [March 15 18:44:58 UTC]
[18:44:58] + Working ...
[18:44:58]
[18:44:58] *------------------------------*
[18:44:58] Folding@Home Gromacs SMP Core
[18:44:58] Version 1.74 (September 24, 2007)
[18:44:58]
[18:44:58] Preparing to commence simulation
[18:44:58] - Ensuring status. Please wait.
[18:45:15] - Looking at optimizations...
[18:45:15] - Working with standard loops on this execution.
[18:45:15] Examination of work files indicates 8 consecutive improper terminations of core.
[18:45:15] - Expanded 607242 -> 3255941 (decompressed 536.1 percent)
[18:45:15]
[18:45:15] Project: 3064 (Run 4, Clone 151, Gen 49)
[18:45:15]
[18:45:15] Entering M.D.
[18:45:22] mdrunner cpfilename:
[18:45:22] Protein: p3064_lambda5_2003
[18:45:22] Writing local files
[18:45:22] Completed 1562232 out of 5000000 steps  (31 percent)
[18:45:22] Extra SSE boost OK.
[18:45:22]
[18:45:33] Warning:  long 1-4 interactions
[18:45:38] CoreStatus = 0 (0)
[18:45:38] Client-core communications error: ERROR 0x0
[18:45:38] This is a sign of more serious problems, shutting down.
--- Opening Log file [March 15 18:45:38 UTC]
# Mac OS X SMP Console Edition ################################################
                       Folding@Home Client Version 6.20
                          http://folding.stanford.edu
Launch directory: /Users/rreini/Library/Folding@home
Executable: /Applications/Folding@home.app/fah6
[18:45:38] - Ask before connecting: No
[18:45:38] - User name: rreini (Team 3446)
[18:45:38] - User ID: 29C56AB032D555FD
[18:45:38] - Machine ID: 1
[18:45:38]
[18:45:38] Loaded queue successfully.
[18:45:38]
[18:45:38] + Processing work unit
[18:45:38] Core required: FahCore_a1.exe
[18:45:38] Core found.
[18:45:38] Working on queue slot 03 [March 15 18:45:38 UTC]
[18:45:38] + Working ...
[18:45:38]
[18:45:38] *------------------------------*
[18:45:38] Folding@Home Gromacs SMP Core
[18:45:38] Version 1.74 (September 24, 2007)
[18:45:38]
[18:45:38] Preparing to commence simulation
[18:45:38] - Ensuring status. Please wait.
[18:45:55] - Looking at optimizations...
[18:45:55] - Working with standard loops on this execution.
[18:45:55] Examination of work files indicates 8 consecutive improper terminations of core.
[18:45:55] - Expanded 607242 -> 3255941 (decompressed 536.1 percent)
[18:45:55]
[18:45:55] Project: 3064 (Run 4, Clone 151, Gen 49)
[18:45:55]
[18:45:55] Entering M.D.
[18:46:01] mdrunner cpfilename:
[18:46:01] Calling FAH init
[18:46:02] mbda5_2003
[18:46:02] Writing local files
[18:46:02] Completed 1562232 out of 5000000 steps  (31 percent)
[18:46:02] Extra SSE boost OK.
[18:46:02]
[18:46:12] Warning:  long 1-4 interactions
Re: Project: 3064 (Run 4, Clone 151, Gen 49)
Someone else was able to complete it successfully two days ago.
Rreini
Post by Rreini »
Any suggestions on what to do -- delete the unit and get another one? My system appears to be functioning properly in other regards
anandhanju
Post by anandhanju »
Yes, I'd go for deleting it. You may need to delete the work directory and the queue.dat file if it gets reassigned to you again.
