Project: 2496 (Run 4, Clone 27, Gen 0) - EUE@56%
anandhanju
Post by anandhanju »
Project: 2496 (Run 4, Clone 27, Gen 0) - EUE@56% [LINCS WARNING]
[22:35:10] Folding@Home Gromacs Core
[22:35:10] Version 1.90 (March 8, 2006)
[22:35:10]
[22:35:10] Preparing to commence simulation
[22:35:10] - Assembly optimizations manually forced on.
[22:35:10] - Not checking prior termination.
[22:35:14] - Expanded 2222140 -> 15109525 (decompressed 679.9 percent)
[22:35:15]
[22:35:15] Project: 2496 (Run 4, Clone 27, Gen 0)
[22:35:15]
[22:35:16] Assembly optimizations on if available.
[22:35:16] Entering M.D.
[22:35:38] (Starting from checkpoint)
[22:35:38] Protein: system
[22:35:38]
[22:35:38] Writing local files
[22:35:38] Completed 62500 out of 250000 steps  (25%)
[22:35:41] Extra SSE boost OK.
[23:05:44] Timered checkpoint triggered.
[23:28:41] Writing local files
[23:28:41] Completed 65000 out of 250000 steps  (26%)
....<snip/>...
[01:49:54] Completed 140000 out of 250000 steps  (56%)
[02:13:54] Quit 101 - Fatal error:
[02:13:54] Step 141060, time 282.12 (ps)  LINCS WARNING
[02:13:54] relative constraint deviation after LINCS:
[02:13:54] max 1626.375000 (between atoms 18613 and 18615) rms 12.007429
[02:13:54]
[02:13:54] Simulation instability has been encountered. The run has entered a
[02:13:54]   state from which no further progress can be made.
[02:13:54] This may be the correct result of the simulation, however if you
[02:13:54]   often see other project units terminating early like this
[02:13:54]   too, you may wish to check the stability of your computer (issues
[02:13:54]   such as high temperature, overclocking, etc.).
[02:13:54] Going to send back what have done.
[02:13:54] logfile size: 56984
[02:13:54] - Writing 57673 bytes of core data to disk...
[02:13:54]   ... Done.
[02:13:54]
[02:13:54] Folding@home Core Shutdown: EARLY_UNIT_END
[02:13:58] CoreStatus = 72 (114)
[02:13:58] Sending work to server
[02:13:58] Project: 2496 (Run 4, Clone 27, Gen 0)
[02:13:58] - Read packet limit of 540015616... Set to 524286976.
[02:13:58] + Attempting to send results [March 15 02:13:58 UTC]
[02:13:58] - Reading file work/wuresults_07.dat from core
[02:13:58]   (Read 57673 bytes from disk)
[02:13:58] Connecting to http://171.65.103.160:8080/
Partial result uploaded successfully.
Re: Project: 2496 (Run 4, Clone 27, Gen 0) - EUE@56%
There are 8 reports for partial credit in the DB ... that probably a bad WU. I've marked it.
