New 250 point p3798
Mactin
New 250 point p3798
Post by Mactin »
I obsserve that Project 3798 has gone from 5 points to 250 points
Sinse they are from a "new server code" server, they dont show up on the PSummary pages.
What are the deadlines ? I sneakernet a few CPUs, this information is important to me.
Thank you all
Grandpa_01
3798 anyone know what it is
Post by Grandpa_01 »
Just wondering if anyone has figured out what project 3798 is yet. My server is running 4 instances of it and has been for a while. It is currently taking about 1 1/2 hrs to run each so it is no longer the little test package. Is it a new project or a test. It appears to be worth 250 PPD and each time 1 completes it adds 1 more point to the WU value (1WU / 2WU / 3WU etc.)
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
pwnchu
Re: New 250 point p3798
Post by pwnchu »
viewtopic.php?f=19&t=7315
Why is the step size 150000 now?
pwnchu wrote:http://foldingforum.org/viewtopic.php?f=19&t=7315
In the referenced thread, Dr. Pande says that the WUs are small to intentionally pound the server code. That was several months ago. The server saturation levels have been tested. Now the WUs have been intentionally enlarged to test other aspects of the code. I'll bet that the processing time, the points per WU, and the number of steps have all changed in proportion.
Some time back there was a problem with server saturation for the PS3. One of the temporary changes made at that time was to take a production WU which happened to be worth 250 points and (essentially) glue a series of five of them into a single WU which was then worth 1250 points and ran 5x as long without an upload/download sequence. At that time, it was a helpful way to continue the project while reducing the load on the server. This is probably something similar.
Amaruk
Post by Amaruk »
I've done a bunch of these in a row.
I knew I was folding them because it increased my processor count again. :?
Project: 3798 (Run 12, Clone 2, Gen 13)
Project: 3798 (Run 60, Clone 1, Gen 15)
Project: 3798 (Run 50, Clone 1, Gen 18)
Project: 3798 (Run 73, Clone 4, Gen 18)
Project: 3798 (Run 21, Clone 3, Gen 19)
Project: 3798 (Run 39, Clone 3, Gen 18)
Project: 3798 (Run 82, Clone 0, Gen 21)
Project: 3798 (Run 42, Clone 4, Gen 22)
Here's the logfile if anyone is interested.
[23:21:50] + Attempting to get work packet
[23:21:50] - Will indicate memory of 1023 MB
[23:21:50] - Connecting to assignment server
[23:21:50] Connecting to http://assign.stanford.edu:8080/
[23:21:50] Posted data.
[23:21:50] Initial: 40AB; - Successful: assigned to (171.64.122.139).
[23:21:50] + News From Folding@Home: Welcome to Folding@Home
[23:21:50] Loaded queue successfully.
[23:21:50] Connecting to http://171.64.122.139:8080/
[23:21:51] Posted data.
[23:21:51] Initial: 0000; - Receiving payload (expected size: 237953)
[23:21:52] - Downloaded at ~232 kB/s
[23:21:52] - Averaged speed for that direction ~295 kB/s
[23:21:52] + Received work.
[23:21:52] Trying to send all finished work units
[23:21:52] + No unsent completed units remaining.
[23:21:52] + Closed connections
[23:21:52]
[23:21:52] + Processing work unit
[23:21:52] Core required: FahCore_78.exe
[23:21:52] Core found.
[23:21:52] Working on queue slot 02 [March 15 23:21:52 UTC]
[23:21:52] + Working ...
[23:21:52] - Calling '.\FahCore_78.exe -dir work/ -suffix 02 -checkpoint 15 -verbose -lifeline 34072 -version 620'
[23:21:52]
[23:21:52] *------------------------------*
[23:21:52] Folding@Home Gromacs Core
[23:21:52] Version 1.90 (March 8, 2006)
[23:21:52]
[23:21:52] Preparing to commence simulation
[23:21:52] - Looking at optimizations...
[23:21:52] - Created dyn
[23:21:52] - Files status OK
[23:21:52] - Expanded 237441 -> 1167708 (decompressed 491.7 percent)
[23:21:52] - Starting from initial work packet
[23:21:52]
[23:21:52] Project: 3798 (Run 12, Clone 2, Gen 13)
[23:21:52]
[23:21:52] Assembly optimizations on if available.
[23:21:52] Entering M.D.
[23:21:58] Protein: p3798
[23:21:58]
[23:21:58] Writing local files
[23:23:20] Extra SSE boost OK.
[23:23:20] Writing local files
[23:23:20] Completed 0 out of 150000 steps  (0%)
[23:25:49] Writing local files
[23:25:49] Completed 1500 out of 150000 steps  (1%)
[23:28:18] Writing local files
[23:28:18] Completed 3000 out of 150000 steps  (2%)
[23:30:47] Writing local files
[23:30:47] Completed 4500 out of 150000 steps  (3%)
[23:33:17] Writing local files
[23:33:17] Completed 6000 out of 150000 steps  (4%)
[23:35:47] Writing local files
[23:35:47] Completed 7500 out of 150000 steps  (5%)
[23:38:18] Writing local files
[23:38:18] Completed 9000 out of 150000 steps  (6%)
[23:40:48] Writing local files
[23:40:48] Completed 10500 out of 150000 steps  (7%)
[23:43:19] Writing local files
[23:43:19] Completed 12000 out of 150000 steps  (8%)
[23:45:48] Writing local files
[23:45:48] Completed 13500 out of 150000 steps  (9%)
[23:48:18] Writing local files
[23:48:18] Completed 15000 out of 150000 steps  (10%)
[23:50:48] Writing local files
[23:50:48] Completed 16500 out of 150000 steps  (11%)
[23:53:18] Writing local files
[23:53:18] Completed 18000 out of 150000 steps  (12%)
[23:55:48] Writing local files
[23:55:48] Completed 19500 out of 150000 steps  (13%)
[23:58:18] Writing local files
[23:58:18] Completed 21000 out of 150000 steps  (14%)
[00:00:47] Writing local files
[00:00:47] Completed 22500 out of 150000 steps  (15%)
[00:03:17] Writing local files
[00:03:17] Completed 24000 out of 150000 steps  (16%)
[00:05:47] Writing local files
[00:05:47] Completed 25500 out of 150000 steps  (17%)
[00:08:25] Writing local files
[00:08:25] Completed 27000 out of 150000 steps  (18%)
[00:11:04] Writing local files
[00:11:04] Completed 28500 out of 150000 steps  (19%)
[00:13:34] Writing local files
[00:13:34] Completed 30000 out of 150000 steps  (20%)
[00:16:05] Writing local files
[00:16:05] Completed 31500 out of 150000 steps  (21%)
[00:18:40] Writing local files
[00:18:40] Completed 33000 out of 150000 steps  (22%)
[00:21:08] Writing local files
[00:21:08] Completed 34500 out of 150000 steps  (23%)
[00:23:41] Writing local files
[00:23:41] Completed 36000 out of 150000 steps  (24%)
[00:26:19] Writing local files
[00:26:19] Completed 37500 out of 150000 steps  (25%)
[00:28:49] Writing local files
[00:28:49] Completed 39000 out of 150000 steps  (26%)
[00:31:25] Writing local files
[00:31:25] Completed 40500 out of 150000 steps  (27%)
[00:34:08] Writing local files
[00:34:08] Completed 42000 out of 150000 steps  (28%)
[00:34:59] - Autosending finished units... [March 16 00:34:59 UTC]
[00:34:59] Trying to send all finished work units
[00:34:59] + No unsent completed units remaining.
[00:34:59] - Autosend completed
[00:36:41] Writing local files
[00:36:41] Completed 43500 out of 150000 steps  (29%)
[00:39:16] Writing local files
[00:39:16] Completed 45000 out of 150000 steps  (30%)
[00:42:00] Writing local files
[00:42:00] Completed 46500 out of 150000 steps  (31%)
[00:44:40] Writing local files
[00:44:40] Completed 48000 out of 150000 steps  (32%)
[00:47:10] Writing local files
[00:47:10] Completed 49500 out of 150000 steps  (33%)
[00:49:40] Writing local files
[00:49:40] Completed 51000 out of 150000 steps  (34%)
[00:52:08] Writing local files
[00:52:09] Completed 52500 out of 150000 steps  (35%)
[00:54:38] Writing local files
[00:54:38] Completed 54000 out of 150000 steps  (36%)
[00:57:09] Writing local files
[00:57:09] Completed 55500 out of 150000 steps  (37%)
[00:59:47] Writing local files
[00:59:47] Completed 57000 out of 150000 steps  (38%)
[01:02:17] Writing local files
[01:02:17] Completed 58500 out of 150000 steps  (39%)
[01:04:49] Writing local files
[01:04:49] Completed 60000 out of 150000 steps  (40%)
[01:07:37] Writing local files
[01:07:37] Completed 61500 out of 150000 steps  (41%)
[01:10:23] Writing local files
[01:10:23] Completed 63000 out of 150000 steps  (42%)
[01:12:59] Writing local files
[01:12:59] Completed 64500 out of 150000 steps  (43%)
[01:15:32] Writing local files
[01:15:32] Completed 66000 out of 150000 steps  (44%)
[01:18:04] Writing local files
[01:18:04] Completed 67500 out of 150000 steps  (45%)
[01:20:39] Writing local files
[01:20:39] Completed 69000 out of 150000 steps  (46%)
[01:23:08] Writing local files
[01:23:08] Completed 70500 out of 150000 steps  (47%)
[01:25:38] Writing local files
[01:25:38] Completed 72000 out of 150000 steps  (48%)
[01:28:07] Writing local files
[01:28:07] Completed 73500 out of 150000 steps  (49%)
[01:30:37] Writing local files
[01:30:37] Completed 75000 out of 150000 steps  (50%)
[01:32:04] Writing local files
[01:32:04] Completed 76500 out of 150000 steps  (51%)
[01:34:34] Writing local files
[01:34:34] Completed 78000 out of 150000 steps  (52%)
[01:37:04] Writing local files
[01:37:04] Completed 79500 out of 150000 steps  (53%)
[01:39:33] Writing local files
[01:39:33] Completed 81000 out of 150000 steps  (54%)
[01:42:05] Writing local files
[01:42:05] Completed 82500 out of 150000 steps  (55%)
[01:44:36] Writing local files
[01:44:36] Completed 84000 out of 150000 steps  (56%)
[01:47:05] Writing local files
[01:47:05] Completed 85500 out of 150000 steps  (57%)
[01:49:35] Writing local files
[01:49:35] Completed 87000 out of 150000 steps  (58%)
[01:52:04] Writing local files
[01:52:04] Completed 88500 out of 150000 steps  (59%)
[01:54:39] Writing local files
[01:54:39] Completed 90000 out of 150000 steps  (60%)
[01:57:08] Writing local files
[01:57:08] Completed 91500 out of 150000 steps  (61%)
[01:59:37] Writing local files
[01:59:37] Completed 93000 out of 150000 steps  (62%)
[02:02:36] Writing local files
[02:02:36] Completed 94500 out of 150000 steps  (63%)
[02:05:27] Writing local files
[02:05:27] Completed 96000 out of 150000 steps  (64%)
[02:07:59] Writing local files
[02:07:59] Completed 97500 out of 150000 steps  (65%)
[02:10:30] Writing local files
[02:10:30] Completed 99000 out of 150000 steps  (66%)
[02:13:02] Writing local files
[02:13:02] Completed 100500 out of 150000 steps  (67%)
[02:15:39] Writing local files
[02:15:39] Completed 102000 out of 150000 steps  (68%)
[02:18:25] Writing local files
[02:18:25] Completed 103500 out of 150000 steps  (69%)
[02:21:05] Writing local files
[02:21:06] Completed 105000 out of 150000 steps  (70%)
[02:23:58] Writing local files
[02:23:58] Completed 106500 out of 150000 steps  (71%)
[02:26:47] Writing local files
[02:26:47] Completed 108000 out of 150000 steps  (72%)
[02:29:40] Writing local files
[02:29:40] Completed 109500 out of 150000 steps  (73%)
[02:32:10] Writing local files
[02:32:10] Completed 111000 out of 150000 steps  (74%)
[02:34:40] Writing local files
[02:34:40] Completed 112500 out of 150000 steps  (75%)
[02:37:09] Writing local files
[02:37:09] Completed 114000 out of 150000 steps  (76%)
[02:39:39] Writing local files
[02:39:39] Completed 115500 out of 150000 steps  (77%)
[02:42:08] Writing local files
[02:42:09] Completed 117000 out of 150000 steps  (78%)
[02:44:40] Writing local files
[02:44:40] Completed 118500 out of 150000 steps  (79%)
[02:47:10] Writing local files
[02:47:10] Completed 120000 out of 150000 steps  (80%)
[02:49:41] Writing local files
[02:49:41] Completed 121500 out of 150000 steps  (81%)
[02:52:10] Writing local files
[02:52:10] Completed 123000 out of 150000 steps  (82%)
[02:54:47] Writing local files
[02:54:47] Completed 124500 out of 150000 steps  (83%)
[02:57:20] Writing local files
[02:57:20] Completed 126000 out of 150000 steps  (84%)
[03:00:01] Writing local files
[03:00:01] Completed 127500 out of 150000 steps  (85%)
[03:02:38] Writing local files
[03:02:38] Completed 129000 out of 150000 steps  (86%)
[03:05:08] Writing local files
[03:05:08] Completed 130500 out of 150000 steps  (87%)
[03:07:37] Writing local files
[03:07:37] Completed 132000 out of 150000 steps  (88%)
[03:10:40] Writing local files
[03:10:40] Completed 133500 out of 150000 steps  (89%)
[03:13:50] Writing local files
[03:13:50] Completed 135000 out of 150000 steps  (90%)
[03:16:58] Writing local files
[03:16:58] Completed 136500 out of 150000 steps  (91%)
[03:19:52] Writing local files
[03:19:52] Completed 138000 out of 150000 steps  (92%)
[03:22:35] Writing local files
[03:22:35] Completed 139500 out of 150000 steps  (93%)
[03:25:27] Writing local files
[03:25:27] Completed 141000 out of 150000 steps  (94%)
[03:28:40] Writing local files
[03:28:40] Completed 142500 out of 150000 steps  (95%)
[03:31:46] Writing local files
[03:31:46] Completed 144000 out of 150000 steps  (96%)
[03:34:47] Writing local files
[03:34:47] Completed 145500 out of 150000 steps  (97%)
[03:37:26] Writing local files
[03:37:26] Completed 147000 out of 150000 steps  (98%)
[03:40:05] Writing local files
[03:40:05] Completed 148500 out of 150000 steps  (99%)
[03:42:46] Writing local files
[03:42:46] Completed 150000 out of 150000 steps  (100%)
[03:42:46] Writing final coordinates.
[03:42:46] Past main M.D. loop
[03:43:46]
[03:43:46] Finished Work Unit:
[03:43:46] - Reading up to 550656 from "work/wudata_02.arc": Read 550656
[03:43:46] - Reading up to 0 from "work/wudata_02.xtc": Read 0
[03:43:46] goefile size: 0
[03:43:46] Leaving Run
[03:43:49] - Writing 573212 bytes of core data to disk...
[03:43:49] Done: 572700 -> 521476 (compressed to 91.0 percent)
[03:43:49]   ... Done.
[03:43:49] - Shutting down core
[03:43:49]
[03:43:49] Folding@home Core Shutdown: FINISHED_UNIT
[03:43:53] CoreStatus = 64 (100)
[03:43:53] Unit 2 finished with 91 percent of time to deadline remaining.
[03:43:53] Updated performance fraction: 0.955939
[03:43:53] Sending work to server
[03:43:53] Project: 3798 (Run 12, Clone 2, Gen 13)
[03:43:53] + Attempting to send results [March 16 03:43:53 UTC]
[03:43:53] - Reading file work/wuresults_02.dat from core
[03:43:53]   (Read 521988 bytes from disk)
[03:43:53] Connecting to http://171.64.122.139:8080/
[03:43:54] Posted data.
[03:43:54] Initial: 0000; - Uploaded at ~510 kB/s
[03:43:54] - Averaged speed for that direction ~287 kB/s
[03:43:54] + Results successfully sent
[03:43:54] Thank you for your contribution to Folding@Home.
[03:43:54] + Number of Units Completed: 177
[03:43:59] Trying to send all finished work units
[03:43:59] + No unsent completed units remaining.
[03:43:59] - Preparing to get new work unit...
[03:43:59] + Attempting to get work packet
[03:43:59] - Will indicate memory of 1023 MB
[03:43:59] - Connecting to assignment server
[03:43:59] Connecting to http://assign.stanford.edu:8080/
[03:43:59] Posted data.
[03:43:59] Initial: 40AB; - Successful: assigned to (171.64.122.139).
[03:43:59] + News From Folding@Home: Welcome to Folding@Home
[03:43:59] Loaded queue successfully.
[03:43:59] Connecting to http://171.64.122.139:8080/
[03:44:00] Posted data.
[03:44:00] Initial: 0000; - Receiving payload (expected size: 238249)
[03:44:01] - Downloaded at ~232 kB/s
[03:44:01] - Averaged speed for that direction ~283 kB/s
[03:44:01] + Received work.
[03:44:01] Trying to send all finished work units
[03:44:01] + No unsent completed units remaining.
[03:44:01] + Closed connections
[03:44:01]
[03:44:01] + Processing work unit
[03:44:01] Core required: FahCore_78.exe
[03:44:01] Core found.
[03:44:01] Working on queue slot 03 [March 16 03:44:01 UTC]
[03:44:01] + Working ...
[03:44:01] - Calling '.\FahCore_78.exe -dir work/ -suffix 03 -checkpoint 15 -verbose -lifeline 34072 -version 620'
[03:44:01]
[03:44:01] *------------------------------*
[03:44:01] Folding@Home Gromacs Core
[03:44:01] Version 1.90 (March 8, 2006)
[03:44:01]
[03:44:01] Preparing to commence simulation
[03:44:01] - Looking at optimizations...
[03:44:01] - Created dyn
[03:44:01] - Files status OK
[03:44:02] - Expanded 237737 -> 1167708 (decompressed 491.1 percent)
[03:44:02] - Starting from initial work packet
[03:44:02]
[03:44:02] Project: 3798 (Run 60, Clone 1, Gen 15)
[03:44:02]
[03:44:02] Assembly optimizations on if available.
[03:44:02] Entering M.D.
[03:44:08] Protein: p3798
[03:44:08]
[03:44:08] Writing local files
[03:45:28] Extra SSE boost OK.
[03:45:28] Writing local files
[03:45:28] Completed 0 out of 150000 steps  (0%)
[03:48:03] Writing local files
[03:48:03] Completed 1500 out of 150000 steps  (1%)
[03:50:38] Writing local files
[03:50:38] Completed 3000 out of 150000 steps  (2%)
[03:53:33] Writing local files
[03:53:33] Completed 4500 out of 150000 steps  (3%)
[03:56:39] Writing local files
[03:56:39] Completed 6000 out of 150000 steps  (4%)
[03:59:17] Writing local files
[03:59:17] Completed 7500 out of 150000 steps  (5%)
[04:02:14] Writing local files
[04:02:14] Completed 9000 out of 150000 steps  (6%)
[04:05:03] Writing local files
[04:05:03] Completed 10500 out of 150000 steps  (7%)
[04:07:48] Writing local files
[04:07:48] Completed 12000 out of 150000 steps  (8%)
[04:10:30] Writing local files
[04:10:30] Completed 13500 out of 150000 steps  (9%)
[04:13:13] Writing local files
[04:13:13] Completed 15000 out of 150000 steps  (10%)
[04:16:01] Writing local files
[04:16:01] Completed 16500 out of 150000 steps  (11%)
[04:18:42] Writing local files
[04:18:42] Completed 18000 out of 150000 steps  (12%)
[04:21:24] Writing local files
[04:21:24] Completed 19500 out of 150000 steps  (13%)
[04:24:05] Writing local files
[04:24:05] Completed 21000 out of 150000 steps  (14%)
[04:26:47] Writing local files
[04:26:47] Completed 22500 out of 150000 steps  (15%)
[04:29:43] Writing local files
[04:29:43] Completed 24000 out of 150000 steps  (16%)
[04:31:34] Writing local files
[04:31:34] Completed 25500 out of 150000 steps  (17%)
[04:34:35] Writing local files
[04:34:35] Completed 27000 out of 150000 steps  (18%)
[04:37:28] Writing local files
[04:37:28] Completed 28500 out of 150000 steps  (19%)
[04:40:11] Writing local files
[04:40:11] Completed 30000 out of 150000 steps  (20%)
[04:42:57] Writing local files
[04:42:57] Completed 31500 out of 150000 steps  (21%)
[04:45:31] Writing local files
[04:45:31] Completed 33000 out of 150000 steps  (22%)
[04:48:23] Writing local files
[04:48:23] Completed 34500 out of 150000 steps  (23%)
[04:51:42] Writing local files
[04:51:42] Completed 36000 out of 150000 steps  (24%)
[04:54:44] Writing local files
[04:54:44] Completed 37500 out of 150000 steps  (25%)
[04:58:01] Writing local files
[04:58:01] Completed 39000 out of 150000 steps  (26%)
[05:00:41] Writing local files
[05:00:41] Completed 40500 out of 150000 steps  (27%)
[05:03:18] Writing local files
[05:03:18] Completed 42000 out of 150000 steps  (28%)
[05:05:46] Writing local files
[05:05:46] Completed 43500 out of 150000 steps  (29%)
[05:08:15] Writing local files
[05:08:15] Completed 45000 out of 150000 steps  (30%)
[05:10:46] Writing local files
[05:10:46] Completed 46500 out of 150000 steps  (31%)
[05:13:18] Writing local files
[05:13:18] Completed 48000 out of 150000 steps  (32%)
[05:15:48] Writing local files
[05:15:48] Completed 49500 out of 150000 steps  (33%)
[05:18:24] Writing local files
[05:18:24] Completed 51000 out of 150000 steps  (34%)
[05:21:07] Writing local files
[05:21:07] Completed 52500 out of 150000 steps  (35%)
[05:23:53] Writing local files
[05:23:53] Completed 54000 out of 150000 steps  (36%)
[05:26:31] Writing local files
[05:26:31] Completed 55500 out of 150000 steps  (37%)
[05:29:11] Writing local files
[05:29:11] Completed 57000 out of 150000 steps  (38%)
[05:32:08] Writing local files
[05:32:08] Completed 58500 out of 150000 steps  (39%)
[05:35:13] Writing local files
[05:35:13] Completed 60000 out of 150000 steps  (40%)
[05:38:12] Writing local files
[05:38:12] Completed 61500 out of 150000 steps  (41%)
[05:41:23] Writing local files
[05:41:23] Completed 63000 out of 150000 steps  (42%)
[05:44:36] Writing local files
[05:44:36] Completed 64500 out of 150000 steps  (43%)
[05:47:50] Writing local files
[05:47:50] Completed 66000 out of 150000 steps  (44%)
[05:51:05] Writing local files
[05:51:05] Completed 67500 out of 150000 steps  (45%)
[05:54:21] Writing local files
[05:54:21] Completed 69000 out of 150000 steps  (46%)
[05:57:34] Writing local files
[05:57:34] Completed 70500 out of 150000 steps  (47%)
[06:00:48] Writing local files
[06:00:48] Completed 72000 out of 150000 steps  (48%)
[06:03:45] Writing local files
[06:03:45] Completed 73500 out of 150000 steps  (49%)
[06:06:54] Writing local files
[06:06:54] Completed 75000 out of 150000 steps  (50%)
[06:09:59] Writing local files
[06:09:59] Completed 76500 out of 150000 steps  (51%)
[06:13:08] Writing local files
[06:13:08] Completed 78000 out of 150000 steps  (52%)
[06:16:05] Writing local files
[06:16:05] Completed 79500 out of 150000 steps  (53%)
[06:18:40] Writing local files
[06:18:40] Completed 81000 out of 150000 steps  (54%)
[06:21:39] Writing local files
[06:21:39] Completed 82500 out of 150000 steps  (55%)
[06:24:42] Writing local files
[06:24:42] Completed 84000 out of 150000 steps  (56%)
[06:27:32] Writing local files
[06:27:32] Completed 85500 out of 150000 steps  (57%)
[06:30:20] Writing local files
[06:30:20] Completed 87000 out of 150000 steps  (58%)
[06:32:56] - Autosending finished units... [March 16 06:32:56 UTC]
[06:32:56] Trying to send all finished work units
[06:32:56] + No unsent completed units remaining.
[06:32:56] - Autosend completed
[06:33:24] Writing local files
[06:33:24] Completed 88500 out of 150000 steps  (59%)
[06:36:24] Writing local files
[06:36:24] Completed 90000 out of 150000 steps  (60%)
[06:39:41] Writing local files
[06:39:41] Completed 91500 out of 150000 steps  (61%)
[06:42:55] Writing local files
[06:42:55] Completed 93000 out of 150000 steps  (62%)
[06:45:58] Writing local files
[06:45:58] Completed 94500 out of 150000 steps  (63%)
[06:49:01] Writing local files
[06:49:01] Completed 96000 out of 150000 steps  (64%)
[06:51:58] Writing local files
[06:51:58] Completed 97500 out of 150000 steps  (65%)
[06:55:00] Writing local files
[06:55:00] Completed 99000 out of 150000 steps  (66%)
[06:57:58] Writing local files
[06:57:58] Completed 100500 out of 150000 steps  (67%)
[07:00:45] Writing local files
[07:00:45] Completed 102000 out of 150000 steps  (68%)
[07:03:13] Writing local files
[07:03:13] Completed 103500 out of 150000 steps  (69%)
[07:05:45] Writing local files
[07:05:45] Completed 105000 out of 150000 steps  (70%)
[07:08:19] Writing local files
[07:08:19] Completed 106500 out of 150000 steps  (71%)
[07:11:23] Writing local files
[07:11:23] Completed 108000 out of 150000 steps  (72%)
[07:15:40] Writing local files
[07:15:40] Completed 109500 out of 150000 steps  (73%)
[07:20:08] Writing local files
[07:20:08] Completed 111000 out of 150000 steps  (74%)
[07:24:01] Writing local files
[07:24:01] Completed 112500 out of 150000 steps  (75%)
[07:28:24] Writing local files
[07:28:24] Completed 114000 out of 150000 steps  (76%)
[07:31:07] Writing local files
[07:31:07] Completed 115500 out of 150000 steps  (77%)
[07:35:32] Writing local files
[07:35:32] Completed 117000 out of 150000 steps  (78%)
[07:39:44] Writing local files
[07:39:44] Completed 118500 out of 150000 steps  (79%)
[07:43:38] Writing local files
[07:43:38] Completed 120000 out of 150000 steps  (80%)
[07:47:49] Writing local files
[07:47:49] Completed 121500 out of 150000 steps  (81%)
[07:51:44] Writing local files
[07:51:44] Completed 123000 out of 150000 steps  (82%)
[07:55:36] Writing local files
[07:55:36] Completed 124500 out of 150000 steps  (83%)
[07:59:46] Writing local files
[07:59:46] Completed 126000 out of 150000 steps  (84%)
[08:04:21] Writing local files
[08:04:21] Completed 127500 out of 150000 steps  (85%)
[08:08:45] Writing local files
[08:08:45] Completed 129000 out of 150000 steps  (86%)
[08:13:11] Writing local files
[08:13:11] Completed 130500 out of 150000 steps  (87%)
[08:17:37] Writing local files
[08:17:37] Completed 132000 out of 150000 steps  (88%)
[08:22:09] Writing local files
[08:22:09] Completed 133500 out of 150000 steps  (89%)
[08:26:44] Writing local files
[08:26:44] Completed 135000 out of 150000 steps  (90%)
[08:31:33] Writing local files
[08:31:33] Completed 136500 out of 150000 steps  (91%)
[08:35:53] Writing local files
[08:35:53] Completed 138000 out of 150000 steps  (92%)
[08:38:37] Writing local files
[08:38:37] Completed 139500 out of 150000 steps  (93%)
[08:41:20] Writing local files
[08:41:20] Completed 141000 out of 150000 steps  (94%)
[08:44:03] Writing local files
[08:44:03] Completed 142500 out of 150000 steps  (95%)
[08:46:32] Writing local files
[08:46:32] Completed 144000 out of 150000 steps  (96%)
[08:49:02] Writing local files
[08:49:02] Completed 145500 out of 150000 steps  (97%)
[08:51:31] Writing local files
[08:51:31] Completed 147000 out of 150000 steps  (98%)
[08:54:00] Writing local files
[08:54:00] Completed 148500 out of 150000 steps  (99%)
[08:56:30] Writing local files
[08:56:30] Completed 150000 out of 150000 steps  (100%)
[08:56:30] Writing final coordinates.
[08:56:30] Past main M.D. loop
[08:57:30]
[08:57:30] Finished Work Unit:
[08:57:30] - Reading up to 550656 from "work/wudata_03.arc": Read 550656
[08:57:30] - Reading up to 0 from "work/wudata_03.xtc": Read 0
[08:57:30] goefile size: 0
[08:57:30] Leaving Run
[08:57:34] - Writing 573212 bytes of core data to disk...
[08:57:34] Done: 572700 -> 520575 (compressed to 90.8 percent)
[08:57:34]   ... Done.
[08:57:34] - Shutting down core
[08:57:34]
[08:57:34] Folding@home Core Shutdown: FINISHED_UNIT
[08:57:37] CoreStatus = 64 (100)
[08:57:37] Unit 3 finished with 89 percent of time to deadline remaining.
[08:57:37] Updated performance fraction: 0.942973
[08:57:37] Sending work to server
[08:57:37] Project: 3798 (Run 60, Clone 1, Gen 15)
[08:57:37] + Attempting to send results [March 16 08:57:37 UTC]
[08:57:37] - Reading file work/wuresults_03.dat from core
[08:57:37]   (Read 521087 bytes from disk)
[08:57:37] Connecting to http://171.64.122.139:8080/
[08:57:38] Posted data.
[08:57:38] Initial: 0000; - Uploaded at ~509 kB/s
[08:57:38] - Averaged speed for that direction ~332 kB/s
[08:57:38] + Results successfully sent
[08:57:38] Thank you for your contribution to Folding@Home.
[08:57:38] + Number of Units Completed: 178
[08:57:42] Trying to send all finished work units
[08:57:42] + No unsent completed units remaining.
[08:57:42] - Preparing to get new work unit...
[08:57:42] + Attempting to get work packet
[08:57:42] - Will indicate memory of 1023 MB
[08:57:42] - Connecting to assignment server
[08:57:42] Connecting to http://assign.stanford.edu:8080/
[08:57:43] Posted data.
[08:57:43] Initial: 40AB; - Successful: assigned to (171.64.122.139).
[08:57:43] + News From Folding@Home: Welcome to Folding@Home
[08:57:43] Loaded queue successfully.
[08:57:43] Connecting to http://171.64.122.139:8080/
[08:57:44] Posted data.
[08:57:44] Initial: 0000; - Receiving payload (expected size: 239212)
[08:57:45] - Downloaded at ~233 kB/s
[08:57:45] - Averaged speed for that direction ~273 kB/s
[08:57:45] + Received work.
[08:57:45] Trying to send all finished work units
[08:57:45] + No unsent completed units remaining.
[08:57:45] + Closed connections
[08:57:45]
[08:57:45] + Processing work unit
[08:57:45] Core required: FahCore_78.exe
[08:57:45] Core found.
[08:57:45] Working on queue slot 04 [March 16 08:57:45 UTC]
[08:57:45] + Working ...
[08:57:45] - Calling '.\FahCore_78.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 34072 -version 620'
[08:57:45]
[08:57:45] *------------------------------*
[08:57:45] Folding@Home Gromacs Core
[08:57:45] Version 1.90 (March 8, 2006)
[08:57:45]
[08:57:45] Preparing to commence simulation
[08:57:45] - Looking at optimizations...
[08:57:45] - Created dyn
[08:57:45] - Files status OK
[08:57:45] - Expanded 238700 -> 1167708 (decompressed 489.1 percent)
[08:57:45] - Starting from initial work packet
[08:57:45]
[08:57:45] Project: 3798 (Run 50, Clone 1, Gen 18)
[08:57:45]
[08:57:45] Assembly optimizations on if available.
[08:57:45] Entering M.D.
[08:57:51] Protein: p3798
[08:57:51]
[08:57:51] Writing local files
[08:59:09] Extra SSE boost OK.
[08:59:09] Writing local files
[08:59:09] Completed 0 out of 150000 steps  (0%)
[09:01:39] Writing local files
[09:01:39] Completed 1500 out of 150000 steps  (1%)
[09:04:08] Writing local files
[09:04:08] Completed 3000 out of 150000 steps  (2%)
[09:06:39] Writing local files
[09:06:39] Completed 4500 out of 150000 steps  (3%)
[09:09:07] Writing local files
[09:09:07] Completed 6000 out of 150000 steps  (4%)
[09:11:38] Writing local files
[09:11:38] Completed 7500 out of 150000 steps  (5%)
[09:14:08] Writing local files
[09:14:08] Completed 9000 out of 150000 steps  (6%)
[09:16:38] Writing local files
[09:16:38] Completed 10500 out of 150000 steps  (7%)
[09:19:08] Writing local files
[09:19:08] Completed 12000 out of 150000 steps  (8%)
[09:21:38] Writing local files
[09:21:38] Completed 13500 out of 150000 steps  (9%)
[09:24:07] Writing local files
[09:24:07] Completed 15000 out of 150000 steps  (10%)
[09:26:37] Writing local files
[09:26:37] Completed 16500 out of 150000 steps  (11%)
[09:29:07] Writing local files
[09:29:07] Completed 18000 out of 150000 steps  (12%)
[09:31:37] Writing local files
[09:31:37] Completed 19500 out of 150000 steps  (13%)
[09:34:06] Writing local files
[09:34:06] Completed 21000 out of 150000 steps  (14%)
[09:36:36] Writing local files
[09:36:36] Completed 22500 out of 150000 steps  (15%)
[09:39:05] Writing local files
[09:39:06] Completed 24000 out of 150000 steps  (16%)
[09:41:37] Writing local files
[09:41:37] Completed 25500 out of 150000 steps  (17%)
[09:44:05] Writing local files
[09:44:05] Completed 27000 out of 150000 steps  (18%)
[09:46:34] Writing local files
[09:46:34] Completed 28500 out of 150000 steps  (19%)
[09:49:04] Writing local files
[09:49:04] Completed 30000 out of 150000 steps  (20%)
[09:51:34] Writing local files
[09:51:34] Completed 31500 out of 150000 steps  (21%)
[09:54:03] Writing local files
[09:54:03] Completed 33000 out of 150000 steps  (22%)
[09:56:34] Writing local files
[09:56:34] Completed 34500 out of 150000 steps  (23%)
[09:59:03] Writing local files
[09:59:03] Completed 36000 out of 150000 steps  (24%)
[10:01:33] Writing local files
[10:01:33] Completed 37500 out of 150000 steps  (25%)
[10:04:02] Writing local files
[10:04:02] Completed 39000 out of 150000 steps  (26%)
[10:06:33] Writing local files
[10:06:33] Completed 40500 out of 150000 steps  (27%)
[10:09:02] Writing local files
[10:09:02] Completed 42000 out of 150000 steps  (28%)
[10:11:32] Writing local files
[10:11:32] Completed 43500 out of 150000 steps  (29%)
[10:14:02] Writing local files
[10:14:02] Completed 45000 out of 150000 steps  (30%)
[10:16:32] Writing local files
[10:16:32] Completed 46500 out of 150000 steps  (31%)
[10:19:02] Writing local files
[10:19:02] Completed 48000 out of 150000 steps  (32%)
[10:21:31] Writing local files
[10:21:31] Completed 49500 out of 150000 steps  (33%)
[10:24:00] Writing local files
[10:24:01] Completed 51000 out of 150000 steps  (34%)
[10:26:30] Writing local files
[10:26:30] Completed 52500 out of 150000 steps  (35%)
[10:27:57] Writing local files
[10:27:57] Completed 54000 out of 150000 steps  (36%)
[10:30:28] Writing local files
[10:30:28] Completed 55500 out of 150000 steps  (37%)
[10:32:58] Writing local files
[10:32:58] Completed 57000 out of 150000 steps  (38%)
[10:35:28] Writing local files
[10:35:28] Completed 58500 out of 150000 steps  (39%)
[10:37:57] Writing local files
[10:37:57] Completed 60000 out of 150000 steps  (40%)
[10:40:27] Writing local files
[10:40:27] Completed 61500 out of 150000 steps  (41%)
[10:42:56] Writing local files
[10:42:56] Completed 63000 out of 150000 steps  (42%)
[10:45:28] Writing local files
[10:45:28] Completed 64500 out of 150000 steps  (43%)
[10:47:57] Writing local files
[10:47:57] Completed 66000 out of 150000 steps  (44%)
[10:50:26] Writing local files
[10:50:26] Completed 67500 out of 150000 steps  (45%)
[10:52:55] Writing local files
[10:52:55] Completed 69000 out of 150000 steps  (46%)
[10:55:25] Writing local files
[10:55:25] Completed 70500 out of 150000 steps  (47%)
[10:57:55] Writing local files
[10:57:55] Completed 72000 out of 150000 steps  (48%)
[11:00:25] Writing local files
[11:00:25] Completed 73500 out of 150000 steps  (49%)
[11:02:55] Writing local files
[11:02:55] Completed 75000 out of 150000 steps  (50%)
[11:05:26] Writing local files
[11:05:26] Completed 76500 out of 150000 steps  (51%)
[11:07:56] Writing local files
[11:07:56] Completed 78000 out of 150000 steps  (52%)
[11:10:26] Writing local files
[11:10:26] Completed 79500 out of 150000 steps  (53%)
[11:12:55] Writing local files
[11:12:55] Completed 81000 out of 150000 steps  (54%)
[11:15:25] Writing local files
[11:15:25] Completed 82500 out of 150000 steps  (55%)
[11:17:55] Writing local files
[11:17:55] Completed 84000 out of 150000 steps  (56%)
[11:20:25] Writing local files
[11:20:25] Completed 85500 out of 150000 steps  (57%)
[11:22:54] Writing local files
[11:22:54] Completed 87000 out of 150000 steps  (58%)
[11:25:24] Writing local files
[11:25:24] Completed 88500 out of 150000 steps  (59%)
[11:27:54] Writing local files
[11:27:54] Completed 90000 out of 150000 steps  (60%)
[11:30:24] Writing local files
[11:30:24] Completed 91500 out of 150000 steps  (61%)
[11:32:54] Writing local files
[11:32:54] Completed 93000 out of 150000 steps  (62%)
[11:35:24] Writing local files
[11:35:24] Completed 94500 out of 150000 steps  (63%)
[11:37:53] Writing local files
[11:37:53] Completed 96000 out of 150000 steps  (64%)
[11:40:24] Writing local files
[11:40:24] Completed 97500 out of 150000 steps  (65%)
[11:42:54] Writing local files
[11:42:54] Completed 99000 out of 150000 steps  (66%)
[11:45:25] Writing local files
[11:45:26] Completed 100500 out of 150000 steps  (67%)
[11:47:54] Writing local files
[11:47:54] Completed 102000 out of 150000 steps  (68%)
[11:50:23] Writing local files
[11:50:23] Completed 103500 out of 150000 steps  (69%)
[11:52:53] Writing local files
[11:52:53] Completed 105000 out of 150000 steps  (70%)
[11:55:23] Writing local files
[11:55:23] Completed 106500 out of 150000 steps  (71%)
[11:57:53] Writing local files
[11:57:53] Completed 108000 out of 150000 steps  (72%)
[12:00:23] Writing local files
[12:00:23] Completed 109500 out of 150000 steps  (73%)
[12:02:53] Writing local files
[12:02:53] Completed 111000 out of 150000 steps  (74%)
[12:05:23] Writing local files
[12:05:23] Completed 112500 out of 150000 steps  (75%)
[12:07:53] Writing local files
[12:07:53] Completed 114000 out of 150000 steps  (76%)
[12:10:23] Writing local files
[12:10:23] Completed 115500 out of 150000 steps  (77%)
[12:12:52] Writing local files
[12:12:52] Completed 117000 out of 150000 steps  (78%)
[12:15:22] Writing local files
[12:15:22] Completed 118500 out of 150000 steps  (79%)
[12:17:52] Writing local files
[12:17:52] Completed 120000 out of 150000 steps  (80%)
[12:20:23] Writing local files
[12:20:23] Completed 121500 out of 150000 steps  (81%)
[12:22:52] Writing local files
[12:22:52] Completed 123000 out of 150000 steps  (82%)
[12:25:23] Writing local files
[12:25:23] Completed 124500 out of 150000 steps  (83%)
[12:27:52] Writing local files
[12:27:53] Completed 126000 out of 150000 steps  (84%)
[12:30:23] Writing local files
[12:30:23] Completed 127500 out of 150000 steps  (85%)
[12:30:52] - Autosending finished units... [March 16 12:30:52 UTC]
[12:30:52] Trying to send all finished work units
[12:30:52] + No unsent completed units remaining.
[12:30:52] - Autosend completed
[12:32:52] Writing local files
[12:32:52] Completed 129000 out of 150000 steps  (86%)
[12:35:23] Writing local files
[12:35:23] Completed 130500 out of 150000 steps  (87%)
[12:37:53] Writing local files
[12:37:53] Completed 132000 out of 150000 steps  (88%)
[12:40:24] Writing local files
[12:40:24] Completed 133500 out of 150000 steps  (89%)
[12:42:53] Writing local files
[12:42:53] Completed 135000 out of 150000 steps  (90%)
[12:45:25] Writing local files
[12:45:25] Completed 136500 out of 150000 steps  (91%)
[12:47:54] Writing local files
[12:47:54] Completed 138000 out of 150000 steps  (92%)
[12:50:24] Writing local files
[12:50:24] Completed 139500 out of 150000 steps  (93%)
[12:52:54] Writing local files
[12:52:54] Completed 141000 out of 150000 steps  (94%)
[12:55:24] Writing local files
[12:55:24] Completed 142500 out of 150000 steps  (95%)
[12:57:54] Writing local files
[12:57:54] Completed 144000 out of 150000 steps  (96%)
[13:00:24] Writing local files
[13:00:24] Completed 145500 out of 150000 steps  (97%)
[13:02:54] Writing local files
[13:02:54] Completed 147000 out of 150000 steps  (98%)
[13:05:25] Writing local files
[13:05:25] Completed 148500 out of 150000 steps  (99%)
[13:07:55] Writing local files
[13:07:55] Completed 150000 out of 150000 steps  (100%)
[13:07:55] Writing final coordinates.
[13:07:55] Past main M.D. loop
[13:08:55]
[13:08:55] Finished Work Unit:
[13:08:55] - Reading up to 550656 from "work/wudata_04.arc": Read 550656
[13:08:55] - Reading up to 0 from "work/wudata_04.xtc": Read 0
[13:08:55] goefile size: 0
[13:08:55] Leaving Run
[13:08:56] - Writing 573212 bytes of core data to disk...
[13:08:56] Done: 572700 -> 519794 (compressed to 90.7 percent)
[13:08:56]   ... Done.
[13:08:56] - Shutting down core
[13:08:56]
[13:08:56] Folding@home Core Shutdown: FINISHED_UNIT
[13:09:00] CoreStatus = 64 (100)
[13:09:00] Unit 4 finished with 91 percent of time to deadline remaining.
[13:09:00] Updated performance fraction: 0.936930
[13:09:00] Sending work to server
[13:09:00] Project: 3798 (Run 50, Clone 1, Gen 18)
[13:09:00] + Attempting to send results [March 16 13:09:00 UTC]
[13:09:00] - Reading file work/wuresults_04.dat from core
[13:09:00]   (Read 520306 bytes from disk)
[13:09:00] Connecting to http://171.64.122.139:8080/
[13:09:02] Posted data.
[13:09:02] Initial: 0000; - Uploaded at ~254 kB/s
[13:09:02] - Averaged speed for that direction ~316 kB/s
[13:09:02] + Results successfully sent
[13:09:02] Thank you for your contribution to Folding@Home.
[13:09:02] + Number of Units Completed: 179
[13:09:06] Trying to send all finished work units
[13:09:06] + No unsent completed units remaining.
[13:09:06] - Preparing to get new work unit...
[13:09:06] + Attempting to get work packet
[13:09:06] - Will indicate memory of 1023 MB
[13:09:06] - Connecting to assignment server
[13:09:06] Connecting to http://assign.stanford.edu:8080/
[13:09:07] Posted data.
[13:09:07] Initial: 40AB; - Successful: assigned to (171.64.122.139).
[13:09:07] + News From Folding@Home: Welcome to Folding@Home
[13:09:07] Loaded queue successfully.
[13:09:07] Connecting to http://171.64.122.139:8080/
[13:09:08] Posted data.
[13:09:08] Initial: 0000; - Receiving payload (expected size: 238896)
[13:09:09] - Downloaded at ~233 kB/s
[13:09:09] - Averaged speed for that direction ~265 kB/s
[13:09:09] + Received work.
[13:09:09] Trying to send all finished work units
[13:09:09] + No unsent completed units remaining.
[13:09:09] + Closed connections
[13:09:09]
[13:09:09] + Processing work unit
[13:09:09] Core required: FahCore_78.exe
[13:09:09] Core found.
[13:09:09] Working on queue slot 05 [March 16 13:09:09 UTC]
[13:09:09] + Working ...
[13:09:09] - Calling '.\FahCore_78.exe -dir work/ -suffix 05 -checkpoint 15 -verbose -lifeline 34072 -version 620'
[13:09:09]
[13:09:09] *------------------------------*
[13:09:09] Folding@Home Gromacs Core
[13:09:09] Version 1.90 (March 8, 2006)
[13:09:09]
[13:09:09] Preparing to commence simulation
[13:09:09] - Looking at optimizations...
[13:09:09] - Created dyn
[13:09:09] - Files status OK
[13:09:09] - Expanded 238384 -> 1167708 (decompressed 489.8 percent)
[13:09:09] - Starting from initial work packet
[13:09:09]
[13:09:09] Project: 3798 (Run 73, Clone 4, Gen 18)
[13:09:09]
[13:09:10] Assembly optimizations on if available.
[13:09:10] Entering M.D.
[13:09:16] Protein: p3798
[13:09:16]
[13:09:16] Writing local files
[13:10:35] Extra SSE boost OK.
[13:10:35] Writing local files
[13:10:36] Completed 0 out of 150000 steps  (0%)
[13:13:04] Writing local files
[13:13:04] Completed 1500 out of 150000 steps  (1%)
[13:15:34] Writing local files
[13:15:34] Completed 3000 out of 150000 steps  (2%)
[13:18:04] Writing local files
[13:18:04] Completed 4500 out of 150000 steps  (3%)
[13:20:34] Writing local files
[13:20:34] Completed 6000 out of 150000 steps  (4%)
[13:23:03] Writing local files
[13:23:03] Completed 7500 out of 150000 steps  (5%)
[13:25:33] Writing local files
[13:25:33] Completed 9000 out of 150000 steps  (6%)
[13:27:01] Writing local files
[13:27:01] Completed 10500 out of 150000 steps  (7%)
[13:29:31] Writing local files
[13:29:31] Completed 12000 out of 150000 steps  (8%)
[13:32:01] Writing local files
[13:32:01] Completed 13500 out of 150000 steps  (9%)
[13:34:31] Writing local files
[13:34:31] Completed 15000 out of 150000 steps  (10%)
[13:37:00] Writing local files
[13:37:00] Completed 16500 out of 150000 steps  (11%)
[13:39:30] Writing local files
[13:39:30] Completed 18000 out of 150000 steps  (12%)
[13:42:00] Writing local files
[13:42:00] Completed 19500 out of 150000 steps  (13%)
[13:44:31] Writing local files
[13:44:31] Completed 21000 out of 150000 steps  (14%)
[13:47:01] Writing local files
[13:47:01] Completed 22500 out of 150000 steps  (15%)
[13:49:32] Writing local files
[13:49:32] Completed 24000 out of 150000 steps  (16%)
[13:52:00] Writing local files
[13:52:00] Completed 25500 out of 150000 steps  (17%)
[13:54:30] Writing local files
[13:54:30] Completed 27000 out of 150000 steps  (18%)
[13:56:59] Writing local files
[13:57:00] Completed 28500 out of 150000 steps  (19%)
[13:59:29] Writing local files
[13:59:29] Completed 30000 out of 150000 steps  (20%)
[14:01:59] Writing local files
[14:01:59] Completed 31500 out of 150000 steps  (21%)
[14:04:29] Writing local files
[14:04:29] Completed 33000 out of 150000 steps  (22%)
[14:06:57] Writing local files
[14:06:57] Completed 34500 out of 150000 steps  (23%)
[14:09:28] Writing local files
[14:09:28] Completed 36000 out of 150000 steps  (24%)
[14:11:57] Writing local files
[14:11:57] Completed 37500 out of 150000 steps  (25%)
[14:14:27] Writing local files
[14:14:27] Completed 39000 out of 150000 steps  (26%)
[14:16:57] Writing local files
[14:16:57] Completed 40500 out of 150000 steps  (27%)
[14:19:27] Writing local files
[14:19:27] Completed 42000 out of 150000 steps  (28%)
[14:21:55] Writing local files
[14:21:55] Completed 43500 out of 150000 steps  (29%)
[14:24:25] Writing local files
[14:24:25] Completed 45000 out of 150000 steps  (30%)
[14:26:54] Writing local files
[14:26:54] Completed 46500 out of 150000 steps  (31%)
[14:29:25] Writing local files
[14:29:25] Completed 48000 out of 150000 steps  (32%)
[14:31:54] Writing local files
[14:31:54] Completed 49500 out of 150000 steps  (33%)
[14:34:24] Writing local files
[14:34:24] Completed 51000 out of 150000 steps  (34%)
[14:36:53] Writing local files
[14:36:54] Completed 52500 out of 150000 steps  (35%)
[14:39:24] Writing local files
[14:39:24] Completed 54000 out of 150000 steps  (36%)
[14:41:53] Writing local files
[14:41:53] Completed 55500 out of 150000 steps  (37%)
[14:44:23] Writing local files
[14:44:23] Completed 57000 out of 150000 steps  (38%)
[14:46:52] Writing local files
[14:46:52] Completed 58500 out of 150000 steps  (39%)
[14:49:25] Writing local files
[14:49:25] Completed 60000 out of 150000 steps  (40%)
[14:51:54] Writing local files
[14:51:54] Completed 61500 out of 150000 steps  (41%)
[14:54:24] Writing local files
[14:54:24] Completed 63000 out of 150000 steps  (42%)
[14:56:53] Writing local files
[14:56:53] Completed 64500 out of 150000 steps  (43%)
[14:59:23] Writing local files
[14:59:23] Completed 66000 out of 150000 steps  (44%)
[15:01:52] Writing local files
[15:01:52] Completed 67500 out of 150000 steps  (45%)
[15:04:23] Writing local files
[15:04:23] Completed 69000 out of 150000 steps  (46%)
[15:06:53] Writing local files
[15:06:53] Completed 70500 out of 150000 steps  (47%)
[15:09:23] Writing local files
[15:09:23] Completed 72000 out of 150000 steps  (48%)
[15:11:52] Writing local files
[15:11:52] Completed 73500 out of 150000 steps  (49%)
[15:14:21] Writing local files
[15:14:22] Completed 75000 out of 150000 steps  (50%)
[15:16:51] Writing local files
[15:16:51] Completed 76500 out of 150000 steps  (51%)
[15:19:21] Writing local files
[15:19:21] Completed 78000 out of 150000 steps  (52%)
[15:21:50] Writing local files
[15:21:50] Completed 79500 out of 150000 steps  (53%)
[15:24:20] Writing local files
[15:24:20] Completed 81000 out of 150000 steps  (54%)
[15:26:50] Writing local files
[15:26:50] Completed 82500 out of 150000 steps  (55%)
[15:29:21] Writing local files
[15:29:21] Completed 84000 out of 150000 steps  (56%)
[15:31:50] Writing local files
[15:31:50] Completed 85500 out of 150000 steps  (57%)
[15:34:20] Writing local files
[15:34:21] Completed 87000 out of 150000 steps  (58%)
[15:36:49] Writing local files
[15:36:50] Completed 88500 out of 150000 steps  (59%)
[15:39:19] Writing local files
[15:39:19] Completed 90000 out of 150000 steps  (60%)
[15:41:48] Writing local files
[15:41:49] Completed 91500 out of 150000 steps  (61%)
[15:44:19] Writing local files
[15:44:19] Completed 93000 out of 150000 steps  (62%)
[15:46:49] Writing local files
[15:46:49] Completed 94500 out of 150000 steps  (63%)
[15:49:21] Writing local files
[15:49:21] Completed 96000 out of 150000 steps  (64%)
[15:51:49] Writing local files
[15:51:49] Completed 97500 out of 150000 steps  (65%)
[15:54:18] Writing local files
[15:54:18] Completed 99000 out of 150000 steps  (66%)
[15:56:48] Writing local files
[15:56:48] Completed 100500 out of 150000 steps  (67%)
[15:59:18] Writing local files
[15:59:18] Completed 102000 out of 150000 steps  (68%)
[16:01:48] Writing local files
[16:01:48] Completed 103500 out of 150000 steps  (69%)
[16:04:18] Writing local files
[16:04:18] Completed 105000 out of 150000 steps  (70%)
[16:06:48] Writing local files
[16:06:48] Completed 106500 out of 150000 steps  (71%)
[16:09:18] Writing local files
[16:09:18] Completed 108000 out of 150000 steps  (72%)
[16:11:47] Writing local files
[16:11:47] Completed 109500 out of 150000 steps  (73%)
[16:14:18] Writing local files
[16:14:18] Completed 111000 out of 150000 steps  (74%)
[16:16:48] Writing local files
[16:16:48] Completed 112500 out of 150000 steps  (75%)
[16:19:18] Writing local files
[16:19:18] Completed 114000 out of 150000 steps  (76%)
[16:21:47] Writing local files
[16:21:47] Completed 115500 out of 150000 steps  (77%)
[16:24:17] Writing local files
[16:24:17] Completed 117000 out of 150000 steps  (78%)
[16:25:44] Writing local files
[16:25:44] Completed 118500 out of 150000 steps  (79%)
[16:28:14] Writing local files
[16:28:14] Completed 120000 out of 150000 steps  (80%)
[16:30:43] Writing local files
[16:30:43] Completed 121500 out of 150000 steps  (81%)
[16:33:13] Writing local files
[16:33:13] Completed 123000 out of 150000 steps  (82%)
[16:35:42] Writing local files
[16:35:42] Completed 124500 out of 150000 steps  (83%)
[16:38:13] Writing local files
[16:38:13] Completed 126000 out of 150000 steps  (84%)
[16:40:43] Writing local files
[16:40:43] Completed 127500 out of 150000 steps  (85%)
[16:43:36] Writing local files
[16:43:36] Completed 129000 out of 150000 steps  (86%)
[16:46:05] Writing local files
[16:46:05] Completed 130500 out of 150000 steps  (87%)
[16:48:35] Writing local files
[16:48:35] Completed 132000 out of 150000 steps  (88%)
[16:51:03] Writing local files
[16:51:03] Completed 133500 out of 150000 steps  (89%)
[16:53:34] Writing local files
[16:53:34] Completed 135000 out of 150000 steps  (90%)
[16:56:03] Writing local files
[16:56:03] Completed 136500 out of 150000 steps  (91%)
[16:58:32] Writing local files
[16:58:32] Completed 138000 out of 150000 steps  (92%)
[17:01:01] Writing local files
[17:01:01] Completed 139500 out of 150000 steps  (93%)
[17:03:31] Writing local files
[17:03:31] Completed 141000 out of 150000 steps  (94%)
[17:06:01] Writing local files
[17:06:01] Completed 142500 out of 150000 steps  (95%)
[17:08:31] Writing local files
[17:08:31] Completed 144000 out of 150000 steps  (96%)
[17:11:00] Writing local files
[17:11:00] Completed 145500 out of 150000 steps  (97%)
[17:13:30] Writing local files
[17:13:30] Completed 147000 out of 150000 steps  (98%)
[17:16:01] Writing local files
[17:16:01] Completed 148500 out of 150000 steps  (99%)
[17:18:31];;; Writing local files
[17:18:31] Completed 150000 out of 150000 steps  (100%)
[17:18:31] Writing final coordinates.
[17:18:31] Past main M.D. loop
[17:19:31]
[17:19:31] Finished Work Unit:
[17:19:31] - Reading up to 550656 from "work/wudata_05.arc": Read 550656
[17:19:31] - Reading up to 0 from "work/wudata_05.xtc": Read 0
[17:19:31] goefile size: 0
[17:19:31] Leaving Run
[17:19:34] - Writing 573212 bytes of core data to disk...
[17:19:35] Done: 572700 -> 519348 (compressed to 90.6 percent)
[17:19:35]   ... Done.
[17:19:35] - Shutting down core
[17:19:35]
[17:19:35] Folding@home Core Shutdown: FINISHED_UNIT
[17:19:37] CoreStatus = 64 (100)
[17:19:37] Unit 5 finished with 91 percent of time to deadline remaining.
[17:19:37] Updated performance fraction: 0.932151
[17:19:37] Sending work to server
[17:19:37] Project: 3798 (Run 73, Clone 4, Gen 18)
[17:19:37] + Attempting to send results [March 16 17:19:37 UTC]
[17:19:37] - Reading file work/wuresults_05.dat from core
[17:19:37]   (Read 519860 bytes from disk)
[17:19:37] Connecting to http://171.64.122.139:8080/
[17:19:39] Posted data.
[17:19:39] Initial: 0000; - Uploaded at ~254 kB/s
[17:19:39] - Averaged speed for that direction ~304 kB/s
[17:19:39] + Results successfully sent
[17:19:39] Thank you for your contribution to Folding@Home.
[17:19:39] + Number of Units Completed: 180
[17:19:43] Trying to send all finished work units
[17:19:43] + No unsent completed units remaining.
[17:19:43] - Preparing to get new work unit...
[17:19:43] + Attempting to get work packet
[17:19:43] - Will indicate memory of 1023 MB
*edit* due to character limit, this is the first half of the file.... :wink:
Amaruk
Post by Amaruk »
....and here is the rest. :lol:
[17:19:43] - Connecting to assignment server
[17:19:43] Connecting to http://assign.stanford.edu:8080/
[17:19:43] Posted data.
[17:19:43] Initial: 40AB; - Successful: assigned to (171.64.122.139).
[17:19:43] + News From Folding@Home: Welcome to Folding@Home
[17:19:43] Loaded queue successfully.
[17:19:43] Connecting to http://171.64.122.139:8080/
[17:19:45] Posted data.
[17:19:45] Initial: 0000; - Receiving payload (expected size: 238511)
[17:19:46] - Downloaded at ~232 kB/s
[17:19:46] - Averaged speed for that direction ~258 kB/s
[17:19:46] + Received work.
[17:19:46] Trying to send all finished work units
[17:19:46] + No unsent completed units remaining.
[17:19:46] + Closed connections
[17:19:46]
[17:19:46] + Processing work unit
[17:19:46] Core required: FahCore_78.exe
[17:19:46] Core found.
[17:19:46] Working on queue slot 06 [March 16 17:19:46 UTC]
[17:19:46] + Working ...
[17:19:46] - Calling '.\FahCore_78.exe -dir work/ -suffix 06 -checkpoint 15 -verbose -lifeline 34072 -version 620'
[17:19:46]
[17:19:46] *------------------------------*
[17:19:46] Folding@Home Gromacs Core
[17:19:46] Version 1.90 (March 8, 2006)
[17:19:46]
[17:19:46] Preparing to commence simulation
[17:19:46] - Looking at optimizations...
[17:19:46] - Created dyn
[17:19:46] - Files status OK
[17:19:46] - Expanded 237999 -> 1167708 (decompressed 490.6 percent)
[17:19:46] - Starting from initial work packet
[17:19:46]
[17:19:46] Project: 3798 (Run 21, Clone 3, Gen 19)
[17:19:46]
[17:19:46] Assembly optimizations on if available.
[17:19:46] Entering M.D.
[17:19:52] Protein: p3798
[17:19:52]
[17:19:52] Writing local files
[17:21:12] Extra SSE boost OK.
[17:21:12] Writing local files
[17:21:12] Completed 0 out of 150000 steps  (0%)
[17:23:42] Writing local files
[17:23:42] Completed 1500 out of 150000 steps  (1%)
[17:26:11] Writing local files
[17:26:11] Completed 3000 out of 150000 steps  (2%)
[17:28:42] Writing local files
[17:28:42] Completed 4500 out of 150000 steps  (3%)
[17:31:12] Writing local files
[17:31:12] Completed 6000 out of 150000 steps  (4%)
[17:33:42] Writing local files
[17:33:42] Completed 7500 out of 150000 steps  (5%)
[17:36:11] Writing local files
[17:36:11] Completed 9000 out of 150000 steps  (6%)
[17:38:42] Writing local files
[17:38:42] Completed 10500 out of 150000 steps  (7%)
[17:41:11] Writing local files
[17:41:11] Completed 12000 out of 150000 steps  (8%)
[17:43:41] Writing local files
[17:43:41] Completed 13500 out of 150000 steps  (9%)
[17:46:11] Writing local files
[17:46:11] Completed 15000 out of 150000 steps  (10%)
[17:48:41] Writing local files
[17:48:41] Completed 16500 out of 150000 steps  (11%)
[17:51:10] Writing local files
[17:51:10] Completed 18000 out of 150000 steps  (12%)
[17:53:42] Writing local files
[17:53:42] Completed 19500 out of 150000 steps  (13%)
[17:56:12] Writing local files
[17:56:12] Completed 21000 out of 150000 steps  (14%)
[17:58:41] Writing local files
[17:58:41] Completed 22500 out of 150000 steps  (15%)
[18:01:10] Writing local files
[18:01:10] Completed 24000 out of 150000 steps  (16%)
[18:03:40] Writing local files
[18:03:40] Completed 25500 out of 150000 steps  (17%)
[18:06:09] Writing local files
[18:06:09] Completed 27000 out of 150000 steps  (18%)
[18:08:41] Writing local files
[18:08:41] Completed 28500 out of 150000 steps  (19%)
[18:11:10] Writing local files
[18:11:10] Completed 30000 out of 150000 steps  (20%)
[18:13:41] Writing local files
[18:13:41] Completed 31500 out of 150000 steps  (21%)
[18:16:11] Writing local files
[18:16:11] Completed 33000 out of 150000 steps  (22%)
[18:18:41] Writing local files
[18:18:41] Completed 34500 out of 150000 steps  (23%)
[18:21:10] Writing local files
[18:21:10] Completed 36000 out of 150000 steps  (24%)
[18:23:41] Writing local files
[18:23:41] Completed 37500 out of 150000 steps  (25%)
[18:26:10] Writing local files
[18:26:10] Completed 39000 out of 150000 steps  (26%)
[18:28:40] Writing local files
[18:28:40] Completed 40500 out of 150000 steps  (27%)
[18:28:49] - Autosending finished units... [March 16 18:28:49 UTC]
[18:28:49] Trying to send all finished work units
[18:28:49] + No unsent completed units remaining.
[18:28:49] - Autosend completed
[18:31:09] Writing local files
[18:31:09] Completed 42000 out of 150000 steps  (28%)
[18:33:39] Writing local files
[18:33:39] Completed 43500 out of 150000 steps  (29%)
[18:36:09] Writing local files
[18:36:09] Completed 45000 out of 150000 steps  (30%)
[18:38:39] Writing local files
[18:38:39] Completed 46500 out of 150000 steps  (31%)
[18:41:08] Writing local files
[18:41:08] Completed 48000 out of 150000 steps  (32%)
[18:43:39] Writing local files
[18:43:39] Completed 49500 out of 150000 steps  (33%)
[18:46:08] Writing local files
[18:46:08] Completed 51000 out of 150000 steps  (34%)
[18:48:39] Writing local files
[18:48:39] Completed 52500 out of 150000 steps  (35%)
[18:51:08] Writing local files
[18:51:08] Completed 54000 out of 150000 steps  (36%)
[18:53:40] Writing local files
[18:53:40] Completed 55500 out of 150000 steps  (37%)
[18:56:08] Writing local files
[18:56:08] Completed 57000 out of 150000 steps  (38%)
[18:58:38] Writing local files
[18:58:38] Completed 58500 out of 150000 steps  (39%)
[19:01:07] Writing local files
[19:01:07] Completed 60000 out of 150000 steps  (40%)
[19:03:38] Writing local files
[19:03:38] Completed 61500 out of 150000 steps  (41%)
[19:06:07] Writing local files
[19:06:07] Completed 63000 out of 150000 steps  (42%)
[19:08:37] Writing local files
[19:08:37] Completed 64500 out of 150000 steps  (43%)
[19:11:06] Writing local files
[19:11:06] Completed 66000 out of 150000 steps  (44%)
[19:13:37] Writing local files
[19:13:37] Completed 67500 out of 150000 steps  (45%)
[19:16:06] Writing local files
[19:16:06] Completed 69000 out of 150000 steps  (46%)
[19:18:37] Writing local files
[19:18:37] Completed 70500 out of 150000 steps  (47%)
[19:21:07] Writing local files
[19:21:07] Completed 72000 out of 150000 steps  (48%)
[19:23:37] Writing local files
[19:23:37] Completed 73500 out of 150000 steps  (49%)
[19:25:05] Writing local files
[19:25:05] Completed 75000 out of 150000 steps  (50%)
[19:27:35] Writing local files
[19:27:35] Completed 76500 out of 150000 steps  (51%)
[19:30:04] Writing local files
[19:30:04] Completed 78000 out of 150000 steps  (52%)
[19:32:34] Writing local files
[19:32:34] Completed 79500 out of 150000 steps  (53%)
[19:35:04] Writing local files
[19:35:04] Completed 81000 out of 150000 steps  (54%)
[19:37:34] Writing local files
[19:37:34] Completed 82500 out of 150000 steps  (55%)
[19:40:03] Writing local files
[19:40:03] Completed 84000 out of 150000 steps  (56%)
[19:42:33] Writing local files
[19:42:33] Completed 85500 out of 150000 steps  (57%)
[19:45:03] Writing local files
[19:45:03] Completed 87000 out of 150000 steps  (58%)
[19:47:33] Writing local files
[19:47:33] Completed 88500 out of 150000 steps  (59%)
[19:50:02] Writing local files
[19:50:02] Completed 90000 out of 150000 steps  (60%)
[19:52:33] Writing local files
[19:52:33] Completed 91500 out of 150000 steps  (61%)
[19:55:02] Writing local files
[19:55:02] Completed 93000 out of 150000 steps  (62%)
[19:57:35] Writing local files
[19:57:35] Completed 94500 out of 150000 steps  (63%)
[20:00:03] Writing local files
[20:00:03] Completed 96000 out of 150000 steps  (64%)
[20:02:33] Writing local files
[20:02:33] Completed 97500 out of 150000 steps  (65%)
[20:05:02] Writing local files
[20:05:02] Completed 99000 out of 150000 steps  (66%)
[20:07:32] Writing local files
[20:07:32] Completed 100500 out of 150000 steps  (67%)
[20:10:02] Writing local files
[20:10:02] Completed 102000 out of 150000 steps  (68%)
[20:12:33] Writing local files
[20:12:33] Completed 103500 out of 150000 steps  (69%)
[20:15:03] Writing local files
[20:15:03] Completed 105000 out of 150000 steps  (70%)
[20:17:33] Writing local files
[20:17:33] Completed 106500 out of 150000 steps  (71%)
[20:20:02] Writing local files
[20:20:02] Completed 108000 out of 150000 steps  (72%)
[20:22:32] Writing local files
[20:22:32] Completed 109500 out of 150000 steps  (73%)
[20:25:02] Writing local files
[20:25:02] Completed 111000 out of 150000 steps  (74%)
[20:27:32] Writing local files
[20:27:32] Completed 112500 out of 150000 steps  (75%)
[20:30:02] Writing local files
[20:30:02] Completed 114000 out of 150000 steps  (76%)
[20:32:32] Writing local files
[20:32:32] Completed 115500 out of 150000 steps  (77%)
[20:35:01] Writing local files
[20:35:01] Completed 117000 out of 150000 steps  (78%)
[20:37:32] Writing local files
[20:37:32] Completed 118500 out of 150000 steps  (79%)
[20:40:01] Writing local files
[20:40:01] Completed 120000 out of 150000 steps  (80%)
[20:42:32] Writing local files
[20:42:32] Completed 121500 out of 150000 steps  (81%)
[20:45:01] Writing local files
[20:45:02] Completed 123000 out of 150000 steps  (82%)
[20:47:32] Writing local files
[20:47:32] Completed 124500 out of 150000 steps  (83%)
[20:50:01] Writing local files
[20:50:01] Completed 126000 out of 150000 steps  (84%)
[20:52:32] Writing local files
[20:52:32] Completed 127500 out of 150000 steps  (85%)
[20:55:02] Writing local files
[20:55:02] Completed 129000 out of 150000 steps  (86%)
[20:57:33] Writing local files
[20:57:33] Completed 130500 out of 150000 steps  (87%)
[21:00:02] Writing local files
[21:00:02] Completed 132000 out of 150000 steps  (88%)
[21:02:31] Writing local files
[21:02:31] Completed 133500 out of 150000 steps  (89%)
[21:05:00] Writing local files
[21:05:00] Completed 135000 out of 150000 steps  (90%)
[21:07:31] Writing local files
[21:07:31] Completed 136500 out of 150000 steps  (91%)
[21:10:00] Writing local files
[21:10:00] Completed 138000 out of 150000 steps  (92%)
[21:12:31] Writing local files
[21:12:31] Completed 139500 out of 150000 steps  (93%)
[21:15:00] Writing local files
[21:15:00] Completed 141000 out of 150000 steps  (94%)
[21:17:31] Writing local files
[21:17:31] Completed 142500 out of 150000 steps  (95%)
[21:20:01] Writing local files
[21:20:01] Completed 144000 out of 150000 steps  (96%)
[21:22:31] Writing local files
[21:22:31] Completed 145500 out of 150000 steps  (97%)
[21:25:01] Writing local files
[21:25:01] Completed 147000 out of 150000 steps  (98%)
[21:27:31] Writing local files
[21:27:31] Completed 148500 out of 150000 steps  (99%)
[21:30:00] Writing local files
[21:30:00] Completed 150000 out of 150000 steps  (100%)
[21:30:00] Writing final coordinates.
[21:30:00] Past main M.D. loop
[21:31:00]
[21:31:00] Finished Work Unit:
[21:31:00] - Reading up to 550656 from "work/wudata_06.arc": Read 550656
[21:31:00] - Reading up to 0 from "work/wudata_06.xtc": Read 0
[21:31:00] goefile size: 0
[21:31:00] Leaving Run
[21:31:04] - Writing 573212 bytes of core data to disk...
[21:31:04] Done: 572700 -> 519627 (compressed to 90.7 percent)
[21:31:05]   ... Done.
[21:31:05] - Shutting down core
[21:31:05]
[21:31:05] Folding@home Core Shutdown: FINISHED_UNIT
[21:31:08] CoreStatus = 64 (100)
[21:31:08] Unit 6 finished with 91 percent of time to deadline remaining.
[21:31:08] Updated performance fraction: 0.928265
[21:31:08] Sending work to server
[21:31:08] Project: 3798 (Run 21, Clone 3, Gen 19)
[21:31:08] + Attempting to send results [March 16 21:31:08 UTC]
[21:31:08] - Reading file work/wuresults_06.dat from core
[21:31:08]   (Read 520139 bytes from disk)
[21:31:08] Connecting to http://171.64.122.139:8080/
[21:31:10] Posted data.
[21:31:10] Initial: 0000; - Uploaded at ~254 kB/s
[21:31:10] - Averaged speed for that direction ~294 kB/s
[21:31:10] + Results successfully sent
[21:31:10] Thank you for your contribution to Folding@Home.
[21:31:10] + Number of Units Completed: 181
[21:31:14] Trying to send all finished work units
[21:31:14] + No unsent completed units remaining.
[21:31:14] - Preparing to get new work unit...
[21:31:14] + Attempting to get work packet
[21:31:14] - Will indicate memory of 1023 MB
[21:31:14] - Connecting to assignment server
[21:31:14] Connecting to http://assign.stanford.edu:8080/
[21:31:14] Posted data.
[21:31:14] Initial: 40AB; - Successful: assigned to (171.64.122.139).
[21:31:14] + News From Folding@Home: Welcome to Folding@Home
[21:31:14] Loaded queue successfully.
[21:31:14] Connecting to http://171.64.122.139:8080/
[21:31:15] Posted data.
[21:31:15] Initial: 0000; - Receiving payload (expected size: 237480)
[21:31:16] - Downloaded at ~231 kB/s
[21:31:16] - Averaged speed for that direction ~253 kB/s
[21:31:16] + Received work.
[21:31:16] Trying to send all finished work units
[21:31:16] + No unsent completed units remaining.
[21:31:16] + Closed connections
[21:31:16]
[21:31:16] + Processing work unit
[21:31:16] Core required: FahCore_78.exe
[21:31:16] Core found.
[21:31:16] Working on queue slot 07 [March 16 21:31:16 UTC]
[21:31:16] + Working ...
[21:31:16] - Calling '.\FahCore_78.exe -dir work/ -suffix 07 -checkpoint 15 -verbose -lifeline 34072 -version 620'
[21:31:16]
[21:31:16] *------------------------------*
[21:31:16] Folding@Home Gromacs Core
[21:31:16] Version 1.90 (March 8, 2006)
[21:31:16]
[21:31:16] Preparing to commence simulation
[21:31:16] - Looking at optimizations...
[21:31:16] - Created dyn
[21:31:16] - Files status OK
[21:31:16] - Expanded 236968 -> 1167708 (decompressed 492.7 percent)
[21:31:16] - Starting from initial work packet
[21:31:16]
[21:31:16] Project: 3798 (Run 39, Clone 3, Gen 18)
[21:31:16]
[21:31:16] Assembly optimizations on if available.
[21:31:16] Entering M.D.
[21:31:22] Protein: p3798
[21:31:22]
[21:31:22] Writing local files
[21:32:41] Extra SSE boost OK.
[21:32:41] Writing local files
[21:32:41] Completed 0 out of 150000 steps  (0%)
[21:35:09] Writing local files
[21:35:09] Completed 1500 out of 150000 steps  (1%)
[21:37:39] Writing local files
[21:37:39] Completed 3000 out of 150000 steps  (2%)
[21:40:09] Writing local files
[21:40:09] Completed 4500 out of 150000 steps  (3%)
[21:42:39] Writing local files
[21:42:39] Completed 6000 out of 150000 steps  (4%)
[21:45:09] Writing local files
[21:45:09] Completed 7500 out of 150000 steps  (5%)
[21:47:40] Writing local files
[21:47:40] Completed 9000 out of 150000 steps  (6%)
[21:50:09] Writing local files
[21:50:09] Completed 10500 out of 150000 steps  (7%)
[21:52:40] Writing local files
[21:52:40] Completed 12000 out of 150000 steps  (8%)
[21:55:10] Writing local files
[21:55:10] Completed 13500 out of 150000 steps  (9%)
[21:57:43] Writing local files
[21:57:43] Completed 15000 out of 150000 steps  (10%)
[22:00:11] Writing local files
[22:00:11] Completed 16500 out of 150000 steps  (11%)
[22:02:41] Writing local files
[22:02:41] Completed 18000 out of 150000 steps  (12%)
[22:05:10] Writing local files
[22:05:10] Completed 19500 out of 150000 steps  (13%)
[22:07:41] Writing local files
[22:07:41] Completed 21000 out of 150000 steps  (14%)
[22:10:10] Writing local files
[22:10:10] Completed 22500 out of 150000 steps  (15%)
[22:12:41] Writing local files
[22:12:41] Completed 24000 out of 150000 steps  (16%)
[22:15:11] Writing local files
[22:15:11] Completed 25500 out of 150000 steps  (17%)
[22:17:41] Writing local files
[22:17:41] Completed 27000 out of 150000 steps  (18%)
[22:20:11] Writing local files
[22:20:11] Completed 28500 out of 150000 steps  (19%)
[22:22:41] Writing local files
[22:22:41] Completed 30000 out of 150000 steps  (20%)
[22:25:11] Writing local files
[22:25:11] Completed 31500 out of 150000 steps  (21%)
[22:27:42] Writing local files
[22:27:42] Completed 33000 out of 150000 steps  (22%)
[22:30:11] Writing local files
[22:30:11] Completed 34500 out of 150000 steps  (23%)
[22:32:42] Writing local files
[22:32:42] Completed 36000 out of 150000 steps  (24%)
[22:35:12] Writing local files
[22:35:12] Completed 37500 out of 150000 steps  (25%)
[22:37:42] Writing local files
[22:37:42] Completed 39000 out of 150000 steps  (26%)
[22:40:12] Writing local files
[22:40:12] Completed 40500 out of 150000 steps  (27%)
[22:42:43] Writing local files
[22:42:43] Completed 42000 out of 150000 steps  (28%)
[22:45:13] Writing local files
[22:45:13] Completed 43500 out of 150000 steps  (29%)
[22:47:43] Writing local files
[22:47:43] Completed 45000 out of 150000 steps  (30%)
[22:50:12] Writing local files
[22:50:12] Completed 46500 out of 150000 steps  (31%)
[22:52:44] Writing local files
[22:52:44] Completed 48000 out of 150000 steps  (32%)
[22:55:13] Writing local files
[22:55:13] Completed 49500 out of 150000 steps  (33%)
[22:57:45] Writing local files
[22:57:45] Completed 51000 out of 150000 steps  (34%)
[23:00:14] Writing local files
[23:00:14] Completed 52500 out of 150000 steps  (35%)
[23:02:44] Writing local files
[23:02:44] Completed 54000 out of 150000 steps  (36%)
[23:05:13] Writing local files
[23:05:13] Completed 55500 out of 150000 steps  (37%)
[23:07:45] Writing local files
[23:07:45] Completed 57000 out of 150000 steps  (38%)
[23:10:14] Writing local files
[23:10:14] Completed 58500 out of 150000 steps  (39%)
[23:12:45] Writing local files
[23:12:45] Completed 60000 out of 150000 steps  (40%)
[23:15:14] Writing local files
[23:15:14] Completed 61500 out of 150000 steps  (41%)
[23:17:45] Writing local files
[23:17:45] Completed 63000 out of 150000 steps  (42%)
[23:20:15] Writing local files
[23:20:15] Completed 64500 out of 150000 steps  (43%)
[23:22:46] Writing local files
[23:22:46] Completed 66000 out of 150000 steps  (44%)
[23:23:55] Writing local files
[23:23:55] Completed 67500 out of 150000 steps  (45%)
[23:26:26] Writing local files
[23:26:26] Completed 69000 out of 150000 steps  (46%)
[23:28:55] Writing local files
[23:28:55] Completed 70500 out of 150000 steps  (47%)
[23:31:26] Writing local files
[23:31:26] Completed 72000 out of 150000 steps  (48%)
[23:33:56] Writing local files
[23:33:56] Completed 73500 out of 150000 steps  (49%)
[23:36:27] Writing local files
[23:36:27] Completed 75000 out of 150000 steps  (50%)
[23:38:56] Writing local files
[23:38:56] Completed 76500 out of 150000 steps  (51%)
[23:41:27] Writing local files
[23:41:27] Completed 78000 out of 150000 steps  (52%)
[23:43:56] Writing local files
[23:43:56] Completed 79500 out of 150000 steps  (53%)
[23:46:27] Writing local files
[23:46:27] Completed 81000 out of 150000 steps  (54%)
[23:48:57] Writing local files
[23:48:58] Completed 82500 out of 150000 steps  (55%)
[23:51:28] Writing local files
[23:51:28] Completed 84000 out of 150000 steps  (56%)
[23:53:57] Writing local files
[23:53:57] Completed 85500 out of 150000 steps  (57%)
[23:56:28] Writing local files
[23:56:28] Completed 87000 out of 150000 steps  (58%)
[23:58:58] Writing local files
[23:58:58] Completed 88500 out of 150000 steps  (59%)
[00:01:31] Writing local files
[00:01:31] Completed 90000 out of 150000 steps  (60%)
[00:04:00] Writing local files
[00:04:00] Completed 91500 out of 150000 steps  (61%)
[00:06:30] Writing local files
[00:06:30] Completed 93000 out of 150000 steps  (62%)
[00:08:59] Writing local files
[00:08:59] Completed 94500 out of 150000 steps  (63%)
[00:11:30] Writing local files
[00:11:30] Completed 96000 out of 150000 steps  (64%)
[00:13:59] Writing local files
[00:13:59] Completed 97500 out of 150000 steps  (65%)
[00:16:30] Writing local files
[00:16:30] Completed 99000 out of 150000 steps  (66%)
[00:19:12] Writing local files
[00:19:12] Completed 100500 out of 150000 steps  (67%)
[00:21:54] Writing local files
[00:21:54] Completed 102000 out of 150000 steps  (68%)
[00:24:37] Writing local files
[00:24:37] Completed 103500 out of 150000 steps  (69%)
[00:26:28] - Autosending finished units... [March 17 00:26:28 UTC]
[00:26:28] Trying to send all finished work units
[00:26:28] + No unsent completed units remaining.
[00:26:28] - Autosend completed
[00:27:14] Writing local files
[00:27:14] Completed 105000 out of 150000 steps  (70%)
[00:30:09] Writing local files
[00:30:09] Completed 106500 out of 150000 steps  (71%)
[00:32:48] Writing local files
[00:32:49] Completed 108000 out of 150000 steps  (72%)
[00:35:33] Writing local files
[00:35:33] Completed 109500 out of 150000 steps  (73%)
[00:38:16] Writing local files
[00:38:16] Completed 111000 out of 150000 steps  (74%)
[00:40:51] Writing local files
[00:40:51] Completed 112500 out of 150000 steps  (75%)
[00:43:28] Writing local files
[00:43:28] Completed 114000 out of 150000 steps  (76%)
[00:46:19] Writing local files
[00:46:19] Completed 115500 out of 150000 steps  (77%)
[00:48:59] Writing local files
[00:48:59] Completed 117000 out of 150000 steps  (78%)
[00:51:41] Writing local files
[00:51:42] Completed 118500 out of 150000 steps  (79%)
[00:54:17] Writing local files
[00:54:17] Completed 120000 out of 150000 steps  (80%)
[00:56:47] Writing local files
[00:56:47] Completed 121500 out of 150000 steps  (81%)
[00:59:16] Writing local files
[00:59:16] Completed 123000 out of 150000 steps  (82%)
[01:01:47] Writing local files
[01:01:47] Completed 124500 out of 150000 steps  (83%)
[01:04:15] Writing local files
[01:04:15] Completed 126000 out of 150000 steps  (84%)
[01:06:46] Writing local files
[01:06:46] Completed 127500 out of 150000 steps  (85%)
[01:09:17] Writing local files
[01:09:17] Completed 129000 out of 150000 steps  (86%)
[01:11:51] Writing local files
[01:11:51] Completed 130500 out of 150000 steps  (87%)
[01:14:25] Writing local files
[01:14:25] Completed 132000 out of 150000 steps  (88%)
[01:17:00] Writing local files
[01:17:00] Completed 133500 out of 150000 steps  (89%)
[01:19:37] Writing local files
[01:19:37] Completed 135000 out of 150000 steps  (90%)
[01:22:17] Writing local files
[01:22:17] Completed 136500 out of 150000 steps  (91%)
[01:24:55] Writing local files
[01:24:55] Completed 138000 out of 150000 steps  (92%)
[01:27:34] Writing local files
[01:27:34] Completed 139500 out of 150000 steps  (93%)
[01:30:13] Writing local files
[01:30:13] Completed 141000 out of 150000 steps  (94%)
[01:32:59] Writing local files
[01:32:59] Completed 142500 out of 150000 steps  (95%)
[01:35:38] Writing local files
[01:35:38] Completed 144000 out of 150000 steps  (96%)
[01:38:26] Writing local files
[01:38:26] Completed 145500 out of 150000 steps  (97%)
[01:41:04] Writing local files
[01:41:04] Completed 147000 out of 150000 steps  (98%)
[01:43:43] Writing local files
[01:43:43] Completed 148500 out of 150000 steps  (99%)
[01:46:15] Writing local files
[01:46:15] Completed 150000 out of 150000 steps  (100%)
[01:46:15] Writing final coordinates.
[01:46:15] Past main M.D. loop
[01:47:15]
[01:47:15] Finished Work Unit:
[01:47:15] - Reading up to 550656 from "work/wudata_07.arc": Read 550656
[01:47:15] - Reading up to 0 from "work/wudata_07.xtc": Read 0
[01:47:15] goefile size: 0
[01:47:15] Leaving Run
[01:47:17] - Writing 573212 bytes of core data to disk...
[01:47:17] Done: 572700 -> 518979 (compressed to 90.6 percent)
[01:47:17]   ... Done.
[01:47:17] - Shutting down core
[01:47:17]
[01:47:17] Folding@home Core Shutdown: FINISHED_UNIT
[01:47:20] CoreStatus = 64 (100)
[01:47:20] Unit 7 finished with 91 percent of time to deadline remaining.
[01:47:20] Updated performance fraction: 0.924829
[01:47:20] Sending work to server
[01:47:20] Project: 3798 (Run 39, Clone 3, Gen 18)
[01:47:20] + Attempting to send results [March 17 01:47:20 UTC]
[01:47:20] - Reading file work/wuresults_07.dat from core
[01:47:20]   (Read 519491 bytes from disk)
[01:47:20] Connecting to http://171.64.122.139:8080/
[01:47:21] Posted data.
[01:47:21] Initial: 0000; - Uploaded at ~508 kB/s
[01:47:21] - Averaged speed for that direction ~337 kB/s
[01:47:21] + Results successfully sent
[01:47:21] Thank you for your contribution to Folding@Home.
[01:47:21] + Number of Units Completed: 182
[01:47:25] Trying to send all finished work units
[01:47:25] + No unsent completed units remaining.
[01:47:25] - Preparing to get new work unit...
[01:47:25] + Attempting to get work packet
[01:47:25] - Will indicate memory of 1023 MB
[01:47:25] - Connecting to assignment server
[01:47:25] Connecting to http://assign.stanford.edu:8080/
[01:47:26] Posted data.
[01:47:26] Initial: 40AB; - Successful: assigned to (171.64.122.139).
[01:47:26] + News From Folding@Home: Welcome to Folding@Home
[01:47:26] Loaded queue successfully.
[01:47:26] Connecting to http://171.64.122.139:8080/
[01:47:27] Posted data.
[01:47:27] Initial: 0000; - Receiving payload (expected size: 238859)
[01:47:27] Conversation time very short, giving reduced weight in bandwidth avg
[01:47:27] - Downloaded at ~466 kB/s
[01:47:27] - Averaged speed for that direction ~277 kB/s
[01:47:27] + Received work.
[01:47:27] Trying to send all finished work units
[01:47:27] + No unsent completed units remaining.
[01:47:27] + Closed connections
[01:47:27]
[01:47:27] + Processing work unit
[01:47:27] Core required: FahCore_78.exe
[01:47:27] Core found.
[01:47:27] Working on queue slot 08 [March 17 01:47:27 UTC]
[01:47:27] + Working ...
[01:47:27] - Calling '.\FahCore_78.exe -dir work/ -suffix 08 -checkpoint 15 -verbose -lifeline 34072 -version 620'
[01:47:27]
[01:47:27] *------------------------------*
[01:47:27] Folding@Home Gromacs Core
[01:47:27] Version 1.90 (March 8, 2006)
[01:47:27]
[01:47:27] Preparing to commence simulation
[01:47:27] - Looking at optimizations...
[01:47:27] - Created dyn
[01:47:27] - Files status OK
[01:47:28] - Expanded 238347 -> 1167708 (decompressed 489.9 percent)
[01:47:28] - Starting from initial work packet
[01:47:28]
[01:47:28] Project: 3798 (Run 82, Clone 0, Gen 21)
[01:47:28]
[01:47:28] Assembly optimizations on if available.
[01:47:28] Entering M.D.
[01:47:34] Protein: p3798
[01:47:34]
[01:47:34] Writing local files
[01:48:54] Extra SSE boost OK.
[01:48:54] Writing local files
[01:48:54] Completed 0 out of 150000 steps  (0%)
[01:51:28] Writing local files
[01:51:28] Completed 1500 out of 150000 steps  (1%)
[01:54:11] Writing local files
[01:54:11] Completed 3000 out of 150000 steps  (2%)
[01:56:48] Writing local files
[01:56:48] Completed 4500 out of 150000 steps  (3%)
[01:59:23] Writing local files
[01:59:24] Completed 6000 out of 150000 steps  (4%)
[02:02:04] Writing local files
[02:02:04] Completed 7500 out of 150000 steps  (5%)
[02:04:34] Writing local files
[02:04:34] Completed 9000 out of 150000 steps  (6%)
[02:07:18] Writing local files
[02:07:18] Completed 10500 out of 150000 steps  (7%)
[02:10:17] Writing local files
[02:10:17] Completed 12000 out of 150000 steps  (8%)
[02:13:06] Writing local files
[02:13:06] Completed 13500 out of 150000 steps  (9%)
[02:15:47] Writing local files
[02:15:47] Completed 15000 out of 150000 steps  (10%)
[02:18:31] Writing local files
[02:18:31] Completed 16500 out of 150000 steps  (11%)
[02:21:26] Writing local files
[02:21:26] Completed 18000 out of 150000 steps  (12%)
[02:23:16] Writing local files
[02:23:16] Completed 19500 out of 150000 steps  (13%)
[02:26:05] Writing local files
[02:26:05] Completed 21000 out of 150000 steps  (14%)
[02:28:45] Writing local files
[02:28:45] Completed 22500 out of 150000 steps  (15%)
[02:31:39] Writing local files
[02:31:39] Completed 24000 out of 150000 steps  (16%)
[02:34:28] Writing local files
[02:34:28] Completed 25500 out of 150000 steps  (17%)
[02:37:24] Writing local files
[02:37:24] Completed 27000 out of 150000 steps  (18%)
[02:40:22] Writing local files
[02:40:22] Completed 28500 out of 150000 steps  (19%)
[02:43:00] Writing local files
[02:43:00] Completed 30000 out of 150000 steps  (20%)
[02:45:41] Writing local files
[02:45:41] Completed 31500 out of 150000 steps  (21%)
[02:48:18] Writing local files
[02:48:18] Completed 33000 out of 150000 steps  (22%)
[02:51:08] Writing local files
[02:51:08] Completed 34500 out of 150000 steps  (23%)
[02:53:48] Writing local files
[02:53:48] Completed 36000 out of 150000 steps  (24%)
[02:56:36] Writing local files
[02:56:36] Completed 37500 out of 150000 steps  (25%)
[03:00:07] Writing local files
[03:00:07] Completed 39000 out of 150000 steps  (26%)
[03:03:28] Writing local files
[03:03:28] Completed 40500 out of 150000 steps  (27%)
[03:07:14] Writing local files
[03:07:14] Completed 42000 out of 150000 steps  (28%)
[03:10:08] Writing local files
[03:10:08] Completed 43500 out of 150000 steps  (29%)
[03:12:57] Writing local files
[03:12:57] Completed 45000 out of 150000 steps  (30%)
[03:15:49] Writing local files
[03:15:49] Completed 46500 out of 150000 steps  (31%)
[03:18:32] Writing local files
[03:18:32] Completed 48000 out of 150000 steps  (32%)
[03:21:40] Writing local files
[03:21:40] Completed 49500 out of 150000 steps  (33%)
[03:24:24] Writing local files
[03:24:24] Completed 51000 out of 150000 steps  (34%)
[03:27:06] Writing local files
[03:27:06] Completed 52500 out of 150000 steps  (35%)
[03:29:49] Writing local files
[03:29:50] Completed 54000 out of 150000 steps  (36%)
[03:32:31] Writing local files
[03:32:31] Completed 55500 out of 150000 steps  (37%)
[03:35:24] Writing local files
[03:35:24] Completed 57000 out of 150000 steps  (38%)
[03:38:46] Writing local files
[03:38:46] Completed 58500 out of 150000 steps  (39%)
[03:41:29] Writing local files
[03:41:29] Completed 60000 out of 150000 steps  (40%)
[03:44:13] Writing local files
[03:44:13] Completed 61500 out of 150000 steps  (41%)
[03:46:56] Writing local files
[03:46:56] Completed 63000 out of 150000 steps  (42%)
[03:49:41] Writing local files
[03:49:41] Completed 64500 out of 150000 steps  (43%)
[03:52:24] Writing local files
[03:52:24] Completed 66000 out of 150000 steps  (44%)
[03:55:08] Writing local files
[03:55:08] Completed 67500 out of 150000 steps  (45%)
[03:57:52] Writing local files
[03:57:52] Completed 69000 out of 150000 steps  (46%)
[04:00:37] Writing local files
[04:00:37] Completed 70500 out of 150000 steps  (47%)
[04:03:57] Writing local files
[04:03:57] Completed 72000 out of 150000 steps  (48%)
[04:06:49] Writing local files
[04:06:49] Completed 73500 out of 150000 steps  (49%)
[04:09:49] Writing local files
[04:09:49] Completed 75000 out of 150000 steps  (50%)
[04:12:51] Writing local files
[04:12:51] Completed 76500 out of 150000 steps  (51%)
[04:15:36] Writing local files
[04:15:36] Completed 78000 out of 150000 steps  (52%)
[04:18:18] Writing local files
[04:18:19] Completed 79500 out of 150000 steps  (53%)
[04:21:01] Writing local files
[04:21:01] Completed 81000 out of 150000 steps  (54%)
[04:23:54] Writing local files
[04:23:54] Completed 82500 out of 150000 steps  (55%)
[04:27:27] Writing local files
[04:27:27] Completed 84000 out of 150000 steps  (56%)
[04:31:01] Writing local files
[04:31:01] Completed 85500 out of 150000 steps  (57%)
[04:33:41] Writing local files
[04:33:41] Completed 87000 out of 150000 steps  (58%)
[04:36:20] Writing local files
[04:36:20] Completed 88500 out of 150000 steps  (59%)
[04:38:57] Writing local files
[04:38:57] Completed 90000 out of 150000 steps  (60%)
[04:41:40] Writing local files
[04:41:40] Completed 91500 out of 150000 steps  (61%)
[04:44:21] Writing local files
[04:44:21] Completed 93000 out of 150000 steps  (62%)
[04:46:50] Writing local files
[04:46:50] Completed 94500 out of 150000 steps  (63%)
[04:49:20] Writing local files
[04:49:20] Completed 96000 out of 150000 steps  (64%)
[04:51:58] Writing local files
[04:51:58] Completed 97500 out of 150000 steps  (65%)
[04:54:34] Writing local files
[04:54:34] Completed 99000 out of 150000 steps  (66%)
[04:57:12] Writing local files
[04:57:12] Completed 100500 out of 150000 steps  (67%)
[04:59:53] Writing local files
[04:59:53] Completed 102000 out of 150000 steps  (68%)
[05:02:23] Writing local files
[05:02:23] Completed 103500 out of 150000 steps  (69%)
[05:04:54] Writing local files
[05:04:54] Completed 105000 out of 150000 steps  (70%)
[05:07:23] Writing local files
[05:07:23] Completed 106500 out of 150000 steps  (71%)
[05:10:10] Writing local files
[05:10:10] Completed 108000 out of 150000 steps  (72%)
[05:12:44] Writing local files
[05:12:44] Completed 109500 out of 150000 steps  (73%)
[05:15:26] Writing local files
[05:15:26] Completed 111000 out of 150000 steps  (74%)
[05:18:06] Writing local files
[05:18:06] Completed 112500 out of 150000 steps  (75%)
[05:20:38] Writing local files
[05:20:38] Completed 114000 out of 150000 steps  (76%)
[05:22:04] Writing local files
[05:22:04] Completed 115500 out of 150000 steps  (77%)
[05:24:49] Writing local files
[05:24:49] Completed 117000 out of 150000 steps  (78%)
[05:27:48] Writing local files
[05:27:48] Completed 118500 out of 150000 steps  (79%)
[05:30:25] Writing local files
[05:30:25] Completed 120000 out of 150000 steps  (80%)
[05:33:17] Writing local files
[05:33:17] Completed 121500 out of 150000 steps  (81%)
[05:35:57] Writing local files
[05:35:57] Completed 123000 out of 150000 steps  (82%)
[05:38:55] Writing local files
[05:38:55] Completed 124500 out of 150000 steps  (83%)
[05:41:54] Writing local files
[05:41:54] Completed 126000 out of 150000 steps  (84%)
[05:44:36] Writing local files
[05:44:36] Completed 127500 out of 150000 steps  (85%)
[05:47:07] Writing local files
[05:47:07] Completed 129000 out of 150000 steps  (86%)
[05:49:38] Writing local files
[05:49:38] Completed 130500 out of 150000 steps  (87%)
[05:52:09] Writing local files
[05:52:09] Completed 132000 out of 150000 steps  (88%)
[05:54:42] Writing local files
[05:54:42] Completed 133500 out of 150000 steps  (89%)
[05:57:35] Writing local files
[05:57:35] Completed 135000 out of 150000 steps  (90%)
[06:00:16] Writing local files
[06:00:16] Completed 136500 out of 150000 steps  (91%)
[06:02:49] Writing local files
[06:02:49] Completed 138000 out of 150000 steps  (92%)
[06:05:20] Writing local files
[06:05:20] Completed 139500 out of 150000 steps  (93%)
[06:07:50] Writing local files
[06:07:50] Completed 141000 out of 150000 steps  (94%)
[06:10:19] Writing local files
[06:10:19] Completed 142500 out of 150000 steps  (95%)
[06:12:54] Writing local files
[06:12:54] Completed 144000 out of 150000 steps  (96%)
[06:15:32] Writing local files
[06:15:32] Completed 145500 out of 150000 steps  (97%)
[06:18:13] Writing local files
[06:18:13] Completed 147000 out of 150000 steps  (98%)
[06:20:57] Writing local files
[06:20:58] Completed 148500 out of 150000 steps  (99%)
[06:23:37] Writing local files
[06:23:37] Completed 150000 out of 150000 steps  (100%)
[06:23:37] Writing final coordinates.
[06:23:37] Past main M.D. loop
[06:24:23] - Autosending finished units... [March 17 06:24:23 UTC]
[06:24:23] Trying to send all finished work units
[06:24:23] + No unsent completed units remaining.
[06:24:23] - Autosend completed
[06:24:38]
[06:24:38] Finished Work Unit:
[06:24:38] - Reading up to 550656 from "work/wudata_08.arc": Read 550656
[06:24:38] - Reading up to 0 from "work/wudata_08.xtc": Read 0
[06:24:38] goefile size: 0
[06:24:38] Leaving Run
[06:24:38] - Writing 573212 bytes of core data to disk...
[06:24:38] Done: 572700 -> 520007 (compressed to 90.7 percent)
[06:24:38]   ... Done.
[06:24:38] - Shutting down core
[06:24:38]
[06:24:38] Folding@home Core Shutdown: FINISHED_UNIT
[06:24:41] CoreStatus = 64 (100)
[06:24:41] Unit 8 finished with 90 percent of time to deadline remaining.
[06:24:41] Updated performance fraction: 0.920611
[06:24:41] Sending work to server
[06:24:41] Project: 3798 (Run 82, Clone 0, Gen 21)
[06:24:41] + Attempting to send results [March 17 06:24:41 UTC]
[06:24:41] - Reading file work/wuresults_08.dat from core
[06:24:41]   (Read 520519 bytes from disk)
[06:24:41] Connecting to http://171.64.122.139:8080/
[06:24:43] Posted data.
[06:24:43] Initial: 0000; - Uploaded at ~254 kB/s
[06:24:43] - Averaged speed for that direction ~320 kB/s
[06:24:43] + Results successfully sent
[06:24:43] Thank you for your contribution to Folding@Home.
[06:24:43] + Number of Units Completed: 183
[06:24:47] Trying to send all finished work units
[06:24:47] + No unsent completed units remaining.
[06:24:47] - Preparing to get new work unit...
[06:24:47] + Attempting to get work packet
[06:24:47] - Will indicate memory of 1023 MB
[06:24:47] - Connecting to assignment server
[06:24:47] Connecting to http://assign.stanford.edu:8080/
[06:24:47] Posted data.
[06:24:47] Initial: 40AB; - Successful: assigned to (171.64.122.139).
[06:24:47] + News From Folding@Home: Welcome to Folding@Home
[06:24:47] Loaded queue successfully.
[06:24:47] Connecting to http://171.64.122.139:8080/
[06:24:48] Posted data.
[06:24:48] Initial: 0000; - Receiving payload (expected size: 238232)
[06:24:49] - Downloaded at ~232 kB/s
[06:24:49] - Averaged speed for that direction ~268 kB/s
[06:24:49] + Received work.
[06:24:49] Trying to send all finished work units
[06:24:49] + No unsent completed units remaining.
[06:24:49] + Closed connections
[06:24:49]
[06:24:49] + Processing work unit
[06:24:49] Core required: FahCore_78.exe
[06:24:49] Core found.
[06:24:49] Working on queue slot 09 [March 17 06:24:49 UTC]
[06:24:49] + Working ...
[06:24:49] - Calling '.\FahCore_78.exe -dir work/ -suffix 09 -checkpoint 15 -verbose -lifeline 34072 -version 620'
[06:24:49]
[06:24:49] *------------------------------*
[06:24:49] Folding@Home Gromacs Core
[06:24:49] Version 1.90 (March 8, 2006)
[06:24:49]
[06:24:49] Preparing to commence simulation
[06:24:49] - Looking at optimizations...
[06:24:49] - Created dyn
[06:24:49] - Files status OK
[06:24:49] - Expanded 237720 -> 1167708 (decompressed 491.2 percent)
[06:24:49] - Starting from initial work packet
[06:24:49]
[06:24:49] Project: 3798 (Run 42, Clone 4, Gen 22)
[06:24:49]
[06:24:49] Assembly optimizations on if available.
[06:24:49] Entering M.D.
[06:24:55] Protein: p3798
[06:24:55]
[06:24:55] Writing local files
[06:26:14] Extra SSE boost OK.
[06:26:14] Writing local files
[06:26:14] Completed 0 out of 150000 steps  (0%)
[06:28:59] Writing local files
[06:28:59] Completed 1500 out of 150000 steps  (1%)
[06:31:28] Writing local files
[06:31:28] Completed 3000 out of 150000 steps  (2%)
[06:34:00] Writing local files
[06:34:00] Completed 4500 out of 150000 steps  (3%)
[06:36:30] Writing local files
[06:36:30] Completed 6000 out of 150000 steps  (4%)
[06:39:01] Writing local files
[06:39:01] Completed 7500 out of 150000 steps  (5%)
[06:41:30] Writing local files
[06:41:30] Completed 9000 out of 150000 steps  (6%)
[06:44:03] Writing local files
[06:44:03] Completed 10500 out of 150000 steps  (7%)
[06:46:32] Writing local files
[06:46:32] Completed 12000 out of 150000 steps  (8%)
[06:49:03] Writing local files
[06:49:03] Completed 13500 out of 150000 steps  (9%)
[06:51:33] Writing local files
[06:51:33] Completed 15000 out of 150000 steps  (10%)
[06:54:05] Writing local files
[06:54:05] Completed 16500 out of 150000 steps  (11%)
[06:56:35] Writing local files
[06:56:35] Completed 18000 out of 150000 steps  (12%)
[06:59:06] Writing local files
[06:59:06] Completed 19500 out of 150000 steps  (13%)
[07:01:36] Writing local files
[07:01:36] Completed 21000 out of 150000 steps  (14%)
[07:04:07] Writing local files
[07:04:07] Completed 22500 out of 150000 steps  (15%)
[07:06:36] Writing local files
[07:06:36] Completed 24000 out of 150000 steps  (16%)
[07:09:08] Writing local files
[07:09:08] Completed 25500 out of 150000 steps  (17%)
[07:11:37] Writing local files
[07:11:38] Completed 27000 out of 150000 steps  (18%)
[07:14:11] Writing local files
[07:14:11] Completed 28500 out of 150000 steps  (19%)
[07:16:40] Writing local files
[07:16:40] Completed 30000 out of 150000 steps  (20%)
[07:19:10] Writing local files
[07:19:10] Completed 31500 out of 150000 steps  (21%)
[07:21:40] Writing local files
[07:21:40] Completed 33000 out of 150000 steps  (22%)
[07:24:11] Writing local files
[07:24:12] Completed 34500 out of 150000 steps  (23%)
[07:26:41] Writing local files
[07:26:41] Completed 36000 out of 150000 steps  (24%)
[07:29:13] Writing local files
[07:29:13] Completed 37500 out of 150000 steps  (25%)
[07:31:43] Writing local files
[07:31:43] Completed 39000 out of 150000 steps  (26%)
[07:34:15] Writing local files
[07:34:15] Completed 40500 out of 150000 steps  (27%)
[07:36:45] Writing local files
[07:36:45] Completed 42000 out of 150000 steps  (28%)
[07:39:16] Writing local files
[07:39:16] Completed 43500 out of 150000 steps  (29%)
[07:41:46] Writing local files
[07:41:46] Completed 45000 out of 150000 steps  (30%)
[07:44:18] Writing local files
[07:44:18] Completed 46500 out of 150000 steps  (31%)
[07:46:47] Writing local files
[07:46:47] Completed 48000 out of 150000 steps  (32%)
[07:49:18] Writing local files
[07:49:18] Completed 49500 out of 150000 steps  (33%)
[07:51:48] Writing local files
[07:51:48] Completed 51000 out of 150000 steps  (34%)
[07:54:20] Writing local files
[07:54:20] Completed 52500 out of 150000 steps  (35%)
[07:56:50] Writing local files
[07:56:50] Completed 54000 out of 150000 steps  (36%)
[07:59:22] Writing local files
[07:59:22] Completed 55500 out of 150000 steps  (37%)
[08:01:51] Writing local files
[08:01:51] Completed 57000 out of 150000 steps  (38%)
[08:04:23] Writing local files
[08:04:23] Completed 58500 out of 150000 steps  (39%)
[08:06:53] Writing local files
[08:06:53] Completed 60000 out of 150000 steps  (40%)
[08:09:25] Writing local files
[08:09:25] Completed 61500 out of 150000 steps  (41%)
[08:11:56] Writing local files
[08:11:56] Completed 63000 out of 150000 steps  (42%)
[08:14:29] Writing local files
[08:14:29] Completed 64500 out of 150000 steps  (43%)
[08:16:58] Writing local files
[08:16:58] Completed 66000 out of 150000 steps  (44%)
[08:19:29] Writing local files
[08:19:29] Completed 67500 out of 150000 steps  (45%)
[08:20:57] Writing local files
[08:20:57] Completed 69000 out of 150000 steps  (46%)
[08:23:29] Writing local files
[08:23:29] Completed 70500 out of 150000 steps  (47%)
[08:25:57] Writing local files
[08:25:58] Completed 72000 out of 150000 steps  (48%)
[08:28:29] Writing local files
[08:28:29] Completed 73500 out of 150000 steps  (49%)
[08:30:59] Writing local files
[08:30:59] Completed 75000 out of 150000 steps  (50%)
[08:33:30] Writing local files
[08:33:30] Completed 76500 out of 150000 steps  (51%)
[08:35:59] Writing local files
[08:35:59] Completed 78000 out of 150000 steps  (52%)
[08:38:31] Writing local files
[08:38:31] Completed 79500 out of 150000 steps  (53%)
[08:41:00] Writing local files
[08:41:00] Completed 81000 out of 150000 steps  (54%)
[08:43:32] Writing local files
[08:43:32] Completed 82500 out of 150000 steps  (55%)
[08:46:01] Writing local files
[08:46:01] Completed 84000 out of 150000 steps  (56%)
[08:48:33] Writing local files
[08:48:33] Completed 85500 out of 150000 steps  (57%)
[08:51:02] Writing local files
[08:51:02] Completed 87000 out of 150000 steps  (58%)
[08:53:33] Writing local files
[08:53:33] Completed 88500 out of 150000 steps  (59%)
[08:56:03] Writing local files
[08:56:03] Completed 90000 out of 150000 steps  (60%)
[08:58:34] Writing local files
[08:58:35] Completed 91500 out of 150000 steps  (61%)
[09:01:04] Writing local files
[09:01:04] Completed 93000 out of 150000 steps  (62%)
[09:03:35] Writing local files
[09:03:35] Completed 94500 out of 150000 steps  (63%)
[09:06:04] Writing local files
[09:06:04] Completed 96000 out of 150000 steps  (64%)
[09:08:36] Writing local files
[09:08:36] Completed 97500 out of 150000 steps  (65%)
[09:11:06] Writing local files
[09:11:06] Completed 99000 out of 150000 steps  (66%)
[09:13:37] Writing local files
[09:13:37] Completed 100500 out of 150000 steps  (67%)
[09:16:06] Writing local files
[09:16:06] Completed 102000 out of 150000 steps  (68%)
[09:18:39] Writing local files
[09:18:39] Completed 103500 out of 150000 steps  (69%)
[09:21:07] Writing local files
[09:21:07] Completed 105000 out of 150000 steps  (70%)
[09:23:37] Writing local files
[09:23:37] Completed 106500 out of 150000 steps  (71%)
[09:26:07] Writing local files
[09:26:07] Completed 108000 out of 150000 steps  (72%)
[09:28:38] Writing local files
[09:28:38] Completed 109500 out of 150000 steps  (73%)
[09:31:08] Writing local files
[09:31:08] Completed 111000 out of 150000 steps  (74%)
[09:33:39] Writing local files
[09:33:39] Completed 112500 out of 150000 steps  (75%)
[09:36:08] Writing local files
[09:36:08] Completed 114000 out of 150000 steps  (76%)
[09:38:40] Writing local files
[09:38:40] Completed 115500 out of 150000 steps  (77%)
[09:41:10] Writing local files
[09:41:10] Completed 117000 out of 150000 steps  (78%)
[09:43:40] Writing local files
[09:43:41] Completed 118500 out of 150000 steps  (79%)
[09:46:10] Writing local files
[09:46:10] Completed 120000 out of 150000 steps  (80%)
[09:48:41] Writing local files
[09:48:41] Completed 121500 out of 150000 steps  (81%)
[09:51:11] Writing local files
[09:51:11] Completed 123000 out of 150000 steps  (82%)
[09:53:42] Writing local files
[09:53:42] Completed 124500 out of 150000 steps  (83%)
[09:56:11] Writing local files
[09:56:11] Completed 126000 out of 150000 steps  (84%)
[09:58:42] Writing local files
[09:58:42] Completed 127500 out of 150000 steps  (85%)
[10:01:11] Writing local files
[10:01:11] Completed 129000 out of 150000 steps  (86%)
[10:03:43] Writing local files
[10:03:43] Completed 130500 out of 150000 steps  (87%)
[10:06:13] Writing local files
[10:06:13] Completed 132000 out of 150000 steps  (88%)
[10:08:45] Writing local files
[10:08:45] Completed 133500 out of 150000 steps  (89%)
[10:11:14] Writing local files
[10:11:14] Completed 135000 out of 150000 steps  (90%)
[10:13:46] Writing local files
[10:13:46] Completed 136500 out of 150000 steps  (91%)
[10:16:16] Writing local files
[10:16:16] Completed 138000 out of 150000 steps  (92%)
[10:18:49] Writing local files
[10:18:49] Completed 139500 out of 150000 steps  (93%)
[10:21:17] Writing local files
[10:21:17] Completed 141000 out of 150000 steps  (94%)
[10:23:48] Writing local files
[10:23:49] Completed 142500 out of 150000 steps  (95%)
[10:26:18] Writing local files
[10:26:18] Completed 144000 out of 150000 steps  (96%)
[10:28:49] Writing local files
[10:28:49] Completed 145500 out of 150000 steps  (97%)
[10:31:19] Writing local files
[10:31:20] Completed 147000 out of 150000 steps  (98%)
[10:33:51] Writing local files
[10:33:51] Completed 148500 out of 150000 steps  (99%)
[10:36:21] Writing local files
[10:36:21] Completed 150000 out of 150000 steps  (100%)
[10:36:21] Writing final coordinates.
[10:36:21] Past main M.D. loop
[10:37:21]
[10:37:21] Finished Work Unit:
[10:37:21] - Reading up to 550656 from "work/wudata_09.arc": Read 550656
[10:37:21] - Reading up to 0 from "work/wudata_09.xtc":; Read 0
[10:37:21] goefile size: 0
[10:37:21] Leaving Run
[10:37:21] - Writing 573212 bytes of core data to disk...
[10:37:22] Done: 572700 -> 519705 (compressed to 90.7 percent)
[10:37:22]   ... Done.
[10:37:22] - Shutting down core
[10:37:22]
[10:37:22] Folding@home Core Shutdown: FINISHED_UNIT
[10:37:26] CoreStatus = 64 (100)
[10:37:26] Unit 9 finished with 91 percent of time to deadline remaining.
[10:37:26] Updated performance fraction: 0.918946
[10:37:26] Sending work to server
[10:37:26] Project: 3798 (Run 42, Clone 4, Gen 22)
[10:37:26] + Attempting to send results [March 17 10:37:26 UTC]
[10:37:26] - Reading file work/wuresults_09.dat from core
[10:37:26]   (Read 520217 bytes from disk)
[10:37:26] Connecting to http://171.64.122.139:8080/
[10:37:28] Posted data.
[10:37:28] Initial: 0000; - Uploaded at ~254 kB/s
[10:37:28] - Averaged speed for that direction ~307 kB/s
[10:37:28] + Results successfully sent
[10:37:28] Thank you for your contribution to Folding@Home.
whynot
Re: New 250 point p3798
Post by whynot »
bruce wrote:
pwnchu wrote:http://foldingforum.org/viewtopic.php?f=19&t=7315
Why is the step size 150000 now?
skip
Some time back there was a problem with server saturation for the PS3. One of the temporary changes made at that time was to take a production WU which happened to be worth 250 points and (essentially) glue a series of five of them into a single WU which was then worth 1250 points and ran 5x as long without an upload/download sequence. At that time, it was a helpful way to continue the project while reducing the load on the server. This is probably something similar.
I believe, that some unnamed sort of crunchers would highly appreciate testing server code for issues with 1000 point worth WUs. :)
I'm counting for science.
Points just make me sick.
whynot wrote:I believe, that some unnamed sort of crunchers would highly appreciate testing server code for issues with 1000 point worth WUs. :)
Well, there are tradeoffs that you may not have considered. Suppose an ordinary WU runs for about 24 hours on hardware XXX and earns, say, 200 points. Combining 5 WUs into a single WU would make them require 5 days of continuous processing to earn 1000 points. Is that better or worse?
Advantages:
Less time wasted waiting to upload/download.
Server loads are lower (Work servers, Assignment servers, Collection servers, and Stats servers).
Disadvantages:
It takes longer before you see the credit for your work.
A serious error might disard a lot more work without any credit.
brityank
Post by brityank »
Advantages:
Disadvantages:
Thanks for all the info; I have a Dell Dimension 4100 still running WinME (Hey - it won't take VistaME! :evil: ) and just got my first one of these 'expanded' WUs. My FahMon lists show it's jumped from ±50PPD to 530PPD :!:
:o :o I'll take as many of those as I can! :lol: :lol:
... ... Free Republic Folders - A Tribute to Ronald Reagan ... ...
brityank wrote:Thanks for all the info; I have a Dell Dimension 4100 still running WinME (Hey - it won't take VistaME! :evil: ) and just got my first one of these 'expanded' WUs. My FahMon lists show it's jumped from ±50PPD to 530PPD :!:
Check the atom-count, too. In my earlier example, I'm talking about making WUs that are worth more points by extending the duration of the run of a specific protein. When you compare the run-time (ie.-points) with two different proteins you have to remember that there are some changes based on the square of the atom-count and others based linearly on the atom-count.
