Project: 2669 (Run 0, Clone 92, Gen 97)EUE@100%
Pick2
Hardware configuration: Linux & CPUs
Post by Pick2 »
This one has Deleted at 100% more than once. Has anyone else finished it ?
[05:58:20] Completed 250000 out of 250000 steps  (100%)
[05:58:28] CoreStatus = 1 (1)
[05:58:28] Sending work to server
[05:58:28] Project: 2669 (Run 0, Clone 92, Gen 97)
[05:58:28] - Error: Could not get length of results file work/wuresults_02.dat
[05:58:28] - Error: Could not read unit 02 file. Removing from queue.
[05:58:28] Trying to send all finished work units
[05:58:28] + No unsent completed units remaining.
I would appreciate it if a mod could check the DB for this one.
Thanks
Re: Project: 2669 (Run 0, Clone 92, Gen 97)EUE@100%
There's no data for this WU in the DB yet ... :(
Pick2
Post by Pick2 »
Thanks for checking ,toTow
It EUE's once , probably 100%. Then DL'd it 3 more times , EUE'd probably right off the bat. Then the EUE'd at the posted snip-it at 100%. Then was at 13% again when I posted here , and then reinstalled the client. this Linux blade had been folding with no problems up until this WU.
I marked the WU as a bad one.
