Project: 2496 (Run 4, Clone 18, Gen 0) EUE@38%
anandhanju
Post by anandhanju »
Project: 2496 (Run 4, Clone 18, Gen 0) - EUE@38% [LINCS WARNING]
[14:38:57] Folding@Home Gromacs Core
[14:38:57] Version 1.90 (March 8, 2006)
[14:38:57]
[14:38:57] Preparing to commence simulation
[14:38:57] - Assembly optimizations manually forced on.
[14:38:57] - Not checking prior termination.
[14:39:01] - Expanded 2222140 -> 15109525 (decompressed 679.9 percent)
[14:39:02]
[14:39:02] Project: 2496 (Run 4, Clone 18, Gen 0)
[14:39:02]
[14:39:03] Assembly optimizations on if available.
[14:39:03] Entering M.D.
[14:39:25] (Starting from checkpoint)
[14:39:25] Protein: system
[14:39:25]
[14:39:25] Writing local files
[14:39:25] Completed 82500 out of 250000 steps  (33%)
[14:39:28] Extra SSE boost OK.
[15:09:31] Timered checkpoint triggered.
[15:34:48] Writing local files
[15:34:48] Completed 85000 out of 250000 steps  (34%)
[16:04:50] Timered checkpoint triggered.
[16:29:18] Writing local files
[16:29:18] Completed 87500 out of 250000 steps  (35%)
[16:59:18] Timered checkpoint triggered.
[17:25:00] Writing local files
[17:25:01] Completed 90000 out of 250000 steps  (36%)
[17:55:02] Timered checkpoint triggered.
[18:25:05] Timered checkpoint triggered.
[18:36:04] Writing local files
[18:36:06] Completed 92500 out of 250000 steps  (37%)
[19:06:08] Timered checkpoint triggered.
[19:34:32] Writing local files
[19:34:32] Completed 95000 out of 250000 steps  (38%)
[20:04:33] Timered checkpoint triggered.
[20:29:56] Quit 101 - Fatal error:
[20:29:56] Step 97490, time 194.98 (ps)  LINCS WARNING
[20:29:56] relative constraint deviation after LINCS:
[20:29:56] max 6385916804878827500.000000 (between atoms 18600 and 18601) rms 77880822366994432.000000
[20:29:56]
[20:29:56] Simulation instability has been encountered. The run has entered a
[20:29:56]   state from which no further progress can be made.
[20:29:56] This may be the correct result of the simulation, however if you
[20:29:56]   often see other project units terminating early like this
[20:29:56]   too, you may wish to check the stability of your computer (issues
[20:29:56]   such as high temperature, overclocking, etc.).
[20:29:56] Going to send back what have done.
[20:29:56] logfile size: 52820
[20:29:56] - Writing 53538 bytes of core data to disk...
[20:29:56]   ... Done.
[20:29:57]
[20:29:57] Folding@home Core Shutdown: EARLY_UNIT_END
[20:29:59] CoreStatus = 72 (114)
[20:29:59] Sending work to server
[20:29:59] Project: 2496 (Run 4, Clone 18, Gen 0)
[20:29:59] - Read packet limit of 540015616... Set to 524286976.
[20:29:59] + Attempting to send results [March 13 20:29:59 UTC]
[20:29:59] - Reading file work/wuresults_05.dat from core
[20:29:59]   (Read 53538 bytes from disk)
[20:29:59] Connecting to http://171.65.103.160:8080
Partial results submitted successfully.
Re: Project: 2496 (Run 4, Clone 18, Gen 0) EUE@38%
There are 8 reports for partial credit at different progresses ... it looks like a bad WU, I've reported it. :(
